uus teema   vasta Tarkvara »  Linux & UNIX »  Küsimused/vastused seoses Ubuntu linuxiga vol 2 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 18, 19, 20 ... 56, 57, 58  järgmine
sõnum 08.05.2009 08:57:21 vasta tsitaadiga
Skeptik kirjutas:
draiveri autor Barros Lee saatis mulle uusima SiS video draiveri (2D) Ubuntu 8.10 jaoks, jagan siis teiega
In console mode execute sis_vga_drv_161208-Ubuntu810.run
$ sudo ./sis_vga_drv_161208-Ubuntu810.run
And modify your Xorg.conf
Add Driver "sis" in Section "Device"
http://www.hot.ee/hvasjad//sis_vga_drv_161208-Ubuntu810.zip
edit:
kohe peale uue draiveri installi sain ekraani native reso paika
Ubuntu 9.04 ei tööta enam selle draiveriga, nüüd hoopis sellega: http://ubuntuforums.org/showpost.php?p=6983046&postcount=119
/etc/X11/xorg.conf:
Driver "sis671"
mahfiaz
sõnum 08.05.2009 11:07:53 vasta tsitaadiga
kaabakas, .doc vorming ei oska leheküljestiile ning paneelistiile.
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 32
lehm2
sõnum 08.05.2009 11:49:22 vasta tsitaadiga
Järgmine katsumus KDE all firefoxi kohandamisega, ei saa kuidagi firefoxi downloadi windowsis faili tüübi ära tundmist, näiteks et teed kaks klikki PDF failile avaneb fail Okularis. Parim lahendus, mis ma leidsin on:
to make pdf open using a specific application when you double click it in the FF download manager, edit /usr/share/applications/mimeinfo.cache , search for: application/pdf= . Put the name of *application*.desktop of the desired application right after = .
So to use okular, it should look like this:
application/pdf=kde4-okularApplication_pdf.desktop
Notice the extra kde4- , this is necessary because okularApplication_pdf.desktop is in the subfolder kde4 in /usr/share/applications.
Replace okularApplication_pdf.desktop with whatever name of the .desktop file of the app you want. If it's in the same folder as mimeinfo.cache, i.e. /usr/share/applications then use the name of the .desktop folder, if it's in a subfolder then prefix it with kde4- , or kde- , whatever. See if this works.
mimeinfo.cache is a dynamic file and will be changed automatically when you install/uninstall a programme (this explains what happened when you uninstalled gimp). Of course you can keep a local copy of this file maintaining your own associations across reinstalls), you need to put this copy in ~/.local/share/applications , also a copy of /usr/share/applications/defaults.
Kuid pathi /usr/share/applications/mimeinfo.cache all seda faili ei olnud. icon_rolleyes.gif
Piilu siia, progreja!
Vajad abi Node.JS-ga ?
Võta ühendust !
Riivo
Riivo
sõnum 08.05.2009 12:07:15 vasta tsitaadiga
lehm2, proovi see fail luua. Aga kas Firefoxi enda seadetest (Edit->Preferences->Applications) ei õnnestunud muuta?
lehm2
sõnum 08.05.2009 12:38:25 vasta tsitaadiga
No menüüst minnes, siis seal pooled asjad puudu .doc .xls, .ppt ja kuskilt juurde ka ei saa lisada. icon_rolleyes.gif
//edit /usr/share/mozilla/extensions kaust on tühi, kas siin midagi ei peaks olema ?
Võta ühendust !
oicu
sõnum 08.05.2009 12:53:22 vasta tsitaadiga
kcontrol->kde components all on File associations. Sealt saab määrata, mis programmiga mingit faili avada. Sellest ei ole abi?
Fiocchi
Fiocchi
sõnum 08.05.2009 13:54:21 vasta tsitaadiga
Mul on viimasel ajal Ubuntuga see häda, et ei saa kodus läpakaga enam netti. Ei kaabliga ega wifiga. Sama ka 8.10 Live CD'ga. Näitab, et ühendab ära, aga amsn sisse ei suuda logida ning firefox lehekülgi ei ava. Samas kaabliga windowsi all probleeme pole(wifi ei tööta siingi). Meil on siin majja tulev nett mitme peale ära jaotatud ja täna avastasin, et sellele ruuterile, mis jagab, on parool peale pandud. Ilmselt on siis veel midagi ära muudetud. Kas on võimalik midagi Ubuntus niimoodi muuta, et sellega ka netti pääseks? Windows ju samas masinas pääseb, seega ei saa olla läpaka viga. Wifi on nagunii kellegi meie ruuterist tulev ja mitte minu oma, nii et sellepärast väga ei pabista. Saaks aga kaabliga netti oleks asi korras.
EDIT: Muidugi nüüd kus siia hädaldama tulin lahenes asi iseenesest ja praegu tundub nett toimivat. icon_rolleyes.gif
viimati muutis Fiocchi 08.05.2009 16:49:44, muudetud 1 kord
uprahaba
sõnum 08.05.2009 15:22:41 vasta tsitaadiga
Ei saa CD-ROMi lahti. Vajutan avamiseks nuppu ja viskab errori. Peale restarti mure kaob mõneks ajaks. Äkki keegi oskab suunata?
Riivo
Riivo
sõnum 08.05.2009 18:52:01 vasta tsitaadiga
uprahaba, kas "eject" terminali annab effekti?
marqs
marqs
sõnum 08.05.2009 19:05:08 vasta tsitaadiga
Firefoxi väga huvita, millised failiseosed on kdes määratud.
Abiks on näiteks kõik failid /usr/bin/xdg-open 'iga avada, reeglina läheb käima õige asi.
http://www.terminaldigit.com/2008/08/08/get-firefox-to-honor-kde-file-associations/
0xDEAD
0xBEEF
lehm2
sõnum 09.05.2009 13:29:03 vasta tsitaadiga
marqs kirjutas:
Aitäh läks kohe väga hästi tööle, ainult et tekkis probleeme printeriga. Printis 20 lehte ja paberi lõppedes enam printerit üles ei leia. Tegin restarti üritasin drivereid uuesti installeerida, kuid ei midagi. Ühendus läbi usb on ära kadunud ning kätte ei saa. Panen logist väikese copy ehk aitab probleemi lahendusele kaasa.
2009-05-09 14:20:46   Rita   HP_LaserJet_1018?serial=KP33Z0T   prnt/backend/hp.c 710: INFO: open device failed stat=12; will retry in 30 seconds...
2009-05-09 14:20:48   Rita   python   io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:48   Rita   python   hp-systray(hpdio)[3416]: error: Unable to communicate with device (code=12): hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:48   Rita   python   hp-systray(hpdio)[3416]: error: Device not found
2009-05-09 14:20:49   Rita   python   io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:49   Rita   python   hp-systray(hpdio)[3416]: error: Unable to communicate with device (code=12): hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:49   Rita   python   hp-systray(hpdio)[3416]: error: Device not found
2009-05-09 14:20:50   Rita   python   io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:50   Rita   python   hp-systray(hpdio)[3416]: error: Unable to communicate with device (code=12): hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:50   Rita   python   hp-systray(hpdio)[3416]: error: Device not found
2009-05-09 14:20:52   Rita   python   io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:52   Rita   python   hp-systray(hpdio)[3416]: error: Unable to communicate with device (code=12): hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:52   Rita   python   hp-systray(hpdio)[3416]: error: Device not found
2009-05-09 14:20:55   Rita   python   io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:55   Rita   python   hp-systray(hpdio)[3416]: error: Unable to communicate with device (code=12): hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:55   Rita   python   hp-systray(hpdio)[3416]: error: Device not found
2009-05-09 14:21:08   Rita   python   hp-toolbox(UI)[3467]: warning: Supplies information not available for this device.
2009-05-09 14:21:14   Rita   python   io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:21:14   Rita   python   hp-systray(hpdio)[3416]: error: Unable to communicate with device (code=12): hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:21:14   Rita   python   hp-systray(hpdio)[3416]: error: Device not found
2009-05-09 14:21:16   Rita   HP_LaserJet_1018?serial=KP33Z0T   io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:21:16   Rita   HP_LaserJet_1018?serial=KP33Z0T   prnt/backend/hp.c 710: INFO: open device failed stat=12; will retry in 30 seconds...
2009-05-09 14:21:46   Rita   HP_LaserJet_1018?serial=KP33Z0T   io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:21:46   Rita   HP_LaserJet_1018?serial=KP33Z0T   prnt/backend/hp.c 710: INFO: open device failed stat=12; will retry in 30 seconds...
2009-05-09 14:22:17   Rita   HP_LaserJet_1018?serial=KP33Z0T   io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:22:17   Rita   HP_LaserJet_1018?serial=KP33Z0T   prnt/backend/hp.c 710: INFO: open device failed stat=12; will retry in 30 seconds...
2009-05-09 14:22:47   Rita   HP_LaserJet_1018?serial=KP33Z0T   io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
Võta ühendust !
EpX
EpX
sõnum 09.05.2009 18:53:51 vasta tsitaadiga
EpX kirjutas:
Kas on mingit võimalust Ubuntu all, kuidas suurendada wireless võrgukaardi võimsust vms? Näiteks keerates powersave maha või koduses võrgus määrata mõni argument manuaalselt? (power, txpower, sens, rts tunduvad midagi sellist pakkuvat?)
iwconfig --help
Usage: iwconfig [interface]
                interface essid {NNN|any|on|off}
                interface mode {managed|ad-hoc|master|...}
                interface freq N.NNN[k|M|G]
                interface channel N
                interface bit {N[k|M|G]|auto|fixed}
                interface rate {N[k|M|G]|auto|fixed}
                interface enc {NNNN-NNNN|off}
                interface key {NNNN-NNNN|off}
                interface power {period N|timeout N|saving N|off}
                interface nickname NNN
                interface nwid {NN|on|off}
                interface ap {N|off|auto}
                interface txpower {NmW|NdBm|off|auto}
                interface sens N
                interface retry {limit N|lifetime N}
                interface rts {N|auto|fixed|off}
                interface frag {N|auto|fixed|off}
                interface modulation {11g|11a|CCK|OFDMg|...}
                interface commit
       Check man pages for more details.
Küsin veel ühe korra uuesti, ehk keegi abivalmim oskab aidata.
DoS
DoS
sõnum 09.05.2009 18:58:56 vasta tsitaadiga
EpX kirjutas:
nagu juba öeldud, siis rtfm?
Kommentaarid: 50 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 47
lehm2
sõnum 12.05.2009 12:06:49 vasta tsitaadiga
Probleem järgnev, sai Windowsist ketta pealt kopeeritud failid linuxi asuvasse kettale, kuid tekkis probleem failide avamisega. Faili avades ütleb faili ei eksisteeri, natuke asja uurides avasin openoffice kaudu faili ning töötas. Läbi Nautiluse kaudu aga ei tööta, kardan et probleem on täpitähti sisaldavate failidige, näiteks openoffices avatud täpitähti sisaldav failinimi on sümboleid täis. Probleem vist Encodinguga, kuid mida muuta või teha seda ma ei tea. icon_rolleyes.gif
Võta ühendust !
Riivo
Riivo
sõnum 12.05.2009 14:16:42 vasta tsitaadiga
lehm2 kirjutas:
Uuri käsku convmv ja seda artiklit. Omale oli abiks ja lahendas sarnase probleemi ära.
lehm2
sõnum 12.05.2009 17:21:43 vasta tsitaadiga
Uurisin ja puursin seda convmv aga lahendust ei kuskilt viskas esialgu kui iso 8859-4-st utf8 tegin vea, et juba faili nimi on utf8. Viimane kord aga proovisin sain veaks:
WARNING: new filename "��2009 05 Kutse yldkoosolekule[1]par.doc" contains characters, which are not POSIX filesystem conform!
Nautilusega vaadates failinimed tunduvad õiged, kuid avades loobib erroreid. icon_rolleyes.gif
Viimase avastusega olen võibolla probleemile lähemal, millegi pärast on locale käsuga väärtused puudu, ehk aitab keegi confi täita ?
'locale
LANG=C
LC_CTYPE="C"
LC_NUMERIC="C"
LC_TIME="C"
LC_COLLATE="C"
LC_MONETARY="C"
LC_MESSAGES="C"
LC_PAPER="C"
LC_NAME="C"
LC_ADDRESS="C"
LC_TELEPHONE="C"
LC_MEASUREMENT="C"
LC_IDENTIFICATION="C"
LC_ALL=
Võta ühendust !
sõnum 12.05.2009 17:25:57 vasta tsitaadiga
Esiteks - kuidas toimus nende failide kopeerimine - võrgukettalt või Linuxi külge monteeritud kõvakettalt otse?
Teiseks - näita probleemse kataloogi sisu listingut.
Enne convmv kasutamist tasuks kataloogist koos sisuga teha koopia juhuks, kui midagi nässu läheb.
Naljatilk
Naljatilk
sõnum 12.05.2009 17:34:39 vasta tsitaadiga
Oskab keegi öelda, miks pärast 9.04 peale minekut mul enam Processor scaling ei tööta?
Samas eemaldasin ligikaudu samal ajal laptop-mode'i.
Kumbast see sõltuda võiks?
(Ei kasuta eriti tihti rüperaali, seepärast pole eriti jõudnud ise uurida)
Vaata pilti
lehm2
sõnum 12.05.2009 17:42:14 vasta tsitaadiga
Kopeerimine käis läbi võrgu teiselt windowsi masinalt, kuid vaatan et probleem polegi ainult kopeeritud failidega, vaid ka nendega, mis internetist, cd-l on. Näiteks ühe internetist suvalise faili allatõmbamisel on failinimeks
http://img60.imageshack.us/my.php?image=tests.png. icon_neutral.gif
Võta ühendust !
sõnum 12.05.2009 17:55:56 vasta tsitaadiga
Mis sul /etc/locale.gen faili sees on? Vaatamiseks:
cat /etc/locale.gen
lehm2
sõnum 12.05.2009 18:01:55 vasta tsitaadiga
Dogbert kirjutas:
cat /etc/locale.gen
Nii vastuseks tuleb
cat /etc/locale.gen
cat: /etc/locale.gen: No such file or directory
Aga language-support ei lähegi sellepärast tööle, kuna ta võtab mõned väärtused confist locale ning nende puududes aga jookseb progra kokku.
locale -a
C
POSIX
et_EE.utf8
Võta ühendust !
sõnum 12.05.2009 18:59:31 vasta tsitaadiga
Kui seda faili pole, siis tuleb see ise teha. Kättesaadavast materjalist (st et lokaadid võetakse failist SUPPORTED):
$ cd ~
$ cat /usr/share/i18n/SUPPORTED | grep -E "(en_US|et_EE)" > locale.gen
Tulemuseks võiks olla midagi sellist:
en_US.UTF-8 UTF-8
en_US ISO-8859-1
en_US.ISO-8859-15 ISO-8859-15
et_EE.UTF-8 UTF-8
et_EE ISO-8859-1
et_EE.ISO-8859-15 ISO-8859-15
(vaatamiseks cat locale.gen)
Kui seal on olemas vähemalt en_US.UTF-8 UTF-8, siis jätka:
$ chmod 644 locale.gen
$ sudo chown root:root locale.gen
$ sudo mv locale.gen /etc/
$ sudo locale-gen
lehm2
sõnum 13.05.2009 15:48:11 vasta tsitaadiga
Õpetus mis tegid sai ilma errorite läbi tehtud,
cat /etc/locale.gen
en_US.UTF-8 UTF-8
en_US ISO-8859-1
et_EE.UTF-8 UTF-8
et_EE ISO-8859-1
ja viimasest käsust saan
Generating locales...
  et_EE.UTF-8... up-to-date
Generation complete.
Kas nüüd vajalik muuta LANG väärtust mingit moodi ? Igatpidi kuidas ma LANG väärtust muuta olen üritan, ei salvestu see ära. icon_rolleyes.gif
locale
LANG=C
LC_CTYPE="C"
LC_NUMERIC="C"
LC_TIME="C"
LC_COLLATE="C"
LC_MONETARY="C"
LC_MESSAGES="C"
LC_PAPER="C"
LC_NAME="C"
LC_ADDRESS="C"
LC_TELEPHONE="C"
LC_MEASUREMENT="C"
LC_ALL=
Ainuke võimalus kuidas ajutiselt väärtust muuta on export commandiga, kuid seaded pole püsivad.
export LANG=et_EE.UTF-8
murka@murka-desktop:~$ locale
LANG=et_EE.UTF-8
LC_CTYPE="et_EE.UTF-8"
LC_NUMERIC="et_EE.UTF-8"
LC_TIME="et_EE.UTF-8"
LC_COLLATE="et_EE.UTF-8"
LC_MONETARY="et_EE.UTF-8"
LC_MESSAGES="et_EE.UTF-8"
LC_PAPER="et_EE.UTF-8"
LC_NAME="et_EE.UTF-8"
LC_ADDRESS="et_EE.UTF-8"
LC_TELEPHONE="et_EE.UTF-8"
LC_MEASUREMENT="et_EE.UTF-8"
LC_IDENTIFICATION="et_EE.UTF-8"
LC_ALL=
Ok, sain lahenduse pikapeale kätte, muutsin LANG väärtuse käsuga export LANG=et_EE.UTF-8. Seega andis mulle võimaluse, siseneda Language Supporti -> Seal oli küll language asemel tühi lahter, kuid valisin Estonian, ning seejärel salvestasin. Muutsin failinimed GUI tooliga(UTF-8 Migration Tool), sain failinimede encodingu korda. Tänud, kes aitasid mind suunamisega! thumbs_up.gif
Võta ühendust !
Fiocchi
Fiocchi
sõnum 13.05.2009 22:20:10 vasta tsitaadiga
Naljatilk kirjutas:
Ei tööta nii, et protsessor uugab pidevalt max võimsusel? Mul oli sama jama, aitas kui protsess trackerd kinni panna. Google rääkis ka, et indekseerimisega on mingi tõsine jama 9.04's. Nii et parem on see esialgu üldse kinni panna. Ma endal eemaldasin start up'ist trackerd'i ja mingi indexeri vms asja ära ja peale seda probleemi pole.
note1
note1
sõnum 16.05.2009 18:01:57 vasta tsitaadiga
Mul on trackerd üldse eemaldatud.
splash ja muu mõttetu praht.
Kommentaarid: 3 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 1
raido357
sõnum 16.05.2009 20:09:27 vasta tsitaadiga
note1 kirjutas:
Kuidas see abi küsijat aitab ?
note1
note1
sõnum 17.05.2009 14:30:25 vasta tsitaadiga
Fiocchi kirjutas:
Synaptic paketihalduris otsingu abiga leida ja saab ka eemaldada.
Aga kas 9.04 on siis teil juba?
Mul alles 8.04.2
Fiocchi
Fiocchi
sõnum 17.05.2009 21:53:48 vasta tsitaadiga
note1 kirjutas:
Mul alles 8.04.2
Naljatilk kirjutas:
Oskab keegi öelda, miks pärast 9.04 peale minekut...
sfx
sõnum 19.05.2009 22:13:15 vasta tsitaadiga
Oskab keegi ehk nõu anda, kuidas volume control tööle saada, kui välised kõlarid ühendatud on.
Kui heli tuleb läpaka (Dell Latitude X300) enda kõlaritest, töötavad nii klaviatuuri shortcutid kui ka ülevalt paneelilt helitugevuse muutmine korralikult, nii kui välised kõlarid või kõrvaklapid ühendada, lakkavad need töötamast.
Peal on uusim 9.04
--edit--
Leidsin juba lahenduse SIIT.
Kommentaarid: 170 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 151
note1
note1
sõnum 20.05.2009 12:48:57 vasta tsitaadiga
Mul on 8.04 LTS ja eemaldasin splashi (kustutasin ka grubi kõivit menüüst splashi rea ära. Nüüd ei tule ubuntu logo ja näen käivituse ajal logisi ja veateateid.
tracerd ja muud säärast - näiteks avahi (avahi on mingi lokaalse võrgu jaoks).
PIII 730Mhz ikka on veidike kiirem.
Pealegi on mul eestikeelne ubuntu ja teid aidata ei oska. Väike probleem , mis kujuneb inglise eestlaste abistamisel. Programmide nimetusi on eestindatud ja 2d ja 3g nuppe samuti. Aga käsiraamat on ingliskeelne..
Kes see loll hakkas küll linuxit eestindama?
File on Fail ja Open on Ava.
mahfiaz
sõnum 22.05.2009 08:22:42 vasta tsitaadiga
note1, mis sa niisama prõõkad. Mõõda oma käivituskiirus enne ja pärast. Kui numbrid letti laod, siis usume.
Mis eestindamisesse puutub, siis miks sa loll siin eesti keeles räägid?
note1
note1
sõnum 22.05.2009 08:45:31 vasta tsitaadiga
mahfiaz kirjutas:
Kah õige.
Ainult, et kas sa ikka teed õieti, kui tõlgid ka rakenduste nimetusi (programmi pealkirju) eesti keelde. Päris raske on meelde tuletada, et mis selle proge ingliskeelne nimetus on. Menüüdes.
Naljatilk
Naljatilk
sõnum 22.05.2009 13:08:09 vasta tsitaadiga
Fiocchi kirjutas:
Naljatilk kirjutas:
Vaata pilti
mahfiaz
sõnum 23.05.2009 16:34:55 vasta tsitaadiga
note1, paned programmi käima ja vaatada Abi → Programmist lähemalt
wolfe
wolfe
sõnum 25.05.2009 14:05:23 Samba Vistaga vasta tsitaadiga
Terv.
Jooksutan Jaunty 9.04 ning olen viimane aasta aega(aeg-ajalt) püüdnud luua võrku vista läpakaga, läbi ruuteri. Ubuntus on samba confitud failiserveriks, jagamaks üht kindlat kausta, milles on kõik chmod jne. tehtud. Kummagil arvutil on eraldi kasutajad kuid lisasin ka Vista kasutaja Sambasse: smbpasswd ja enable'sin selle. Pmst. peaks asi toimima. Ma suudan pingida arvuteid omavahel, Vista tulemüür sai üleüldse maha võetud, kuid kui püüan Vistas "Map Network Location" \\ubuntu_IP\MyFiles siis viskab veateate, et ei suutnud seda lokaliseerida.
medieval
medieval
sõnum 25.05.2009 14:31:10 Re: Samba Vistaga vasta tsitaadiga
wolfe kirjutas:
Terv.
Vista ei suuda su ext3 failisüsteemi lugeda. Otsi internetist drivereid/progamme.
kaabakas
kaabakas
sõnum 25.05.2009 14:51:14 vasta tsitaadiga
wolfe, mis juhtub kui winexploreris aadressiribale \\ubuntu_ip kirjutada? Mida näitab ubuntus testparm ja samba logi?
Adebisi
sõnum 25.05.2009 14:56:34 vasta tsitaadiga
wolfe, kaustal Guest access lubatud?
Kommentaarid: 58 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 55
tom1245
sõnum 25.05.2009 15:58:24 Re: Samba Vistaga vasta tsitaadiga
medieval kirjutas:
wolfe kirjutas:
Terv.
miks ta ei peaks lugema? WinXP küll loeb.
Ehitusteemalised arutelud:
https://www.ehitusfoorum.com
Kommentaarid: 84 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 78
note1
note1
sõnum 25.05.2009 16:14:41 vasta tsitaadiga
Ni lollile küsimusele ei olegi vastust.
Kas Vista ja Jaunty enam üldse tänapäeval ühildub?
Ma olen ka loll, näete!
Cancer
sõnum 25.05.2009 20:17:16 vasta tsitaadiga
wolfe, Network discovery ikka sees on?
D I G I T A L L Y - I M P O R T E D ● Electronic Dance Music with Highly Addictive Elements
kaabakas
kaabakas
sõnum 26.05.2009 07:18:59 vasta tsitaadiga
1) Kulla inimesed, see kas vista ext3 oskab ei ole mingilgi määral relevantne üle võrgu failide jagamise juures. (Et oleks kirjas, siis draiver on selleks puhuks olemas.)
2) Google otsing 'vista samba' andis hea portsu tarka juttu ühildamise kohta. Enne edasist abistamise katset tahaks teada, et wolfe on selle läbi töötanud.
note1
note1
sõnum 26.05.2009 07:45:48 vasta tsitaadiga
Minul on nii, et ma pean ufw lubama samba pordid. Mul on ufw sees.
Pealegi on mul buntut natuke nuditud ja lokaalse võrgu tuvastus-plugin on eemaldatud:
http://ubuntust.blogspot.com/
wolfe
wolfe
sõnum 26.05.2009 10:06:24 vasta tsitaadiga
Ok jõudsin ka siia teemasse tagasi.
Ega ma naljalt abipalve postitusi tee, sai tubli tükk päevast googeldatud eri variante. Leidsin isegi, et Vista kasutavat vaikimisi NTLMv2 autentimist, mida näiteks. Samba 2.x ei räägi, no olgu endal on 3.x aga sai Vistas registris väike asi muudetud, et seda ei oleks. Testparm sai ammu tehtud ja samba logid läbi vaadatud, olen veendunud, et Samba töötab.
fyrzen@spyder:/etc/samba$ testparm
Load smb config files from /etc/samba/smb.conf
Processing section "[print$]"
Processing section "[printers]"
Processing section "[MyFiles]"
Loaded services file OK.
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
[global]
   server string =
   null passwords = Yes
   passdb backend = tdbsam
   username map = /etc/samba/smbusers
   syslog only = Yes
   announce version = 5.0
   name resolve order = hosts wins bcast
   socket options = TCP_NODELAY IPTOS_LOWDELAY SO_KEEPALIVE SO_RCVBUF=8192 SO_SNDBUF=8192
   printcap name = CUPS
[print$]
   path = /var/lib/samba/printers
   write list = root
   create mask = 0664
   directory mask = 0775
   guest ok = Yes
[printers]
   path = /tmp
   guest ok = Yes
   printable = Yes
   browseable = No
[MyFiles]
   path = /home/samba/
   force user = fyrzen
   force group = fyrzen
   read only = No
   create mask = 0644
/var/log/log.smbd
[2009/05/24 12:46:47,  0] smbd/server.c:main(1260)
  smbd version 3.3.2 started.
  Copyright Andrew Tridgell and the Samba Team 1992-2009
[2009/05/24 12:46:47,  0] printing/print_cups.c:cups_connect(103)
  Unable to connect to CUPS server localhost:631 - Connection refused
[2009/05/24 12:51:12,  0] smbd/server.c:main(1260)
[2009/05/24 14:48:19,  0] smbd/server.c:main(1260)
[2009/05/25 00:14:25,  0] smbd/server.c:main(1260)
...Siit edasi on pmst samad teated samba startimisest, nojah iga kord kui smb.conf oli muuta vaja võtsin ta maha.
Ülejäänud samba logid on ka suht veateate vabad. Ainult log.winbindd-idmap sisaldab mingeid mõttetuid erroreid, et ei läinud tööle. Ega ma ei püüagi mingit domeeni vms. luua ega Samba läbi ühendust või printereid. jagada. Vaja ainult lihtsat failiserverit.
Vista poole pealt, network discovery on sees.
Kuna Vistal oli veel vana Norton antiviirus, mille eest taheti raha, et jätkata kasutamist, otsustasin selle maha lasta. Nüüd kasutab Vista AVG'd ja windows tulemüüri. See näib olevat põhjustanud: "a device attached to the system is not functioning" veateate, kui püüan mappida, lahenduste hulka kuulub file and printer sharing maha võtmine, jne. Ma arvan, et AVG meelega teeb seda, sest eelmine päev lakkas üks viirusetõrje komponent töötamast iga kord, kui püüdsin mappida võrgu asukohta ja täna töötab viirusetõrje vigadeta.
note1
note1
sõnum 26.05.2009 10:57:07 vasta tsitaadiga
Jaunty ja id kaardi tarkvara testimine (beta):
Paigalda firefoxile plugin:
ftp://ftp.smartlink.ee/pub/id/plugins
Lisa repositoorium
terminalis:
$sudo wget http://ubuntu.planet.ee/pub/id/ubuntu_9.04/idkaart.list --output-document=/etc/apt/sources.list.d/idkaart.list
$sudo apt-get update
Nüüd saad synapticus vaadata, mis tarkvara sa paigaldama pead:
sisaldab digidoc, qesteidutil, qdigitoc jt.
Ise plaanin ka jautyt testida..
mihkelv
sõnum 26.05.2009 11:37:58 vasta tsitaadiga
Miks peaks keegi tahtma sinu pakivaramut kasutada?
Riivo
Riivo
sõnum 26.05.2009 13:25:27 vasta tsitaadiga
mihkelv kirjutas:
Need pole tema, vaid ametlikud. Ja see tarkvara on veel alfa staadiumis.
https://id.eesti.ee/trac/
note1
note1
sõnum 26.05.2009 15:26:35 vasta tsitaadiga
sudo apt-get install opensc pcscd libccid
pidin paigaldama veel need, kuid kõik asjad ei hakanudki tööle.
Ühesõnaga poolik veel.
Peab sellega hakkama saama:
https://ideelabor.ee/opensource/wiki/IdKaardiTarkvara/UbuntuLinux
mihkelv
sõnum 26.05.2009 17:28:30 vasta tsitaadiga
riivo21 kirjutas:
mihkelv kirjutas:
hmm
idkaart.list sisaldab rida:
deb http://ubuntu.planet.ee/pub/id/ubuntu_9.04 ./
Smartlink'i "ametlik" varamu asub ju ftp.smartlink.ee serveris.
note1
note1
sõnum 26.05.2009 19:06:21 vasta tsitaadiga
uus teema   vasta Tarkvara »  Linux & UNIX »  Küsimused/vastused seoses Ubuntu linuxiga vol 2 mine lehele eelmine  1, 2, 3 ... 18, 19, 20 ... 56, 57, 58  järgmine
