Deadlock
18.03.2009 17:53:14
Transport tycoon Deluxe OpenTTD |
Tahaks transport tycoon deluxe sõbraga läbi neti mängida, aga ei saa serverit hostida, sest ei saa portide avamisega korrektselt hakkama...
What port does OpenTTD use?
* the default port is 3979, but you can change it to anything you like when you start a server. If you set up your own server behind a router, you need to forward both TCP and UDP on that port.
* Communication with the master-server works via port 3979 over UDP (inbound + outbound) and 3978 over UDP (outbound)
* If you are joining a server you do not need to forward any ports, as connections are outbound only. |
On the hosting computer:
* Make sure the port that OpenTTD listens on (3979 by default) is not blocked by any firewall (check XP/Vista firewall, and any possible third-party firewalls).
* If you have a router with NAT (most users have this), you need to tell it to forward incoming traffic on port 3979 to port 3979 on your local computer.
For example on my router I have a rule to forward 3979 to 10.9.9.3 which is the local ip of my computer. While my public IP is 213.x.y.z. If you have not changed anything your local IP is most likely in the slower to type 168.192.x.y range. |
Pilt kohast, kus peaks saama porte local computerisse juhtida, näeb välja selline:
| Kommentaarid: 8 loe/lisa |
18.03.2009 19:26:24
| Port range 3979 mõlemasse, translate to 3979 ja siis mäpid selle mõnele sisemisele ip'le.
| Kommentaarid: 85 loe/lisa |
Deadlock
18.03.2009 20:00:02
Nii, hetkel tundub, et server ilmub nähtavaks ainult siis kui täidan esimesed kaks lahtrit 3978 ja 3979 (Joinida ikka ei saaa, jookseb lihtsalt kokku). Teistel juhtudel lihtsalt serverit ei ilmu. Siis ka mitte, kui kahte viimast lahtrit näpin, st ei jäta neid tühjaks.
Missuguse osa ma local IP aadressist sinna viimasesse lahtrisse sisestama peaksin? Sinna mahub ainult 5 tähemärki.
viimati muutis Deadlock 18.03.2009 20:09:20, muudetud 1 kord |
Foxxx
| Kommentaarid: 64 loe/lisa |
61 |
Deadlock
18.03.2009 20:11:27
Tänud
DeTHiCa.
18.03.2009 21:39:45
ja kui siis kah hakkama ei saa siis on Hamachi üks suurepärane programm millega ei tohiks probleeme tekkida.
ise sõbraga kasutasime seda et TTD pelada.
136 |
fic
01.07.2009 14:14:35
Kuna on olemas võrgumängu kohta sama teema, siis küsiks siin üldiselt mängu kohta küsimusi. Samuti võib savegamed siia jätta, huvitav oleks näha teiste foorumlaste projekte.
Kas kuidagi saab maha võtta ka selle, et tehased end ei sulgeks? Võrku ei jõua arendadagi, sest pidevalt lähevad kinni need, kuhu "pole veel jõudnud".
_________________ PhotograFICal |
13.07.2009 00:25:11
keegi Windows 7 all ka seda jooksutab?
käivitades annab "has stopped working" errorit. xp ja vista compatibility mode proovitud - ei tööta samuti
313 |
Mart352
| Kommentaarid: 54 loe/lisa |
51 |
13.07.2009 00:42:55
| mul on build 7229, 32-bit
313 |
Mart352
13.07.2009 00:46:11
| Skeptik kirjutas: |
| mul on build 7229, 32-bit |
Huvi pärast proovisin 32 bit versiooni ka ära ja ka töötab
OTTD tirisin zip faili. installikat ei ole proovinud, äkki selles ongi mingi kamm?
Eriti ei usu, et uuema buildiga asjad enam tööle ei lähe
51 |
13.07.2009 00:51:54
sama siin, 32-bit zip ja TTD failid pärit sealt foorumi teemast
313 |
13.07.2009 14:07:08
| eks ma proovin uuesti Windows 7 RTM all, tundub, et kala on kuskil seal. ei viitsi praegu enam jamada sellega.
313 |
Redikate
17.08.2011 18:11:39
Panin praegu servu ülesse. Algas asi 1950'ndast aastast.
Esialgu on lubatud 10 kompaniid. Plaanis hoida serverit vähe pikemalt üleval, niiet homme maha teda ei võta.
Istun Starmani XL neti taga niiet peaks paar mängijat kannatama küll.
Server info:
ip: 82.131.30.84
pw: tere
Viimase OpenTTD saab siit:
http://www.openttd.org/en/download-stable
Teretulnud on mõistusega mängijad ning igasugune sigatsemine toob kiirelt
Mingeid küsimusi vms, siis võtke PM'iga ühendust.
_________________ http://nodejs.org/
"I'm also a person. Programming is just one thing I do."
viimati muutis Redikate 17.08.2011 18:49:39, muudetud 1 kord |
| Kommentaarid: 34 loe/lisa |
33 |
Lovvi
17.08.2011 18:29:02
| Mis serveri nimi, ma IP läbi liitumist ei leia
| Kommentaarid: 60 loe/lisa |
57 |
Redikate
17.08.2011 18:40:54
hv.ee Private OpenTTD Server.
"I'm also a person. Programming is just one thing I do." |
33 |
Forgotten
21.08.2011 13:09:38
| Milline nendest fooridest toimib sedasi nagu tavalises TTD-s ?
Villemk2
13.11.2011 17:31:15
Miks HV.ee serveri Versioon 1.1.2 on?
| Kommentaarid: 127 loe/lisa |
119 |
indrek27
14.11.2011 13:15:20
ma ühes kaardis tegin ümber mapi ringikujulise edasi-tagasi raudtee. kõik rongid juhtisin sinna peale ja proovisin igasuguseid fooride lahendusi.
aga ikka suht ruttu jookseb see asi seal sõlme. kui seal sada rongi on troppima hakanud, oi jeerum
nad võiks teha juurde 2realise raudtee võimaluse, kohe paigaldad 2rida.
_________________ Teeme lapse või ostame iPhone'i? |
0 |
14.11.2011 19:10:31
| Villemk2 kirjutas: |
Miks HV.ee serveri Versioon 1.1.2 on?  |
Sest ma pole seda uuendanud, kuna keegi pole torkinud?
1.1.3 nüüd.
Villemk2
14.11.2011 19:20:25
ma hakkan torkima siis kui aega saan
119 |
vipu
03.07.2012 19:14:51
| Uus versioon on jälle väljas, panen peale ja teen oma mappi edasi. Ma juba pikka aega mängin ühte mappi, vahest päris huvitav ehitada.
