uus teema   vasta Tarkvara »  Tarkvara »  Mozilla Firefox arutlus/probleemid. märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 58, 59, 60 ... 213, 214, 215  järgmine
AJ
AJ
sõnum 22.04.2009 20:49:07 vasta tsitaadiga
Firefox issues security update
http://hothardware.com/News/Firefox-issues-security-update/
According to the company's website:
Mozilla developers identified and fixed several stability bugs in the browser engine used in Firefox and other Mozilla-based products. Some of these crashes showed evidence of memory corruption under certain circumstances and we presume that with enough effort at least some of these could be exploited to run arbitrary code.
Thunderbird shares the browser engine with Firefox and could be vulnerable if JavaScript were to be enabled in mail. This is not the default setting and we strongly discourage users from running JavaScript in mail. Without further investigation we cannot rule out the possibility that for some of these an attacker might be able to prepare memory for exploitation through some means other than JavaScript such as large images.
sõnum 22.04.2009 23:53:48 vasta tsitaadiga
Mingi veider jama:
Selle lööb ette iga kord kui Add-onsid lahti teen.Ei oskagi kohe pakkuda mis võib põhjuseks olla.Kahel erinevalt konfigureeritud ja erinevate lisadega firefoxil sama jama.Safe Modes firefox käivitada siis samuti sama jama.
Täna ainult kaks suuremat muudatust teinud:
Uuendasin FF 3.0.0.9 peale ja lasin ajutiselt(nagu ma korra paari kuu jooksul teen) antiviiruse peale.Äkki keerasin NOD32 liiga karmiks? icon_smile.gif
Look Right
Anna vin
Look Right
sõnum 23.04.2009 00:04:40 vasta tsitaadiga
I just ran into the same problem!
When going to Tools->Addons, i get:
"services.addons.mozilla.org:443 uses an invalid security certificate"
Turns out that my system clock was off...
Once I fixed the date everything worked like a charm.
link
sõnum 23.04.2009 00:11:37 vasta tsitaadiga
taikonaut kirjutas:
link
Kontrollisin üle.Käsitsi sünkroonisin veel aja igaks juhuks aga ikka sama jama.
Look Right
Anna vin
Look Right
sõnum 23.04.2009 00:39:10 vasta tsitaadiga
I had the same problem, extensions complained about an invalic certificate from services.addons.mozilla.org:443.
I could solve it by doing this: (as I have the german version of firefox there is some guesswork about the terms involved!)
In Firefox Open
Tools > Options > Advanced > Encryption : Show certificates
There you can define "exemptions" (not sure about the term)
Enter "services.addons.mozilla.org:443" un the URL field and the annoyance is gone
edit: FF supportist lugedes, siis paljud kirjutavad ka seda, et tulemüür/av on kurjalt seades. Seal võib ka kala olla.
sõnum 23.04.2009 01:41:14 vasta tsitaadiga
taikonaut kirjutas:
In Firefox Open
Errorist sain lahti aga ühtegi Add-oni siiski uuendada ei lase.
Tõenäoliselt siis on asi jah selles,et NOD32 liiga kurjaks keeratud mul.Homme lasen maha.Siis peaks(loodetavasti) jälle kõik normi minema 8)
Look Right
Anna vin
Look Right
sõnum 23.04.2009 01:47:43 vasta tsitaadiga
Kui uuendada ei lase, siis uusi installida ka ei luba?
sõnum 23.04.2009 01:57:04 vasta tsitaadiga
taikonaut kirjutas:
Ei tea.Ei vedele siin .xpi formaadis add-one kõvakettal kahjuks icon_smile.gif .Õnneks FEBE-ga sai backupid profiilidest ära tehtud.Ühel brauseril on 22 Aprill backup ja teisel 7 Aprill.Isegi kui see jama osutub pöördumatuks, siis saan maha lasta kogu värgi ja backupist täisprofiili asemele thumbs_up.gif .
Look Right
Anna vin
Look Right
sõnum 23.04.2009 02:11:31 vasta tsitaadiga
FF supportis mingi vana soovitas ka uus profiil teha. Kuid ise ma ei usu, et see aitab.
edit:
no tõmbasin alla mingi suvalise add-on'i - Cooliris
link. . Võid ju proovida, kas installib ära.
sõnum 23.04.2009 02:14:24 vasta tsitaadiga
Ahhaa.Leidsin probleemi allika üles icon_smile.gif .
NOD32 settingutes:
Antivirus and antispyware - Web access protection - HTTP,HTTPS - HTTPS scanner setup - HTTPS filtering mode - Do not use HTTPS protocol checking valida.
Look Right
Anna vin
Look Right
sõnum 23.04.2009 02:20:02 vasta tsitaadiga
sõnum 23.04.2009 22:29:26 vasta tsitaadiga
Kas mulle ainult tundub nii või on Add-Onide allalaadimised aeglasemaks muutunud?
Mõtlen just seda kui addonide aken avada ja uuenduse leiab,siis hakkab seda alla laadima.
Look Right
Anna vin
Look Right
sõnum 23.04.2009 23:58:45 vasta tsitaadiga
Ei ütleks. Ise küll aru ei saanud, et oleks nagu eriti aeglane olnud.
MotorHead
MotorHead
sõnum 25.04.2009 14:36:01 vasta tsitaadiga
Võimalik et enne räägitud, kuid ei leidnud. U2U teavitussüsteem jooksutab FF ja IE kokku. IE viskab errori, et pluginiga tekkis error jne. Mis plugin seda U2U teavitab täpsemalt? OS: Vista.
Kommentaarid: 103 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 94
maxsimiljo
maxsimiljo
sõnum 29.04.2009 20:39:00 vasta tsitaadiga
Minu FF ei salvesta enam muudatusi. Ehk siis booksmarke, passe, isegi add-one. Probleem siis täpseltmalt selles, et esialgu näitab küll et bookmark on olemas, aga FFi kinnipanemisel ja uuesti avamisel seda enam seal pole. Sama asi ka add-onide uninstallimisega, nimekirjas valin unintsall, siis käsib restartida FF ja peale restarti on ikka see olemas. icon_rolleyes.gif Kiire Google ei aidanud.
radok
sõnum 29.04.2009 22:14:14 vasta tsitaadiga
Tools->Options->Privacy vaatasid üle?
Äkki siit linnuke eest: Always clear my private data when I close Firefox. ?
Look Right
Anna vin
Look Right
sõnum 29.04.2009 22:28:25 vasta tsitaadiga
See peaks kustutama igast history ja entry'd jms, cookied ka. Bookmarke ta küll ära ei kustuta.
sõnum 30.04.2009 09:08:57 vasta tsitaadiga
Võimalik et mõni su andmebaasifail on viga saanud.
Mul lõpetas Firefox ajaloo salvestamise, kuna peamine firefoxi sqlite andmebaas oli katki läinud (eeldatavasti vigase toiteploki tõttu, mis juhuslikel aegadel arvutit välja lükkas).
Lahenduse kiiremaks ja paremaks leidmiseks soovitan minna irc'sse irc.mozilla.org serverisse #firefox kanalile.
http://www.mibbit.com
Mozilla server on seal nimekirjas olemas, seega ei tohiks midagi keerulist olla.
AJ
AJ
sõnum 30.04.2009 11:27:51 vasta tsitaadiga
Järjekordne Beta Firefox.
Firefox 3.5 Beta 4 available for testing now
http://mozillalinks.org/wp/2009/04/firefox-35-beta-4-available-for-testing-now/
zx
zx
sõnum 30.04.2009 13:46:03 vasta tsitaadiga
Tere,
küsiks, kas teistel on ka sellist probleemi, või mulle tundub,
et uuemad FF-d laevad paljude pisikeste piltidegaga lehte kaua.
Või annab seda laadimist kuidagi kiirendada.
Kasvõi sellesama lehe - https://foorum.hinnavaatlus.ee/viewforum.php?f=5
RELOAD võtab esimeste tekstide ilmumisesest (2 sekundit) kuni täieliku laadimiseni ~10sek ja kole on vaadata kuidas neid pisipilte ridarealt ekraanile joonistatakse.
Miskid madalamaversiooni FF-d tundusid kiiremad olema.
Või on see miski plugina kõrvalnäht?
IE-l sama leht reloadiga 2 sekundiga täiesti ees. Chromega ka.
Interneti kiiruses küsimust pole.
Kommentaarid: 144 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 129
Valdars
Valdars
sõnum 30.04.2009 13:52:11 vasta tsitaadiga
Ma pakuks, et pigem mingi sinupoolne kala. Võibolla cache sul jamab või ongi tõepoolest mingi addon.
Kommentaarid: 48 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 45
zx
zx
sõnum 30.04.2009 14:15:47 vasta tsitaadiga
või viirustõrje, kaspersky, eks katsetan, teises arvutis just proovisin ja 1-2 sec. reload icon_rolleyes.gif
aga siiski, viirustõrje peaks ka teistele brauseritele samahästi mõjuma, aga aeglane on just FF !?
EDIT: addonid disablesin ära, ei miskit erilist tulemust
viirustõrje sulgemine võttis aja küll 2-3 sekundile, kuid ikka pole nii kiire ja miks see viirustõrje siis teistele brauseritele ei mõju icon_evil.gif
sõnum 30.04.2009 14:31:41 vasta tsitaadiga
zx kirjutas:
Tere,
Siinpool pole probleemi.Laeb alla 2 sekundi.Mis antiviirus on?
Valdars
Valdars
sõnum 30.04.2009 14:40:48 vasta tsitaadiga
Tee uus puhas profiil ja profiil selle alt.
maxsimiljo
maxsimiljo
sõnum 30.04.2009 14:55:08 vasta tsitaadiga
mikk36 kirjutas:
Täitsa võimalik, jamasin mingi aeg nende asjadega. Igatahes reintsall aitas. Tänud thumbs_up.gif
mario20031
mario20031
sõnum 06.05.2009 19:37:14 vasta tsitaadiga
nothing important
viimati muutis mario20031 19.08.2012 04:44:31, muudetud 1 kord
Kommentaarid: 15 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 13
strohher
strohher
sõnum 07.05.2009 10:23:55 vasta tsitaadiga
Kuidas sellest lahti saab, see krdi most visited? Back forward nuppude all.
Tunguusia tundraahv
Kommentaarid: 33 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 30
marco
marco
sõnum 07.05.2009 10:27:35 vasta tsitaadiga
strohher, redigeeri järjehoidjaid?
Does "genuine" mean "with the real bugs"?
strohher
strohher
sõnum 07.05.2009 10:58:35 vasta tsitaadiga
marco, ei leia küll sealt selle kustutamise võimalust. Raiskab ruumi ainult icon_confused.gif
Terve selle punasega ümbritsetud kasti koristaks ära.
Tunguusia tundraahv
tiirP
tiirP
sõnum 07.05.2009 11:33:35 vasta tsitaadiga
strohher, bookmarks toolbar linnukene eest ära võtta
Kommentaarid: 115 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 107
strohher
strohher
sõnum 07.05.2009 11:33:56 vasta tsitaadiga
Tunguusia tundraahv
Valdars
Valdars
sõnum 07.05.2009 11:39:03 vasta tsitaadiga
Most visited on kaust bookmarkide all, sealt see kas ära kustutada või mujale tõsta.
vilfrid
vilfrid
sõnum 07.05.2009 12:38:09 vasta tsitaadiga
Mis ei tähenda, et peaks bookmarkidest loobuma.
Look Right
Anna vin
Look Right
sõnum 07.05.2009 22:05:48 vasta tsitaadiga
Kuidas sa need bookmarksid sinna üles said?
DoS
DoS
sõnum 07.05.2009 23:47:08 vasta tsitaadiga
ma pakun et https://addons.mozilla.org/en-US/firefox/addon/6545
Kommentaarid: 50 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 47
vilfrid
vilfrid
sõnum 07.05.2009 23:47:44 vasta tsitaadiga
taikonaut kirjutas:
Parem klikk-customize ja lohista see bookmarkide riba sinna üles.
Pärast võta linnuke bookmarks toolbari eest ära.
sõnum 09.05.2009 21:58:40 vasta tsitaadiga
Kas saaks kuidagi nii teha,et DownThemAll oleks def allalaadija Firefoxis?.Mõnele lingile klikkan siis avaneks DTA mitte def allalaadija?
Praegu tsipa tüütu eraldi klõpsu teha paremklikkmenüüs icon_confused.gif .
AJ
AJ
sõnum 11.05.2009 13:06:46 vasta tsitaadiga
Future Firefox will be multiprocess
http://mozillalinks.org/wp/2009/05/future-firefox-will-be-multiprocess/
Goldec
Goldec
sõnum 11.05.2009 23:04:48 vasta tsitaadiga
2009 aastal seda kindlasti ei juhtu.
Kommentaarid: 9 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 7
Look Right
Anna vin
Look Right
sõnum 11.05.2009 23:13:36 vasta tsitaadiga
vilfrid kirjutas:
taikonaut kirjutas:
libe
kvaliteetne mees
libe
sõnum 17.05.2009 21:10:25 vasta tsitaadiga
kas keegi oskab aidata
nimelt sooviks firefox 2.x sarnast URL dragi ka firefox 3.x'le
vanas firefoxis urli kasvõi siia foorumi postitusaknasse lohistades tuli alati Title ja siis URL
nüüd 3.x versioonis tuleb ainult URL ja title peab ise kirjutama või eraldi kopeerima
kas on mingit lahendust
olen googlest otsinud ja extensionite hulgast - tutkit
Dude .
sõnum 22.05.2009 20:58:04 vasta tsitaadiga
Okei, mingi eriline kala on täna sisse tulnud. Iga kord kui arvuti väljalülitada, siis logib igalt poolt välja - isegi kui on pandud peale, et automaatselt sisse logiks erinevates foorumites jne. Igalpool oli sedasi, et kasutaja logis ise sisse, kui arvuti tööle panin, aga nüüd tuleb igakord uuesti sisse logida..
TALUSILDID
sõnum 23.05.2009 01:11:24 vasta tsitaadiga
Options -> Privacy: Always clear my private data when I close Firefox - sealt "linnuke" maha. Aga see peaks küpsised hävitama igal Firefoxi sulgemisel, nii et vist ei sobi päris täpselt su kirjeldusega.
Teine võimalus - sul on mingi rämpsupuhasti automaatselt pandud käivituma igal sisse- või väljalogimisel ja see sööb su küpsised ära. Näiteks CCleaner Options -> Settings: Run CCleaner when the computer starts.
Peaksid natuke mõtlema ja meenutama, mida sa enne probleemi tekkimist tegid - variante küpsiste kadumiseks on rohkem kui üks.
Dude .
sõnum 23.05.2009 22:34:06 vasta tsitaadiga
Midagi ei teinud nagu. Linnuke on seal esimesel asjal maas. Options'ite alt on kõik korras, et salvestaks ilusti küpsiseid ja hoiaks alles jne. Sellist asja nagu CCleaner pole (+ muud sellised asjad)..
TALUSILDID
mario20031
mario20031
sõnum 24.05.2009 00:11:10 vasta tsitaadiga
nothing important
viimati muutis mario20031 19.08.2012 04:44:11, muudetud 1 kord
Mikk00
Mikk00
sõnum 24.05.2009 21:32:35 vasta tsitaadiga
Kuidas oleks võimalik panna nii et kui ma midagi hiirega copyn (http aadressi) ja mouse gesturega uue tabi avan et siis ta automaatselt viskaks selle copytud aadressi aadressireale?
(Enne formatit oli nii, nüüd ei oska tagasi enam panna)
Life is a lemon and i want my money back
Dude .
sõnum 24.05.2009 22:14:47 vasta tsitaadiga
Selekteeri aadressiriba, võta aadressist kinni ja rebi sinna, kuhu uus tab tekkima peaks ?
TALUSILDID
Tiiger15
Tiiger15
sõnum 26.05.2009 17:43:07 vasta tsitaadiga
Selline jama, et firefox ei lase oma pluginate lehelt midagi installida.
Nt. DownThemAll ütleb nii:
Firefox ei saanud paigaldada faili asukohas
siis see www.aadress.com
põhjusel:
Ootamatu paigaldamise viga
Vaata vigade konsooli, et näha rohkem detaile
-203
My choices, my life - don't judge me, just try better!
Kommentaarid: 19 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 15
mahfiaz
sõnum 26.05.2009 18:36:59 vasta tsitaadiga
Tiiger15, ja vigade konsool ütleb ... ?
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 32
Tiiger15
Tiiger15
sõnum 26.05.2009 18:58:24 vasta tsitaadiga
Hoiatus: Viga parameetri 'cursor' väärtuse parsimisel. Deklaratsiooni ei kasutatud.
Lähtefail: http://show.textads.ee/styles/728x90.css
Rida: 1
Selliseid ja ka rate.ee nime sisaldavat oli seal vist 1000tk icon_biggrin.gif
EDIT: Ise küsin ja peaaegu ise vastan kah:
Corrupt extension files
Corrupt extension configuration files can cause problems when trying to install an extension. Deleting these files will make Firefox recreate them (removing any corruption) the next time it starts. You won't lose your extensions or their settings by deleting these files.
1. From the menu at the top of the Firefox windowbar, select FileFirefox and then select the ExitQuit FirefoxQuit menu item.
2. Go to your profile folder.
3. Delete the following files:
* extensions.ini
* extensions.cache
* extensions.rdf
4. Restart Firefox.
Ainuke jama on see, et ma ei saa aru mida täpselt mul 1. punkt teha käseb. Mul FF eestikeelne kah. (Käseb FF sulgeda) Ja kus see profile folder asub?
uus teema   vasta Tarkvara »  Tarkvara »  Mozilla Firefox arutlus/probleemid. mine lehele eelmine  1, 2, 3 ... 58, 59, 60 ... 213, 214, 215  järgmine
