anim
07.03.2009 18:19:35
| omal on FS Lifebook S seeria läpakas, millel on ka webcam ja see töötab uvcvideo nimelise draiveriga
| Kommentaarid: 23 loe/lisa |
22 |
Vylx
11.03.2009 01:57:44
Selline mure hetkel liveCD`ga, arvatavasti draiveritega seotud - ei saa kuidagi ruuteriga ühendust (kaart/ruuter/kaabel on korras - testitud) Kuid mida täpsemalt uurida, kahjuks veel ei oska välja lugeda ise.
Terminal väidab:
# ubuntu@ubuntu:~$ dmesg | grep 8139
[ 3.631942] 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[ 4.280361] 8139cp 0000:01:07.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip
[ 4.280368] 8139cp 0000:01:07.0: Try the "8139too" driver instead.
[ 4.284116] 8139too Fast Ethernet driver 0.9.28
[ 4.284423] 8139too 0000:01:07.0: PCI INT A -> Link[APC3] -> GSI 18 (level, high) -> IRQ 18
[ 4.285237] eth0: RealTek RTL8139 at 0xc400, 00:40:95:30:62:5e, IRQ 18
[ 4.285240] eth0: Identified 8139 chip type 'RTL-8139C'
# ubuntu@ubuntu:~$ lspci | grep 8139
01:07.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
# ubuntu@ubuntu:~$ lsmod | grep 8139
8139too 31616 0
8139cp 27520 0
mii 13440 2 8139too,8139cp
# ubuntu@ubuntu:~$ lspci -vv
00:00.0 Host bridge: nVidia Corporation nForce2 IGP2 (rev c1)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Region 0: Memory at e0000000 (32-bit, prefetchable) [size=128M]
Capabilities: <access denied>
Kernel driver in use: agpgart-nvidia
Kernel modules: nvidia-agp
00:00.1 RAM memory: nVidia Corporation nForce2 Memory Controller 0 (rev c1)
Subsystem: nVidia Corporation Device 0c17
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
00:00.2 RAM memory: nVidia Corporation nForce2 Memory Controller 4 (rev c1)
00:00.3 RAM memory: nVidia Corporation nForce2 Memory Controller 3 (rev c1)
00:00.4 RAM memory: nVidia Corporation nForce2 Memory Controller 2 (rev c1)
00:00.5 RAM memory: nVidia Corporation nForce2 Memory Controller 5 (rev c1)
00:01.0 ISA bridge: nVidia Corporation nForce2 ISA Bridge (rev a4)
Subsystem: nVidia Corporation Device 0c11
Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
00:01.1 SMBus: nVidia Corporation nForce2 SMBus (MCP) (rev a2)
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 11
Region 0: I/O ports at e400 [size=32]
Kernel driver in use: nForce2_smbus
Kernel modules: i2c-nforce2
00:02.0 USB Controller: nVidia Corporation nForce2 USB Controller (rev a4) (prog-if 10)
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0 (750ns min, 250ns max)
Interrupt: pin A routed to IRQ 21
Region 0: Memory at eb001000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci_hcd
Kernel modules: ohci-hcd
00:02.1 USB Controller: nVidia Corporation nForce2 USB Controller (rev a4) (prog-if 10)
Interrupt: pin B routed to IRQ 20
Region 0: Memory at eb002000 (32-bit, non-prefetchable) [size=4K]
00:02.2 USB Controller: nVidia Corporation nForce2 USB Controller (rev a4) (prog-if 20)
Interrupt: pin C routed to IRQ 22
Region 0: Memory at eb003000 (32-bit, non-prefetchable) [size=256]
Kernel driver in use: ehci_hcd
Kernel modules: ehci-hcd
00:08.0 PCI bridge: nVidia Corporation nForce2 External PCI Bridge (rev a3)
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap- 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
I/O behind bridge: 0000c000-0000cfff
Memory behind bridge: ea000000-eaffffff
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr+ DiscTmrStat- DiscTmrSERREn-
Kernel modules: shpchp
00:09.0 IDE interface: nVidia Corporation nForce2 IDE (rev a2) (prog-if 8a [Master SecP PriP])
Subsystem: Device f0de:05b2
Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Region 0: [virtual] Memory at 000001f0 (32-bit, non-prefetchable) [disabled] [size=8]
Region 1: [virtual] Memory at 000003f0 (type 3, non-prefetchable) [disabled] [size=1]
Region 2: [virtual] Memory at 00000170 (32-bit, non-prefetchable) [disabled] [size=8]
Region 3: [virtual] Memory at 00000370 (type 3, non-prefetchable) [disabled] [size=1]
Region 4: I/O ports at f000 [size=16]
Kernel driver in use: pata_amd
Kernel modules: pata_amd
00:1e.0 PCI bridge: nVidia Corporation nForce2 AGP (rev c1)
Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32
Bus: primary=00, secondary=02, subordinate=02, sec-latency=32
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: e8000000-e9ffffff
Prefetchable memory behind bridge: c0000000-dfffffff
Secondary status: 66MHz+ FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
01:06.0 Multimedia audio controller: C-Media Electronics Inc CM8738 (rev 10)
Subsystem: C-Media Electronics Inc CM8738
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32 (500ns min, 6000ns max)
Interrupt: pin A routed to IRQ 17
Region 0: I/O ports at c000 [size=256]
Kernel driver in use: C-Media PCI
Kernel modules: snd-cmipci
Subsystem: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32 (8000ns min, 16000ns max)
Interrupt: pin A routed to IRQ 18
Region 0: I/O ports at c400 [size=256]
Region 1: Memory at ea000000 (32-bit, non-prefetchable) [size=256]
Kernel driver in use: 8139too
Kernel modules: 8139cp, 8139too
02:00.0 VGA compatible controller: ATI Technologies Inc RV350 AP [Radeon 9600]
Subsystem: ATI Technologies Inc RV350 AP [Radeon 9600]
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32 (2000ns min), Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 19
Region 0: Memory at c0000000 (32-bit, prefetchable) [size=256M]
Region 1: I/O ports at d000 [size=256]
Region 2: Memory at e9000000 (32-bit, non-prefetchable) [size=64K]
[virtual] Expansion ROM at e8000000 [disabled] [size=128K]
Kernel modules: radeonfb
02:00.1 Display controller: ATI Technologies Inc RV350 AP [Radeon 9600] (Secondary)
Subsystem: ATI Technologies Inc Device 4151
Region 0: Memory at d0000000 (32-bit, prefetchable) [disabled] [size=256M]
Region 1: Memory at e9010000 (32-bit, non-prefetchable) [disabled] [size=64K]
# ubuntu@ubuntu:~$ ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:40:95:30:62:5e
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:18 Base address:0xc400
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:304 errors:0 dropped:0 overruns:0 frame:0
TX packets:304 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:20016 (20.0 KB) TX bytes:20016 (20.0 KB)
pan0 Link encap:Ethernet HWaddr 32:45:ed:bd:84:2d
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) |
| Kommentaarid: 51 loe/lisa |
49 |
DoS
| Kommentaarid: 50 loe/lisa |
47 |
Vylx
11.03.2009 11:21:16
Selle W-O-L / Power triki kohta olen lugenud ja ka proovinud varem igatpidi - pole aidanud:
a) installides uusimad ethernet draiverid ja device manageri all enabledes WOL (kuigi BIOS`is pole mul sellist valikut) ning proovinud restartides/shutdownides bootida livecd`ga.
b) eemaldanud kõik HDD`d kastist jättes vaid CD-ROM`i livecd jaoks. Lisaks eemaldanud enne käimapanekut netikaabli/voolujuhtme kastilt ning 2x 10sec vajutanud power nuppu (et poleks kübetki voolu käivitamise hetkel ühesgi seadmes)
On olnud ka olukord, kus kastis on installitud vaid Ubuntu - ei mingit dualboot, lisa kettaid jne. Probleem oli siis täpselt sama (Ubuntu 6.06), seega jäi asi sinnapaika tookord, kuni tänaseni. (Seniajani olnud asenduseks Win XP võrgu probleemideta. Tõsi küll, kaart töötab ainult 10mb half või full duplexil windowsis. Kuigi proovisin ka 10mb mõlemat, nii half/full duplexit Ubuntus mii-tooliga, kui ka ethtool`ga - ei aidanud)
Ruuteris on DHCP enabletud. Mõlemad laptopid saavad ka kenasti liveCD`ga DHCP`lt vajalikud andmed kätte (kaabliga - disablesin wifi kaardid testimiseks), ilma ühtegi nuppu vajutamata.
# ubuntu@ubuntu:~$ uname -r
# ubuntu@ubuntu:~$ sudo dhclient -r
Internet Systems Consortium DHCP Client V3.1.1
Copyright 2004-2008 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/sw/dhcp/
Listening on LPF/pan0/b6:a9:ea:24:8b:66
Sending on LPF/pan0/b6:a9:ea:24:8b:66
Listening on LPF/eth0/00:40:95:30:62:5e
Sending on LPF/eth0/00:40:95:30:62:5e
Sending on Socket/fallback |
# ubuntu@ubuntu:~$ sudo dhclient eth0 (proovisin ka ainult "sudo dhclient" - tulemus sama. Ainult et, siis requestisid infot eth0 ja ka pan0.)
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 5
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 11
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 15
DHCPDISCOVER on eth0 to 255.255.255.255 port 67 interval 8
No DHCPOFFERS received.
No working leases in persistent database - sleeping. |
viimati muutis Vylx 11.03.2009 12:58:48, muudetud 1 kord |
49 |
DoS
11.03.2009 12:18:28
Kui aega on, võid 9.04'ga proovida, millel peaks 2.6.28 olema http://cdimage.ubuntu.com/daily-live/current/
Ja siis veel selline variant:
This solution worked for me, my card appeared to be configured properly on ubuntu 7.10 but wouldnt actually connect to my router. I booted into windows and unticked the box for "Let windows power down this device"
rebooted to ubuntu and it works now |
47 |
Vylx
11.03.2009 17:20:36
Niih, 9.04 proovitud. Paremaks läks kohe - nüüd kuvas kõik väljad väärtustega kohe ilusti ära, mitte ei olnud "not available"
Peale selle, sai tehtud:
# ubuntu@ubuntu:~$ sudo mii-tool eth0 -F 10baseT-FD
# ubuntu@ubuntu:~$ sudo rmmod 8139too
# ubuntu@ubuntu:~$ sudo modprobe 8139too |
...ja ülejäänud tegi DHCP ise, automaatselt. Töötab kenasti nüüd. Tänud
Nüüd jäänud vaid mõelda, kuidas kõike seda automaatselt teha iga boodi aeg.
49 |
mahfiaz
| Kommentaarid: 32 loe/lisa |
mightythor
13.03.2009 17:03:10
| HHE kirjutas: |
Proovisid ka, mis maitsega oli?  |
minule meeldis väga Maitset kirjeldada on keeruline, aga nagu cola ja marjajook segamini.
ma olen samuti selle kohta lugenud, kuid kuidas see tehniliselt võimalik saab olla, et mingi Windows'i seadistus omab mõju ka Linux'i all?
| Kommentaarid: 62 loe/lisa |
53 |
Chaza!
13.03.2009 18:57:09
| mightythor kirjutas: |
ma olen samuti selle kohta lugenud, kuid kuidas see tehniliselt võimalik saab olla, et mingi Windows'i seadistus omab mõju ka Linux'i all? |
Äkki windows lülitab seadme välja, ning linux ei oska enam sisse lülitada. Selleks ongi vaja, et win seadet välja ei lüliks.
_________________ Linux - Future
1984 was not supposed to be instruction manual |
| Kommentaarid: 58 loe/lisa |
53 |
mightythor
13.03.2009 20:31:30
| Chaza! kirjutas: |
Äkki windows lülitab seadme välja, ning linux ei oska enam sisse lülitada. Selleks ongi vaja, et win seadet välja ei lüliks. |
ta võib ju seadme välja lülitada, kuid kuidas see valik restardi "üle elab"? St Linux ei tohiks kuskilt otsast Windowsi operatsioonisüsteemi seadistustest hoolida
53 |
anim
13.03.2009 21:04:12
| olen ise ka näinud kuidas win lülitab wifi välja nii, et linux seadet enam ei näe - kahjuks pole täpne masin enam meeles (vist oli mingi thinkpad)
22 |
marqs
13.03.2009 21:12:05
ta võib ju seadme välja lülitada, kuid kuidas see valik restardi "üle elab"? St Linux ei tohiks kuskilt otsast Windowsi operatsioonisüsteemi seadistustest hoolida  |
Pigem ikka kaardi, mitte wini seade. Väidetavalt avitab paljudel juhtudel ka masina toitest välja lülimine.
_________________ 0xDEAD
0xBEEF |
| Kommentaarid: 28 loe/lisa |
mightythor
14.03.2009 12:45:40
| marqs kirjutas: |
Pigem ikka kaardi, mitte wini seade. Väidetavalt avitab paljudel juhtudel ka masina toitest välja lülimine. |
et siis kaardil on mingi mikrokontroller, mille koosseisus on ka pisike volatile tüüpi mälu/register...ja see mikrokontroller reguleerib, kas kaart töötab või mitte? Ning kui toide eemaldada, siis see mälukontrolleri register võtab algseisu
53 |
raido357
27.03.2009 11:05:06
9.04 Beta väljas
Jaunty
| Kommentaarid: 78 loe/lisa |
Cheetah
28.03.2009 23:54:23
Sai ka siis ubuntu proovimiseks peale pandud. Kuidas mõnda mängu käima saab panna?
| Kommentaarid: 91 loe/lisa |
84 |
asjameez
29.03.2009 00:08:51
Cheetah, kui mõtled Windowsi mänge, siis installi Synapticust "WINE".
http://wiki.winehq.org/winetricks
Ning vahest tuleb kasuks ka directx9 installimine winetricksiga.
Linuxi mängude puhul otsi netist/synapticust .deb pakke ja installi klikiga arhiivi ikoonil.
| Kommentaarid: 63 loe/lisa |
61 |
Cheetah
29.03.2009 00:23:16
asjameez, Tänan, proovin
84 |
Mario.
30.03.2009 21:03:51
Tere tere.
Nii. Mõtlesin et proovin esmakordselt igavusest Ubuntu mälupulga pealt:
http://www.pendrivelinux.com/live-ubuntu-810-usb-persistent-install-windows/#more-630
Formatin ma mälupulka kui palju tahes ja teen kõik uuesti nii nagu seal, jääb ette käsurida millega ma midagi edasi teha ei oska:
Või palun viidake veel mugavale ja mobiilsele usb pulga pealt laetavale linuxile koos sätete salvestamisega.
6 :: |
217 |
Chaza!
30.03.2009 22:39:53
| MarioA. kirjutas: |
Tere tere.
Või palun viidake veel mugavale ja mobiilsele usb pulga pealt laetavale linuxile koos sätete salvestamisega. |
Puppy Linux pulgale parim
53 |
Vincenzo
30.03.2009 22:51:50
| MarioA. kirjutas: |
| Formatin ma mälupulka kui palju tahes ja... |
Miks mitte minna kõige lihtsamat teed ja lasta unetbootinil kõik enda eest ära teha?
| Kommentaarid: 4 loe/lisa |
Mario.
31.03.2009 08:12:35
| Vincenzo kirjutas: |
| MarioA. kirjutas: |
Miks mitte minna kõige lihtsamat teed ja lasta unetbootinil kõik enda eest ära teha? |
Ei tööta, sama jama. Ehk on asi Isos või mälupulgas.
Proovin puppy.t - ei tööta. Mingi "job is turned off" ja ei leia vajalikku faili.
| can't acess tty: job control tunned off |
Kas Ubuntu eee on kohandatud riistvara toetuse poolest ainult eee pc-le või võiks julgeda seda peale ajada ka teistele netbookidele nagu lenovo s10?
6 :: |
217 |
Vincenzo
31.03.2009 10:20:20
| MarioA. kirjutas: |
| Ei tööta, sama jama. Ehk on asi Isos või mälupulgas. |
Huvitav. Ehk asi ikkagi rauas? BIOSi sätted üle vaadatud ja paigas? Ei teeks paha ka mõne teise pulgaga proovida. Või SD kaardiga.. Kuvatõmmisest ei saa eriti sotti, et kuskohas ta toppama jääb. Ehk saab sealt abi.
| MarioA. kirjutas: |
| Kas Ubuntu eee on kohandatud riistvara toetuse poolest ainult eee pc-le või võiks julgeda seda peale ajada ka teistele netbookidele nagu lenovo s10? |
Platvorm neil ju sama, ei tohiks mingit vahet olla.
ps. enda eee 901-l mõned nädalad juba Easy Peasy 1.0 jooksnud. Julgen soovitada
note1
31.03.2009 13:34:45
Muideks jaunty'le (9.04) on juba firefox for ubuntu eesti keele pakk valmis tehtud.
Ilmub stabiilsesse, vast.
Mario.
31.03.2009 14:40:26
| Kuidas ma easy peasy saan usb peale? uNetBootin-i valikus ei ole toda või pean valima ubuntu kuna selle baasil ta on.
6 :: |
217 |
Vincenzo
31.03.2009 17:11:37
| MarioA. kirjutas: |
| Kuidas ma easy peasy saan usb peale? uNetBootin-i valikus ei ole toda või pean valima ubuntu kuna selle baasil ta on. |
Ei-ei. Laadid siit tõmmise (ISO) alla ja näitad unetbootinile ette, et kus asub iso ja kuhu (pulgale) ta peab selle kirjutama.
