uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 7 (arutelu ja probleemid) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 182, 183, 184 ... 746, 747, 748  järgmine
sõnum 27.05.2009 22:43:15 vasta tsitaadiga
lisasin õiged hash'id ka oma eelmisesse posti.
MÜÜA: Xbox 360 E 250GB (UUS)
pavka
sõnum 27.05.2009 23:12:25 vasta tsitaadiga
Kas on ka infot, mida täiendati?
sõnum 27.05.2009 23:18:19 vasta tsitaadiga
pavka kirjutas:
Liikus küll info 7140 kohta ja lisatud oli väike nimekiri muudatustest aga kas see ka tõele vastab ei oska öelda.Niikaua kui täpsemat kinnitust ei saa soovitan järgnevasse teatava skepsisega suhtuda icon_wink.gif
1. You can now add anything to the Taskbar.
2. Icons slightly expand when you hover over them on the taskbar.
3. The "System" menu is more simplistic, and easier to navigate.
4. You can change the login screen picture through the "Personalization" menu.
5. The menu/lists that pop up when you right click on things now have the Aero Glass effect.
6. The default icons for Folders have changed to be the transparent blue ones featured a long time ago.
8. The Minimize/Maximize/Exit buttons on the top-right of a window have changed icons, and are a bit smaller than the Vista/7 counterparts.
9. [BIG ONE]: There's an "Upload" feature for Pictures, files, and videos. If you right-click a file, and click "Upload", you can make it automatically upload to a website of your choice. After uploading, a pop-up will appear saying it's done, and clicking "OK" will cause the link/download link to the file to appear in the popup box. I tried ImageShack and Facebook, and they work.
10. Spanish, Chinese, Korean, and Japanese unicode(s) and settings are integrated, so one can run foreign apps or use foreign keyboards without changing languages & restarting.
11. The Orb on the taskbar changes color, based on the dominant R/G/B/Y color of your taskbar (or your wallpaper, if the taskbar is 100% transparent)
Via: http://windows7forums.com/windows-7-rumors-news/5757-build-7140-details-leaked.html
Win11 25H2 upgrade skriptid neile kelle masin ise ei taha 23H2 või 24H2 pealt ennast uuendada:
Gizmoz
Gizmoz
sõnum 27.05.2009 23:44:56 vasta tsitaadiga
keegi torrentit ka jagab uue buildi kohta ?
huvitavad mõlemad nii x64 kui x86
viimati muutis Gizmoz 27.05.2009 23:50:14, muudetud 1 kord
sõnum 27.05.2009 23:49:51 vasta tsitaadiga
Gizmoz kirjutas:
keegi torrentit ka jagab ?
Tahad ma jagan värskelt sadanud lund? icon_smile.gif .Sest tõenäosus on umbes sama kui,et ma jagaks avalikult siin torrentit icon_biggrin.gif
Fate
Fate
sõnum 27.05.2009 23:55:10 vasta tsitaadiga
Uuele buildile minnes on clean install või format või ta on lihtsalt nagu "win update" ja pärast restarti mul vägevam?
sõnum 28.05.2009 01:22:36 vasta tsitaadiga
Fate kirjutas:
No kui vähegi aega, siis ikka clean install thumbs_up.gif .Pealegi ega see kaua ei võta.Pealegi upgrade puhul peab samuti mõned programmid ikka uuesti installima.Iseasi palju keegi installib programme arendusversioonis olevale buildile ja palju keegi kardab clean installiga kaotada.Mul suht stock enamus sellised Beta ja RC versioonid(v.a kui testin jõudlust, siis timmin endale sobivaks) seega kui uus tuleb vms siis pole probleemi jälle uus clean installiga peale laksata thumbs_up.gif
libe
kvaliteetne mees
libe
sõnum 28.05.2009 06:47:53 vasta tsitaadiga
tomorrow kirjutas:
Fate kirjutas:
küsimus oli, et kas on võimalik upgradeda, sitta sellest, mida sina eelistad
mul ainsa operatsioonisüsteemina ei ole mõistlik iga buildiga clean installida - kuid kui eelmainitud kõlakas vähegi pädeb, siis upgradeks küll icon_idea.gif
soovija
soovija
sõnum 28.05.2009 08:14:38 vasta tsitaadiga
tomorrow kirjutas:
Via: ....
See login taustapildi muutmine on küll väga tore lisa, muidugi ka need uued omadused, mis samuti meeldivad, kuid olen alati soovinud just login keskkonda muuta.
Edit: kahjuks fake jah
sulomile
sulomile
sõnum 28.05.2009 09:11:59 vasta tsitaadiga
http://logonstudio.en.softonic.com/
Laadi omale see programm ja muuda oma logimise taustapilte palju jaksad thumbs_up.gif
Oleks mina näinud, kuis sind tehti, oleks öelnud: ärge tehke.
Look Right
Anna vin
Look Right
sõnum 28.05.2009 11:25:28 vasta tsitaadiga
See kõlab lahedalt. Kui läpaka tagasi saan remondist, siis peab ka järgi katsetama.
DeTHiCa.
DeTHiCa.
sõnum 28.05.2009 12:30:41 vasta tsitaadiga
vana beeta aegumisest:
Exploring Windows: Special Beta Edition -- Correction
Because you signed up to test the Windows 7 Beta, we recently sent you mail about the expiration dates for the Beta and Release Candidate. Unfortunately, we made a mistake.
We said the Beta would start shutting down every two hours on June 1, 2009. The correct date is July 1, 2009.
sõnum 28.05.2009 12:58:25 vasta tsitaadiga
libe kirjutas:
No see on puhtalt sinu mure kui kasutad prerelease OS-i oma põhioperatsioonisüsteemina.Õigemini see on teadlik risk sinu poolt icon_rolleyes.gif
soovija kirjutas:
Seda on saanud juba aastaid muuta.Kas siis siin postitatud LogonStudioga või siis manuaalselt Resource Hackeriga system32 kaustas imageres32.dll muutes ja muudetud DLL windowsi installatsioonifaili lisades,et juba esimesel sisselogimisel oleks see ees thumbs_up.gif
Gizmoz
Gizmoz
sõnum 28.05.2009 12:59:14 vasta tsitaadiga
keegi seda uut buildi x64-na ka leidnud on ?
Vahur
Vahur
sõnum 28.05.2009 13:05:51 vasta tsitaadiga
Gizmoz, x64 build lekkis ennem välja isegi kui x86. Kirjutasin seda eespool ka.
Ertymo
sõnum 28.05.2009 13:18:25 vasta tsitaadiga
Gizmoz kirjutas:
www.ziddu.com/download/4930982/windows7x86x64.rar.html
Hollow
Hollow
sõnum 28.05.2009 15:53:12 vasta tsitaadiga
Sai täna siis proovitud Fujitsu Siemens aka. AVerMedia Volar X USB HDTV tunerit RC peal... ja viimaste uuendustega on tulnud peale ka tugi, et ta suudav vista draiverid selle all ära installeerida... varem sai proovitud, siis käivitades draiveri exe, pakkis ta selle ainult lahti ja peale ei paigaldanud... tuli anda käsitsi kataloog ette ja siis suutis draiverid omaks võtta.
Eestikeele paketist... mina ei saa aru, miks peab olema tõlgitud Installima ja desinstallima... miks mitte paigaldamine ja eemaldamine
sõnum 28.05.2009 15:58:11 vasta tsitaadiga
Hollow kirjutas:
ei saa lisamata jätta, et...
desinstalli pülga tüürelid ja redigeeri sirviku küpsise suvandeid icon_lol.gif icon_lol.gif icon_lol.gif
lauripoiss
sõnum 28.05.2009 16:27:14 vasta tsitaadiga
Kas see build 7137 on ikka RC või lihtsalt tavaline build?
Look Right
Anna vin
Look Right
sõnum 28.05.2009 16:36:11 vasta tsitaadiga
Skeptik kirjutas:
sakinaga
sõnum 28.05.2009 16:41:50 vasta tsitaadiga
uninstall usbdrive(?) drivers and edit(?) browser cookies options. Rohkem ei suutnud välja mõelda icon_razz.gif
libe
kvaliteetne mees
libe
sõnum 28.05.2009 17:06:06 vasta tsitaadiga
tomorrow kirjutas:
libe kirjutas:
soovija kirjutas:
ja ikka sa räägid aiaaugust
heff
sõnum 28.05.2009 17:29:45 vasta tsitaadiga
maatriks kirjutas:
pülk peaks vist mp3-mängijale viitama, pole kindel aga arvan nii, kuskilt lugesin seda.
igal juhul huvitav, et üsna lampi on RC bootimine jube pikaks veninud, muidu kõik tavapärane aga kui "Starting Windows" kirjake tuleb, peab kuskil 20 sekundit ootama, siis hakkab windowsi logo alles trikke tegema, edasi kulgeb kõik normaalselt. Varem tuli see kiri ja max 1 sekund hiljem tuli logo sinna keerutama.
soovija
soovija
sõnum 28.05.2009 17:30:28 vasta tsitaadiga
sulomile kirjutas:
See jah sweet, aga ma just lootsin built-in Windows 7 lahendust icon_smile.gif
sõnum 28.05.2009 17:45:23 vasta tsitaadiga
lauripoiss kirjutas:
Pre-RTM ehk siis tavaline jah
libe kirjutas:
tomorrow kirjutas:
libe kirjutas:
soovija kirjutas:
uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 7 (arutelu ja probleemid) mine lehele eelmine  1, 2, 3 ... 182, 183, 184 ... 746, 747, 748  järgmine
