ertr2
26.10.2008 11:17:22
[X360] Forza Motorsport 3 |
Forza Motorsport 3
Forza 3 will feature an all new graphics engine, with four times the texture resolution and 10 times the polys per car. It'll have 400 cars from 50 manufacturers that can race across 100 real-world tracks. New courses include Suzuka, Nürburgring Nordschleife and the Sebring International Raceway. New environments include the Montserrat region in Spain, the Amalfi Coast in Italy and the American Southwest. To give a sense of how much the visuals have improved, all 400 cars are being built with 10 times the polygons as Forza Motorsport 2.
The single-player game will feature 200 different events while the online multiplayer mode now sports a game rules editor that allows you to tweak exactly how you'll play with others. There'll also be auto-braking and a rewind feature implemented that allow you to retry sections if you screw up.
Forza Motorsport 3 will also feature an in-game video editor.
Multiplayer: jah
Uudised ja eelvaated: Gamespot
Ülevaade: Gamespot
Screenshotid: Gamespot
Videod: Gamespot
| Kommentaarid: 67 loe/lisa |
65 |
henri200
26.10.2008 12:05:29
* New race modes (drag, drift, oval, point to point racing, etc.)
nah nad hea mängu suudavad ära rikkuda
| Kommentaarid: 62 loe/lisa |
59 |
06.01.2009 03:53:35
| While Forza 2 was big, its said that FM3 is so large that the DVD format has become an issue. With a total of 400+ cars and over 100 tracks it will likely ship on two separate discs. A preview of Forza Motorsport 3 will likely be shown later this year at the E3 show. We cant wait to get our hands on a copy since our thumbs are just now healing from the first game. |
Forza 3 artwork leaked: http://www.forzacentral.com/forum/showthread.php?t=30934
313 |
ppg
11.01.2009 22:24:26
| henri200, pole mõtet hakata solkima kui pole meieni veel midagi jõudnud, GT5P-s samuti olemas drift mode.
138 |
EvilKatarn
diivanilill
11.01.2009 22:29:00
Siit tuleb ikka tugevalt loota ropphead graafikat. Et kõik võrestikud oleks renderdatud, mitte mingid kuradi jpeg tekstuurid
81 |
ppg
11.01.2009 22:36:31
Ise ootan paremat juhitavust, mul mõlemad konsoolid ning mõlemal ka roolid, ning peab tõdema tõsiasja et GT5P juhitavus oli üle Forza2-e omast...400 cars
138 |
henri200
11.01.2009 22:39:03
| Ega need GT5 ja Forza erilised simud polegi, konsoolidel üldse pole. PC peal on neid piisavalt, LFS, iRacing, rFactor, GTR2 jnejne...Varsti küll tuleb X360-le Race Pro mis on siis GTR Evo n-ö konsooli versioon koos mõnede lisaga (ja mõne kaotatud raja ja autoga). Loodame, et nad ikka väga arkaadi ei tee konsooli tarbeks, ja et Lizard engine ei ole solk
59 |
ppg
12.01.2009 05:59:54
| henri200, kui gt5p-s valida physix professionali peale, siis tegu korraliku simuga siiski, vaevalt et Forza3 kellelgi sõidu huvilisel ostmata jääb.
138 |
Look Right
Anna vin
13.01.2009 14:10:27
Driftitamine läheb liiga NFS moodi juba. Mulle ka ei meeldiks. Aga drag meeldib küll . PtPr mulle ka eriti ei meeldi. Jällegi NFS seeriast ära tüüdanud. Kahe plaadi peal on ka nats jura, ei viitsi seda plaati vahetada.
_________________ Ehitusprojektid ja konstruktiivsed lahendused HV kasutajatele soodsamalt
M: Zafira A/Astra G põhjakaitse - 30€ |
| Kommentaarid: 19 loe/lisa |
18 |
kalapala
13.01.2009 14:25:14
| taikonaut kirjutas: |
Driftitamine läheb liiga NFS moodi juba. Mulle ka ei meeldiks. Aga drag meeldib küll . PtPr mulle ka eriti ei meeldi. Jällegi NFS seeriast ära tüüdanud. Kahe plaadi peal on ka nats jura, ei viitsi seda plaati vahetada. |
Kui see hakkab kahel plaadil olema, siis saab seda kindlasti ka kettale installeerida, seega pole vaja plaati vahetada ja mõttetu on võrrelda Forzat ja NFS-iga, üks on ikkagi simulaatori moodi, teine on puhas arcade.
13.01.2009 15:02:04
driftida saab ju FM2-s ka...
313 |
ppg
13.01.2009 18:44:14
Ärge halage veel kaas HV-lased, drift mode võib vabalt olla selline nagu GT5P et ta lihtsalt hindab punkidega kui hästi sa driftisid, thats all, gt5p professional mode-s samuti pole asi nii nagu nfs seerias et lööd gaasi põhja ja vaid keerab paremale/vasakule, forza-s tuleb kindlasti sarnane juhitavus, et autol kenalt külg ette saada peab vaeva nägema. (vales suunas pööre ja agressiivne pööre õiges, sama aeg muidugi no power ning kui külg ees siis gaasiga mängeldes hoida autol külg ees kurvi lõpuni ning sujuvalt (kui tagaveoline) lõpetada manööfer , proovige kellel ps3 ja gt5P näiteks m3-ga seda, polegi nii lihtne pro füüsikaga )
138 |
Look Right
Anna vin
15.01.2009 19:53:00
| Skeptik kirjutas: |
driftida saab ju FM2-s ka...  |
No jaa, TC maha ja litsub kurvis gaazi. Dragi saad ka sõita: võta Nürnburgi rada ja saad ka peasirgel dragida. Romurallit saad ka teha, kui tahad.
18 |
15.01.2009 20:15:57
Kes siis TC'd üldse kasutab ?
TC'ga hakkab ju rajal igav, ei saa drifti lasta ega midagi juhtides teiste häirimiseks
| Kommentaarid: 85 loe/lisa |
15.01.2009 23:43:46
| Skeptik kirjutas: |
No jaa, TC maha ja litsub kurvis gaazi. Dragi saad ka sõita: võta Nürnburgi rada ja saad ka peasirgel dragida. Romurallit saad ka teha, kui tahad. |
http://www.youtube.com/watch?v=DAKxsHe8l0g&fmt=22
313 |
Look Right
Anna vin
16.01.2009 01:31:37
Mnjaa, poisid oskavad sõita küll. Ikka jubedalt peavad vennad ikka ennem harjutama, et nõnda sõita.
18 |
henri200
18.02.2009 13:51:36
Forza Motorsport 3 - Coming this Christmas
According to VG247.com, Microsoft plans to release the third installment of their Forza Motorsport series this Christmas. While a successor to Forza Motorsport 2 had been rumored since last summer, no official word had been released until now.
No details on the games content are available yet, rumors are suggesting as much as 100 tracks and 400 different cars. Developed by Turn 10 Studios, Forza Motorsport is Microsofts answer to Polyphonys hugely popular Gran Turismo series in the field of semi-simulation driving games.
Via VG247.com |
59 |
313 |
ppg
18.02.2009 20:16:36
| forzat ootan samuti väga, rool ja box sellejaoks pmst seisavadki, kasutan ps3 hetkel rohkem, kuna GT5:P+G25 on sõidumõnu rohkem kui Forza2+MS Racing Wheel
138 |
11.03.2009 08:24:31
Like most of the development team at Turn 10, my focus has been solely on our future project, making sure that we deliver on our aspirations for what we think are some pretty awesome community features and ways for those who love cars (and speedboats/helicopters) to interact with each other. Secrecy being what it is, now is obviously not the time to divulge such details. Besides, when we do announce our next game and show you what it looks like, itll be done with a bang, not just the whimper of a blog post. Youll know when the time is right and I think our fans will like what they see. Still, progress on the game continues and Landin and I have been playing the snot out of it on a daily basis.
The past few weeks have seen the graphics really come into its own and, well, being the eyecandy junkie that I am, Ive been spending quite a lot of time just admiring the game from a visual standpoint. Landin and I spent quite a few days this week taking screenshots just so we could have the hotness on our PC desktops as wallpapers. In fact, others in the studio began taking their own screenshots in an attempt to out-sexy each others photos. The end result? A huge folder full of sweet looking screenshots and wallpapers to last us well into next year. The good news is, of course, that when we can share with everyone what were building here, showing off the game wont really be much of a problem. But all in due time
all in due time. Meanwhile, Im going to continue drooling over our ever-growing portfolio of car porn, if you will. |
http://forzamotorsport.net/news/pitpassreports/pitpass130.htm
313 |
EvilKatarn
diivanilill
11.03.2009 09:37:25
| Skeptik kirjutas: |
The past few weeks have seen the graphics really come into its own and, well, being the eyecandy junkie that I am, I’ve been spending quite a lot of time just admiring the game from a visual standpoint. |
Loodame, et see vastab tõele.
81 |
11.03.2009 10:44:00
ja loodetavasti oli see speedboats/helicopters ikka naljana mõeldud
313 |
PeZ
11.03.2009 11:08:18
nad võiks mängulusti ka seekord lisada forzasse
| Kommentaarid: 12 loe/lisa |
11.03.2009 11:17:20
| mängulust täiesti olemas nende jaoks, kes taolisi mänge naudivad. kui gameplay-s midagi kapitaalselt muutma hakata ja üritada kõigile meelejärgi olla, ei pruugi enam head asja saada. pärast ei meeldi enam neile, kes olid FM2 sihtgrupiks.
313 |
EvilKatarn
diivanilill
11.03.2009 15:52:30
Forza 2 oli alguses minu jaoks ikka tülgastavalt igav, kui pidin mingite pannidega ringi rallima.
Põnevaks läks siis, kui online osa avastasin ning sain ka superautod kätte.
81 |
