uus teema   vasta Tarkvara »  Arvutimängude foorum »  Transport tycoon Deluxe OpenTTD märgi kõik teemad loetuks
Deadlock
sõnum 18.03.2009 17:53:14 Transport tycoon Deluxe OpenTTD vasta tsitaadiga
Tahaks transport tycoon deluxe sõbraga läbi neti mängida, aga ei saa serverit hostida, sest ei saa portide avamisega korrektselt hakkama...
What port does OpenTTD use?
* the default port is 3979, but you can change it to anything you like when you start a server. If you set up your own server behind a router, you need to forward both TCP and UDP on that port.
* Communication with the master-server works via port 3979 over UDP (inbound + outbound) and 3978 over UDP (outbound)
* If you are joining a server you do not need to forward any ports, as connections are outbound only.
On the hosting computer:
* Make sure the port that OpenTTD listens on (3979 by default) is not blocked by any firewall (check XP/Vista firewall, and any possible third-party firewalls).
* If you have a router with NAT (most users have this), you need to tell it to forward incoming traffic on port 3979 to port 3979 on your local computer.
For example on my router I have a rule to forward 3979 to 10.9.9.3 which is the local ip of my computer. While my public IP is 213.x.y.z. If you have not changed anything your local IP is most likely in the slower to type 168.192.x.y range.
Pilt kohast, kus peaks saama porte local computerisse juhtida, näeb välja selline:
sõnum 18.03.2009 19:26:24 vasta tsitaadiga
Port range 3979 mõlemasse, translate to 3979 ja siis mäpid selle mõnele sisemisele ip'le.
Deadlock
sõnum 18.03.2009 20:00:02 vasta tsitaadiga
Nii, hetkel tundub, et server ilmub nähtavaks ainult siis kui täidan esimesed kaks lahtrit 3978 ja 3979 (Joinida ikka ei saaa, jookseb lihtsalt kokku). Teistel juhtudel lihtsalt serverit ei ilmu. Siis ka mitte, kui kahte viimast lahtrit näpin, st ei jäta neid tühjaks.
Missuguse osa ma local IP aadressist sinna viimasesse lahtrisse sisestama peaksin? Sinna mahub ainult 5 tähemärki.
viimati muutis Deadlock 18.03.2009 20:09:20, muudetud 1 kord
Foxxx
Foxxx
sõnum 18.03.2009 20:07:28 vasta tsitaadiga
http://portforward.com/english/routers/port_forwarding/Thomson-Alcatel/Speedtouch780v6/Caesar_IV.htm
Samm-sammult õpetus
Kommentaarid: 64 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 61
Deadlock
sõnum 18.03.2009 20:11:27 vasta tsitaadiga
Foxxx kirjutas:
Samm-sammult õpetus
Tänud
DeTHiCa.
DeTHiCa.
sõnum 18.03.2009 21:39:45 vasta tsitaadiga
ja kui siis kah hakkama ei saa siis on Hamachi üks suurepärane programm millega ei tohiks probleeme tekkida.
ise sõbraga kasutasime seda et TTD pelada.
fic
fic
sõnum 01.07.2009 14:14:35 vasta tsitaadiga
Kuna on olemas võrgumängu kohta sama teema, siis küsiks siin üldiselt mängu kohta küsimusi. Samuti võib savegamed siia jätta, huvitav oleks näha teiste foorumlaste projekte.
Kas kuidagi saab maha võtta ka selle, et tehased end ei sulgeks? Võrku ei jõua arendadagi, sest pidevalt lähevad kinni need, kuhu "pole veel jõudnud".
PhotograFICal
sõnum 13.07.2009 00:25:11 vasta tsitaadiga
keegi Windows 7 all ka seda jooksutab?
käivitades annab "has stopped working" errorit. xp ja vista compatibility mode proovitud - ei tööta samuti icon_rolleyes.gif
Mart352
Mart352
sõnum 13.07.2009 00:29:17 vasta tsitaadiga
Skeptik kirjutas:
Seal teemas unustasin vist mainida, et OS-iks Windows 7 RC
Sealt tirisin Win64 versiooni http://www.openttd.org/en/download-stable
ning siis data kausta kopeerisin need failid http://download.transporttycoon.net/files/ttd-graphics.rar
mingit comp mode vmt ei pannud.
sõnum 13.07.2009 00:42:55 vasta tsitaadiga
mul on build 7229, 32-bit
Mart352
Mart352
sõnum 13.07.2009 00:46:11 vasta tsitaadiga
Skeptik kirjutas:
Huvi pärast proovisin 32 bit versiooni ka ära ja ka töötab
OTTD tirisin zip faili. installikat ei ole proovinud, äkki selles ongi mingi kamm?
sõnum 13.07.2009 00:51:54 vasta tsitaadiga
sama siin, 32-bit zip ja TTD failid pärit sealt foorumi teemast eusa_think.gif
sõnum 13.07.2009 01:25:25 vasta tsitaadiga
sõnum 13.07.2009 14:07:08 vasta tsitaadiga
eks ma proovin uuesti Windows 7 RTM all, tundub, et kala on kuskil seal. ei viitsi praegu enam jamada sellega.
Redikate
Redikate
sõnum 17.08.2011 18:11:39 vasta tsitaadiga
Panin praegu servu ülesse. Algas asi 1950'ndast aastast.
Esialgu on lubatud 10 kompaniid. Plaanis hoida serverit vähe pikemalt üleval, niiet homme maha teda ei võta.
Istun Starmani XL neti taga niiet peaks paar mängijat kannatama küll.
Server info:
ip: 82.131.30.84
pw: tere
Viimase OpenTTD saab siit:
Teretulnud on mõistusega mängijad ning igasugune sigatsemine toob kiirelt bananadance2.gif
Mingeid küsimusi vms, siis võtke PM'iga ühendust.
http://nodejs.org/
"I'm also a person. Programming is just one thing I do."
viimati muutis Redikate 17.08.2011 18:49:39, muudetud 1 kord
Lovvi
Lovvi
sõnum 17.08.2011 18:29:02 vasta tsitaadiga
Mis serveri nimi, ma IP läbi liitumist ei leia
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 58
Redikate
Redikate
sõnum 17.08.2011 18:40:54 vasta tsitaadiga
hv.ee Private OpenTTD Server.
http://nodejs.org/
sõnum 17.08.2011 18:46:09 vasta tsitaadiga
Redikate, https://foorum.hinnavaatlus.ee/viewtopic.php?t=148000
Forgotten
sõnum 21.08.2011 13:09:38 vasta tsitaadiga
Milline nendest fooridest toimib sedasi nagu tavalises TTD-s ?
Kommentaarid: 5 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 4
sõnum 21.08.2011 13:40:54 vasta tsitaadiga
http://wiki.openttd.org/Signals
TTD's olid olemas vaid Two-way ja one-way signalid.
Villemk2
Villemk2
sõnum 13.11.2011 17:31:15 vasta tsitaadiga
Kommentaarid: 129 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 121
indrek27
sõnum 14.11.2011 13:15:20 vasta tsitaadiga
ma ühes kaardis tegin ümber mapi ringikujulise edasi-tagasi raudtee. kõik rongid juhtisin sinna peale ja proovisin igasuguseid fooride lahendusi.
aga ikka suht ruttu jookseb see asi seal sõlme. kui seal sada rongi on troppima hakanud, oi jeerum
nad võiks teha juurde 2realise raudtee võimaluse, kohe paigaldad 2rida.
Teeme lapse või ostame iPhone'i?
Kommentaarid: 1 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 0
sõnum 14.11.2011 19:10:31 vasta tsitaadiga
Villemk2 kirjutas:
Sest ma pole seda uuendanud, kuna keegi pole torkinud?
1.1.3 nüüd.
Villemk2
Villemk2
sõnum 14.11.2011 19:20:25 vasta tsitaadiga
vipu
vipu
sõnum 03.07.2012 19:14:51 vasta tsitaadiga
Uus versioon on jälle väljas, panen peale ja teen oma mappi edasi. Ma juba pikka aega mängin ühte mappi, vahest päris huvitav ehitada.
Kommentaarid: 5 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 4
Redikate
Redikate
sõnum 03.07.2012 21:37:37 vasta tsitaadiga
vipu kirjutas:
Mingeid notable change ka?
http://nodejs.org/
vipu
vipu
sõnum 08.07.2012 18:20:17 vasta tsitaadiga
Avastasin huvitava triki kuidas saab mängus aktsiatega teenida hõlpsalt näiteks 1 miljard eurot.
Ühesõnaga enda firma peab olema suur ja ohver siis ka suur. ctrl+alt+c avaneb petukonsool (1 valikus saab niisama endale raha teha, aga see pole see).
Teises valikus saab valida millist ettevõtet on soov juhtida, tuleb valida kõige suurem konkurent.
Konkurendina võtad enda firma lehe ja ostad enda firmast 75% aktsiatest.
Nüüd lähed tagasi oma firmasse ja ostad omakorda temalt 75% aktsiatest.
Nüüd lähed tema ettevõttesse tagasi ja müüte endalt ostetud aktsiad maha.
Nüüd lähed oma firmasse ja müüd omakorda tema aktsiad maha ja oled teeninud näiteks miljardi või enam.
Trikk on selles, et kui tema ostab teie firma aktsiad, siis tema firma väärtus kahaneb aktsiate summa võrra ja aktsiaid tagasi ostes tema firma uuesti suureneb.
Aga sina saad tema aktsiad poolmuidu.
Kaarta
sõnum 19.02.2021 15:08:06 vasta tsitaadiga
OpenTTD on tulemas Steami 1. Aprillist: https://store.steampowered.com/app/1536610/OpenTTD/
Kommentaarid: 52 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 50
kala1
kala1
sõnum 01.04.2021 18:25:59 vasta tsitaadiga
M: LG 29wk500-p
The German soldier has impressed the world, however the Italian Bersagliere soldier has impressed the German soldier.
Kommentaarid: 52 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 48
sõnum 27.10.2023 20:29:33 vasta tsitaadiga
Keda huvitab, siis siit saab selle image-i, kust "gm" kausta OpenTTD kausta tõstes tekib mängus originaalmuusika valik.
Ja siin on juttu terve Euroopa mapist: https://www.pcgamer.com/heres-all-of-europe-in-a-giant-openttd-map/ (downloadini viib ka)
Tahaks seda Hansaliidu mapi leida kuskilt:
MacT
sõnum 28.10.2023 19:20:16 vasta tsitaadiga
rmc See on Europe 1.0. Leidsin video kommentaaride hulgast. Üles pandud 2009.
https://bananas.openttd.org/package/scenario/000000b0/2009-03-11T01:54:24+00:00
viimati muutis MacT 28.10.2023 22:03:48, muudetud 1 kord
Kommentaarid: 17 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 13
sõnum 28.10.2023 20:02:55 vasta tsitaadiga
Jep, neid on erinevaid.
Bananas-es üleval olevaid asju muidu leiab OpenTTD seest ka otsinguga.
EDIT: Oota, see videos olev stsenaarium on Europe 1.0? Aaaa, ok. Vaatan.
labidas
labidas
sõnum 30.10.2023 23:32:39 vasta tsitaadiga
Mõtlesin, et korra mängin nostalgia pärast... korraga oli 3 tundi läinud.
Hea mäng. 10/10. icon_biggrin.gif
MacT
sõnum 22.11.2023 21:32:05 vasta tsitaadiga
rmc kirjutas:
Leidsid stsenaariumi, mida otsisid?
sõnum 22.11.2023 21:35:19 vasta tsitaadiga
labidas, nii see teeb, jah. Mul alati proovimisele pikad märkamatult kadunud tunnid multiplayerit. Enamasti kõigil unetundide puudus järgmisel päeval kohustuste juurde minnes icon_lol.gif
MacT kirjutas:
Enamik tiritud scenarioid ei toimi, ütleb, et loodud uuemale versioonile, vmt. - võiks automaatselt requirementid peale panna ja maha võtta vastavalt scenariotele.
Vb. vaja mingid jubinad lisaks tirida pre-requisite-na nö?
MacT
sõnum 22.11.2023 21:48:33 vasta tsitaadiga
rmc, kahju, et ei toimi. Pigem siis liiga vana stsenaarium ja mäng ise uuem versioonis juba.
M: Leidsin kommentaaride hulgast, et video üleslaadija tegi varukoopia:
https://drive.google.com/drive/folders/1QS0CVynWQ4q1eTjXqweWoHYeSSmSfd36
