27.05.2009 22:43:15
| lisasin õiged hash'id ka oma eelmisesse posti.
pavka
27.05.2009 23:12:25
Lasin täna just 7127 peale ja nüüd juba 7137 väljas
Kas on ka infot, mida täiendati?
27.05.2009 23:18:19
| pavka kirjutas: |
Kas on ka infot, mida täiendati? |
Liikus küll info 7140 kohta ja lisatud oli väike nimekiri muudatustest aga kas see ka tõele vastab ei oska öelda.Niikaua kui täpsemat kinnitust ei saa soovitan järgnevasse teatava skepsisega suhtuda
1. You can now add anything to the Taskbar.
2. Icons slightly expand when you hover over them on the taskbar.
3. The "System" menu is more simplistic, and easier to navigate.
4. You can change the login screen picture through the "Personalization" menu.
5. The menu/lists that pop up when you right click on things now have the Aero Glass effect.
6. The default icons for Folders have changed to be the transparent blue ones featured a long time ago.
8. The Minimize/Maximize/Exit buttons on the top-right of a window have changed icons, and are a bit smaller than the Vista/7 counterparts.
9. [BIG ONE]: There's an "Upload" feature for Pictures, files, and videos. If you right-click a file, and click "Upload", you can make it automatically upload to a website of your choice. After uploading, a pop-up will appear saying it's done, and clicking "OK" will cause the link/download link to the file to appear in the popup box. I tried ImageShack and Facebook, and they work.
10. Spanish, Chinese, Korean, and Japanese unicode(s) and settings are integrated, so one can run foreign apps or use foreign keyboards without changing languages & restarting.
11. The Orb on the taskbar changes color, based on the dominant R/G/B/Y color of your taskbar (or your wallpaper, if the taskbar is 100% transparent) |
Via: http://windows7forums.com/windows-7-rumors-news/5757-build-7140-details-leaked.html
_________________ Win11 25H2 upgrade skriptid neile kelle masin ise ei taha 23H2 või 24H2 pealt ennast uuendada:
Youtube lisa vene jama eemaldamiseks:
https://foorum.hinnavaatlus.ee/viewtopic.php?p=11745846#11745846 |
Gizmoz
27.05.2009 23:44:56
keegi torrentit ka jagab uue buildi kohta ?
huvitavad mõlemad nii x64 kui x86
viimati muutis Gizmoz 27.05.2009 23:50:14, muudetud 1 kord |
Fate
27.05.2009 23:55:10
| Uuele buildile minnes on clean install või format või ta on lihtsalt nagu "win update" ja pärast restarti mul vägevam?
28.05.2009 01:22:36
| Fate kirjutas: |
| Uuele buildile minnes on clean install või format või ta on lihtsalt nagu "win update" ja pärast restarti mul vägevam? |
No kui vähegi aega, siis ikka clean install .Pealegi ega see kaua ei võta.Pealegi upgrade puhul peab samuti mõned programmid ikka uuesti installima.Iseasi palju keegi installib programme arendusversioonis olevale buildile ja palju keegi kardab clean installiga kaotada.Mul suht stock enamus sellised Beta ja RC versioonid(v.a kui testin jõudlust, siis timmin endale sobivaks) seega kui uus tuleb vms siis pole probleemi jälle uus clean installiga peale laksata
libe
kvaliteetne mees
28.05.2009 06:47:53
| tomorrow kirjutas: |
| Fate kirjutas: |
No kui vähegi aega, siis ikka clean install .Pealegi ega see kaua ei võta.Pealegi upgrade puhul peab samuti mõned programmid ikka uuesti installima.Iseasi palju keegi installib programme arendusversioonis olevale buildile ja palju keegi kardab clean installiga kaotada.Mul suht stock enamus sellised Beta ja RC versioonid(v.a kui testin jõudlust, siis timmin endale sobivaks) seega kui uus tuleb vms siis pole probleemi jälle uus clean installiga peale laksata  |
küsimus oli, et kas on võimalik upgradeda, sitta sellest, mida sina eelistad
mul ainsa operatsioonisüsteemina ei ole mõistlik iga buildiga clean installida - kuid kui eelmainitud kõlakas vähegi pädeb, siis upgradeks küll
_________________ ☠ |
soovija
28.05.2009 08:14:38
Via: .... |
See login taustapildi muutmine on küll väga tore lisa, muidugi ka need uued omadused, mis samuti meeldivad, kuid olen alati soovinud just login keskkonda muuta.
Edit: kahjuks fake jah
sulomile
28.05.2009 09:11:59
http://logonstudio.en.softonic.com/
Laadi omale see programm ja muuda oma logimise taustapilte palju jaksad
_________________ Oleks mina näinud, kuis sind tehti, oleks öelnud: ärge tehke. |
Look Right
Anna vin
28.05.2009 11:25:28
See kõlab lahedalt. Kui läpaka tagasi saan remondist, siis peab ka järgi katsetama.
_________________ Ehitusprojektid ja konstruktiivsed lahendused HV kasutajatele soodsamalt
M: Zafira A/Astra G põhjakaitse - 30€ |
DeTHiCa.
28.05.2009 12:30:41
vana beeta aegumisest:
Exploring Windows: Special Beta Edition -- Correction
Because you signed up to test the Windows 7 Beta, we recently sent you mail about the expiration dates for the Beta and Release Candidate. Unfortunately, we made a mistake.
We said the Beta would start shutting down every two hours on June 1, 2009. The correct date is July 1, 2009. |
28.05.2009 12:58:25
| libe kirjutas: |
mul ainsa operatsioonisüsteemina ei ole mõistlik iga buildiga clean installida - kuid kui eelmainitud kõlakas vähegi pädeb, siis upgradeks küll  |
No see on puhtalt sinu mure kui kasutad prerelease OS-i oma põhioperatsioonisüsteemina.Õigemini see on teadlik risk sinu poolt
| soovija kirjutas: |
| olen alati soovinud just login keskkonda muuta. |
Seda on saanud juba aastaid muuta.Kas siis siin postitatud LogonStudioga või siis manuaalselt Resource Hackeriga system32 kaustas imageres32.dll muutes ja muudetud DLL windowsi installatsioonifaili lisades,et juba esimesel sisselogimisel oleks see ees
Gizmoz
28.05.2009 12:59:14
| keegi seda uut buildi x64-na ka leidnud on ?
Vahur
28.05.2009 13:05:51
| Gizmoz, x64 build lekkis ennem välja isegi kui x86. Kirjutasin seda eespool ka.
Ertymo
Hollow
28.05.2009 15:53:12
Sai täna siis proovitud Fujitsu Siemens aka. AVerMedia Volar X USB HDTV tunerit RC peal... ja viimaste uuendustega on tulnud peale ka tugi, et ta suudav vista draiverid selle all ära installeerida... varem sai proovitud, siis käivitades draiveri exe, pakkis ta selle ainult lahti ja peale ei paigaldanud... tuli anda käsitsi kataloog ette ja siis suutis draiverid omaks võtta.
Eestikeele paketist... mina ei saa aru, miks peab olema tõlgitud Installima ja desinstallima... miks mitte paigaldamine ja eemaldamine
28.05.2009 15:58:11
| Hollow kirjutas: |
Eestikeele paketist... mina ei saa aru, miks peab olema tõlgitud Installima ja desinstallima... miks mitte paigaldamine ja eemaldamine |
ei saa lisamata jätta, et...
desinstalli pülga tüürelid ja redigeeri sirviku küpsise suvandeid
lauripoiss
28.05.2009 16:27:14
| Kas see build 7137 on ikka RC või lihtsalt tavaline build?
Look Right
Anna vin
28.05.2009 16:36:11
| Skeptik kirjutas: |
desinstalli pülga tüürelid ja redigeeri sirviku küpsise suvandeid  |
Mis see ingliskeeles oleks siis? Midagi ei saa aru
sakinaga
28.05.2009 16:41:50
uninstall usbdrive(?) drivers and edit(?) browser cookies options. Rohkem ei suutnud välja mõelda
libe
kvaliteetne mees
28.05.2009 17:06:06
| libe kirjutas: |
| soovija kirjutas: |
Seda on saanud juba aastaid muuta.Kas siis siin postitatud LogonStudioga või siis manuaalselt Resource Hackeriga system32 kaustas imageres32.dll muutes ja muudetud DLL windowsi installatsioonifaili lisades,et juba esimesel sisselogimisel oleks see ees  |
ja ikka sa räägid aiaaugust
heff
28.05.2009 17:29:45
| maatriks kirjutas: |
uninstall usbdrive(?) drivers and edit(?) browser cookies options. Rohkem ei suutnud välja mõelda  |
pülk peaks vist mp3-mängijale viitama, pole kindel aga arvan nii, kuskilt lugesin seda.
igal juhul huvitav, et üsna lampi on RC bootimine jube pikaks veninud, muidu kõik tavapärane aga kui "Starting Windows" kirjake tuleb, peab kuskil 20 sekundit ootama, siis hakkab windowsi logo alles trikke tegema, edasi kulgeb kõik normaalselt. Varem tuli see kiri ja max 1 sekund hiljem tuli logo sinna keerutama.
soovija
28.05.2009 17:30:28
See jah sweet, aga ma just lootsin built-in Windows 7 lahendust
28.05.2009 17:45:23
| lauripoiss kirjutas: |
| Kas see build 7137 on ikka RC või lihtsalt tavaline build? |
Pre-RTM ehk siis tavaline jah
| libe kirjutas: |
| libe kirjutas: |
| soovija kirjutas: |
ja ikka sa räägid aiaaugust |
Keegi ei käse lugeda
