Dominus
25.01.2009 20:14:36
LightsabeR, sul on õigus. Carebeari tavaline päev - farmib terve päev oma ilusa armoriga ja mõni vend tuleb koksab maha.
I started the game and equipped my leafblade.
Took the 2 goblin quests and I was off.
Found a goblin camp, and also a guy with half HP with some armor i wanted.
Killed him, took his stuff, killed the goblin, took his stuff, and ran off laughing.
Waited for alignment to go away and then went back to town to bank.
Bank is great. You can fit so much stuff in there. Really great UI all around.
Really customizable things. And the encumbrance system is not annoying at all.
You can carry a lot of things. I had like 9 bows 10 swords and a ton more armor and
random food items. |
Mõnus imo
76 |
LightsabeR
| Kommentaarid: 14 loe/lisa |
14 |
Dominus
26.01.2009 02:08:06
No ta oli ju ka "encumbered" olekus. Ehk paksu valmis. Üritab joosta/sprintida...tulutult...saab owni
update @ http://betaleaks.blogspot.com/
During my playtime, I figured out how to get a mount.You need to get Steedgrass, which is a herb found from herb gathering. Once you have the Steedgrass, you need to buy the Taming skill and a taming whistle which are at NPCs inside the cities. So after I figured out all that I was naturally excited to tell someone I was grouped with that I found Steedgrass. He gave me a congratulations by killing me with a bow after I was done fighting a goblin shaman. Cool kid, huh? -_-
76 |
Timberg
ööKARU
26.01.2009 16:39:23
| Nu.. kes betas?
272 |
LightsabeR
26.01.2009 16:59:50
| Timberg kirjutas: |
| Nu.. kes betas? |
Ma kardan, et võimalus suht väike, et mõni HV'lane betas on praegu.
Beta leak quote: "I noticed about 250-300 people online"
14 |
Dominus
76 |
Timberg
ööKARU
28.01.2009 12:15:48
Wowis sellist pulli ei saanud teha, et keset combatit 1vs1 lähed mobi taha ja lööd noa selga (va juhul kui sa teda ära ei CC).
Darkfallis saab? Üks youtube video nagu jättis veidi sellise mulje.. samas..
272 |
LightsabeR
28.01.2009 14:00:20
| Timberg kirjutas: |
Darkfallis saab? Üks youtube video nagu jättis veidi sellise mulje.. samas.. |
Ei saa nagu hästi aru mida sa silmas pead. Miks ei peaks saama mobile selja taha minna? ummm...
Aga neid klippe oli küll piin vaadata. Kurat ega YouTube'l asjata HQ võimalus juurde ei lisatud.
14 |
ottf
28.01.2009 14:33:33
krt see gameplay beta järgi tundub küll ikka mega sitt....
Pikemalt sellise puise tatsamisega mängida raudselt ei kannata, kui siis ainult proovida ehk....
| Kommentaarid: 6 loe/lisa |
Timberg
ööKARU
28.01.2009 14:36:37
| LightsabeR kirjutas: |
| Ei saa nagu hästi aru mida sa silmas pead. Miks ei peaks saama mobile selja taha minna? ummm... |
Mm.. see.. mm.. kurat keeruline. Mäletad kui me deathmatchi seal tabasalus hella hundi kokkutulekul tegime? Ma olin hästi kiire ja läksin keset matchi su selja taha ning suskasin sulle tagant .P
Tegelikult.. ehe.. ehee.. Oi. Olid ajad - mälestused..
Tegelikult pean silmas seda, et wowis ükskõik kui vinge rogue sa ka ei ole, ei ole vahet kas hüppad või kargad, sest mobile sa backstabi keset combatit teha ei saa, sest ta vaatab sulle alati otsa. Ehk siis.. keerab ennast alati tegelase poole.
Mobi saab tagant rünnata siis kui:
1. Lähened talle stealthist
2. Stunnid/crowdcontrolid ta ära ja lähed selja taga
3. Mob keskendub teise mängija peksmisele.. ja lähed selja taga
Mida mina tahan.. oleks selline combat, kus mobi reageerimisaeg ja reaktsioonid ei ole alati "üliinimlikud". FPS'is võib hea mängija korraga mitu keskpärast mängijat lähivõitluses tappa, kui jookseb nende vaateväljast välja. Vastased küll tulistavad, aga mööda. Samal ajal äsad ühele noaga, teisele hs ja kolmandale lased mp5 pool salve lihtsalt keresse :P
Tahan mobidega sama teha, mida saan mängijatega COD4 mitmikmängus teha. Tahan teatud situatsioonides või "Sprinti" kasutades omada võimet manööverdada end lollidest NPC'dest paremini ja omada neid löökide/aimiga ja nende löökide või laskude eest põiklemisega, mitte sellega, et mul on neist 400% kõvem armor, rohkem elusid või suurema dpsiga relv.
272 |
Dominus
28.01.2009 15:09:04
| ottf kirjutas: |
Pikemalt sellise puise tatsamisega mängida raudselt ei kannata, kui siis ainult proovida ehk.... |
Sa pead silmas mida täpsemalt? Gameplayd või animatsioone/graafikat?
| Aga neid klippe oli küll piin vaadata. Kurat ega YouTube'l asjata HQ võimalus juurde ei lisatud. |
HQ täitsa olemas kõigil videodel ju.
Videod muideks lindistatud 800x600 settingutel.
76 |
Dominus
76 |
Scart
28.01.2009 15:33:46
Issand jumal.
Kui see ongi see mighty Darkfail, siis.... 10 aastat vanad käkerdised oma arhailise 3d pildiga on paremad, kui see.
101 |
LightsabeR
28.01.2009 16:11:42
Hehe, kõik kurdavad ikka peamiselt graafika pärast. Ma usun, et kui ikka enda arvuti ekraanil korraliku resoga asja tööle paned, siis näeb ikka jupi maad parem välja, kui mingites low quality juutuubi videotes. Kuid tõepoolest, ega need graafika ja animatsioonid just kõige silmatorkavamad pole. Kuid tuleb meeles pidada, et mängus on ikka põhi rõhk ju gameplay'l, eriti DF'i puhul. Mind see graafika ja animatsioonid eriti murelikuks ei tee, neid saab alati uuendada/parandada, pigem tekitab muret mõnede beta leakerite jutt, kus räägivad, et melee combat on mingi mõttetu "circle jerk".
Eks näeb... kuu aega veel neil võimalik nokkida selle kallal, ehk beta lõpu poole on asjad paremad. Pealegi... neil on alati võimalik releasi veel edasi lükata, põhiline, et mingit lombakat mängu välja ei lase.
Enda arvates ei tasuks Aventurine poiste vastu eriti kriitiline olla. Tüübid üritavad teha seamless worldis sandbox mängu, millel on lisaks kõigele ka real time combat. See on ikka suht ambitsioonikas ettevõtmine, eriti veel nii pisikese firma jaoks. Tuleb mis sealt lõpuks tuleb, kuid mina peale DF'i ja Mortal Online'i ei näe ühtegi MMO'd tulemas, mis mind vähemalgi määral huvitaks. Praegu väljas olevatest themepark käkkidest ei taha üldse mõelda...
14 |
Dominus
28.01.2009 16:33:51
Tahtsin just ka paar sõna sekka öelda vastuseks Scart-ile aga LightsabeR tegi seda minu eest
Kui sulle on graafika kõige tähtsam siis soovitan mõne muu mängu poole vaadata. Hetkel on Darkfall siiski betas ning teda pidevalt uuendatakse. Peamine, et mäng igaühel stabiilselt jookseks siis saab hiljem graafikat, animatsioone jms. kohendada.
Arvestades, et Aventurines on töötajaid ~20? ja eelarve pisike siis saavad nad päris hästi hakkama. Age of Conan oli hype vaata kui palju, raha pandi alla ka mõnusalt. Lõpptulemus aga ...
Ise hoidun ka WoW & Clones tüüpi mängudest eemale. Ootan parem Mortal Online ja Darkfalli release ära.
76 |
Scart
28.01.2009 16:37:42
| Dominus kirjutas: |
Kui sulle on graafika kõige tähtsam siis soovitan mõne muu mängu poole vaadata. Hetkel on Darkfall siiski betas ning teda pidevalt uuendatakse. Peamine, et mäng igaühel stabiilselt jookseks siis saab hiljem graafikat, animatsioone jms. kohendada. |
Ah, et mis see graafika siia puutub? Kollide mudelid, animatsioonid, põhimõtteliselt kogu see värk meenutas mulle Hexenit või Ravenit ja see ei säti seda MMOd just eriti positiivsesse valgusesse. Mis kurat selle sihtimise ja mobide ringitaidlemisega oli? Puuraiumine on Runescapes edumeelsem, kui Darkfallis. Kurb. Kaamera kõrgus oli sellise FoVi jaoks rängalt vale ja jättis mulje, nagu jookseks hiiglaste maailmas ringi päkapikud jne jne jne.
Ja oh seda irooniat, kui öeldakse: "asi alles beetas". Sama öeldi ka AoC kohta ja mäletame tõesti, kuidas see lõpuks MMOde ajaloo suurima naljana välja tuli. Kui mäng ei ole eelneva eiteamitmeaastaga suutnud sinnamaale jõuda, et see ka midagi väärt oleks, ei jõua ta sinna kohe kindlasti viimase kolme nädalaga. Mida varem vännpoid sellest aru saavad, seda vähem AoC taolisi fekaalihunnikuid maailma satub.
viimati muutis Scart 28.01.2009 16:39:23, muudetud 1 kord |
101 |
ottf
28.01.2009 16:45:05
Dominus
Gameplay on feeling kuidas char sul käitub, kuidas kaamera pöörab ja kõik see...
Graafika on see kui täpselt on model välja joonistatud, kui hea on selle animatsioon, textuurid ja 100 muud asja...
Antud juhul on mõlemad sitad kuubis...
spellcasting + woodchop video on ikka ülim jura.
oota ma lisan su lausele...
Ja oh seda irooniat, kui öeldakse: "asi alles beetas". Sama öeldi ka WAR-i kohta ja mäletame tõesti, kuidas see lõpuks MMOde ajaloo suurima järgmise naljana välja tuli
ja veel
võiks sama wotlki kohta öelda.. olgem ausad suht poolik kuigi paremini välja kukkund kui ülal mainitud asjad.
Siis öeldakse, et "ma kah hoidun wowi kloonidest" no tegelt?
WoW-i kloon saaks tõenäoliselt parimaks mänguks ja ainult sellel oleks midagi vastu panna võibolla....
wowi kloon: rohkem sandboxi, pvp loot, rohkem riski, rohkem player driven economyt, parem crafting, marketing, community, guildid, allianced...
võta tee, idee on olemas ja kuhu triivida aga siiani teevad kõik põlveotsas sitta valmis
expansionit näol võib seda contenti sitaks juurde toppida, raide, asju, tilulilu... võiks kõigepealt põhi asjaga hakkama saada.
kui raam on jura siis ei ole ka loota, et tulevikus patchidega asi paremaks läheb... pigem patchidega on putitatud vana sodi.
ainult blizzard on reliisind patche mis annavad isegi täiesti uut contenti juurde, niisama.....
imo.
LightsabeR
28.01.2009 16:51:33
| ottf kirjutas: |
wowi kloon: rohkem sandboxi, pvp loot, rohkem riski, rohkem player driven economyt, parem crafting, marketing, community, guildid, allianced... |
Sa räägid ju endale vastu. Kust august on tegemist WoW'i klooniga, kui sa kõik need nimetatud asjad sinna juurde topid? Mis sa pead silmas ainult WoW'i graafikat või?
Kuid Scart, ottf, teil on muidugi õigus, "still in beta" pole just kõige parem vabandus, kuid vähemalt annab aega asja natuke lihvida. Eks näeb, mis saab.
Point on selles, et AoC failis, kuna tal polnud midagi mängijale pakkuda peale hea graafika. WAR... no WAR'i betat ma natuke näppisin, kuid mind jättis see mäng väga külmaks.
Darkfalli puhul on aga tegemist sandbox mänguga, kus sisuliselt visatakse mängijad serverisse ja siis lastakse neil omavahel maid jagada ja ise mäng huvitavaks teha. Selles kogu sandboxi mõte ongi - player driven content!
Ehk siis kui nad suudavad põhi funktsioonid tööle saada, siis on DF sandbox fännide jaoks juba edukas mäng.
14 |
dstar
28.01.2009 16:55:55
Ei tea mängust eriti midagi, aga need YT videod on ikka päris jubedad. 3rd person kaamera on masendav - tegelane oleks nagu ekraani alumisse serva kinni liimitud, kaamera pööramine Doom stiilis aastast 1993. Graafika on üks pruun soga, animatsioonid kanged ja puised, menüüd koledad. Ja sellise jama eest nõutakse veel raha? WTF!?
Aga siin lohutuseks ühe (pimeda?) YT kommija arvamus:
"this is the first leak that has actually got me really excited about this game. i can now see that it has true potential to hook me as a subscriber for a while"
Dominus
28.01.2009 16:58:23
Heh. Eriti hägune silmanägemine sul kui võrdled Hexenit Darkfalliga, Scart.
Sihtimine on FPS-i laadne, mitte näiteks nagu wowis kus sa klõpsad hiirega vaenlasel ja vajutad nuppe 1-9 kuni üks teist kutupiilu on. Ma saan aru, et kogu see zig-zag liikumine ja sihtimine ajab sind segadusse.
Pealegi mobid ei seisa paigal nagu lambad oodates oma elupäevade lõppu. Nad jooksevad ringi, kutsuvad teisi mobe appi ja segavad su keskendumist.
Ma ei saa aru miks ainult wow/hammerz mängijad siin trollivad?
UO, Shadowbane, Eve jt. mängude austajad võiks ka sõna võtta.
76 |
Scart
28.01.2009 16:59:27
| "still in beta" pole just kõige parem vabandus, kuid vähemalt annab aega asja natuke lihvida. Eks näeb, mis saab. |
Ootame ja vaatame, ikka. Lihtsalt, see video tekitas minus muidu väga positiivse mängu kohta väga negatiivse mulje. Olen ikka läbi lapanud screenshotid ja muu, mis selle mängu kohta väljas aga sealt vaatas vastu täiesti Quake 2 mootoril pruun soga, mitte Darkfall, mida olen enne näinud. Loodetavasti oli tegu mingisuguse pooliku asjaga, sest kui see oligi Darkfall- on need 20 venda küll päris mitu aastat oma elust raisanud mitte millegi peale.
101 |
Dominus
28.01.2009 17:05:38
Ärge võrrelge reaalset ingame mängu YT videodega.
Nendel klippidel on aluseks 800x600 resol lindistatud medium või low settings graafika.
Kodulehe screenshotid on see õige graafika mida sa mängus näed.
76 |
Marduuhin
108 |
tomps01
28.01.2009 18:38:08
| Dominus kirjutas: |
UO, Shadowbane, Eve jt. mängude austajad võiks ka sõna võtta. |
Ma olen solidari austaja, nii et täidan su soovi ja võtan sõna.
DFO peaks tulema hardcore FFA PVP ja full looti sisaldav revulutsiooniline ning eriline MMORPG.
| Dominus kirjutas: |
Mõnus imo  |
Lahe... mängus on goblinid ja isegi 2 goblin questi (Took the 2 goblin quests). Pank rokib, sinna saab palju-palju asju panna ja UI on sigahea. Inventory rokib ka, sest sinna saab ka palju-palju-palju asju panna. Mõnna, täpselt need asjad, mis sõnade "revulutsiooniline-eriline massive FFA PvP" kuuldes esimesena mõttesse tulevad.
... ehk lühidalt mida siin trollida on?
Mind isiklikult huvitaks DFO ja EVE võrdlus, kuid esimeses on hetkel paarsada tüüpi, kes on saanud ainult paar päeva mängu uurida ning teises künmned tuhanded, kes on aastaid mänginud.
Ja lõpetaks küsimusega - mitu rewied/youtubi videot on vaja, et DFO launch 1 minuti võrra varem saabuks?
Mikiki
28.01.2009 19:51:17
Hehee Dominus ära üritagi Scart'i ümber veenda. Ta trollib kõike, kasvõi oma lemmikute lemmikut WoW'i.
Muidu tahaks juba näha/proovida, kas see PvP tõesti siis vajab ka muud oskust kui arvutamist mitme sekundi tagant, mis spelli/skilli klõpsida...Praegu see ringiratast ümber vastase jooksmine tundus küll mõttetu.
Eks näeb mis tuleb. Kui nad suudaksid ainult oma PvP lubadused täita oleks asi korras ja rahvas saaks gankida ja teisi taguda kuni vajadus mõne PvE orientatsiooniga mängu järgi jälle tekib.
| Kommentaarid: 9 loe/lisa |
9 |
