kasutaja01
31.10.2009 21:05:41
| tomorrow kirjutas: |
Ma arvan et see Win7 valikutest tekitatav Recovery Disk on just see 100MB variant ehk siis pmst kirjutatakse WinRE plaadile ja kogu lugu
Läpakatootjate Recovery plaadid/partitsioonid on iseasi |
Ehk siis see ja mitte see. Aga eelmine HP lauakas oli mul selline, kus andis ühe korra võimaluse teha endale Recovery diski, mis siis taastas tehase seaded ja mingeid teisi variante oli seal ka ( sai eraldi draivereid ja sofi installid jms)
Hollow
31.10.2009 21:06:28
| kasutaja01 kirjutas: |
Ehk siis see ja mitte see. Aga eelmine HP lauakas oli mul selline, kus andis ühe korra võimaluse teha endale Recovery diski, mis siis taastas tehase seaded ja mingeid teisi variante oli seal ka ( sai eraldi draivereid ja sofi installid jms) |
sa ei räägi recoverist vaid preInstallist
31.10.2009 21:11:34
Hollow: Eksid vähe. Justnimelt Recover-DVD tehakse tänapäeval ja vanasti tehti Recover-CD.
Nii, et kui ostad arvuti, siis loe kaasasolevatest paberitest, et mida tootajfirma nõuab:
"Esimesena tuleb teha Recover-DVD".
AJ
31.10.2009 21:42:11
Windows 7 Turn Laptops into Wi-Fi Hotspots
http://www.tomshardware.co.uk/Windows-Laptop-Internet-hotspot-Connectify,news-32167.html
PC Advisor reports that Philadelphia developer Nomadio has discovered an unfinished Windows 7 feature (Virtual Wi-Fi) that can turn a laptop into a Wi-Fi hotspot. That means other devices in the near vicinity can access the Internet without the need for special tunneling software. The company has now exploited the uncovered treasure and created a free application called Connectify, released just last week.
Microsoft's research group originally began development of Virtual Wi-Fi years ago; the feature would take a network card and virtually split it into several, separate adaptors. However, Microsoft halted its development back in 2006, but apparently never removed the feature from the operating system. Now it appears in Windows 7 as "Native 802.11 Virtual Wireless Fidelity (Virtual Wi-Fi) object identifiers (OIDs)".
Alex Gizis, CEO of Nomadio, told PC Advisor that driver support for Virtual Wi-Fi was never finished. With that said, the driver-level "stuff" isn't present, however the "low-level code" is still intact. There's also no application or setting to turn the feature on. Naturally, this is where Connectify comes in.
But Gizis was quick to point out that the software differs from Internet connection sharing. "For one thing, it shows up as a real wireless access point," Gizis said. "Two, internet connection sharing has issues. It returns to the default settings every time you shut down a connection. And three, you can join another wireless network and still run the Connectify Hotspot on the same Wi-Fi card." |
riiks
31.10.2009 21:46:40
| Kas kellelgi printer share või homegroup töötab win7 all? Kui siis võiks kogemusi jagada
Look Right
Anna vin
31.10.2009 21:51:47
Hetkel ei saa homegroup asja katsetada ise, kuid kodus töötas küll
_________________ Ehitusprojektid ja konstruktiivsed lahendused HV kasutajatele soodsamalt
M: Zafira A/Astra G põhjakaitse - 30€ |
KrisVr
31.10.2009 21:54:38
| Mul töötab homegroup küll kenasti. Algul oli küll mingi n**s, et ei saanud korralikult tööle, nüüd normaalne.
Gap
31.10.2009 22:15:04
Tänud veelkord eelmistele abistajatele sain ilusti installi tehtud väga äge ikka tundub olevat esialgu .... tahtsin veel mõnda asja küsida et sry ei jaga asja väga hästi, aga tekkis küsimus et peale installi ja värki oli kõik okei... isegi nett oli olemas, ei olnud vaja installida Realtek Network mingeid drivereid ja erinevalt Vistast kus peale formatti ei olnud netti siis update pakkus just seda Realteki värki ja tegin asja ära ja peale seda tekkis probleem et see problems ja solutions ütles on mingi konflikt selle Realtek-i driveritega ja netti polnud siis mõtlesin et mida kuradit ma nüüd siis teen maha ka ei saanud seda kuidagi kuskil installida siis oma tarkusega uurisin et mis see system restore on ... tegin selle ära siis arvuti tegi restardi ja nett oli olemas .... vabandust kui rumal küsimus aga mind huivtab et mis see system restore nagu tegi kas ta nagu taastas selle algse olukorra enne selle mittevajalikku update tegemist .... et kas see nagu midagi halba ei teinud ?
ja Vista all peal olnud Kaspersky 2009 ei kõlvanudgi selle Win7-ele litsentsi oli jäänud kuni jaanuari alguseni... millegipärast nagu ei hakanud tööle viskas mingeid erroreid... aga noh pole hullu panin algatuseks sellle eset nod trial versiooni...
Prayer
31.10.2009 22:43:24
| Gap kirjutas: |
| ...siis update pakkus just seda Realteki värki ja tegin asja ära ja peale seda tekkis probleem et see problems ja solutions ütles on mingi konflikt selle Realtek-i driveritega ja netti polnud... |
Paar kolm lehekülge tagasi oli sellest juttu, Device Manager ja "roll back driver" on lihtsamaks lahenduseks.
Soovitan Realteki kodulehelt tüürelid tõmmata ja WU's raudvara puudutavad uuendused lihtsalt kõik ära peita.
| riiks kirjutas: |
| Kas kellelgi printer share või homegroup töötab win7 all? Kui siis võiks kogemusi jagada |
Mis kogemusi täpsemalt vaja jagada on?
Asi töötab nii nagu peab, kui "advanced sharing options" all on kõik konfitud (network discovery ja file and printer sharing lubatud, turvaseaded maha võetud või kui on peal siis peab ka vastavad kasutajad ning salasõnad olema tehtud arvutites... üldiselt kõigi valikute juures on nende funktsioonid küllaltki selgelt lahti seletatud).
Kaustade jagamiseks polegi muud vaja teha kui paremklikk hiirega kaustal, vali "Share with >" ja saab ühe nupuvajutusega kodugrupis vajaliku välja jagada kohe.
Printer, kui see paigaldamise käigus ei saanud välja jagatud, siis Printers and Devices all sellel topeltklõps ning "Customize your printer" alt leiab jagamise valikud.
riiks
31.10.2009 22:59:08
| No mul seal advanced sharing setingus printersharing aktiveeritud, kaustade sharemisega probleemi polegi, näitab võrgus teist arvutit ja puha. Aga kui prineri optionist share panna, siis viskab errori ette. Ja kui selle ilusa ikooniga üritada homegruppi teha siis nõuab ipv6 sisse lülitamist . Võibolla siis priner uuesti installida - sai win7 otse Vistale selga keevitatud.
ents75
01.11.2009 00:25:29
| gan3b kirjutas: |
That's a must be. |
x2
Kust selliseid ülihäid vidinaid veel leida võiks?
Prayer
01.11.2009 00:39:54
| riiks kirjutas: |
| Ja kui selle ilusa ikooniga üritada homegruppi teha siis nõuab ipv6 sisse lülitamist. |
Vista ja 7 IPv6 on vaikimisi sees paigaldamisel, kontrolli üle võrgukaardi seadetes.
riiks
01.11.2009 03:34:20
| Võrgukaardi seadetes on linnuke ees ipv6 -l ja seaded auto peal. Aga niipalju kui uurisin siis see süsteem alles läheb käiku 2011 vist laiemale publikule. Tahaks lihtsalt prinerit share peale panna, aga küllap ehk asi selles et win7 draivereid ja tarkvara pole veel brother dcp-110c - le.
Prayer
01.11.2009 08:48:38
| riiks kirjutas: |
| Võrgukaardi seadetes on linnuke ees ipv6 -l ja seaded auto peal. Aga niipalju kui uurisin siis see süsteem alles läheb käiku 2011 vist laiemale publikule. Tahaks lihtsalt prinerit share peale panna, aga küllap ehk asi selles et win7 draivereid ja tarkvara pole veel brother dcp-110c - le. |
Ega oskagi rohkem midagi pakkuda, endal on Brother HL-1240 võrgutatud D-Link print serveriga ja kogemata on ühel arvutil ka jagamine peale läinud ning tõrkeid pole olnud.
viimati muutis Prayer 01.11.2009 10:11:19, muudetud 1 kord |
SilQ
01.11.2009 10:01:10
Gap:
ja Vista all peal olnud Kaspersky 2009 ei kõlvanudgi selle Win7-ele litsentsi oli jäänud kuni jaanuari alguseni... millegipärast nagu ei hakanud tööle viskas mingeid erroreid... aga noh pole hullu panin algatuseks sellle eset nod trial versiooni... |
Mul funksib Kaspersky 09 väga ilusti. Muidugi Kasperskyl on ka 2010 aasta versioon olemas. Ise pole veel proovind.
Look Right
Anna vin
01.11.2009 11:44:31
Sai ka täisversioon viimaks peale lastud. A siuke nõme kala, et ei lase ühte kausta ära kustutada, ütleb, et seda kausta ei eksisteeri enam. Kuid ometi ma näen seda
edit: leidsin ise lahenduse:
CoiL
01.11.2009 12:08:33
jägaja, mul karvane tunne, et asi ei ole OS-i põhjustatud
Aga teisest teemast siia ka:
Uusimad ATK0110 ACPI drivud peaks olema. Kui kellelgi probleeme sleep režiimist naasemisega võiks proovida, äkki aitab
e: See peaks kõikidele emaplaatidele sobima aga kindel ei ole! Rohkem lugemist ACPI kohta: http://en.wikipedia.org/wiki/Advanced_Configuration_and_Power_Interface
viimati muutis CoiL 01.11.2009 12:18:37, muudetud 1 kord |
Gap
01.11.2009 12:30:31
| SilQ kirjutas: |
Mul funksib Kaspersky 09 väga ilusti. Muidugi Kasperskyl on ka 2010 aasta versioon olemas. Ise pole veel proovind. |
Sul 64 bit op süsteem ?
üks küsimus oleks ka veel Kuidas ma saan taskbari algseaded taastada ? kruttisin siin neid ikoone mingi õpetus järgi mis oli väga keeruline siis mingi ime läbi sain omale selle switch between windows ikooni vasakule poole nagu vistal aga kuidas ma tagasi saan panna nii nagu enne oli ? lihtsalt huvi pärast tahaks teada
CoiL
01.11.2009 12:36:27
| CorsairX kirjutas: |
e: See peaks kõikidele emaplaatidele sobima aga kindel ei ole! Rohkem lugemist ACPI kohta: http://en.wikipedia.org/wiki/Advanced_Configuration_and_Power_Interface |
Unustasin veel mainida, et see ACPI pack sisaldab Win7/Win2000/Vista 32-bit & Win7/Win2000/Vista 64-bit drivusid.
Hollow
01.11.2009 14:49:58
Uudiseid siis nendele kes kasutavad läpakat millel 965 chipset ja x3100 graafika... tõmbasin täna inteli lehelt viimased chipseti ja graafika driverid
kui ennem oli Aero Graphics 3,0 ja Gaming Graphics 3,1 siis nüüd on 3,5 ja 4,0
nii et juu nad on Win7 jaoks seal siiski midagi uuendanud ja muutnud
SilQ
01.11.2009 17:27:15
Gap:
Sul 64 bit op süsteem ? |
jep, 64
WäntWõll
make.believe
01.11.2009 17:46:32
Mis mõttes, kiiruselt või, Operale vaevalt miski vastu saab, võimaluste poolest meeldib ja kasutan enim Firefoxi, kuigi jah, pisut aeglasemalt tõmbab ennast tööle ja nõuab enim ressursi.
TRA olen ausalt joonud enim valget vett aga see post muudab minu elu,piix olen liiga lähedal ultimaatumile ja hetkel on püksid ribadeks naerud,kus KRT sellised failid sünnivad(sooviks kõrval olla
Asjad on naljast ja naerust kaugel
Aurah
01.11.2009 19:28:26
kas keegi oskaks mind aidata ja öelda, kuidas saada Nvidia control panel kätte? ...ei suuda seda lihtsalt üles leida...ja see ka, et kas SLI ikka töötab win7 all?....olen veits lugenud, et on esinenud jamasid sellega. Aga jah...emsalt tahaks teada, kust ma saaks üldse SLI'le enable panna:P
01.11.2009 19:36:36
| Aurah kirjutas: |
kas keegi oskaks mind aidata ja öelda, kuidas saada Nvidia control panel kätte? ...ei suuda seda lihtsalt üles leida...ja see ka, et kas SLI ikka töötab win7 all?....olen veits lugenud, et on esinenud jamasid sellega. Aga jah...emsalt tahaks teada, kust ma saaks üldse SLI'le enable panna:P |
Järgmine juba jälle
Paki driverid lahti
Eemalda PhysX ja 3DVision paketid kaustast
Installi setup.exe kaudu
SLI saad Nvidia CP-st siis sisse lülitada pärast driverite reinstalli
Kiiresti saab CP-le ligi paremklikiga desktopil
_________________ Win11 25H2 upgrade skriptid neile kelle masin ise ei taha 23H2 või 24H2 pealt ennast uuendada:
Youtube lisa vene jama eemaldamiseks:
https://foorum.hinnavaatlus.ee/viewtopic.php?p=11745846#11745846 |
