nolifer
18.12.2008 21:50:56
patch 1.02
Far Cry®2 v1.02 Update
If you had problems applying the 1st patch (1.01), please apply this cumulative patch.
STEAM users: Please wait until the patch is available through Steam.
General changes
- Added triple-header support to the game.
- A widescreen option has been added and can be enabled only in single player mode.
Multiplayer changes
- Fixed the direct join by IP functionality.
- Added the minimum number of players in the host options.
- Added the player's death count in the scoreboard.
- The host can now set the respawn time in Advanced options, for player matches only.
- The host can now set the starting rank of all players in the match, in Advanced options, for player matches only.
- The VIP is shown on the scoreboard, for your team only.
- The scoreboard is now displayed by the highest XP points to the lowest.
- The ping system has been improved to display a more accurate result.
- It is now possible to conduct a multiplayer match search from the map leader board.
- Fixed certain characters that weren't allowed during profile creation (- . _ ,)
- It is now possible to add a clan name to the player¦s name through the use_clan_tag console command.
- Players can now filter the server list using different parameters (ping, PunkBuster, game mode, dedicated, server name, number of players, ranked/unranked).
- The IEDs are now destructible by shooting on them or throwing a grenade close to them.
- In ranked matches, players can now play more than one match on the same host.
- Added quickmatch to the map download screen. It will matchmake on the selected map.
- The distance from a wounded teammate is now displayed.
- The host can now select a VIP before starting the match.
- It is now possible to use the use_clan_tag command.
- Fixed a bug with clan tag and multiple clients
- Multiplayer: Minimum players numbers default setting is now 4
- Fixed some unrepresentative text in the scoreboard.
- Added text to display distance when teamate is down
- Fix a freeze issue in match list if the player press ESC after trying to enter in a match with a password.
http://www.gamershell.com/download_37208.shtml
| Kommentaarid: 8 loe/lisa |
Marduuhin
19.12.2008 01:20:36
| nolifer kirjutas: |
| - A widescreen option has been added and can be enabled only in single player mode. |
:o Multit mängitaksegi tavaliselt ainult 4:3 ekraanidega!??
_________________ Eesti õigekeelsussõnaraamat ÕS 2018 |
108 |
MarekSäde
19.12.2008 10:20:31
| Eks ta võrdsuse huvides on, laiekraan annab ikka eelise.
| Kommentaarid: 68 loe/lisa |
66 |
| Kommentaarid: 92 loe/lisa |
Helbeke
19.12.2008 19:32:58
see nn laiekraani tugi on teil "kalasilmapilguga" vaatamine? öäk :=
_________________ i like my sugar with coffe and cream |
| Kommentaarid: 16 loe/lisa |
Helbeke
19.12.2008 21:50:57
mingi komanda partei paik liikus ka varem. sai kohe kinga. mäng on ise on üldse tüütult igav - pole viitsinud juba kuu (vist) 50% kaugemale mängida.
nolifer
20.12.2008 04:33:15
| Helbeke kirjutas: |
| see nn laiekraani tugi on teil "kalasilmapilguga" vaatamine? öäk := |
sa nii asjapulk ma vaatan, tegelikult sp on vahe küll, kui enne oli pilt suht venitatud, nüüd harjumatu mängida, pilt on ikka korralikult kokku surutud
Aah
21.12.2008 12:07:40
Nii, uuendused peal + need lisa missioonid. Alustasin nüüd mängu otsast peale. Laiekraan toimib väga hästi (y) , näeb rohkem kui autoga sõidad. Pilt korralik. Paistab et enam ei ole seda tobedat spawnimist. Peksin KP laiali ja läksin eemale asuvasse majja magama. Hommikul sõitsin sealt KPst mööda , kõik vennikesed vedelesid seal endistviisi.Pikapeale peaksid nad tagasi tulema? Kui ennem sai koguda jackal tape siis nüüd on olemas ka predecessor taped. Objective värvidele lisandus uus värv , valge. See on vist lisamissiooni teema. Ühesõnaga asi on poole mängitavam kui enne.
| Helbeke kirjutas: |
Mis see on mingi kantpea (4:3) kibe jutt vä?
| Kommentaarid: 21 loe/lisa |
21 |
Jaan700
22.12.2008 18:44:51
Kas keegi läbi Hamachi on ka asja juba proovinud ?
| Kommentaarid: 25 loe/lisa |
25 |
Leinö
23.12.2008 15:59:46
olen, ei saanud tööle
| Kommentaarid: 34 loe/lisa |
33 |
kaspir
24.12.2008 12:27:14
Kas keegi viitsiks mingi save'i üles visata, kus on teisest mäpist mingi esimesed missioonid tehtud? Formatiga unustasin save'i teha.
_________________ |
| Kommentaarid: 15 loe/lisa |
G80
24.12.2008 12:28:20
| tomorrow kirjutas: |
Lõpuks ometi native laiekraantugi  |
See on küll fail, kui laiekraani tuge ei ole mängus kohe olemas imo.
210 |
Erx15
27.12.2008 23:28:20
Sain ka siis mängu, ja üllatas, kui suur junnimine selle mp-ga ikka on.
Vaja on kasutajat ja mingit x koodi.
Kustkohast ma selle koodi saan?
| Kommentaarid: 17 loe/lisa |
16 |
Heineken
28.12.2008 00:28:33
Kas seal mitte serial key'd vaja ei ole ? Selle leiad plaadikarbi küljest . Kui pira on , siis ära hakka lolle küsimusi küsima .
| Kommentaarid: 24 loe/lisa |
23 |
Erx15
28.12.2008 00:45:34
Ofkoors ei ole pira.
miks seda seriali 2 korda on vaja?
16 |
km2000
28.12.2008 23:51:10
| kuidas ma selle teemanid kohvri üles leian, vahepeal jääb roheline seisma küll majas sees, aga tolku sellest ei ole.
29 |
Evil14
28.12.2008 23:55:08
km2000, igale poole tuleb vaadata ja mingi kummalise heli järgi leiab üles
| Kommentaarid: 229 loe/lisa |
200 |
omgwtf
29.12.2008 00:31:53
Vahest on katusel jne
137 |
softis
29.12.2008 00:45:51
Üldjuhul polegi lihtsalt kuskil nähtaval kohal ju... Kui majapeal jääb põlema tuluke, siis on tavaliselt mingis laudadega kinnilöödud ukse taga või siis kuskil katusel.
21 |
soodent
02.01.2009 23:39:48
Vista all sli kaartidega on keegi normaalse fps ka kätte saanud?Isegi ilma aa imeb täiega.Paistab ülemaailmne probleem olema dx10 sli incompatibility far cry 2 all.
| Kommentaarid: 822 loe/lisa |
19 :: |
6 :: |
564 |
xxlmaster
03.01.2009 01:57:42
| soodent kirjutas: |
| Vista all sli kaartidega on keegi normaalse fps ka kätte saanud?Isegi ilma aa imeb täiega.Paistab ülemaailmne probleem olema dx10 sli incompatibility far cry 2 all. |
Palju see FPS sul siis on?
Endal pole pätse ega midagi, kõik põhjas ja mingi 50 stabiilselt. Kui väga räigeks lahinguks läheb siis langeb 30 peale.
| Kommentaarid: 83 loe/lisa |
77 |
Leinö
03.01.2009 13:38:06
| Erx15 kirjutas: |
miks seda seriali 2 korda on vaja? |
Vast ikka 1 kord. Installides ju key´d ei küsi... MP minnes nõuab seda.
33 |
soodent
03.01.2009 14:47:14
Dx10 all 9800gx2 on benchmark very high 1680x1050 keskmine fps kusagil 10-15.Dx9 samas üle 50 fps.AA juurde pannes tuleb kohe räme kukkumine alates 4xAA.
Far Cry 2 on nvidia sli antireklaam.Kusjuures kõiksugu foorumites seda teemat arutatakse ja xp kasutajad pole võimelised sellest aru saama.
Ei eelda ka siin dx9 kasutajate poolt mõistmist.Arutusel oli ikka nvidia sli mitte ati cf.
19 :: |
6 :: |
564 |
omgwtf
03.01.2009 14:49:45
soodent, Far cry2 on VAID 9800GX2 antireklaam Selle kaardiga on olnud Far crys probleeme esimesest päevast kui mäng väljus. Muud SLI lahendused toimivad ideaalselt igas poosis Isegi järgmine Nvidia vahvel ragistab mõnuga seda mängu
137 |
soodent
03.01.2009 14:55:49
Ei tööta nad päris ideaalselt midagi- AA peale pannes ja dx10 tuleb räme pidur ka teiste sli kaartidega.
See 9800gx2 dx10 suremine on muidugi eriti dramaatiline.Ei saagi aru kes süüdi- kas ubisft või nvidia.
19 :: |
6 :: |
564 |
omgwtf
03.01.2009 15:00:14
http://guru3d.com/article/geforce-gtx-295-preview/7 Nvidia tulevane vahvel ragistab küll lõpuni korralikult kuniks lõppeb mälu otsa resolutsiooni tõttu
GTX280 SLI toimib ka kenasti Viga puhtatl selles vanas 9800GX2 keegi ei viitsi tegeleda nende drivudega enam mis sellele kaardile sobiks jne.. Unustatud asi
137 |
soodent
03.01.2009 15:31:32
Ma ei saa nüüd aru- kui me räägime 9800gx2 ja sli omadustest siis on võrdlus ikka 8800 ja 9800 seeria sli-ga.Mida udutad...
HV all mingit arukust oodata ikka mõttetu.Masendav tase.Seal võrdluses pole ultra high.
19 :: |
6 :: |
564 |
omgwtf
03.01.2009 15:45:47
| Masendav on see,et 9800GX2 ei saa far cry 2`ga hakkama ja sa nimetad kogu nvidia SLId siin mängus suureks FAILiks ja ootad vastu mingit arukust..
137 |
soodent
03.01.2009 15:54:03
8800, 9800 sli ja 9800gx2 on kõik hädas dx10 all ja eriti aa kasutusel kui sa ikka ei mõista.
Su 295 gtx oli siis mingi mõistlik vastus.Mida sa tõestad??Võrdle sama ajastu asju ja loe foorumeid.
Klassikaline eesti foorumi kasutaja- tahaks hirmsalt "ära panna" ja kui ei leia midagi objektiivset, siis mõtleb välja.
19 :: |
6 :: |
564 |
omgwtf
03.01.2009 16:01:45
| soodent kirjutas: |
Klassikaline eesti foorumi kasutaja- tahaks hirmsalt "ära panna" ja kui ei leia midagi objektiivset, siis mõtleb välja. |
Ei viitsi mingit "ära panemist" siin mängida Ise sa ei oska ennast väljendada
| Far Cry 2 on nvidia sli antireklaam |
Mina tõin näited kus SLI on väga edukas ja toimiv See kui vanakooli tehikal ei tööta SLI on teine asi.
137 |
soodent
03.01.2009 16:18:50
Tõid näiteid- mina nägin sli su lingil vaid 295 gtx ja high quality....Dx9 peal on 9800gx2 täitsa norm.Kõva vanakool- 6 kuud tootmises olnud kaart...
19 :: |
6 :: |
564 |
Mercury
03.01.2009 16:21:02
Vabandust, aga pole viitsimist 85 lehte läbi vaadata.
Kuidas saab mängus FPS vaadata?
| Kommentaarid: 61 loe/lisa |
60 |
omgwtf
03.01.2009 16:23:29
| Veebruar või märts 2008 tuli välja see "6 kuud" vana kaart
137 |
xxlmaster
03.01.2009 17:41:09
| Mercury kirjutas: |
Kuidas saab mängus FPS vaadata? |
sa ei peagi viimaseid lehti läbi lappama. Selleks on fraps et näha FPS-i endal kõik põhjas ja päeva 50+ öösel 80+
77 |
TruePlaya
03.01.2009 21:33:45
Eeee pole ammu seda teemat siin lugenud on mingi patch ka väljas juba?
| Kommentaarid: 30 loe/lisa |
WäntWõll
make.believe
03.01.2009 21:49:26
Ei tohiks olla peale Inteli spets map-packiga
300 |
xxlmaster
77 |
nolifer
03.01.2009 22:09:07
1.02 samuti väljas, soojalt soovitatav mp jaoks+laiekraantugi
xxlmaster
03.01.2009 22:22:32
| nolifer kirjutas: |
1.02 samuti väljas, soojalt soovitatav mp jaoks+laiekraantugi |
tee link lahti seal ongi ju 1.02
77 |
Leinö
03.01.2009 22:27:07
| xxlmaster kirjutas: |
| Mercury kirjutas: |
sa ei peagi viimaseid lehti läbi lappama. Selleks on fraps et näha FPS-i endal kõik põhjas ja päeva 50+ öösel 80+  |
Konsool lahti ja /drawFPS 1 ja näed oma FPS.
33 |
Mercury
03.01.2009 23:55:14
| amachie kirjutas: |
| Mercury kirjutas: |
Konsool lahti ja /drawFPS 1 ja näed oma FPS. |
Jah tänan, leidsin is ka et mängus on konsool olemas
60 |
Heineken
04.01.2009 00:26:40
| soodent, tolle kaardi 512MB jääb kah omajagu jalgu . Mäletan kunagi oli mingi revüü kus võrreldi HD 4870 512MB ja 1GB versioone ja 1GB peal jooksis see tunduvalt paremini . Kuid kui DX10 ei taha kuidagi joosta , miks mitte lihtsalt DX9 peale minna . Mis resolutsioonist üldse jutt käib ?
23 |
xxlmaster
04.01.2009 00:28:18
| Heineken kirjutas: |
| soodent, tolle kaardi 512MB jääb kah omajagu jalgu . Mäletan kunagi oli mingi revüü kus võrreldi HD 4870 512MB ja 1GB versioone ja 1GB peal jooksis see tunduvalt paremini . Kuid kui DX10 ei taha kuidagi joosta , miks mitte lihtsalt DX9 peale minna . Mis resolutsioonist üldse jutt käib ? |
Proovisin ka korra DX9 sain u 15+
77 |
Heineken
04.01.2009 01:26:37
15FPS perfi juurde ? Normaalne . Ja mul sellega seoses tuleb üks revüü meelde , kus HD 4870 peal jooksis DX10 isegi pisut paremini , kui DX9 ( nii 0.5 FPS paremini vms ) ja ma mõtlesin et ongi pmst esimene mäng , kus DX10 jookseb paremini .
23 |
omgwtf
04.01.2009 01:33:43
DX10 jooksebki paremini kui DX9 Vähemalt minu jooksis kui kunagi sai mängitud
137 |
xxlmaster
04.01.2009 01:39:50
just ütlesin et sain DX9 juurde 15+ seega niisama ringi joostes umes 65+ bazookaga pauku tehes alla 30 ei langenud
77 |
