ertr2
26.10.2008 12:17:22
[X360] Forza Motorsport 3 |
Forza Motorsport 3
Forza 3 will feature an all new graphics engine, with four times the texture resolution and 10 times the polys per car. It'll have 400 cars from 50 manufacturers that can race across 100 real-world tracks. New courses include Suzuka, Nürburgring Nordschleife and the Sebring International Raceway. New environments include the Montserrat region in Spain, the Amalfi Coast in Italy and the American Southwest. To give a sense of how much the visuals have improved, all 400 cars are being built with 10 times the polygons as Forza Motorsport 2.
The single-player game will feature 200 different events while the online multiplayer mode now sports a game rules editor that allows you to tweak exactly how you'll play with others. There'll also be auto-braking and a rewind feature implemented that allow you to retry sections if you screw up.
Forza Motorsport 3 will also feature an in-game video editor.
Multiplayer: jah
Uudised ja eelvaated: Gamespot
Ülevaade: Gamespot
Screenshotid: Gamespot
Videod: Gamespot
| Kommentaarid: 67 loe/lisa |
65 |
henri200
26.10.2008 13:05:29
* New race modes (drag, drift, oval, point to point racing, etc.)
nah nad hea mängu suudavad ära rikkuda
| Kommentaarid: 62 loe/lisa |
59 |
06.01.2009 04:53:35
| While Forza 2 was big, its said that FM3 is so large that the DVD format has become an issue. With a total of 400+ cars and over 100 tracks it will likely ship on two separate discs. A preview of Forza Motorsport 3 will likely be shown later this year at the E3 show. We cant wait to get our hands on a copy since our thumbs are just now healing from the first game. |
Forza 3 artwork leaked: http://www.forzacentral.com/forum/showthread.php?t=30934
313 |
ppg
11.01.2009 23:24:26
| henri200, pole mõtet hakata solkima kui pole meieni veel midagi jõudnud, GT5P-s samuti olemas drift mode.
138 |
EvilKatarn
diivanilill
11.01.2009 23:29:00
Siit tuleb ikka tugevalt loota ropphead graafikat. Et kõik võrestikud oleks renderdatud, mitte mingid kuradi jpeg tekstuurid
81 |
ppg
11.01.2009 23:36:31
Ise ootan paremat juhitavust, mul mõlemad konsoolid ning mõlemal ka roolid, ning peab tõdema tõsiasja et GT5P juhitavus oli üle Forza2-e omast...400 cars
138 |
henri200
11.01.2009 23:39:03
| Ega need GT5 ja Forza erilised simud polegi, konsoolidel üldse pole. PC peal on neid piisavalt, LFS, iRacing, rFactor, GTR2 jnejne...Varsti küll tuleb X360-le Race Pro mis on siis GTR Evo n-ö konsooli versioon koos mõnede lisaga (ja mõne kaotatud raja ja autoga). Loodame, et nad ikka väga arkaadi ei tee konsooli tarbeks, ja et Lizard engine ei ole solk
59 |
ppg
12.01.2009 06:59:54
| henri200, kui gt5p-s valida physix professionali peale, siis tegu korraliku simuga siiski, vaevalt et Forza3 kellelgi sõidu huvilisel ostmata jääb.
138 |
Look Right
Anna vin
13.01.2009 15:10:27
Driftitamine läheb liiga NFS moodi juba. Mulle ka ei meeldiks. Aga drag meeldib küll . PtPr mulle ka eriti ei meeldi. Jällegi NFS seeriast ära tüüdanud. Kahe plaadi peal on ka nats jura, ei viitsi seda plaati vahetada.
_________________ Ehitusprojektid ja konstruktiivsed lahendused HV kasutajatele soodsamalt
M: Zafira A/Astra G põhjakaitse - 30€ |
| Kommentaarid: 19 loe/lisa |
18 |
kalapala
13.01.2009 15:25:14
| taikonaut kirjutas: |
Driftitamine läheb liiga NFS moodi juba. Mulle ka ei meeldiks. Aga drag meeldib küll . PtPr mulle ka eriti ei meeldi. Jällegi NFS seeriast ära tüüdanud. Kahe plaadi peal on ka nats jura, ei viitsi seda plaati vahetada. |
Kui see hakkab kahel plaadil olema, siis saab seda kindlasti ka kettale installeerida, seega pole vaja plaati vahetada ja mõttetu on võrrelda Forzat ja NFS-iga, üks on ikkagi simulaatori moodi, teine on puhas arcade.
13.01.2009 16:02:04
driftida saab ju FM2-s ka...
313 |
ppg
13.01.2009 19:44:14
Ärge halage veel kaas HV-lased, drift mode võib vabalt olla selline nagu GT5P et ta lihtsalt hindab punkidega kui hästi sa driftisid, thats all, gt5p professional mode-s samuti pole asi nii nagu nfs seerias et lööd gaasi põhja ja vaid keerab paremale/vasakule, forza-s tuleb kindlasti sarnane juhitavus, et autol kenalt külg ette saada peab vaeva nägema. (vales suunas pööre ja agressiivne pööre õiges, sama aeg muidugi no power ning kui külg ees siis gaasiga mängeldes hoida autol külg ees kurvi lõpuni ning sujuvalt (kui tagaveoline) lõpetada manööfer , proovige kellel ps3 ja gt5P näiteks m3-ga seda, polegi nii lihtne pro füüsikaga )
138 |
Look Right
Anna vin
15.01.2009 20:53:00
| Skeptik kirjutas: |
driftida saab ju FM2-s ka...  |
No jaa, TC maha ja litsub kurvis gaazi. Dragi saad ka sõita: võta Nürnburgi rada ja saad ka peasirgel dragida. Romurallit saad ka teha, kui tahad.
18 |
15.01.2009 21:15:57
Kes siis TC'd üldse kasutab ?
TC'ga hakkab ju rajal igav, ei saa drifti lasta ega midagi juhtides teiste häirimiseks
| Kommentaarid: 85 loe/lisa |
16.01.2009 00:43:46
| Skeptik kirjutas: |
No jaa, TC maha ja litsub kurvis gaazi. Dragi saad ka sõita: võta Nürnburgi rada ja saad ka peasirgel dragida. Romurallit saad ka teha, kui tahad. |
http://www.youtube.com/watch?v=DAKxsHe8l0g&fmt=22
313 |
Look Right
Anna vin
16.01.2009 02:31:37
Mnjaa, poisid oskavad sõita küll. Ikka jubedalt peavad vennad ikka ennem harjutama, et nõnda sõita.
18 |
henri200
18.02.2009 14:51:36
Forza Motorsport 3 - Coming this Christmas
According to VG247.com, Microsoft plans to release the third installment of their Forza Motorsport series this Christmas. While a successor to Forza Motorsport 2 had been rumored since last summer, no official word had been released until now.
No details on the games content are available yet, rumors are suggesting as much as 100 tracks and 400 different cars. Developed by Turn 10 Studios, Forza Motorsport is Microsofts answer to Polyphonys hugely popular Gran Turismo series in the field of semi-simulation driving games.
Via VG247.com |
59 |
313 |
ppg
18.02.2009 21:16:36
| forzat ootan samuti väga, rool ja box sellejaoks pmst seisavadki, kasutan ps3 hetkel rohkem, kuna GT5:P+G25 on sõidumõnu rohkem kui Forza2+MS Racing Wheel
138 |
11.03.2009 09:24:31
Like most of the development team at Turn 10, my focus has been solely on our future project, making sure that we deliver on our aspirations for what we think are some pretty awesome community features and ways for those who love cars (and speedboats/helicopters) to interact with each other. Secrecy being what it is, now is obviously not the time to divulge such details. Besides, when we do announce our next game and show you what it looks like, itll be done with a bang, not just the whimper of a blog post. Youll know when the time is right and I think our fans will like what they see. Still, progress on the game continues and Landin and I have been playing the snot out of it on a daily basis.
The past few weeks have seen the graphics really come into its own and, well, being the eyecandy junkie that I am, Ive been spending quite a lot of time just admiring the game from a visual standpoint. Landin and I spent quite a few days this week taking screenshots just so we could have the hotness on our PC desktops as wallpapers. In fact, others in the studio began taking their own screenshots in an attempt to out-sexy each others photos. The end result? A huge folder full of sweet looking screenshots and wallpapers to last us well into next year. The good news is, of course, that when we can share with everyone what were building here, showing off the game wont really be much of a problem. But all in due time
all in due time. Meanwhile, Im going to continue drooling over our ever-growing portfolio of car porn, if you will. |
http://forzamotorsport.net/news/pitpassreports/pitpass130.htm
313 |
EvilKatarn
diivanilill
11.03.2009 10:37:25
| Skeptik kirjutas: |
The past few weeks have seen the graphics really come into its own and, well, being the eyecandy junkie that I am, I’ve been spending quite a lot of time just admiring the game from a visual standpoint. |
Loodame, et see vastab tõele.
81 |
11.03.2009 11:44:00
ja loodetavasti oli see speedboats/helicopters ikka naljana mõeldud
313 |
PeZ
11.03.2009 12:08:18
nad võiks mängulusti ka seekord lisada forzasse
| Kommentaarid: 12 loe/lisa |
11.03.2009 12:17:20
| mängulust täiesti olemas nende jaoks, kes taolisi mänge naudivad. kui gameplay-s midagi kapitaalselt muutma hakata ja üritada kõigile meelejärgi olla, ei pruugi enam head asja saada. pärast ei meeldi enam neile, kes olid FM2 sihtgrupiks.
313 |
EvilKatarn
diivanilill
11.03.2009 16:52:30
Forza 2 oli alguses minu jaoks ikka tülgastavalt igav, kui pidin mingite pannidega ringi rallima.
Põnevaks läks siis, kui online osa avastasin ning sain ka superautod kätte.
81 |
11.03.2009 16:56:35
| Sellest hetkest on jah põnevam, kui saab juba sellised autod kätte, mis jõuavad kurvis ratta ringi ajada, läheb väheke lõbusamaks sõit.
ppg
12.03.2009 20:57:35
| Mulle meeldiks vastupidi, forza-s saab väga kergelt juba võimsad autod kätte, võiks rohkem vaeva näha ca. 150-200 hp klassi autodega et saada paremaid.
138 |
13.03.2009 17:58:04
| Samas karjääri all on ju piisavalt sõitmist nõrgemate autodega ? (igasugu stock, võimsusega ja klassiga piiratud sõidud)
23.04.2009 11:20:27
sai TDU2 kohta infot nuhitud ja jäi silma ka selline asi. tundub, et RABCAT modelleerib Forza 3 jaoks 3D automudeleid.
| 2008 - Confidential project - Turn10 / Microsoft Game Studios - Xbox360 |
http://www.rabcat.com/_website2009/sites/track02.htm
viimati muutis SKG 23.04.2009 11:35:07, muudetud 1 kord |
313 |
313 |
woo456
| Kommentaarid: 8 loe/lisa |
05.05.2009 12:52:01
| palun ärge solkige seda teemat ära. kui midagi asjalikku siia lisada pole, siis jätke postitus tegemata. samuti lähevad kustutamisele ka vaidlust õhutavad postid - selleks on juba eraldi teema.
313 |
henri200
20.05.2009 21:21:58
Fanatec has started pre-prodcution of their Porsche 911 Turbo S racing wheel, the only Xbox 360 compatible wheel in Fantecs product lineup.
Interestingly, Fanatec points out that the production was delayed due to Microsoft demanding support of a particular feature in their upcoming Forza 3 title - A game that hasnt even been officially announced yet!
The wheel will also make an appearance on the E3 expo in Los Angeles in June. The Fanatec Porsche 911 Turbo S wheel is available in three different versions, ranging from the Pure edition for 189 to the Clubsport edition that comes with Fanatecs much anticipated Aluminum Clubsport pedal set. European sim racers can pre-order the Turbo S wheel here, interested North American visitors please visit the US store. |
Edit:
Pildil Le Mansi rada, all kuupäev 12 Juuni, päev pärast seda on Le Mansi 24h sõit. Eks näis mis see tähendab.
59 |
rere252
EvilKatarn
diivanilill
02.06.2009 12:11:33
| henri200 kirjutas: |
Demo release võiks see olla. Loogiline oleks ka.
81 |
02.06.2009 23:34:52
Forza Motorsport 3 will be ready to ship this October. |
313 |
Mindfreak
03.06.2009 11:06:44
| Ootan seda pela suure huviga. Treiler paistab vägev.
30 |
rere252
03.06.2009 21:06:27
| igatahes haip on räme. ärge selle järgi ootusi eriti kõrgeks ajage.
313 |
EvilKatarn
diivanilill
03.06.2009 21:10:44
| Nagunii tuleb hea ju...
81 |
03.06.2009 21:12:43
nujah, aga 10x suurem polycount ja 4x suuremad tekstuurid?
muidugi dev walkthrough videod on päris vinged...
viimati muutis SKG 03.06.2009 21:13:36, muudetud 1 kord |
313 |
woo456
03.06.2009 21:17:11
| Haip või mitte, mäng on minu game wishlisti eesotsas igatahes.
henri200
03.06.2009 21:17:14
| Liiga mainstreamiks kätte läinud. jama
59 |
03.06.2009 21:23:21
| Liiga mainstreamiks kätte läinud. jama |
Forza 2 oli ja on 360 peal üks mainstreamimaid mänge üldse! mida sa veel ei taha? selle tõestuseks on juba see, et MS neid oma konsoolidega tasuta kaasa pani ja kui suurel hulgal inimestel see mäng kasvõi siit foorumist olemas on. tegelt ma ei mõsita, mille põhjal sa seda üldse väidad?
aga kui see mäng peaks tõesti niivõrd kobe tulema, nagu seal videos, siis ei jää muud üle kui end täis lasta
313 |
henri200
03.06.2009 21:24:39
| Skeptik kirjutas: |
aga kui see mäng peaks tõesti niivõrd kobe tulema, nagu seal videos, siis ei jää muud üle kui end täis lasta  |
Ta oli suht kuulus jah, aga nagu näha on nad sinna toppinud drifti sisse, juhitavust ILMSELT lihtsamaks teinud ja liiga palju panevad rõhku visuaalsele damage-ile. Pigem arendagu füüsilist damage-it.
59 |
03.06.2009 21:30:16
| Skeptik kirjutas: |
Ta oli suht kuulus jah, aga nagu näha on nad sinna toppinud drifti sisse, juhitavust ILMSELT lihtsamaks teinud ja liiga palju panevad rõhku visuaalsele damage-ile. Pigem arendagu füüsilist damage-it. |
kas drift teeb tõesti mängu automaatselt mainstreamiks? video põhjal see võis ju ka samahästi show-off olla, mitte game mode? lihtsam juhitavus, kust sa seda võtad? pigem just täpsem kui nende sõnul füüsikamootorit arendatud on? füüsilise damage-ga tuleb vist nagunii sein ette kuskil, kuna autotootjad ei soovi, et mängudes nende masinad pilbasteks lõhutakse, mis on muidugi kummaline.
313 |
virx
03.06.2009 21:34:32
| drift ei olnud forza 2-ki tegelikult nn. ametlikult olemas, seda tegid kasutajad ise oma autodega et külge laskma hakkaks, seal ei olnud drift setinguid ega muud sellekohast olemaski. ilmselt tuleb F3-s samamoodi auto ise paika panna ja sõitma minna. võta ükspuha mis auto F2-s ja see ei drifti sul.
309 |
03.06.2009 21:39:21
| virx, tagaveoline bemm M3 ja Mazda MX-7 driftisid ilma mingi erilise seadistuseta nagu nalja. tuleb lihtsalt ilma abideta sõita.
313 |
virx
03.06.2009 22:13:45
| Skeptik, mõni üksik vb tõesti aga drifti seadistused olid erinevates selleteemalistes foorumites üleval. et iga auto kumm vilistama ajada siis ei saa päris juhuse peale lootma jääda.
309 |
henri200
03.06.2009 22:16:50
Vahepeal nad kuskil ütlesid, et drift tuleb. Ja need igast Amalfi rajad jne, puhas mõttetus
59 |
