Tervist!
Järgnev probleem on hakanud esinema viimase paari päeva jooksul. Esineb ainult "Battlefield Heroes" nimelist mängu mängides. Keset mängu läheb pilt mustaks, arvuti crashib (ctrl alt delete, alt f4 - mitte miski ei tööta, ainuke võimalus restart). Ekraani ülal vasakul nurgas vahelduv teade "digital/analog".
Ehk oskab keegi öelda, mis võiks olla probleemi põhjuseks ja lahendust pakkuda?
DXDIAG
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3
Language: English (Regional Setting: Estonian)
System Manufacturer: System manufacturer
System Model: P5E3-WS-Pro
BIOS: BIOS Date: 02/15/08 17:37:06 Ver: 08.00.12
Processor: Intel(R) Core(TM)2 Duo CPU E8200 @ 2.66GHz (2 CPUs)
Memory: 2046MB RAM
Page File: 377MB used, 3050MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file nv4_disp.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 8800 GT
Manufacturer: NVIDIA
Chip type: GeForce 8800 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0611&SUBSYS_82671043&REV_A2
Display Memory: 512.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: Default Monitor
Monitor Max Res:
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.8084 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 12/3/2008 00:11:00, 6166272 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 12/3/2008 00:11:00, 6209536 bytes
Device Identifier: {D7B71E3E-4551-11CF-676C-6CA203C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0611
SubSys ID: 0x82671043
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SoundMAX HD Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_11D4&DEV_198B&SUBSYS_1043829B&REV_1004
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: ADIHdAud.sys
Driver Version: 5.10.0001.6110 (English)
WHQL Logo'd: Yes
Date and Size: 1/16/2007 04:09:06, 293888 bytes
Other Files:
Driver Provider: AnalogDevices
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): Yes
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCCC
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC51A
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Logitech BT Mini-Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC714
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: USB to Serial
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0D9F, 0x0002
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x2937
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/14/2008 01:15:38, 59520 bytes
| Driver: usbd.sys, 8/23/2001 14:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Logitech HID-Compliant Keyboard
| Vendor/Product ID: 0x046D, 0xC713
| Matching Device ID: hid\vid_046d&pid_c713
| Lower Filters: LHidFilt
| Service: kbdhid
| Driver: kbdhid.sys, 4/14/2008 01:09:50, 14592 bytes
| Driver: kbdclass.sys, 4/14/2008 01:09:48, 24576 bytes
| Driver: LHidFilt.Sys, 2/29/2008 03:13:16, 35344 bytes
| Driver: WdfCoInstaller01005.dll, 6/22/2007 11:34:02, 1419232 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 06:43:22, 40840 bytes
+ Logitech HID-compliant Cordless Mouse
| Matching Device ID: hid\vid_046d&pid_c51a&mi_00
| Upper Filters: LMouFilt
| Service: mouhid
| Driver: mouhid.sys, 8/17/2001 13:48:00, 12160 bytes
| Driver: mouclass.sys, 4/14/2008 01:09:48, 23040 bytes
| Driver: LMouFilt.Sys, 2/29/2008 03:13:24, 36880 bytes
| Driver: KHALMNPR.Exe, 2/29/2008 03:12:38, 76304 bytes
+ HID-compliant Mouse
| Matching Device ID: hid\vid_046d&pid_c714&col01
| Service: mouhid
+ Logitech HID-compliant Touch Pad Mouse
| Matching Device ID: hid\vid_046d&pid_c714&col02
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Passed, Half Duplex: Passed, Mic: Passed
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 123.6 GB
Total Space: 143.1 GB
File System: NTFS
Model: WDC WD1500AHFD-00RAR5
Drive: E:
Free Space: 72.2 GB
Total Space: 476.9 GB
File System: NTFS
Model: WDC WD5000AAKS-00A7B0
Drive: F:
Model: ASUS DRW-2014L1T
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (Estonian), 4/14/2008 01:10:48, 62976 bytes
Drive: G:
Model: AZ5094Y WTT040J SCSI CdRom Device
System Devices
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_8086&DEV_29E9&SUBSYS_00000000&REV_01\3&11583659&0&30
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/14/2008 01:06:46, 68224 bytes
Name: Intel(R) X38 Express Chipset Processor to I/O Controller - 29E0
Device ID: PCI\VEN_8086&DEV_29E0&SUBSYS_00000000&REV_01\3&11583659&0&00
Driver: n/a
Name: Intel(R) ICH9 Family PCI Express Root Port 5 - 2948
Device ID: PCI\VEN_8086&DEV_2948&SUBSYS_00000000&REV_02\3&11583659&0&E4
Name: Intel(R) ICH9 Family PCI Express Root Port 4 - 2946
Device ID: PCI\VEN_8086&DEV_2946&SUBSYS_00000000&REV_02\3&11583659&0&E3
Name: Intel(R) ICH9 Family PCI Express Root Port 3 - 2944
Device ID: PCI\VEN_8086&DEV_2944&SUBSYS_00000000&REV_02\3&11583659&0&E2
Name: Intel(R) ICH9 Family PCI Express Root Port 1 - 2940
Device ID: PCI\VEN_8086&DEV_2940&SUBSYS_00000000&REV_02\3&11583659&0&E0
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_8086&DEV_293E&SUBSYS_829B1043&REV_02\3&11583659&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 7/22/2007 13:14:06, 138752 bytes
Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C
Device ID: PCI\VEN_8086&DEV_293C&SUBSYS_82771043&REV_02\3&11583659&0&D7
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/14/2008 01:15:36, 30208 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/14/2008 01:15:38, 143872 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/14/2008 06:42:10, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/14/2008 01:15:38, 59520 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 06:41:56, 7168 bytes
Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A
Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_82771043&REV_02\3&11583659&0&EF
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2939
Device ID: PCI\VEN_8086&DEV_2939&SUBSYS_82771043&REV_02\3&11583659&0&D2
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/14/2008 01:15:36, 20608 bytes
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2938
Device ID: PCI\VEN_8086&DEV_2938&SUBSYS_82771043&REV_02\3&11583659&0&D1
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2937
Device ID: PCI\VEN_8086&DEV_2937&SUBSYS_82771043&REV_02\3&11583659&0&D0
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2936
Device ID: PCI\VEN_8086&DEV_2936&SUBSYS_82771043&REV_02\3&11583659&0&EA
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2935
Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_82771043&REV_02\3&11583659&0&E9
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2934
Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_82771043&REV_02\3&11583659&0&E8
Name: Intel(R) ICH9 Family SMBus Controller - 2930
Device ID: PCI\VEN_8086&DEV_2930&SUBSYS_82771043&REV_02\3&11583659&0&FB
Driver: n/a
Name: Intel(R) ICH9 2 port Serial ATA Storage Controller 2 - 2926
Device ID: PCI\VEN_8086&DEV_2926&SUBSYS_82771043&REV_02\3&11583659&0&FD
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 13:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (Estonian), 4/14/2008 01:10:30, 24960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/14/2008 01:10:32, 96512 bytes
Name: Intel(R) ICH9 4 port Serial ATA Storage Controller 1 - 2920
Device ID: PCI\VEN_8086&DEV_2920&SUBSYS_82771043&REV_02\3&11583659&0&FA
Name: PCI standard ISA bridge
Device ID: PCI\VEN_8086&DEV_2916&SUBSYS_00000000&REV_02\3&11583659&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/14/2008 01:06:42, 37248 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_92\3&11583659&0&F0
Name: Marvell 61xx Marvell RAID Controller
Device ID: PCI\VEN_11AB&DEV_6145&SUBSYS_82B61043&REV_A1\4&332B0EE8&0&00E4
Driver: C:\WINDOWS\system32\DRIVERS\mv61xx.sys, 1.02.0000.0046 (English), 6/15/2007 10:52:02, 143256 bytes
Name: Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller #2
Device ID: PCI\VEN_11AB&DEV_4364&SUBSYS_826E1043&REV_12\4&279E7BDF&0&00E2
Driver: n/a
Device ID: PCI\VEN_11AB&DEV_4364&SUBSYS_826E1043&REV_12\4&2393AE88&0&00E3
Driver: n/a
Name: VIA OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_81FE1043&REV_C0\4&19ABE7DE&0&18F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/14/2008 01:16:20, 61696 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/14/2008 01:16:20, 53376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/14/2008 01:21:26, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/14/2008 01:21:26, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 16:46:40, 6400 bytes
Name: NVIDIA GeForce 8800 GT
Device ID: PCI\VEN_10DE&DEV_0611&SUBSYS_82671043&REV_A2\4&78EEA88&0&0030
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 6209536 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 6166272 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 163908 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 618496 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 1560576 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 9404416 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 13680640 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvmccsrs.dll, 6.14.0011.8084 (Arabic), 12/3/2008 00:11:00, 45056 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 4710400 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 3485696 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 1286144 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 3796992 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 2744320 bytes
Driver: C:\WINDOWS\system32\NvPVEnc.ax, 6.14.0011.8084 (English), 12/3/2008 00:11:00, 1253376 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 12/3/2008 00:11:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 12/3/2008 00:11:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.03.0005.0028 (English), 12/3/2008 00:11:00, 122880 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.03.0005.0028 (English), 12/3/2008 00:11:00, 122880 bytes
Device ID: PCI\VEN_1033&DEV_0125&SUBSYS_00000000&REV_06\4&662654C&0&01E0
Device ID: PCI\VEN_1033&DEV_0125&SUBSYS_00000000&REV_06\4&662654C&0&00E0
DirectX Components
ddraw.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:52 279552 bytes
ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:52 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 10496 bytes
d3d8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:52 1179648 bytes
d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:52 8192 bytes
d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:52 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:52 824320 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 14:00:00 33040 bytes
dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 229888 bytes
dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 14:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 57344 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:18 29696 bytes
dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:18 17920 bytes
dpnet.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:39:22 3072 bytes
dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:39:20 3072 bytes
dpvoice.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 212480 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:20 83456 bytes
dpvvox.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 116736 bytes
dpvacm.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 14:00:00 53520 bytes
dinput.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 158720 bytes
dinput8.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 394240 bytes
joy.cpl: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:42 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 14:00:00 76800 bytes
pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:04 35328 bytes
dsound.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 1293824 bytes
dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 19456 bytes
dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 71680 bytes
dmusic.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 104448 bytes
dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 61440 bytes
dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 35840 bytes
dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 105984 bytes
dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 82432 bytes
system.dll: 1.01.4322.2032 English Final Retail 5/3/2009 14:47:42 1224704 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 6/10/2009 18:59:26 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 5/14/2009 17:00:14 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 5/14/2009 17:00:15 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 5/14/2009 17:00:16 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 5/14/2009 17:00:17 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 5/14/2009 17:00:17 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 6/10/2009 18:59:27 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 5/14/2009 17:00:18 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 5/14/2009 17:00:18 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 5/14/2009 17:00:19 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 5/14/2009 17:00:21 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 6/10/2009 18:59:27 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 6/10/2009 18:59:27 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 6/10/2009 18:59:27 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 6/10/2009 18:59:27 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 6/10/2009 18:59:26 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 6/10/2009 18:59:26 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 6/10/2009 18:59:25 223232 bytes
dx7vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 619008 bytes
dx8vb.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 1227264 bytes
dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 14:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 4/14/2008 06:41:58 1028096 bytes
wsock32.dll: 5.01.2600.5512 English Final Retail 4/14/2008 06:42:12 22528 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:41:50 70656 bytes
devenum.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:41:52 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 4/14/2008 06:41:54 498742 bytes
mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:41:58 35328 bytes
mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/14/2008 06:42:44 148992 bytes
msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:42:00 14336 bytes
encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:41:54 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 7/22/2007 13:18:54 211456 bytes
qcap.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:42:04 192512 bytes
qdv.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:42:04 279040 bytes
qdvd.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:42:04 386048 bytes
qedit.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:42:04 562176 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 23:51:34 733696 bytes
quartz.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:42:04 1288192 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 4/14/2008 06:42:08 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 06:42:44 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 06:42:44 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 06:41:56 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 06:41:56 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 06:41:56 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 06:41:56 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 06:41:56 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 06:42:44 154624 bytes
mswebdvd.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:42:02 203776 bytes
ks.sys: 5.03.2600.5512 Estonian Final Retail 4/14/2008 01:46:38 141056 bytes
ksproxy.ax: 5.03.2600.5512 Estonian Final Retail 4/14/2008 06:42:44 129536 bytes
ksuser.dll: 5.03.2600.5512 Estonian Final Retail 4/14/2008 06:41:58 4096 bytes
stream.sys: 5.03.2600.5512 Estonian Final Retail 4/14/2008 01:15:16 49408 bytes
mspclock.sys: 5.03.2600.5512 Estonian Final Retail 4/14/2008 01:09:52 5376 bytes
mspqm.sys: 5.01.2600.5512 Estonian Final Retail 4/14/2008 01:09:52 4992 bytes
mskssrv.sys: 5.03.2600.5512 Estonian Final Retail 4/14/2008 01:09:54 7552 bytes
swenum.sys: 5.03.2600.5512 Estonian Final Retail 4/14/2008 01:09:54 4352 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 06:42:44 118272 bytes
msvidctl.dll: 6.05.2600.5512 English Final Retail 4/14/2008 06:42:02 1428992 bytes
vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:44 30208 bytes
msyuv.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:02 16896 bytes
wstdecod.dll: 5.03.2600.5512 English Final Retail 4/14/2008 06:42:12 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0005.1750
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5512
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0005.1750
ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0005.1750
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,1.00.0004.0042
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5512
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5512
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.5512
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
DivX for Blizzard Decoder Filter,0x00800000,1,1,,
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5512
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
MPV Decoder Filter,0x00500001,1,1,Mpeg2DecFilter.ax,1.00.0000.0003
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,1.00.0000.0004
FLV Splitter,0x00600000,1,1,FLVSplitter.ax,1.00.0000.0001
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5512
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5512
WavPack Audio Decoder,0x00600000,1,1,WavPackDSDecoder.ax,1.01.0000.0484
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.07.0401.0003
Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.07.0401.0003
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,2.00.0002.0036
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5512
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5512
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.5512
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5512
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5512
Haali Video Renderer,0x00200000,1,0,dxr.dll,
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.07.0401.0003
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DirectVobSub,0x00200000,2,1,VSFilter.dll,1.00.0001.0003
DirectVobSub (auto-loading version),0x00800002,2,1,VSFilter.dll,1.00.0001.0003
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.07.0401.0003
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5512
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.00.0005.1750
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,2.00.0002.0030
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
FLV Source,0x00600000,0,0,FLVSplitter.ax,1.00.0000.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.5512
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5512
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5512
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5512
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5512
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
Nero File Source,0x00200000,0,1,NeFileSrc.ax,1.00.0000.0006
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,1.00.0000.0004
WavPack Audio Splitter,0x00600000,1,1,WavPackDSSplitter.ax,1.01.0000.0323
ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.00.0005.1750
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,2.00.0002.0030
Nero Digital Parser,0x00600000,0,3,NDParser.ax,2.00.0002.0036
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5512
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5512
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5512
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,1.00.0001.0008
Haali Video Sink,0x00200000,1,0,splitter.ax,1.07.0401.0003
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5512
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5512
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.00.0005.1750
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5512
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
VP60® Simple Profile ,0x00200000,1,1,qcap.dll,6.05.2600.5512
VP61® Advanced Profile,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5512
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5512
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5512
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5512
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5512
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5512
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5512
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5512
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.5512
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5512
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5512
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5512
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5512
Audio Capture Sources:
SoundMAX HD Audio,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5512
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.5512
WDM Streaming Capture Devices:
SoundMAX HD Audio,0x00000000,0,0,,
WDM Streaming Rendering Devices:
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.5512
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.5512
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.5512
Audio Renderers:
SoundMAX HD Audio,0x00200000,1,0,quartz.dll,6.05.2600.5512
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5512
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5512
DirectSound: SoundMAX HD Audio,0x00200000,1,0,quartz.dll,6.05.2600.5512
WDM Streaming System Devices:
SoundMAX HD Audio,0x00200000,19,3,,5.03.2600.5512
Tänud!
