virx
17.02.2009 04:51:39
| ceemic, ainuke SS mis nö. kohe saada oleks on Zeus 850W (single 70A) - 3091.-
309 |
Chidori
17.02.2009 09:42:24
Huvitav - ma saaksin Decathloni odavamalt kui Zeusi...
100% modulaar - naq keegi kavatseks endale sellisest toitest secondarit ehitada.
99 |
Jaan
17.02.2009 11:46:05
| virx kirjutas: |
| ceemic, ainuke SS mis nö. kohe saada oleks on Zeus 850W (single 70A) - 3091.- |
850W Zeus ei ole single 12V rail, vaid 4: http://www.silverstonetek.com/products/p_contents.php?pno=st85zf&area=
Decathlon on Silverstone-i single rail tooteseeria.
mul on Silverstone-i kohta oma spikker, panen selle ka siia, äkki kellelgi kasu.
Tooteseeria, 12v railide arv/nende summaarne võimsus, müra, modulaarsus, kasuteguri auhinnad.
Strider
ST350- 2x12V 250W 22dBA min
ST400- 2x12V 348w 23dBA min
ST35F- 2x12V 300W 22dBA min
ST40F- 2x12V 350W 22dBA min
ST50F- 2x12V 432W 22dBA min
ST56F- 2x12V 480W 21dBA min
ST60F- 2x12V 576W modular 18dBA min 80 Bronze
ST70F- 4x12V 600W modular 18dBA min
ST75F- 4x12V 648W modular 22dBA min
ST85F- 2x12V 768W modular 20dBA min
ST1000NV 2x12V 840W modular 22dBA min
ST1200 6x12V 1125W modular 19dBA min
Decathlon
DA650- 1x12V 648W modular 22dBA min
DA700- 1x12V 696W modular 22dBA min
DA750- 1x12V 720W modular 22dBA min
DA800- 1x12V 792W modular 22dBA min
DA1000- 1x12V 960W modular 22dBA min
DA1200- 1x12V 1080W modualr 23dBA min
ZEUS
ST56ZF- 1x12V 465W 24dBA min
ST65ZF- 4x12V 504W 29dBA min
ST75ZF- 4x12V 720W 24dBA min
ST85ZF- 4x12V 840W 24dBA min
ZU1200M- 6x12V 1180W 22dBA@300, 28@600, 40@1200W, 6/1 rail
ZM1200M- 6x12V 1140W 22dBA@300, 28@600, 40@1200W, 6/1 rail
OP
OP650- 1x12V 648W 22dBA min
OP700- 1x12V 696W 22dBA min
OP750- 1x12V 720W 22dBA min
OP800- 1x12V 792W 22dBA min
OP850- 1x12V 840W 22dBA min
OP1000-E 1x12V 960W 22dBA min
OP1200- 1x12V 1080W 23dBA min
ELEMENT
ST40EF- 2X12V 336w
ST500EF-Plus 2x12 432W
ST500EF-Plus sc 2x12V 432W scort cable edition
ST60EF- 2x12V 576W silent 80 Bronze
ST65EF- 2x12V 600W silent 80 Bronze
ST75EF- 2x12V 720W silent 80 Bronze
ST85EF- 2x12V 780W
NIGHTJAR
ST30NF 1x12V 216W fanless
ST45NF 1x12V 420W 80 Bronze
GEMINI
ST46GF 460+460W hot swap 1x12V 360W
ST55GF 550+550W hot swap 1x12V 456W |
Kui hästi läheb, saab lähiajal seda tootjat ka Eestist osta.
viimati muutis Jaan 17.02.2009 13:03:00, muudetud 1 kord |
123 |
ceemic
24/7@kalal
17.02.2009 12:08:05
| virx, kust sa muidu saaksid selle OP1000-E 2,5k eest? Saksast või Soomest?
322 |
virx
17.02.2009 15:55:22
| ceemic, Soomest.
309 |
henri200
18.02.2009 15:16:40
Toitekal on vent nohisema hakanud (Fortron 400W), ja teeb tiba rohkem lärmi kui tavaliselt. Seega tahaks selle ära vahetada, niipalju uurisin seda venti, et on kontrolleri otsas ja oli mingine 2000RPM vent.
Nüüd tekib küsimus, et on see hull kui panen näiteks S-FLEX 12000rpm asemele?
| Kommentaarid: 62 loe/lisa |
59 |
Lotharius
rallisibul
18.02.2009 15:24:47
Eks ikka oleneb sellest kui efektiivselt kumbki õhku liigutab.
117 |
Chidori
18.02.2009 15:30:31
| 12 000 rpm? wow - Uuri asja lähedamalt, tavaliselt seal 2500-3000rpm fannid ja 1200rpm S-flex ei pruugi "idle" oleksu üldse toimida madala voolu tõttu. Multimeeter oleks kah abiks.
99 |
henri200
18.02.2009 15:32:23
| Chidori kirjutas: |
| 12 000 rpm? wow - Uuri asja lähedamalt, tavaliselt seal 2500-3000rpm fannid ja 1200rpm S-flex ei pruugi "idle" oleksu üldse toimida madala voolu tõttu. Multimeeter oleks kah abiks. |
Eh, 1200rpm ikka jah, väike näpukas. Noh, s-flex-i võib ka emaplaadiga ühendada, et ta koguaeg @ 1200rpm töötaks.
59 |
Chidori
18.02.2009 15:38:35
| 1200rpm s-flex @ 1200rpm saab ilusti hakkama kui sa tapvalt suurt koormust asjale ei lükka.
99 |
tungraud
18.02.2009 15:42:17
[quote="henri200"]Toitekal on vent nohisema hakanud (Fortron 400W), ja teeb tiba rohkem lärmi kui tavaliselt. Seega tahaks selle ära vahetada, niipalju uurisin seda venti, et on kontrolleri otsas ja oli mingine 2000RPM vent.
Nüüd tekib küsimus, et on see hull kui panen näiteks S-FLEX 12000rpm asemele?[/quote]
S-flex 1200 kohta võin julgelt väita et see ei hakka seal üldse pöörlema, järgi proovitud, kuna fortron kasutab minit üliimelikku lähenemist siis on kasutusel 2k rpm vent ja 3,5v toite peal. Kui temp tõuseb siis tõuseb pinge kuskil 5v kanti. Kolmveerand ventikatest e ikäivitunud ka suurema koormusega üldse. Sai ka 12v proovitud, siis kippus ventikas lausa lendama, ja tegi metsikut lärmi (originaal vent).
Mina lahendasin probleemi, nii, et ostsin ordist AC 12025 1500rpm PWM vendi ja ühendasin prose jahutuse toitega jadamisi. ST toiteka vent töötab vastavalt prose vendi kiirusega. Kui prosel 1500rpm siis toitekal kuskil 900. Sain vaiksemaks. Ainus asi mis võib häirida, on see, et toiteka vendi pöörded kõiguvad üsna ergalt. Programme avades jne. Hind ka oluliselt odavan kui s-flexil ja ka fdb laagritega.
_________________ liquid cooled brains. red coolant....
viimati muutis tungraud 18.02.2009 15:43:23, muudetud 1 kord |
| Kommentaarid: 7 loe/lisa |
vambola
18.02.2009 16:11:26
Kui suures ulatuses Fortroni vendikontroller pinget muudab? Kui ta jõudeolekus pinge päris madalale laseb ja suurel koormusel kõrgeks, siis oleks 1600-1900rpm vent hea lahendus. Nende stardipinge on väga väike ja pöörded ka väga madalad väiksemal pingel.
1200rpm S-Flexi stardipinge on üsna kõrge, ta ei pruugi üldse käimagi hakata ja koormuse all võib 1200 rpm olla pisut vähe. See sõltub kõik muidugi konkreetse toiteploki vendikontrollerist.
Kontrolleri taha ühendamiseks kõige kindlam variant on 1900rpm S-Flex.
Kõige lihtsam on muidugi pidevalt 12v järgi panna aga imo on see ikka way liiga hullult lärmakas lahendus.
120 |
henri200
18.02.2009 16:32:33
| 1200RPM s-flex @ 12v ei tohiks olla väga lärmakas. Koormuse kohta niipalju, et mängin.
59 |
CoiL
18.02.2009 18:41:33
| tungraud kirjutas: |
| henri200 kirjutas: |
Nüüd tekib küsimus, et on see hull kui panen näiteks S-FLEX 12000rpm asemele? |
Mina lahendasin probleemi, nii, et ostsin ordist AC 12025 1500rpm PWM vendi ja ühendasin prose jahutuse toitega jadamisi. ST toiteka vent töötab vastavalt prose vendi kiirusega. Kui prosel 1500rpm siis toitekal kuskil 900. Sain vaiksemaks. Ainus asi mis võib häirida, on see, et toiteka vendi pöörded kõiguvad üsna ergalt. Programme avades jne. Hind ka oluliselt odavan kui s-flexil ja ka fdb laagritega. |
Endal oli sama pull põmst. 500W Fortron BSII-l sai vent vahetatud ja orig. vendi kohast voolu võttes ei hakanud 100rpm KAMA-flex üldse tööle.
Lahendasin sedasi, et panin lihtsalt 24/7 emaplaadi 3-pin ühendusega jooksma. Ära jahutas ilusti aga kahtlustan, et vendi eemaldamise tõttu
muutusid toiteploki skeemis mingid väärtused ning varsti andis toide otsad (samas oli suht vana ja hooratud ka teine juba).
| Kommentaarid: 95 loe/lisa |
83 |
henri200
18.02.2009 19:02:42
| Siis tuleks vast hankida mingi ~1000rpm vent ja ühendada emaplaadi 3pin-iga. Kuna praegu 1200rpm S Flex-e pole saadaval eestis, siis on mingeid häid alternatiive ka?
59 |
vambola
18.02.2009 19:09:24
| henri200, miks sa ei taha ühendada 1900rpm S-Flexi toiteka kontrolleri külge? See on parim võimalik lahendus, milleks sulle alternatiivid?
120 |
henri200
18.02.2009 19:10:31
| Töötaks see siis normaalselt, ei ei oleks idles vale kiirus jne?
59 |
vambola
18.02.2009 20:32:01
| Sa saad ta ju vajadusel panna 5-7v pealt molexist käima aga igal juhul tasub proovimist ka toiteploki külge ühendamine. Paindlikkuse tõttu ongi targem osta 1900rpm variant.
120 |
18.02.2009 21:03:18
vambola: Molex-ist 7V pinge võtmise korral võid oma toiteploki elu ohtu seada Palju õigem on sel juhul osta lähimast elektoonikapoest 8V või 9V stabilisaator (näiteks L7808 või L7809). Maksab a 10 krooni tükk ja "tuhandeid kroone" maksav toitekas töötab rõõmsalt edasi
Või siis arvutipoest spetsiaalne "pingealaldi", mis teeb 12V-st 7V.
CorsairX: See, Sinu tollane BlueStorm, võis tegelikult ka juba algusest saadik tootepraak olla. Et trafo pidas mingi aja vastu ja siis lõpuks läksid keerud lühisesse. Kas kehva laki või kehva trafo kerimise tõttu vms. Igatahes vahetatud trafoga käib see BS II täiesti rõõmsalt uuesti edasi.
211 |
vambola
18.02.2009 21:08:42
| tahanteada kirjutas: |
vambola: Molex-ist 7V pinge võtmise korral võid oma toiteploki elu ohtu seada |
Võin seada või sean? Seleta täpsemalt.
120 |
Chidori
18.02.2009 21:10:35
| 1900 on liig - ma olen BS2 sisse pannud 1600 ja 1900 rpm S-Flexe - 1600 on idles surmvait aga käib ringi - eeldaks seal 800rpm kandis. 1900rpm on aga idles juba miskine 1000rpm ja koormuse tõustes tõuseb ka kiirus.
99 |
vambola
18.02.2009 21:24:23
| Nii et S-Flex on siiski parim valik asendusvendiks igale toiteplokile. Vaikusesõpradele 1600 ja segastele 1900 8)
120 |
henri200
18.02.2009 21:26:00
Noh, eks tuleb siis 1600rpm osta .. Aga kuidas selle kontrolleriga ühendada? Joota lihtslalt vms.?
59 |
Chidori
18.02.2009 21:27:18
| +/- toite otsa ja kollane speed juhe toitest välja.... midagi keerulist seal küll ei ole.
99 |
18.02.2009 21:33:55
vambola: Mõningad jubinad võivad "vastu taevast lennata" ja siis lidud remondifirmade või garantiiremondi vahel 8) Olen ise paari, selliselt kutuks lastud toidet remontinud, seetõttu on see oht täiesti reaalselt olemas.
Näiteks AK kodulehel on ka mõned ventikatele sobivad "pingealaldid" olemas.
http://www.arvutikeskus.ee/index.php?pid=0&id=33&menyy_id=33
211 |
vambola
18.02.2009 21:40:47
Mina ei hakka kuhugi liduma, ma soovin tehnilist seletust asjale.
Ma kasutan ka selliseid asju.
Aga ikkagi - mis siis põhjustab 'vastu taevast lendamist? Seleta julgelt, ma saan aru küll.
viimati muutis vambola 18.02.2009 21:43:43, muudetud 1 kord |
120 |
Chidori
18.02.2009 21:42:28
Mul on Lanboxis BS2 koos 1900rpm fanniga - E5200+2900XT loadis ( Folding ) panid toite vuhisema päris korralikult - tagant tuli päris korraliku survega vaatamata sellele, et RPM oli vaid 1100.
Ma muudaks oma väiteid siis väheke:
1600rpm idle võiks siis olla kuskil 600rpm - 1900rpm idle kuskil 900rpm.
99 |
henri200
18.02.2009 21:43:21
Loodan, et 1600rpm jahutab piisavalt ära siis
59 |
Chidori
18.02.2009 22:14:09
no mul on LANBOX + 2900XT ja kusjuures kõik müramatistatud... aga tagant tuleb täitsa jahedat õhku mingil imelikul põhjusel toidab ilusti ära - vähemalt BS2'e sees olev Yate loon ei liiguta kohe üldse õhku... Samal rpmil selle Yate'ga ei olnud mingit õhuvoolu tunda tagant.
| Raud » Kast / Toide / Casemod » kirjutas: |
| Mis teeb toiteplokist hea toiteploki ? |
TAGAN teeb toiteplokiste hea toiteploki.
Superrock on surmvaikne - igaühele soovitaks 680w.
99 |
omgwtf
18.02.2009 22:18:09
| Kahju,et TT ei hiilga vaikusega.. Krt ainus asi mis masinas kohiseb netis istudes on just toide ja samas tundub mulle,et idle ja load heli on sama st siis koguaeg@ max rpm laksab ventikas..
137 |
Chidori
18.02.2009 22:31:16
| toughpowerite kala - peale ca 6 kuud läheb asi lolliks ja laseb aint 100% peal.
99 |
omgwtf
18.02.2009 22:44:24
Kusjuures jah alguses oli hiirvaikne.. Hetkel ka seda tegelt ei saa mingiks müraks nimetada,kuid kui telekas kinni ja vaikselt istud netsi siis on kohin kuulda..
Tuuniks vähe ventikat a mingi loll kleeps ka peal mille lõhkudes kaob vist garantii ja kuskil jäi silma,et suht lammutama peab,et saada lahti asja.. 700W Fortronil vahetasin ventika ära ja oli selline silent pill,et jube
137 |
elukaz
19.02.2009 00:03:13
| vambola kirjutas: |
Aga ikkagi - mis siis põhjustab 'vastu taevast lendamist? Seleta julgelt, ma saan aru küll. |
Toitekaga vast ei juhtu midagi, küll aga kõigi teiste komponentidega sest kui põlve otsas ühendus teha või juhtub vendiga midagi et lühisesse läheb siis on +5 ja +12 railid koos ehk siis on +12 kerge sinna jooksma kuhu 5 volti on ette nähtud.
tahanteada oskab kindlasti täpsemalt öelda mis toitekates läbi läheb sest ta on neid ju mitmeid remontinud mis selle pärast otsad on andnud.
158 |
vambola
19.02.2009 00:13:24
elukaz, see on naeruväärne selgitus. Mis takistab venti 12v ahelat lühistamast?
Ja ma tahaks teada, mis nipiga saab keegi aru, et toiteka on surmanud just 12v ja 5v ahela vahele asetet vent?
Ma saan aru, kui räägitakse 5v ahela ülekoormamisest. 5v ahelat ei koorma mõne vendiga üle.
120 |
elukaz
19.02.2009 00:37:04
| vambola kirjutas: |
Paistab et ei saanud aru. 12V maha lühistamisel saab kannatada ainult lühise tekitaja ehk mingi juhe ja toitekal läheb kaitse peale. Railide kokku laskmisel peab peab 5V rail piisavalt voolu tarbima enne et kaitse rakenduks ja see vool tekib neist komponentidest mis muidu 5V peal käivad.
Nippidest räägib tahanteada, tal kombeks igast paska kokku puhuda.
viimati muutis elukaz 19.02.2009 00:38:12, muudetud 1 kord |
158 |
WäntWõll
make.believe
19.02.2009 00:37:20
vambola, Jutt jummala õige
Suht segane ja isegi nati jabur jutt käib siin
300 |
vambola
19.02.2009 00:42:00
| elukaz kirjutas: |
Siin võib isegi iva sees olla. Tahaks mõnda moodsa toiteploki skeemi näha, pole ühtegi uurinud.
120 |
elukaz
19.02.2009 00:46:07
Selles mõttes et kannatavad need jupid mis asuvad teisel pool toidet nagu kõvakettad ja emaplaat vms.
158 |
vambola
19.02.2009 00:49:26
| No see kehtib juhul, kui õnnestub tõesti 12v ja 5v ära lühistada. Kui seda ei tee, siis ei ole ju mingit probleemi.
120 |
elukaz
19.02.2009 00:56:22
See ongi see oht kui vent nende kahe vahele ühendada nii et juhtmed ripendavad.
Mitte et ma ise nii ei teeks
158 |
wrx123
19.02.2009 14:59:19
kellelgi on ideid?
| Kommentaarid: 17 loe/lisa |
16 |
company
19.02.2009 16:17:37
wrx123 Tundub, et mingi sümboolne erinevus siiski on nendel plokkidel. Vaata täieliku speci, sealt näed.
ATX-350PNF
ATX-350PNR
Jaan
19.02.2009 16:44:52
350PNF- 3,3V-22A, 5V-21A, 12V-18+16A (max 300W)
350PNR- 3,3V-20A, 5V-16A. 12V-10+13A (max 276W)
võimalik, et pole õige info, pärit piltidelt:
123 |
omgwtf
19.02.2009 16:46:56
Kiiret kinnitust oleks hädasti vaja AHV idelt FSP250-60GEN= mingi imelik pisike junn mida ei asenda tavalise 400W Fortroniga?
137 |
Jaan
19.02.2009 18:03:22
| omgwtf kirjutas: |
Kiiret kinnitust oleks hädasti vaja AHV idelt FSP250-60GEN= mingi imelik pisike junn mida ei asenda tavalise 400W Fortroniga?  |
Kui mõõtmetelt mahub, siis miks mitte.
Ma olen vist näinud sellist mingis HP kastis..
123 |
Anti
20.02.2009 07:53:59
Ei hakka uut teemat tegema, aga vaja oleks ära toita komplekt LP SLI-D NF4, opteron x2, 4x1GB, 8800GTS, 2x120GB ram, optiline. Võibolla natuke vahepeal sussitan väikest overclocki ka, aga ei midagi ekstreemset.
Milline toide ~900-1000kr eest? Ise vaatasin arvutikeskusest Fortron Bluestorm II 500W. Kuidas selline on?
240 |
AJ
| Kommentaarid: 37 loe/lisa |
36 |
company
20.02.2009 09:54:06
Kui kellelgi juhtumisi mõni tuttav Iirimaal kalkuneid kitkumas on, siis sealtpoolt on saadaval päris heade hindadega vidinaid PC'le.
Näiteks Corsair Powersupply 1000W Black 3208.- (Iirimaal). Lätlased pakuvad sama toodet 2857.-
viimati muutis company 20.02.2009 10:37:27, muudetud 1 kord |
One
20.02.2009 10:27:56
link :: koduleht
Kuulge, rääkige kas Xilence 580W toitekas on normaalne?
Raskuse poolest on sisu küll ja amprid ka nagu normaalsed.
Miinus tundub olevat sleevita juhtmed.
Vent peaks vaikne olema, teoorias võimsust omajagu.
On too 500W Bluestormiga võrreldav?
Xilence RedWing tootesari vast täissaast olla ei tohiks.
On kellelgi kogemusi?
728 |
20.02.2009 11:07:22
| company kirjutas: |
Näiteks Corsair Powersupply 1000W Black 3208.- (Iirimaal). Lätlased pakuvad sama toodet 2857.-  |
Misasi see Black on?.Mudel HX1000?.Muid 1kW Corsairil hetkel nagu pole.Ja on see lõunanaabrite 2,8k ka reaalselt saada?
| Kommentaarid: 92 loe/lisa |
