AJ
22.04.2009 20:49:07
Firefox issues security update
http://hothardware.com/News/Firefox-issues-security-update/
According to the company's website:
Mozilla developers identified and fixed several stability bugs in the browser engine used in Firefox and other Mozilla-based products. Some of these crashes showed evidence of memory corruption under certain circumstances and we presume that with enough effort at least some of these could be exploited to run arbitrary code.
Thunderbird shares the browser engine with Firefox and could be vulnerable if JavaScript were to be enabled in mail. This is not the default setting and we strongly discourage users from running JavaScript in mail. Without further investigation we cannot rule out the possibility that for some of these an attacker might be able to prepare memory for exploitation through some means other than JavaScript such as large images. |
| Kommentaarid: 37 loe/lisa |
36 |
22.04.2009 23:53:48
Mingi veider jama:
Selle lööb ette iga kord kui Add-onsid lahti teen.Ei oskagi kohe pakkuda mis võib põhjuseks olla.Kahel erinevalt konfigureeritud ja erinevate lisadega firefoxil sama jama.Safe Modes firefox käivitada siis samuti sama jama.
Täna ainult kaks suuremat muudatust teinud:
Uuendasin FF 3.0.0.9 peale ja lasin ajutiselt(nagu ma korra paari kuu jooksul teen) antiviiruse peale.Äkki keerasin NOD32 liiga karmiks?
| Kommentaarid: 92 loe/lisa |
Look Right
Anna vin
23.04.2009 00:04:40
I just ran into the same problem!
When going to Tools->Addons, i get:
"services.addons.mozilla.org:443 uses an invalid security certificate" |
Turns out that my system clock was off...
Once I fixed the date everything worked like a charm. |
link
| Kommentaarid: 19 loe/lisa |
18 |
Look Right
Anna vin
23.04.2009 00:39:10
I had the same problem, extensions complained about an invalic certificate from services.addons.mozilla.org:443.
I could solve it by doing this: (as I have the german version of firefox there is some guesswork about the terms involved!)
In Firefox Open
Tools > Options > Advanced > Encryption : Show certificates
There you can define "exemptions" (not sure about the term)
Enter "services.addons.mozilla.org:443" un the URL field and the annoyance is gone |
edit: FF supportist lugedes, siis paljud kirjutavad ka seda, et tulemüür/av on kurjalt seades. Seal võib ka kala olla.
Äkki see
18 |
23.04.2009 01:41:14
| taikonaut kirjutas: |
In Firefox Open
Äkki see  |
Errorist sain lahti aga ühtegi Add-oni siiski uuendada ei lase.
Tõenäoliselt siis on asi jah selles,et NOD32 liiga kurjaks keeratud mul.Homme lasen maha.Siis peaks(loodetavasti) jälle kõik normi minema 8)
Look Right
Anna vin
23.04.2009 01:47:43
Kui uuendada ei lase, siis uusi installida ka ei luba?
_________________ Ehitusprojektid ja konstruktiivsed lahendused HV kasutajatele soodsamalt
M: Zafira A/Astra G põhjakaitse - 30€ |
18 |
23.04.2009 01:57:04
| Kui uuendada ei lase, siis uusi installida ka ei luba? |
Ei tea.Ei vedele siin .xpi formaadis add-one kõvakettal kahjuks .Õnneks FEBE-ga sai backupid profiilidest ära tehtud.Ühel brauseril on 22 Aprill backup ja teisel 7 Aprill.Isegi kui see jama osutub pöördumatuks, siis saan maha lasta kogu värgi ja backupist täisprofiili asemele .
Look Right
Anna vin
23.04.2009 02:11:31
FF supportis mingi vana soovitas ka uus profiil teha. Kuid ise ma ei usu, et see aitab.
edit:
| Ei vedele siin .xpi formaadis add-one kõvakettal kahjuks |
no tõmbasin alla mingi suvalise add-on'i - Cooliris
link. . Võid ju proovida, kas installib ära.
18 |
Look Right
Anna vin
23.04.2009 02:20:02
Nii et ikka oli liiga kurjas seades nod. Pmst tihendi viga
18 |
Look Right
Anna vin
23.04.2009 23:58:45
Ei ütleks. Ise küll aru ei saanud, et oleks nagu eriti aeglane olnud.
18 |
MotorHead
25.04.2009 14:36:01
| Võimalik et enne räägitud, kuid ei leidnud. U2U teavitussüsteem jooksutab FF ja IE kokku. IE viskab errori, et pluginiga tekkis error jne. Mis plugin seda U2U teavitab täpsemalt? OS: Vista.
93 |
maxsimiljo
29.04.2009 20:39:00
Minu FF ei salvesta enam muudatusi. Ehk siis booksmarke, passe, isegi add-one. Probleem siis täpseltmalt selles, et esialgu näitab küll et bookmark on olemas, aga FFi kinnipanemisel ja uuesti avamisel seda enam seal pole. Sama asi ka add-onide uninstallimisega, nimekirjas valin unintsall, siis käsib restartida FF ja peale restarti on ikka see olemas. Kiire Google ei aidanud.
| Kommentaarid: 28 loe/lisa |
28 |
radok
29.04.2009 22:14:14
Tools->Options->Privacy vaatasid üle?
Äkki siit linnuke eest: Always clear my private data when I close Firefox. ?
| Kommentaarid: 26 loe/lisa |
26 |
Look Right
Anna vin
29.04.2009 22:28:25
See peaks kustutama igast history ja entry'd jms, cookied ka. Bookmarke ta küll ära ei kustuta.
18 |
30.04.2009 09:08:57
Võimalik et mõni su andmebaasifail on viga saanud.
Mul lõpetas Firefox ajaloo salvestamise, kuna peamine firefoxi sqlite andmebaas oli katki läinud (eeldatavasti vigase toiteploki tõttu, mis juhuslikel aegadel arvutit välja lükkas).
Lahenduse kiiremaks ja paremaks leidmiseks soovitan minna irc'sse irc.mozilla.org serverisse #firefox kanalile.
http://www.mibbit.com
Mozilla server on seal nimekirjas olemas, seega ei tohiks midagi keerulist olla.
| Kommentaarid: 85 loe/lisa |
AJ
36 |
zx
30.04.2009 13:46:03
Tere,
küsiks, kas teistel on ka sellist probleemi, või mulle tundub,
et uuemad FF-d laevad paljude pisikeste piltidegaga lehte kaua.
Või annab seda laadimist kuidagi kiirendada.
Kasvõi sellesama lehe - https://foorum.hinnavaatlus.ee/viewforum.php?f=5
RELOAD võtab esimeste tekstide ilmumisesest (2 sekundit) kuni täieliku laadimiseni ~10sek ja kole on vaadata kuidas neid pisipilte ridarealt ekraanile joonistatakse.
Miskid madalamaversiooni FF-d tundusid kiiremad olema.
Või on see miski plugina kõrvalnäht?
IE-l sama leht reloadiga 2 sekundiga täiesti ees. Chromega ka.
Interneti kiiruses küsimust pole.
129 |
Valdars
30.04.2009 13:52:11
| Ma pakuks, et pigem mingi sinupoolne kala. Võibolla cache sul jamab või ongi tõepoolest mingi addon.
| Kommentaarid: 48 loe/lisa |
45 |
zx
30.04.2009 14:15:47
või viirustõrje, kaspersky, eks katsetan, teises arvutis just proovisin ja 1-2 sec. reload
aga siiski, viirustõrje peaks ka teistele brauseritele samahästi mõjuma, aga aeglane on just FF !?
EDIT: addonid disablesin ära, ei miskit erilist tulemust
viirustõrje sulgemine võttis aja küll 2-3 sekundile, kuid ikka pole nii kiire ja miks see viirustõrje siis teistele brauseritele ei mõju
129 |
30.04.2009 14:31:41
| zx kirjutas: |
Tere,
Interneti kiiruses küsimust pole. |
Siinpool pole probleemi.Laeb alla 2 sekundi.Mis antiviirus on?
Valdars
30.04.2009 14:40:48
| Tee uus puhas profiil ja profiil selle alt.
45 |
maxsimiljo
30.04.2009 14:55:08
| mikk36 kirjutas: |
Mozilla server on seal nimekirjas olemas, seega ei tohiks midagi keerulist olla. |
Täitsa võimalik, jamasin mingi aeg nende asjadega. Igatahes reintsall aitas. Tänud
28 |
mario20031
06.05.2009 19:37:14
nothing important
viimati muutis mario20031 19.08.2012 04:44:31, muudetud 1 kord |
| Kommentaarid: 15 loe/lisa |
strohher
07.05.2009 10:23:55
Kuidas sellest lahti saab, see krdi most visited? Back forward nuppude all.
_________________ Tunguusia tundraahv |
30 |
marco
07.05.2009 10:27:35
strohher, redigeeri järjehoidjaid?
_________________ Does "genuine" mean "with the real bugs"? |
| Kommentaarid: 9 loe/lisa |
9 |
strohher
07.05.2009 10:58:35
marco, ei leia küll sealt selle kustutamise võimalust. Raiskab ruumi ainult
Terve selle punasega ümbritsetud kasti koristaks ära.
30 |
tiirP
07.05.2009 11:33:35
strohher, bookmarks toolbar linnukene eest ära võtta
107 |
strohher
07.05.2009 11:33:56
Cofy, aitäh
30 |
Valdars
07.05.2009 11:39:03
| Most visited on kaust bookmarkide all, sealt see kas ära kustutada või mujale tõsta.
45 |
vilfrid
07.05.2009 12:38:09
Mis ei tähenda, et peaks bookmarkidest loobuma.
Look Right
Anna vin
07.05.2009 22:05:48
Kuidas sa need bookmarksid sinna üles said?
18 |
DoS
| Kommentaarid: 50 loe/lisa |
47 |
vilfrid
07.05.2009 23:47:44
| Kuidas sa need bookmarksid sinna üles said? |
Parem klikk-customize ja lohista see bookmarkide riba sinna üles.
Pärast võta linnuke bookmarks toolbari eest ära.
AJ
36 |
Goldec
11.05.2009 23:04:48
| 2009 aastal seda kindlasti ei juhtu.
Look Right
Anna vin
11.05.2009 23:13:36
| vilfrid kirjutas: |
Pärast võta linnuke bookmarks toolbari eest ära. |
Tänud
18 |
libe
kvaliteetne mees
17.05.2009 21:10:25
kas keegi oskab aidata
nimelt sooviks firefox 2.x sarnast URL dragi ka firefox 3.x'le
vanas firefoxis urli kasvõi siia foorumi postitusaknasse lohistades tuli alati Title ja siis URL
nüüd 3.x versioonis tuleb ainult URL ja title peab ise kirjutama või eraldi kopeerima
kas on mingit lahendust
olen googlest otsinud ja extensionite hulgast - tutkit
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
Dude .
22.05.2009 20:58:04
Okei, mingi eriline kala on täna sisse tulnud. Iga kord kui arvuti väljalülitada, siis logib igalt poolt välja - isegi kui on pandud peale, et automaatselt sisse logiks erinevates foorumites jne. Igalpool oli sedasi, et kasutaja logis ise sisse, kui arvuti tööle panin, aga nüüd tuleb igakord uuesti sisse logida..
_________________ TALUSILDID |
| Kommentaarid: 16 loe/lisa |
16 |
23.05.2009 01:11:24
Options -> Privacy: Always clear my private data when I close Firefox - sealt "linnuke" maha. Aga see peaks küpsised hävitama igal Firefoxi sulgemisel, nii et vist ei sobi päris täpselt su kirjeldusega.
Teine võimalus - sul on mingi rämpsupuhasti automaatselt pandud käivituma igal sisse- või väljalogimisel ja see sööb su küpsised ära. Näiteks CCleaner Options -> Settings: Run CCleaner when the computer starts.
Peaksid natuke mõtlema ja meenutama, mida sa enne probleemi tekkimist tegid - variante küpsiste kadumiseks on rohkem kui üks.
Dude .
23.05.2009 22:34:06
Midagi ei teinud nagu. Linnuke on seal esimesel asjal maas. Options'ite alt on kõik korras, et salvestaks ilusti küpsiseid ja hoiaks alles jne. Sellist asja nagu CCleaner pole (+ muud sellised asjad)..
16 |
mario20031
24.05.2009 00:11:10
nothing important
viimati muutis mario20031 19.08.2012 04:44:11, muudetud 1 kord |
Mikk00
24.05.2009 21:32:35
Kuidas oleks võimalik panna nii et kui ma midagi hiirega copyn (http aadressi) ja mouse gesturega uue tabi avan et siis ta automaatselt viskaks selle copytud aadressi aadressireale?
(Enne formatit oli nii, nüüd ei oska tagasi enam panna)
_________________ Life is a lemon and i want my money back |
Dude .
24.05.2009 22:14:47
Selekteeri aadressiriba, võta aadressist kinni ja rebi sinna, kuhu uus tab tekkima peaks ?
16 |
Tiiger15
26.05.2009 17:43:07
Selline jama, et firefox ei lase oma pluginate lehelt midagi installida.
Nt. DownThemAll ütleb nii:
Firefox ei saanud paigaldada faili asukohas
siis see www.aadress.com
põhjusel:
Ootamatu paigaldamise viga
Vaata vigade konsooli, et näha rohkem detaile
-203
_________________ My choices, my life - don't judge me, just try better! |
15 |
mahfiaz
26.05.2009 18:36:59
| Tiiger15, ja vigade konsool ütleb ... ?
| Kommentaarid: 32 loe/lisa |
Tiiger15
26.05.2009 18:58:24
Hoiatus: Viga parameetri 'cursor' väärtuse parsimisel. Deklaratsiooni ei kasutatud.
Lähtefail: http://show.textads.ee/styles/728x90.css
Rida: 1
Selliseid ja ka rate.ee nime sisaldavat oli seal vist 1000tk
EDIT: Ise küsin ja peaaegu ise vastan kah:
Corrupt extension files
Corrupt extension configuration files can cause problems when trying to install an extension. Deleting these files will make Firefox recreate them (removing any corruption) the next time it starts. You won't lose your extensions or their settings by deleting these files.
1. From the menu at the top of the Firefox windowbar, select FileFirefox and then select the ExitQuit FirefoxQuit menu item.
2. Go to your profile folder.
3. Delete the following files:
* extensions.ini
* extensions.cache
* extensions.rdf
4. Restart Firefox.
Ainuke jama on see, et ma ei saa aru mida täpselt mul 1. punkt teha käseb. Mul FF eestikeelne kah. (Käseb FF sulgeda) Ja kus see profile folder asub?
15 |
