08.05.2009 08:57:21
| Skeptik kirjutas: |
draiveri autor Barros Lee saatis mulle uusima SiS video draiveri (2D) Ubuntu 8.10 jaoks, jagan siis teiega
In console mode execute sis_vga_drv_161208-Ubuntu810.run
$ sudo ./sis_vga_drv_161208-Ubuntu810.run
And modify your Xorg.conf
Add Driver "sis" in Section "Device" |
http://www.hot.ee/hvasjad//sis_vga_drv_161208-Ubuntu810.zip
edit:
kohe peale uue draiveri installi sain ekraani native reso paika |
Ubuntu 9.04 ei tööta enam selle draiveriga, nüüd hoopis sellega: http://ubuntuforums.org/showpost.php?p=6983046&postcount=119
/etc/X11/xorg.conf:
313 |
mahfiaz
08.05.2009 11:07:53
| kaabakas, .doc vorming ei oska leheküljestiile ning paneelistiile.
| Kommentaarid: 32 loe/lisa |
lehm2
08.05.2009 11:49:22
Järgmine katsumus KDE all firefoxi kohandamisega, ei saa kuidagi firefoxi downloadi windowsis faili tüübi ära tundmist, näiteks et teed kaks klikki PDF failile avaneb fail Okularis. Parim lahendus, mis ma leidsin on:
to make pdf open using a specific application when you double click it in the FF download manager, edit /usr/share/applications/mimeinfo.cache , search for: application/pdf= . Put the name of *application*.desktop of the desired application right after = .
So to use okular, it should look like this:
application/pdf=kde4-okularApplication_pdf.desktop
Notice the extra kde4- , this is necessary because okularApplication_pdf.desktop is in the subfolder kde4 in /usr/share/applications.
Replace okularApplication_pdf.desktop with whatever name of the .desktop file of the app you want. If it's in the same folder as mimeinfo.cache, i.e. /usr/share/applications then use the name of the .desktop folder, if it's in a subfolder then prefix it with kde4- , or kde- , whatever. See if this works.
mimeinfo.cache is a dynamic file and will be changed automatically when you install/uninstall a programme (this explains what happened when you uninstalled gimp). Of course you can keep a local copy of this file maintaining your own associations across reinstalls), you need to put this copy in ~/.local/share/applications , also a copy of /usr/share/applications/defaults.
Kuid pathi /usr/share/applications/mimeinfo.cache all seda faili ei olnud.
_________________ Piilu siia, progreja!
Vajad abi Node.JS-ga ?
Võta ühendust ! |
| Kommentaarid: 15 loe/lisa |
Riivo
08.05.2009 12:07:15
| lehm2, proovi see fail luua. Aga kas Firefoxi enda seadetest (Edit->Preferences->Applications) ei õnnestunud muuta?
221 |
lehm2
08.05.2009 12:38:25
No menüüst minnes, siis seal pooled asjad puudu .doc .xls, .ppt ja kuskilt juurde ka ei saa lisada.
//edit /usr/share/mozilla/extensions kaust on tühi, kas siin midagi ei peaks olema ?
Võta ühendust ! |
oicu
08.05.2009 12:53:22
| kcontrol->kde components all on File associations. Sealt saab määrata, mis programmiga mingit faili avada. Sellest ei ole abi?
| Kommentaarid: 9 loe/lisa |
9 |
Fiocchi
08.05.2009 13:54:21
Mul on viimasel ajal Ubuntuga see häda, et ei saa kodus läpakaga enam netti. Ei kaabliga ega wifiga. Sama ka 8.10 Live CD'ga. Näitab, et ühendab ära, aga amsn sisse ei suuda logida ning firefox lehekülgi ei ava. Samas kaabliga windowsi all probleeme pole(wifi ei tööta siingi). Meil on siin majja tulev nett mitme peale ära jaotatud ja täna avastasin, et sellele ruuterile, mis jagab, on parool peale pandud. Ilmselt on siis veel midagi ära muudetud. Kas on võimalik midagi Ubuntus niimoodi muuta, et sellega ka netti pääseks? Windows ju samas masinas pääseb, seega ei saa olla läpaka viga. Wifi on nagunii kellegi meie ruuterist tulev ja mitte minu oma, nii et sellepärast väga ei pabista. Saaks aga kaabliga netti oleks asi korras.
EDIT: Muidugi nüüd kus siia hädaldama tulin lahenes asi iseenesest ja praegu tundub nett toimivat.
viimati muutis Fiocchi 08.05.2009 16:49:44, muudetud 1 kord |
| Kommentaarid: 16 loe/lisa |
15 |
uprahaba
08.05.2009 15:22:41
Ei saa CD-ROMi lahti. Vajutan avamiseks nuppu ja viskab errori. Peale restarti mure kaob mõneks ajaks. Äkki keegi oskab suunata?
Tänud abistajale!
Riivo
08.05.2009 18:52:01
| uprahaba, kas "eject" terminali annab effekti?
221 |
marqs
| Kommentaarid: 28 loe/lisa |
lehm2
09.05.2009 13:29:03
Aitäh läks kohe väga hästi tööle, ainult et tekkis probleeme printeriga. Printis 20 lehte ja paberi lõppedes enam printerit üles ei leia. Tegin restarti üritasin drivereid uuesti installeerida, kuid ei midagi. Ühendus läbi usb on ära kadunud ning kätte ei saa. Panen logist väikese copy ehk aitab probleemi lahendusele kaasa.
2009-05-09 14:20:46 Rita HP_LaserJet_1018?serial=KP33Z0T prnt/backend/hp.c 710: INFO: open device failed stat=12; will retry in 30 seconds...
2009-05-09 14:20:48 Rita python io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:48 Rita python hp-systray(hpdio)[3416]: error: Unable to communicate with device (code=12): hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:48 Rita python hp-systray(hpdio)[3416]: error: Device not found
2009-05-09 14:20:49 Rita python io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:49 Rita python hp-systray(hpdio)[3416]: error: Unable to communicate with device (code=12): hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:49 Rita python hp-systray(hpdio)[3416]: error: Device not found
2009-05-09 14:20:50 Rita python io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:50 Rita python hp-systray(hpdio)[3416]: error: Unable to communicate with device (code=12): hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:50 Rita python hp-systray(hpdio)[3416]: error: Device not found
2009-05-09 14:20:52 Rita python io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:52 Rita python hp-systray(hpdio)[3416]: error: Unable to communicate with device (code=12): hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:52 Rita python hp-systray(hpdio)[3416]: error: Device not found
2009-05-09 14:20:55 Rita python io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:55 Rita python hp-systray(hpdio)[3416]: error: Unable to communicate with device (code=12): hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:20:55 Rita python hp-systray(hpdio)[3416]: error: Device not found
2009-05-09 14:21:08 Rita python hp-toolbox(UI)[3467]: warning: Supplies information not available for this device.
2009-05-09 14:21:14 Rita python io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:21:14 Rita python hp-systray(hpdio)[3416]: error: Unable to communicate with device (code=12): hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:21:14 Rita python hp-systray(hpdio)[3416]: error: Device not found
2009-05-09 14:21:16 Rita HP_LaserJet_1018?serial=KP33Z0T io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:21:16 Rita HP_LaserJet_1018?serial=KP33Z0T prnt/backend/hp.c 710: INFO: open device failed stat=12; will retry in 30 seconds...
2009-05-09 14:21:46 Rita HP_LaserJet_1018?serial=KP33Z0T io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:21:46 Rita HP_LaserJet_1018?serial=KP33Z0T prnt/backend/hp.c 710: INFO: open device failed stat=12; will retry in 30 seconds...
2009-05-09 14:22:17 Rita HP_LaserJet_1018?serial=KP33Z0T io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
2009-05-09 14:22:17 Rita HP_LaserJet_1018?serial=KP33Z0T prnt/backend/hp.c 710: INFO: open device failed stat=12; will retry in 30 seconds...
2009-05-09 14:22:47 Rita HP_LaserJet_1018?serial=KP33Z0T io/hpmud/musb.c 1104: unable to open hp:/usb/HP_LaserJet_1018?serial=KP33Z0T
Võta ühendust ! |
EpX
09.05.2009 18:53:51
| EpX kirjutas: |
Kas on mingit võimalust Ubuntu all, kuidas suurendada wireless võrgukaardi võimsust vms? Näiteks keerates powersave maha või koduses võrgus määrata mõni argument manuaalselt? (power, txpower, sens, rts tunduvad midagi sellist pakkuvat?)
iwconfig --help
Usage: iwconfig [interface]
interface essid {NNN|any|on|off}
interface mode {managed|ad-hoc|master|...}
interface freq N.NNN[k|M|G]
interface channel N
interface bit {N[k|M|G]|auto|fixed}
interface rate {N[k|M|G]|auto|fixed}
interface enc {NNNN-NNNN|off}
interface key {NNNN-NNNN|off}
interface power {period N|timeout N|saving N|off}
interface nickname NNN
interface nwid {NN|on|off}
interface ap {N|off|auto}
interface txpower {NmW|NdBm|off|auto}
interface sens N
interface retry {limit N|lifetime N}
interface rts {N|auto|fixed|off}
interface frag {N|auto|fixed|off}
interface modulation {11g|11a|CCK|OFDMg|...}
interface commit
Check man pages for more details.
Küsin veel ühe korra uuesti, ehk keegi abivalmim oskab aidata.
DoS
09.05.2009 18:58:56
| EpX kirjutas: |
| Küsin veel ühe korra uuesti, ehk keegi abivalmim oskab aidata. |
nagu juba öeldud, siis rtfm?
IWCONFIG(8) Linux Programmer's Manual IWCONFIG(8)
NAME
iwconfig - configure a wireless network interface
SYNOPSIS
iwconfig interface [essid X] [nwid N] [mode M] [freq F]
[channel C][sens S ][ap A ][nick NN ]
[rate R] [rts RT] [frag FT] [txpower T]
[enc E] [key K] [power P] [retry R]
[modu M] [commit]
iwconfig --help
iwconfig --version
DESCRIPTION
Iwconfig is similar to ifconfig(8), but is dedicated to the wireless interfaces. It is used to set the
parameters of the network interface which are specific to the wireless operation (for example : the fre‐
quency). Iwconfig may also be used to display those parameters, and the wireless statistics (extracted
from /proc/net/wireless).
All these parameters and statistics are device dependent. Each driver will provide only some of them
depending on hardware support, and the range of values may change. Please refer to the man page of each
device for details.
PARAMETERS
essid Set the ESSID (or Network Name - in some products it may also be called Domain ID). The ESSID is
used to identify cells which are part of the same virtual network.
As opposed to the AP Address or NWID which define a single cell, the ESSID defines a group of
cells connected via repeaters or infrastructure, where the user may roam transparently.
With some cards, you may disable the ESSID checking (ESSID promiscuous) with off or any (and on
to reenable it).
If the ESSID of your network is one of the special keywords (off, on or any), you should use --
to escape it.
Examples :
iwconfig eth0 essid any
iwconfig eth0 essid "My Network"
iwconfig eth0 essid -- "ANY"
nwid Set the Network ID. As all adjacent wireless networks share the same medium, this parameter is
used to differentiate them (create logical colocated networks) and identify nodes belonging to
the same cell.
This parameter is only used for pre-802.11 hardware, the 802.11 protocol uses the ESSID and AP
Address for this function.
With some cards, you may disable the Network ID checking (NWID promiscuous) with off (and on to
reenable it).
Examples :
iwconfig eth0 nwid AB34
iwconfig eth0 nwid off
nick[name]
Set the nickname, or the station name. Some 802.11 products do define it, but this is not used as
far as the protocols (MAC, IP, TCP) are concerned and completely useless as far as configuration
goes. Only some wireless diagnostic tools may use it.
Example :
iwconfig eth0 nickname "My Linux Node"
mode Set the operating mode of the device, which depends on the network topology. The mode can be Ad-
Hoc (network composed of only one cell and without Access Point), Managed (node connects to a
network composed of many Access Points, with roaming), Master (the node is the synchronisation
master or acts as an Access Point), Repeater (the node forwards packets between other wireless
nodes), Secondary (the node acts as a backup master/repeater), Monitor (the node is not associ‐
ated with any cell and passively monitor all packets on the frequency) or Auto.
Example :
iwconfig eth0 mode Managed
iwconfig eth0 mode Ad-Hoc
freq/channel
Set the operating frequency or channel in the device. A value below 1000 indicates a channel num‐
ber, a value greater than 1000 is a frequency in Hz. You may append the suffix k, M or G to the
value (for example, "2.46G" for 2.46 GHz frequency), or add enough '0'.
Channels are usually numbered starting at 1, and you may use iwlist(8) to get the total number of
channels, list the available frequencies, and display the current frequency as a channel. Depend‐
ing on regulations, some frequencies/channels may not be available.
When using Managed mode, most often the Access Point dictates the channel and the driver may
refuse the setting of the frequency. In Ad-Hoc mode, the frequency setting may only be used at
initial cell creation, and may be ignored when joining an existing cell.
You may also use off or auto to let the card pick up the best channel (when supported).
Examples :
iwconfig eth0 freq 2422000000
iwconfig eth0 freq 2.422G
iwconfig eth0 channel 3
iwconfig eth0 channel auto
ap Force the card to register to the Access Point given by the address, if it is possible. This
address is the cell identity of the Access Point, as reported by wireless scanning, which may be
different from its network MAC address. If the wireless link is point to point, set the address
of the other end of the link. If the link is ad-hoc, set the cell identity of the ad-hoc network.
When the quality of the connection goes too low, the driver may revert back to automatic mode
(the card selects the best Access Point in range).
You may also use off to re-enable automatic mode without changing the current Access Point, or
you may use any or auto to force the card to reassociate with the currently best Access Point.
Example :
iwconfig eth0 ap 00:60:1D:01:23:45
iwconfig eth0 ap any
iwconfig eth0 ap off
rate/bit[rate]
For cards supporting multiple bit rates, set the bit-rate in b/s. The bit-rate is the speed at
which bits are transmitted over the medium, the user speed of the link is lower due to medium
sharing and various overhead.
You may append the suffix k, M or G to the value (decimal multiplier : 10^3, 10^6 and 10^9 b/s),
or add enough '0'. Values below 1000 are card specific, usually an index in the bit-rate list.
Use auto to select automatic bit-rate mode (fallback to lower rate on noisy channels), which is
the default for most cards, and fixed to revert back to fixed setting. If you specify a bit-rate
value and append auto, the driver will use all bit-rates lower and equal than this value.
Examples :
iwconfig eth0 rate 11M
iwconfig eth0 rate auto
iwconfig eth0 rate 5.5M auto
txpower
For cards supporting multiple transmit powers, sets the transmit power in dBm. If W is the power
in Watt, the power in dBm is P = 30 + 10.log(W). If the value is postfixed by mW, it will be
automatically converted to dBm.
In addition, on and off enable and disable the radio, and auto and fixed enable and disable power
control (if those features are available).
Examples :
iwconfig eth0 txpower 15
iwconfig eth0 txpower 30mW
iwconfig eth0 txpower auto
iwconfig eth0 txpower off
sens Set the sensitivity threshold. This define how sensitive is the card to poor operating conditions
(low signal, interference). Positive values are assumed to be the raw value used by the hardware
or a percentage, negative values are assumed to be dBm. Depending on the hardware implementation,
this parameter may control various functions.
On modern cards, this parameter usually control handover/roaming threshold, the lowest signal
level for which the hardware remains associated with the current Access Point. When the signal
level goes below this threshold the card starts looking for a new/better Access Point. Some cards
may use the number of missed beacons to trigger this. For high density of Access Points, a higher
threshold make sure the card is always associated with the best AP, for low density of APs, a
lower threshold minimise the number of failed handoffs.
On more ancient card this parameter usually controls the defer threshold, the lowest signal level
for which the hardware considers the channel busy. Signal levels above this threshold make the
hardware inhibits its own transmission whereas signals weaker than this are ignored and the hard‐
ware is free to transmit. This is usually strongly linked to the receive threshold, the lowest
signal level for which the hardware attempts packet reception. Proper setting of these thresholds
prevent the card to waste time on background noise while still receiving weak transmissions. Mod‐
ern designs seems to control those thresholds automatically.
Example :
iwconfig eth0 sens -80
iwconfig eth0 sens 2
retry Most cards have MAC retransmissions, and some allow to set the behaviour of the retry mechanism.
To set the maximum number of retries, enter limit `value'. This is an absolute value (without
unit), and the default (when nothing is specified). To set the maximum length of time the MAC
should retry, enter lifetime `value'. By defaults, this value in in seconds, append the suffix m
or u to specify values in milliseconds or microseconds.
You can also add the short, long, min and max modifiers. If the card supports automatic mode,
they define the bounds of the limit or lifetime. Some other cards define different values depend‐
ing on packet size, for example in 802.11 min limit is the short retry limit (non RTS/CTS pack‐
ets).
Examples :
iwconfig eth0 retry 16
iwconfig eth0 retry lifetime 300m
iwconfig eth0 retry short 12
iwconfig eth0 retry min limit 8
rts[_threshold]
RTS/CTS adds a handshake before each packet transmission to make sure that the channel is clear.
This adds overhead, but increases performance in case of hidden nodes or a large number of active
nodes. This parameter sets the size of the smallest packet for which the node sends RTS ; a value
equal to the maximum packet size disables the mechanism. You may also set this parameter to auto,
fixed or off.
Examples :
iwconfig eth0 rts 250
iwconfig eth0 rts off
frag[mentation_threshold]
Fragmentation allows to split an IP packet in a burst of smaller fragments transmitted on the
medium. In most cases this adds overhead, but in a very noisy environment this reduces the error
penalty and allow packets to get through interference bursts. This parameter sets the maximum
fragment size which is always lower than the maximum packet size.
This parameter may also control Frame Bursting available on some cards, the ability to send mul‐
tiple IP packets together. This mechanism would be enabled if the fragment size is larger than
You may also set this parameter to auto, fixed or off.
Examples :
iwconfig eth0 frag 512
iwconfig eth0 frag off
key/enc[ryption]
Used to manipulate encryption or scrambling keys and security mode.
To set the current encryption key, just enter the key in hex digits as XXXX-XXXX-XXXX-XXXX or
XXXXXXXX. To set a key other than the current key, prepend or append [index] to the key itself
(this won't change which is the active key). You can also enter the key as an ASCII string by
using the s: prefix. Passphrase is currently not supported.
To change which key is the currently active key, just enter [index] (without entering any key
value).
off and on disable and reenable encryption.
The security mode may be open or restricted, and its meaning depends on the card used. With most
cards, in open mode no authentication is used and the card may also accept non-encrypted ses‐
sions, whereas in restricted mode only encrypted sessions are accepted and the card will use
authentication if available.
If you need to set multiple keys, or set a key and change the active key, you need to use multi‐
ple key directives. Arguments can be put in any order, the last one will take precedence.
Examples :
iwconfig eth0 key 0123-4567-89
iwconfig eth0 key [3] 0123-4567-89
iwconfig eth0 key s:password [2]
iwconfig eth0 key [2]
iwconfig eth0 key open
iwconfig eth0 key off
iwconfig eth0 key restricted [3] 0123456789
iwconfig eth0 key 01-23 key 45-67 [4] key [4]
power Used to manipulate power management scheme parameters and mode.
To set the period between wake ups, enter period `value'. To set the timeout before going back
to sleep, enter timeout `value'. To set the generic level of power saving, enter saving `value'.
You can also add the min and max modifiers. By default, those values are in seconds, append the
suffix m or u to specify values in milliseconds or microseconds. Sometimes, those values are
without units (number of beacon periods, dwell, percentage or similar).
off and on disable and reenable power management. Finally, you may set the power management mode
to all (receive all packets), unicast (receive unicast packets only, discard multicast and broad‐
cast) and multicast (receive multicast and broadcast only, discard unicast packets).
Examples :
iwconfig eth0 power period 2
iwconfig eth0 power 500m unicast
iwconfig eth0 power timeout 300u all
iwconfig eth0 power saving 3
iwconfig eth0 power off
iwconfig eth0 power min period 2 power max period 4
modu[lation]
Force the card to use a specific set of modulations. Modern cards support various modulations,
some which are standard, such as 802.11b or 802.11g, and some proprietary. This command force the
card to only use the specific set of modulations listed on the command line. This can be used to
fix interoperability issues.
The list of available modulations depend on the card/driver and can be displayed using iwlist
modulation. Note that some card/driver may not be able to select each modulation listed indepen‐
dantly, some may come as a group. You may also set this parameter to auto let the card/driver do
its best.
Examples :
iwconfig eth0 modu 11g
iwconfig eth0 modu CCK OFDMa
iwconfig eth0 modu auto
commit Some cards may not apply changes done through Wireless Extensions immediately (they may wait to
aggregate the changes or apply it only when the card is brought up via ifconfig). This command
(when available) forces the card to apply all pending changes.
This is normally not needed, because the card will eventually apply the changes, but can be use‐
ful for debugging.
DISPLAY
For each device which supports wireless extensions, iwconfig will display the name of the MAC protocol
used (name of device for proprietary protocols), the ESSID (Network Name), the NWID, the frequency (or
channel), the sensitivity, the mode of operation, the Access Point address, the bit-rate, the RTS
threshold, the fragmentation threshold, the encryption key and the power management settings (depending
on availability).
The parameters displayed have the same meaning and values as the parameters you can set, please refer to
the previous part for a detailed explanation of them.
Some parameters are only displayed in short/abbreviated form (such as encryption). You may use iwlist(8)
to get all the details.
Some parameters have two modes (such as bitrate). If the value is prefixed by `=', it means that the
parameter is fixed and forced to that value, if it is prefixed by `:', the parameter is in automatic
mode and the current value is shown (and may change).
Access Point/Cell
An address equal to 00:00:00:00:00:00 means that the card failed to associate with an Access
Point (most likely a configuration issue). The Access Point parameter will be shown as Cell in
ad-hoc mode (for obvious reasons), but otherwise works the same.
If /proc/net/wireless exists, iwconfig will also display its content. Note that those values will depend
on the driver and the hardware specifics, so you need to refer to your driver documentation for proper
interpretation of those values.
Link quality
Overall quality of the link. May be based on the level of contention or interference, the bit or
frame error rate, how good the received signal is, some timing synchronisation, or other hardware
metric. This is an aggregate value, and depends totally on the driver and hardware.
Signal level
Received signal strength (RSSI - how strong the received signal is). May be arbitrary units or
dBm, iwconfig uses driver meta information to interpret the raw value given by /proc/net/wireless
and display the proper unit or maximum value (using 8 bit arithmetic). In Ad-Hoc mode, this may
be undefined and you should use iwspy.
Noise level
Background noise level (when no packet is transmitted). Similar comments as for Signal level.
Rx invalid nwid
Number of packets received with a different NWID or ESSID. Used to detect configuration problems
or adjacent network existence (on the same frequency).
Rx invalid crypt
Number of packets that the hardware was unable to decrypt. This can be used to detect invalid
encryption settings.
Rx invalid frag
Number of packets for which the hardware was not able to properly re-assemble the link layer
fragments (most likely one was missing).
Tx excessive retries
Number of packets that the hardware failed to deliver. Most MAC protocols will retry the packet a
number of times before giving up.
Invalid misc
Other packets lost in relation with specific wireless operations.
Missed beacon
Number of periodic beacons from the Cell or the Access Point we have missed. Beacons are sent at
regular intervals to maintain the cell coordination, failure to receive them usually indicates
that the card is out of range.
AUTHOR
Jean Tourrilhes - jt@hpl.hp.com
FILES
/proc/net/wireless
SEE ALSO
ifconfig(8), iwspy(8), iwlist(8), iwevent(8), iwpriv(8), wireless(7).
wireless-tools 30 March 2006 IWCONFIG(8)
| Kommentaarid: 50 loe/lisa |
47 |
lehm2
12.05.2009 12:06:49
Probleem järgnev, sai Windowsist ketta pealt kopeeritud failid linuxi asuvasse kettale, kuid tekkis probleem failide avamisega. Faili avades ütleb faili ei eksisteeri, natuke asja uurides avasin openoffice kaudu faili ning töötas. Läbi Nautiluse kaudu aga ei tööta, kardan et probleem on täpitähti sisaldavate failidige, näiteks openoffices avatud täpitähti sisaldav failinimi on sümboleid täis. Probleem vist Encodinguga, kuid mida muuta või teha seda ma ei tea.
Võta ühendust ! |
Riivo
12.05.2009 14:16:42
| lehm2 kirjutas: |
Probleem järgnev, sai Windowsist ketta pealt kopeeritud failid linuxi asuvasse kettale, kuid tekkis probleem failide avamisega. Faili avades ütleb faili ei eksisteeri, natuke asja uurides avasin openoffice kaudu faili ning töötas. Läbi Nautiluse kaudu aga ei tööta, kardan et probleem on täpitähti sisaldavate failidige, näiteks openoffices avatud täpitähti sisaldav failinimi on sümboleid täis. Probleem vist Encodinguga, kuid mida muuta või teha seda ma ei tea.  |
Uuri käsku convmv ja seda artiklit. Omale oli abiks ja lahendas sarnase probleemi ära.
221 |
lehm2
12.05.2009 17:21:43
Uurisin ja puursin seda convmv aga lahendust ei kuskilt viskas esialgu kui iso 8859-4-st utf8 tegin vea, et juba faili nimi on utf8. Viimane kord aga proovisin sain veaks:
| WARNING: new filename "��2009 05 Kutse yldkoosolekule[1]par.doc" contains characters, which are not POSIX filesystem conform! |
Nautilusega vaadates failinimed tunduvad õiged, kuid avades loobib erroreid.
Viimase avastusega olen võibolla probleemile lähemal, millegi pärast on locale käsuga väärtused puudu, ehk aitab keegi confi täita ?
'locale
LANG=C
LC_CTYPE="C"
LC_NUMERIC="C"
LC_TIME="C"
LC_COLLATE="C"
LC_MONETARY="C"
LC_MESSAGES="C"
LC_PAPER="C"
LC_NAME="C"
LC_ADDRESS="C"
LC_TELEPHONE="C"
LC_MEASUREMENT="C"
LC_IDENTIFICATION="C"
LC_ALL=
Võta ühendust ! |
12.05.2009 17:25:57
Esiteks - kuidas toimus nende failide kopeerimine - võrgukettalt või Linuxi külge monteeritud kõvakettalt otse?
Teiseks - näita probleemse kataloogi sisu listingut.
Enne convmv kasutamist tasuks kataloogist koos sisuga teha koopia juhuks, kui midagi nässu läheb.
Naljatilk
12.05.2009 17:34:39
Oskab keegi öelda, miks pärast 9.04 peale minekut mul enam Processor scaling ei tööta?
Samas eemaldasin ligikaudu samal ajal laptop-mode'i.
Kumbast see sõltuda võiks?
(Ei kasuta eriti tihti rüperaali, seepärast pole eriti jõudnud ise uurida)
_________________ Vaata pilti |
| Kommentaarid: 11 loe/lisa |
lehm2
12.05.2009 17:42:14
Kopeerimine käis läbi võrgu teiselt windowsi masinalt, kuid vaatan et probleem polegi ainult kopeeritud failidega, vaid ka nendega, mis internetist, cd-l on. Näiteks ühe internetist suvalise faili allatõmbamisel on failinimeks
http://img60.imageshack.us/my.php?image=tests.png.
Võta ühendust ! |
12.05.2009 17:55:56
Mis sul /etc/locale.gen faili sees on? Vaatamiseks:
lehm2
12.05.2009 18:01:55
| Dogbert kirjutas: |
Nii vastuseks tuleb
cat /etc/locale.gen
cat: /etc/locale.gen: No such file or directory
Aga language-support ei lähegi sellepärast tööle, kuna ta võtab mõned väärtused confist locale ning nende puududes aga jookseb progra kokku.
locale -a
C
POSIX
et_EE.utf8
Võta ühendust ! |
12.05.2009 18:59:31
Kui seda faili pole, siis tuleb see ise teha. Kättesaadavast materjalist (st et lokaadid võetakse failist SUPPORTED):
$ cd ~
$ cat /usr/share/i18n/SUPPORTED | grep -E "(en_US|et_EE)" > locale.gen |
Tulemuseks võiks olla midagi sellist:
en_US.UTF-8 UTF-8
en_US ISO-8859-1
en_US.ISO-8859-15 ISO-8859-15
et_EE.UTF-8 UTF-8
et_EE ISO-8859-1
et_EE.ISO-8859-15 ISO-8859-15
(vaatamiseks cat locale.gen)
Kui seal on olemas vähemalt en_US.UTF-8 UTF-8, siis jätka:
$ chmod 644 locale.gen
$ sudo chown root:root locale.gen
$ sudo mv locale.gen /etc/
$ sudo locale-gen
lehm2
13.05.2009 15:48:11
Õpetus mis tegid sai ilma errorite läbi tehtud,
cat /etc/locale.gen
en_US.UTF-8 UTF-8
en_US ISO-8859-1
et_EE.UTF-8 UTF-8
et_EE ISO-8859-1
ja viimasest käsust saan
Generating locales...
et_EE.UTF-8... up-to-date
Generation complete.
Kas nüüd vajalik muuta LANG väärtust mingit moodi ? Igatpidi kuidas ma LANG väärtust muuta olen üritan, ei salvestu see ära.
locale
LANG=C
LC_CTYPE="C"
LC_NUMERIC="C"
LC_TIME="C"
LC_COLLATE="C"
LC_MONETARY="C"
LC_MESSAGES="C"
LC_PAPER="C"
LC_NAME="C"
LC_ADDRESS="C"
LC_TELEPHONE="C"
LC_MEASUREMENT="C"
LC_ALL=
Ainuke võimalus kuidas ajutiselt väärtust muuta on export commandiga, kuid seaded pole püsivad.
export LANG=et_EE.UTF-8
murka@murka-desktop:~$ locale
LANG=et_EE.UTF-8
LC_CTYPE="et_EE.UTF-8"
LC_NUMERIC="et_EE.UTF-8"
LC_TIME="et_EE.UTF-8"
LC_COLLATE="et_EE.UTF-8"
LC_MONETARY="et_EE.UTF-8"
LC_MESSAGES="et_EE.UTF-8"
LC_PAPER="et_EE.UTF-8"
LC_NAME="et_EE.UTF-8"
LC_ADDRESS="et_EE.UTF-8"
LC_TELEPHONE="et_EE.UTF-8"
LC_MEASUREMENT="et_EE.UTF-8"
LC_IDENTIFICATION="et_EE.UTF-8"
LC_ALL=
Ok, sain lahenduse pikapeale kätte, muutsin LANG väärtuse käsuga export LANG=et_EE.UTF-8. Seega andis mulle võimaluse, siseneda Language Supporti -> Seal oli küll language asemel tühi lahter, kuid valisin Estonian, ning seejärel salvestasin. Muutsin failinimed GUI tooliga(UTF-8 Migration Tool), sain failinimede encodingu korda. Tänud, kes aitasid mind suunamisega!
Võta ühendust ! |
Fiocchi
13.05.2009 22:20:10
| Naljatilk kirjutas: |
(Ei kasuta eriti tihti rüperaali, seepärast pole eriti jõudnud ise uurida) |
Ei tööta nii, et protsessor uugab pidevalt max võimsusel? Mul oli sama jama, aitas kui protsess trackerd kinni panna. Google rääkis ka, et indekseerimisega on mingi tõsine jama 9.04's. Nii et parem on see esialgu üldse kinni panna. Ma endal eemaldasin start up'ist trackerd'i ja mingi indexeri vms asja ära ja peale seda probleemi pole.
15 |
note1
16.05.2009 18:01:57
Mul on trackerd üldse eemaldatud.
splash ja muu mõttetu praht.
raido357
16.05.2009 20:09:27
| note1 kirjutas: |
splash ja muu mõttetu praht. |
Kuidas see abi küsijat aitab ?
| Kommentaarid: 78 loe/lisa |
note1
17.05.2009 14:30:25
| Fiocchi kirjutas: |
Ei tööta nii, et protsessor uugab pidevalt max võimsusel? Mul oli sama jama, aitas kui protsess trackerd kinni panna. Google rääkis ka, et indekseerimisega on mingi tõsine jama 9.04's. Nii et parem on see esialgu üldse kinni panna. Ma endal eemaldasin start up'ist trackerd'i ja mingi indexeri vms asja ära ja peale seda probleemi pole. |
Synaptic paketihalduris otsingu abiga leida ja saab ka eemaldada.
Aga kas 9.04 on siis teil juba?
Mul alles 8.04.2
Fiocchi
17.05.2009 21:53:48
| note1 kirjutas: |
Mul alles 8.04.2 |
| Oskab keegi öelda, miks pärast 9.04 peale minekut... |
Kolm korda võid arvata, neist kaks ei lähe arvesse
15 |
sfx
19.05.2009 22:13:15
Oskab keegi ehk nõu anda, kuidas volume control tööle saada, kui välised kõlarid ühendatud on.
Kui heli tuleb läpaka (Dell Latitude X300) enda kõlaritest, töötavad nii klaviatuuri shortcutid kui ka ülevalt paneelilt helitugevuse muutmine korralikult, nii kui välised kõlarid või kõrvaklapid ühendada, lakkavad need töötamast.
Peal on uusim 9.04
--edit--
Leidsin juba lahenduse SIIT.
| Kommentaarid: 170 loe/lisa |
151 |
note1
20.05.2009 12:48:57
Mul on 8.04 LTS ja eemaldasin splashi (kustutasin ka grubi kõivit menüüst splashi rea ära. Nüüd ei tule ubuntu logo ja näen käivituse ajal logisi ja veateateid.
tracerd ja muud säärast - näiteks avahi (avahi on mingi lokaalse võrgu jaoks).
PIII 730Mhz ikka on veidike kiirem.
Pealegi on mul eestikeelne ubuntu ja teid aidata ei oska. Väike probleem , mis kujuneb inglise eestlaste abistamisel. Programmide nimetusi on eestindatud ja 2d ja 3g nuppe samuti. Aga käsiraamat on ingliskeelne..
Kes see loll hakkas küll linuxit eestindama?
File on Fail ja Open on Ava.
mahfiaz
22.05.2009 08:22:42
note1, mis sa niisama prõõkad. Mõõda oma käivituskiirus enne ja pärast. Kui numbrid letti laod, siis usume.
Mis eestindamisesse puutub, siis miks sa loll siin eesti keeles räägid?
note1
22.05.2009 08:45:31
| mahfiaz kirjutas: |
Mis eestindamisesse puutub, siis miks sa loll siin eesti keeles räägid? |
Kah õige.
Ainult, et kas sa ikka teed õieti, kui tõlgid ka rakenduste nimetusi (programmi pealkirju) eesti keelde. Päris raske on meelde tuletada, et mis selle proge ingliskeelne nimetus on. Menüüdes.
Naljatilk
22.05.2009 13:08:09
| Fiocchi kirjutas: |
Just selles probleem seisnebki.. Uurin esimesel võimalusel.
mahfiaz
23.05.2009 16:34:55
| note1, paned programmi käima ja vaatada Abi → Programmist lähemalt
wolfe
25.05.2009 14:05:23
Samba Vistaga |
Terv.
Jooksutan Jaunty 9.04 ning olen viimane aasta aega(aeg-ajalt) püüdnud luua võrku vista läpakaga, läbi ruuteri. Ubuntus on samba confitud failiserveriks, jagamaks üht kindlat kausta, milles on kõik chmod jne. tehtud. Kummagil arvutil on eraldi kasutajad kuid lisasin ka Vista kasutaja Sambasse: smbpasswd ja enable'sin selle. Pmst. peaks asi toimima. Ma suudan pingida arvuteid omavahel, Vista tulemüür sai üleüldse maha võetud, kuid kui püüan Vistas "Map Network Location" \\ubuntu_IP\MyFiles siis viskab veateate, et ei suutnud seda lokaliseerida.
Miks Vista Ubuntut ei näe?
15 |
medieval
25.05.2009 14:31:10
Re: Samba Vistaga |
| wolfe kirjutas: |
Terv.
Miks Vista Ubuntut ei näe?  |
Vista ei suuda su ext3 failisüsteemi lugeda. Otsi internetist drivereid/progamme.
kaabakas
25.05.2009 14:51:14
wolfe, mis juhtub kui winexploreris aadressiribale \\ubuntu_ip kirjutada? Mida näitab ubuntus testparm ja samba logi?
medieval,
96 |
Adebisi
25.05.2009 14:56:34
| wolfe, kaustal Guest access lubatud?
| Kommentaarid: 58 loe/lisa |
55 |
tom1245
25.05.2009 15:58:24
Re: Samba Vistaga |
| medieval kirjutas: |
| wolfe kirjutas: |
Terv.
Vista ei suuda su ext3 failisüsteemi lugeda. Otsi internetist drivereid/progamme. |
miks ta ei peaks lugema? WinXP küll loeb.
_________________ Ehitusteemalised arutelud:
https://www.ehitusfoorum.com |
| Kommentaarid: 84 loe/lisa |
note1
25.05.2009 16:14:41
Ni lollile küsimusele ei olegi vastust.
Kas Vista ja Jaunty enam üldse tänapäeval ühildub?
Ma olen ka loll, näete!
Cancer
| Kommentaarid: 13 loe/lisa |
kaabakas
26.05.2009 07:18:59
1) Kulla inimesed, see kas vista ext3 oskab ei ole mingilgi määral relevantne üle võrgu failide jagamise juures. (Et oleks kirjas, siis draiver on selleks puhuks olemas.)
2) Google otsing 'vista samba' andis hea portsu tarka juttu ühildamise kohta. Enne edasist abistamise katset tahaks teada, et wolfe on selle läbi töötanud.
96 |
note1
26.05.2009 07:45:48
Minul on nii, et ma pean ufw lubama samba pordid. Mul on ufw sees.
Pealegi on mul buntut natuke nuditud ja lokaalse võrgu tuvastus-plugin on eemaldatud:
http://ubuntust.blogspot.com/
wolfe
26.05.2009 10:06:24
Ok jõudsin ka siia teemasse tagasi.
Ega ma naljalt abipalve postitusi tee, sai tubli tükk päevast googeldatud eri variante. Leidsin isegi, et Vista kasutavat vaikimisi NTLMv2 autentimist, mida näiteks. Samba 2.x ei räägi, no olgu endal on 3.x aga sai Vistas registris väike asi muudetud, et seda ei oleks. Testparm sai ammu tehtud ja samba logid läbi vaadatud, olen veendunud, et Samba töötab.
fyrzen@spyder:/etc/samba$ testparm
Load smb config files from /etc/samba/smb.conf
Processing section "[print$]"
Processing section "[printers]"
Processing section "[MyFiles]"
Loaded services file OK.
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
[global]
server string =
null passwords = Yes
passdb backend = tdbsam
username map = /etc/samba/smbusers
syslog only = Yes
announce version = 5.0
name resolve order = hosts wins bcast
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_KEEPALIVE SO_RCVBUF=8192 SO_SNDBUF=8192
printcap name = CUPS
[print$]
path = /var/lib/samba/printers
write list = root
create mask = 0664
directory mask = 0775
guest ok = Yes
[printers]
path = /tmp
guest ok = Yes
printable = Yes
browseable = No
[MyFiles]
path = /home/samba/
force user = fyrzen
force group = fyrzen
read only = No
create mask = 0644
/var/log/log.smbd
[2009/05/24 12:46:47, 0] smbd/server.c:main(1260)
smbd version 3.3.2 started.
Copyright Andrew Tridgell and the Samba Team 1992-2009
[2009/05/24 12:46:47, 0] printing/print_cups.c:cups_connect(103)
Unable to connect to CUPS server localhost:631 - Connection refused
[2009/05/24 12:51:12, 0] smbd/server.c:main(1260)
[2009/05/24 14:48:19, 0] smbd/server.c:main(1260)
[2009/05/25 00:14:25, 0] smbd/server.c:main(1260)
...Siit edasi on pmst samad teated samba startimisest, nojah iga kord kui smb.conf oli muuta vaja võtsin ta maha. |
Ülejäänud samba logid on ka suht veateate vabad. Ainult log.winbindd-idmap sisaldab mingeid mõttetuid erroreid, et ei läinud tööle. Ega ma ei püüagi mingit domeeni vms. luua ega Samba läbi ühendust või printereid. jagada. Vaja ainult lihtsat failiserverit.
Vista poole pealt, network discovery on sees.
Kuna Vistal oli veel vana Norton antiviirus, mille eest taheti raha, et jätkata kasutamist, otsustasin selle maha lasta. Nüüd kasutab Vista AVG'd ja windows tulemüüri. See näib olevat põhjustanud: "a device attached to the system is not functioning" veateate, kui püüan mappida, lahenduste hulka kuulub file and printer sharing maha võtmine, jne. Ma arvan, et AVG meelega teeb seda, sest eelmine päev lakkas üks viirusetõrje komponent töötamast iga kord, kui püüdsin mappida võrgu asukohta ja täna töötab viirusetõrje vigadeta.
15 |
note1
26.05.2009 10:57:07
Jaunty ja id kaardi tarkvara testimine (beta):
Paigalda firefoxile plugin:
ftp://ftp.smartlink.ee/pub/id/plugins
Lisa repositoorium
terminalis:
$sudo wget http://ubuntu.planet.ee/pub/id/ubuntu_9.04/idkaart.list --output-document=/etc/apt/sources.list.d/idkaart.list
$sudo apt-get update |
Nüüd saad synapticus vaadata, mis tarkvara sa paigaldama pead:
sisaldab digidoc, qesteidutil, qdigitoc jt.
Ise plaanin ka jautyt testida..
mihkelv
26.05.2009 11:37:58
| Miks peaks keegi tahtma sinu pakivaramut kasutada?
| Kommentaarid: 6 loe/lisa |
Riivo
26.05.2009 13:25:27
| mihkelv kirjutas: |
| Miks peaks keegi tahtma sinu pakivaramut kasutada? |
Need pole tema, vaid ametlikud. Ja see tarkvara on veel alfa staadiumis.
https://id.eesti.ee/trac/
221 |
note1
mihkelv
note1
26.05.2009 19:06:21
Eks kaevake mind kohtusse!
