uus teema   vasta Tarkvara »  Arvutimängude foorum »  Far Cry 2 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 41, 42, 43 ... 46, 47, 48  järgmine
nolifer
sõnum 18.12.2008 21:50:56 vasta tsitaadiga
Far Cry®2 v1.02 Update
If you had problems applying the 1st patch (1.01), please apply this cumulative patch.
STEAM users: Please wait until the patch is available through Steam.
General changes
- Added triple-header support to the game.
- A widescreen option has been added and can be enabled only in single player mode.
Multiplayer changes
- Fixed the direct join by IP functionality.
- Added the minimum number of players in the host options.
- Added the player's death count in the scoreboard.
- The host can now set the respawn time in Advanced options, for player matches only.
- The host can now set the starting rank of all players in the match, in Advanced options, for player matches only.
- The VIP is shown on the scoreboard, for your team only.
- The scoreboard is now displayed by the highest XP points to the lowest.
- The ping system has been improved to display a more accurate result.
- It is now possible to conduct a multiplayer match search from the map leader board.
- Fixed certain characters that weren't allowed during profile creation (- . _ ,)
- It is now possible to add a clan name to the player¦s name through the use_clan_tag console command.
- Players can now filter the server list using different parameters (ping, PunkBuster, game mode, dedicated, server name, number of players, ranked/unranked).
- The IEDs are now destructible by shooting on them or throwing a grenade close to them.
- In ranked matches, players can now play more than one match on the same host.
- Added quickmatch to the map download screen. It will matchmake on the selected map.
- The distance from a wounded teammate is now displayed.
- The host can now select a VIP before starting the match.
- It is now possible to use the use_clan_tag command.
- Fixed a bug with clan tag and multiple clients
- Multiplayer: Minimum players numbers default setting is now 4
- Fixed some unrepresentative text in the scoreboard.
- Added text to display distance when teamate is down
- Fix a freeze issue in match list if the player press ESC after trying to enter in a match with a password.
http://www.gamershell.com/download_37208.shtml
Marduuhin
Marduuhin
sõnum 19.12.2008 01:20:36 vasta tsitaadiga
nolifer kirjutas:
:o Multit mängitaksegi tavaliselt ainult 4:3 ekraanidega!??
Eesti õigekeelsussõnaraamat ÕS 2018
Kommentaarid: 128 loe/lisa Kasutajad arvavad:  :: 1 :: 2 :: 108
MarekSäde
sõnum 19.12.2008 10:20:31 vasta tsitaadiga
Eks ta võrdsuse huvides on, laiekraan annab ikka eelise.
Kommentaarid: 68 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 66
sõnum 19.12.2008 11:20:44 vasta tsitaadiga
Helbeke
Helbeke
sõnum 19.12.2008 19:32:58 vasta tsitaadiga
see nn laiekraani tugi on teil "kalasilmapilguga" vaatamine? öäk :=
i like my sugar with coffe and cream
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 13
sõnum 19.12.2008 21:43:50 vasta tsitaadiga
Helbeke kirjutas:
Helbeke
Helbeke
sõnum 19.12.2008 21:50:57 vasta tsitaadiga
mingi komanda partei paik liikus ka varem. sai kohe kinga. mäng on ise on üldse tüütult igav - pole viitsinud juba kuu (vist) 50% kaugemale mängida.
nolifer
sõnum 20.12.2008 04:33:15 vasta tsitaadiga
Helbeke kirjutas:
sa nii asjapulk ma vaatan, tegelikult sp on vahe küll, kui enne oli pilt suht venitatud, nüüd harjumatu mängida, pilt on ikka korralikult kokku surutud thumbs_up.gif
Aah
Aah
sõnum 21.12.2008 12:07:40 vasta tsitaadiga
Nii, uuendused peal + need lisa missioonid. Alustasin nüüd mängu otsast peale. Laiekraan toimib väga hästi (y) , näeb rohkem kui autoga sõidad. Pilt korralik. Paistab et enam ei ole seda tobedat spawnimist. Peksin KP laiali ja läksin eemale asuvasse majja magama. Hommikul sõitsin sealt KPst mööda , kõik vennikesed vedelesid seal endistviisi.Pikapeale peaksid nad tagasi tulema? Kui ennem sai koguda jackal tape siis nüüd on olemas ka predecessor taped. Objective värvidele lisandus uus värv , valge. See on vist lisamissiooni teema. Ühesõnaga asi on poole mängitavam kui enne.
Helbeke kirjutas:
Mis see on mingi kantpea (4:3) kibe jutt vä?
Jaan700
sõnum 22.12.2008 18:44:51 vasta tsitaadiga
Kas keegi läbi Hamachi on ka asja juba proovinud icon_razz.gif ?
Leinö
Leinö
sõnum 23.12.2008 15:59:46 vasta tsitaadiga
kaspir
kaspir
sõnum 24.12.2008 12:27:14 vasta tsitaadiga
Kas keegi viitsiks mingi save'i üles visata, kus on teisest mäpist mingi esimesed missioonid tehtud? Formatiga unustasin save'i teha.
š
Kommentaarid: 15 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 13
G80
G80
sõnum 24.12.2008 12:28:20 vasta tsitaadiga
tomorrow kirjutas:
See on küll fail, kui laiekraani tuge ei ole mängus kohe olemas imo. icon_rolleyes.gif
Ära siia kliki
Kommentaarid: 256 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 210
sõnum 24.12.2008 18:30:30 vasta tsitaadiga
G80 kirjutas:
tomorrow kirjutas:
Eriti veel sellises A kategooria mängus mida mõned ikka ootasid icon_neutral.gif
Erx15
Erx15
sõnum 27.12.2008 23:28:20 vasta tsitaadiga
Sain ka siis mängu, ja üllatas, kui suur junnimine selle mp-ga ikka on.
Vaja on kasutajat ja mingit x koodi.
Kustkohast ma selle koodi saan?
Heineken
sõnum 28.12.2008 00:28:33 vasta tsitaadiga
Kas seal mitte serial key'd vaja ei ole ? Selle leiad plaadikarbi küljest . Kui pira on , siis ära hakka lolle küsimusi küsima thumbs_up.gif .
Erx15
Erx15
sõnum 28.12.2008 00:45:34 vasta tsitaadiga
Ofkoors ei ole pira.
miks seda seriali 2 korda on vaja?
km2000
sõnum 28.12.2008 23:51:10 vasta tsitaadiga
kuidas ma selle teemanid kohvri üles leian, vahepeal jääb roheline seisma küll majas sees, aga tolku sellest ei ole.
Kommentaarid: 33 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 29
Evil14
Evil14
sõnum 28.12.2008 23:55:08 vasta tsitaadiga
km2000, igale poole tuleb vaadata ja mingi kummalise heli järgi leiab üles thumbs_up.gif
Kommentaarid: 229 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 200
omgwtf
omgwtf
sõnum 29.12.2008 00:31:53 vasta tsitaadiga
softis
softis
sõnum 29.12.2008 00:45:51 vasta tsitaadiga
Üldjuhul polegi lihtsalt kuskil nähtaval kohal ju... Kui majapeal jääb põlema tuluke, siis on tavaliselt mingis laudadega kinnilöödud ukse taga või siis kuskil katusel.
sõnum 29.12.2008 05:27:30 vasta tsitaadiga
Mängisin veidi Windows 7 all FC2 ja tundus sujuvam kui Vista all.Huvitav...
soodent
sõnum 02.01.2009 23:39:48 vasta tsitaadiga
Vista all sli kaartidega on keegi normaalse fps ka kätte saanud?Isegi ilma aa imeb täiega.Paistab ülemaailmne probleem olema dx10 sli incompatibility far cry 2 all.
Kommentaarid: 822 loe/lisa Kasutajad arvavad:  :: 19 :: 6 :: 564
xxlmaster
xxlmaster
sõnum 03.01.2009 01:57:42 vasta tsitaadiga
soodent kirjutas:
Palju see FPS sul siis on?
Endal pole pätse ega midagi, kõik põhjas ja mingi 50 stabiilselt. Kui väga räigeks lahinguks läheb siis langeb 30 peale.
sõnum 03.01.2009 02:54:57 vasta tsitaadiga
soodent kirjutas:
Miks sa DX10 all jooksutad?.Mul DX9 all SLI kaartidega küll parem fps jah icon_rolleyes.gif
Leinö
Leinö
sõnum 03.01.2009 13:38:06 vasta tsitaadiga
Erx15 kirjutas:
Vast ikka 1 kord. Installides ju key´d ei küsi... MP minnes nõuab seda.
soodent
sõnum 03.01.2009 14:47:14 vasta tsitaadiga
Dx10 all 9800gx2 on benchmark very high 1680x1050 keskmine fps kusagil 10-15.Dx9 samas üle 50 fps.AA juurde pannes tuleb kohe räme kukkumine alates 4xAA.
Far Cry 2 on nvidia sli antireklaam.Kusjuures kõiksugu foorumites seda teemat arutatakse ja xp kasutajad pole võimelised sellest aru saama.
Ei eelda ka siin dx9 kasutajate poolt mõistmist.Arutusel oli ikka nvidia sli mitte ati cf.
omgwtf
omgwtf
sõnum 03.01.2009 14:49:45 vasta tsitaadiga
soodent, Far cry2 on VAID 9800GX2 antireklaam icon_idea.gif Selle kaardiga on olnud Far crys probleeme esimesest päevast kui mäng väljus. Muud SLI lahendused toimivad ideaalselt igas poosis thumbs_up.gif Isegi järgmine Nvidia vahvel ragistab mõnuga seda mängu thumbs_up.gif
soodent
sõnum 03.01.2009 14:55:49 vasta tsitaadiga
Ei tööta nad päris ideaalselt midagi- AA peale pannes ja dx10 tuleb räme pidur ka teiste sli kaartidega.
See 9800gx2 dx10 suremine on muidugi eriti dramaatiline.Ei saagi aru kes süüdi- kas ubisft või nvidia.
omgwtf
omgwtf
sõnum 03.01.2009 15:00:14 vasta tsitaadiga
http://guru3d.com/article/geforce-gtx-295-preview/7 Nvidia tulevane vahvel ragistab küll lõpuni korralikult kuniks lõppeb mälu otsa resolutsiooni tõttu thumbs_up.gif
GTX280 SLI toimib ka kenasti thumbs_up.gif Viga puhtatl selles vanas 9800GX2 keegi ei viitsi tegeleda nende drivudega enam mis sellele kaardile sobiks jne.. Unustatud asi icon_cry.gif
soodent
sõnum 03.01.2009 15:31:32 vasta tsitaadiga
Ma ei saa nüüd aru- kui me räägime 9800gx2 ja sli omadustest siis on võrdlus ikka 8800 ja 9800 seeria sli-ga.Mida udutad...
HV all mingit arukust oodata ikka mõttetu.Masendav tase.Seal võrdluses pole ultra high.
omgwtf
omgwtf
sõnum 03.01.2009 15:45:47 vasta tsitaadiga
Masendav on see,et 9800GX2 ei saa far cry 2`ga hakkama ja sa nimetad kogu nvidia SLId siin mängus suureks FAILiks ja ootad vastu mingit arukust..
soodent
sõnum 03.01.2009 15:54:03 vasta tsitaadiga
8800, 9800 sli ja 9800gx2 on kõik hädas dx10 all ja eriti aa kasutusel kui sa ikka ei mõista.
Su 295 gtx oli siis mingi mõistlik vastus.Mida sa tõestad??Võrdle sama ajastu asju ja loe foorumeid.
Klassikaline eesti foorumi kasutaja- tahaks hirmsalt "ära panna" ja kui ei leia midagi objektiivset, siis mõtleb välja.
omgwtf
omgwtf
sõnum 03.01.2009 16:01:45 vasta tsitaadiga
soodent kirjutas:
Ei viitsi mingit "ära panemist" siin mängida icon_lol.gif Ise sa ei oska ennast väljendada
Mina tõin näited kus SLI on väga edukas ja toimiv icon_rolleyes.gif See kui vanakooli tehikal ei tööta SLI on teine asi.
soodent
sõnum 03.01.2009 16:18:50 vasta tsitaadiga
Tõid näiteid- mina nägin sli su lingil vaid 295 gtx ja high quality....Dx9 peal on 9800gx2 täitsa norm.Kõva vanakool- 6 kuud tootmises olnud kaart...
Mercury
sõnum 03.01.2009 16:21:02 vasta tsitaadiga
Vabandust, aga pole viitsimist 85 lehte läbi vaadata.
Kuidas saab mängus FPS vaadata?
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 60
omgwtf
omgwtf
sõnum 03.01.2009 16:23:29 vasta tsitaadiga
Veebruar või märts 2008 tuli välja see "6 kuud" vana kaart
xxlmaster
xxlmaster
sõnum 03.01.2009 17:41:09 vasta tsitaadiga
Mercury kirjutas:
sa ei peagi viimaseid lehti läbi lappama. Selleks on fraps et näha FPS-i endal kõik põhjas ja päeva 50+ öösel 80+ hevi.gif
TruePlaya
TruePlaya
sõnum 03.01.2009 21:33:45 vasta tsitaadiga
Eeee pole ammu seda teemat siin lugenud on mingi patch ka väljas juba? icon_rolleyes.gif
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 27
WäntWõll
make.believe
WäntWõll
sõnum 03.01.2009 21:49:26 vasta tsitaadiga
xxlmaster
xxlmaster
sõnum 03.01.2009 22:00:29 vasta tsitaadiga
TruePlaya kirjutas:
http://www.fileshack.com/file.x/13229/Far+Cry+2+Retail+1.01+Patch
nolifer
sõnum 03.01.2009 22:09:07 vasta tsitaadiga
xxlmaster kirjutas:
TruePlaya kirjutas:
1.02 samuti väljas, soojalt soovitatav mp jaoks+laiekraantugi
xxlmaster
xxlmaster
sõnum 03.01.2009 22:22:32 vasta tsitaadiga
nolifer kirjutas:
xxlmaster kirjutas:
TruePlaya kirjutas:
Leinö
Leinö
sõnum 03.01.2009 22:27:07 vasta tsitaadiga
xxlmaster kirjutas:
Mercury kirjutas:
Konsool lahti ja /drawFPS 1 ja näed oma FPS.
Mercury
sõnum 03.01.2009 23:55:14 vasta tsitaadiga
amachie kirjutas:
xxlmaster kirjutas:
Mercury kirjutas:
Heineken
sõnum 04.01.2009 00:26:40 vasta tsitaadiga
soodent, tolle kaardi 512MB jääb kah omajagu jalgu . Mäletan kunagi oli mingi revüü kus võrreldi HD 4870 512MB ja 1GB versioone ja 1GB peal jooksis see tunduvalt paremini . Kuid kui DX10 ei taha kuidagi joosta , miks mitte lihtsalt DX9 peale minna . Mis resolutsioonist üldse jutt käib ?
xxlmaster
xxlmaster
sõnum 04.01.2009 00:28:18 vasta tsitaadiga
Heineken kirjutas:
Proovisin ka korra DX9 sain u 15+
Heineken
sõnum 04.01.2009 01:26:37 vasta tsitaadiga
15FPS perfi juurde ? Normaalne icon_lol.gif . Ja mul sellega seoses tuleb üks revüü meelde , kus HD 4870 peal jooksis DX10 isegi pisut paremini , kui DX9 ( nii 0.5 FPS paremini vms ) ja ma mõtlesin et ongi pmst esimene mäng , kus DX10 jookseb paremini icon_lol.gif .
omgwtf
omgwtf
sõnum 04.01.2009 01:33:43 vasta tsitaadiga
DX10 jooksebki paremini kui DX9 thumbs_up.gif Vähemalt minu jooksis kui kunagi sai mängitud icon_wink.gif
xxlmaster
xxlmaster
sõnum 04.01.2009 01:39:50 vasta tsitaadiga
icon_rolleyes.gif just ütlesin et sain DX9 juurde 15+ seega niisama ringi joostes umes 65+ bazookaga pauku tehes alla 30 ei langenud
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Far Cry 2 mine lehele eelmine  1, 2, 3 ... 41, 42, 43 ... 46, 47, 48  järgmine
