sulomile
12.12.2008 15:11:18
| tomorrow kirjutas: |
| Adds new capabilities to DirectX Graphic display reliability. The graphics experience has been greatly improved for users, such as gamers, running applications that require a lot of graphics processing. |
| Improves audio and video performance for streaming high definition content |
| Small file performance on the previous page showed that read times were slightly down and that appears to have directly impacted Windows Vista SP2 beta's boot time - it's around two seconds or three percent slower than our SP1 installation. |
| Interestingly, our Crysis level load time was also impacted by this as well - and to a much greater extent - with our test taking on average almost five percent longer. |
Mis .Lubamatu
| A pair of Radeon HD 4870 1GB cards running in CrossFire seem to benefit from some pretty significant improvements in Crysis with the Service Pack 2 beta installed - we witnessed a 9.2 percent increase, which is going to be fairly noticeable in real world gaming scenarios at the frame rates we're seeing here. |
Huvitav, et Dell D630-l peale SP2-te ja Delli kodukalt kõige uuemate videokaardi draiverite allalaadimist, muutus sees kasutajakogemuse indeks 3,0 pealt 2,8-ks just Aero jõudluse osas, muud jäid samaks.
Samas ka peale SP2 installi tulid järgmine päev juba uued Security Updeted SP2-le, nii et ikka leitakse üha uusi auke süsteemis
_________________ Oleks mina näinud, kuis sind tehti, oleks öelnud: ärge tehke. |
Firefly
13.12.2008 12:09:51
| sulomile, halb oleks kui ei leitaks uusi auke ja see, et töö käib kiiresti on ju ainult hea näitaja.
apelsin16
13.12.2008 17:44:23
tere siuke probleem et viimasel aja kui windowsi käima panen viskab bluescreeni ja annab sellise veateate
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6001.2.1.0.256.1
Locale ID: 1061
Additional information about the problem:
BCCode: a
BCP1: 0000428C
BCP2: 00000002
BCP3: 00000000
BCP4: 820882AA
OS Version: 6_0_6001
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\Mini121308-02.dmp
C:\Users\t0x1c\AppData\Local\Temp\WER-157826-0.sysdata.xml
C:\Users\t0x1c\AppData\Local\Temp\WERAAAF.tmp.version.txt
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
äkki keegi oskab aidata
diizel
16.12.2008 00:53:14
Tahaks kasutada speech recognitioni, aga kuna on eesti keele pakk peal, siis ta seda ei luba. Ütleb, et praeguses keeles kõnetuvastust ei toetata.
Kas oleks kuidagi võimalik kasutada inglise keelest kõnetuvastust, ilma et peaksin eesti keele maha laskma?
der hammer
17.12.2008 01:25:25
Ostsin uue ketta mille tahaks teha windowsi kettaks. Win aga aktiveeritud juba ühel kettal. Kas ta lubab kütta sama cd-key kui intallin wini uue kettale ? Ilma ,et ta black listi läheks vms.
_________________ Tere. |
17.12.2008 02:01:00
| saab ikka, ei juhtu midagi halba
softis
17.12.2008 05:29:41
Probleem:
Helitugevus muutub laule kuulates ja vahel ka filme vaadates. Päris ajaliselt ta ei toimu, mingis mõttes nagu järgiks biiti, et kui on kiire, siis on kõvem ja kui siis tempomuutus toimub, siis läheb vaiksemaks.
Mis kuramuse kala see on? Ja kuidas seda muuta?
HighEnd
17.12.2008 08:04:04
softis, äge süsteem Mis kõlaritega kuulad? kontrolli juhtmed üle. Vb on Op sys power saves vms.
Trinity
17.12.2008 09:26:22
| softis kirjutas: |
Probleem:
Mis kuramuse kala see on? Ja kuidas seda muuta? |
Rumal küsimus, aga codekid ikka up to date ? Ja helikaarti driverid?
softis
17.12.2008 14:31:56
Kõik kuramuse driverid on up-to-date ja juhe on ka klappidel-kõlaritel terve.
Selles see paganama probleem ongi, et justkui oleks kõik korras, aga tegelikult saad ikka mingit intelligentset rütmidiskot
Opsüsteem power save modes küll pole. Sai archicadiga mütatud ja siis kulub iga elektron ära.
17.12.2008 18:54:30
| softis kirjutas: |
Opsüsteem power save modes küll pole. Sai archicadiga mütatud ja siis kulub iga elektron ära. |
Tundub nagu mingi proge möllab(a`la monitorudel dynamic contrast)
aise
17.12.2008 20:38:55
mure, tuttava arvuti paneb sinist pidevalt, peale restarti saab 3-4min kasutada ja pämm kinni. 0x0000007E, solution finder arvab sama mis mina, et on mingi viirusepede sees, arvutil puudus viirusetõrje kas on mingit viirusetõrje programmi mida saaks CD pealt käima lasta? safe mode pealt teeb samuti ja ka last good gonfiguration teeb samuti...
apelsin16
17.12.2008 20:50:31
| aise kirjutas: |
mure, tuttava arvuti paneb sinist pidevalt, peale restarti saab 3-4min kasutada ja pämm kinni. 0x0000007E, solution finder arvab sama mis mina, et on mingi viirusepede sees, arvutil puudus viirusetõrje kas on mingit viirusetõrje programmi mida saaks CD pealt käima lasta? safe mode pealt teeb samuti ja ka last good gonfiguration teeb samuti... |
viiruste kohta küsi Lord Ami
17.12.2008 21:00:50
| aise kirjutas: |
0x0000007E võib viidata ka tervele reale probleemidele.Kõik uuendused ja SP1 peal ikka?
aise
18.12.2008 00:47:21
[quote="tomorrow"]
| aise kirjutas: |
0x0000007E võib viidata ka tervele reale probleemidele.Kõik uuendused ja SP1 peal ikka?[/quote
vist on peal jah, aga ega midagi ei jõua installida ka kui pole kuna 100% paneb sinist peale 3-4min win´s olemist. startupi jõudsin puhtaks teha, mingi .dll oli kahtlane ja videodriverid kiskusin ka maha aga sellest kasu polnud, peab siis format tegema ikka
miq1988
18.12.2008 01:37:11
| aise kirjutas: |
Ema arvutil oli mingi aeg sarnased sümptomid.
Peale restarti natuke aega ja ekraan sinine.. Ja mõne aja pärast see odav codegeni toitekas maha põleski.
sulomile
18.12.2008 16:07:27
Samad sümptomid ja lahendus: toiteka vahetus
aise
18.12.2008 17:21:50
| sulomile kirjutas: |
| Samad sümptomid ja lahendus: toiteka vahetus |
tegemist on läpakaga, millel on praeguseks uus Vista peal ja kõik korras, tegin format.
X
19.12.2008 15:47:30
Tere!
Miks vistal on mingi eraldi paritisioon, system partition vms, ca 2GB? Lisaks tavalisele C kettale? Olgu öeldud, et tegemist on eelinstallitud windowsiga Lenovo T400-le?
19.12.2008 15:49:37
| see on recovery partitsioon, sest installiplaate sulle ju kaasa ei tulnud
Jann1
19.12.2008 16:11:44
Nii sõbrad.
Tuttava läpakale läheb vista peale (ultimate)
Kuidas saaks selle eestikeelseks muuta, et võhik saaks midagigi aru mida arvuti räägib talle?
erxx
19.12.2008 16:16:38
| Jann1 kirjutas: |
Nii sõbrad.
Kuidas saaks selle eestikeelseks muuta, et võhik saaks midagigi aru mida arvuti räägib talle? |
Vaata uuenduste alt, seal peaks olemas olema, vähemalt mul on
Jann1
19.12.2008 16:18:58
| Jah sealt saab sikutada omale eestikeelse paketi aga küsimus kuidas muuuta!
erxx
19.12.2008 16:24:09
| Jann1 kirjutas: |
| Jah sealt saab sikutada omale eestikeelse paketi aga küsimus kuidas muuuta! |
No control panel, seal mingi language värk ja siis sellest aknast mis tuleb sealt võtad "keyboards and languages" ja vast sealt suudad ise ära tuvastada koha, aga enne pead alla laadima uuendusega.
Jann1
19.12.2008 16:24:20
| ok proovin.
erxx
Jann1
19.12.2008 16:31:04
Jah sain ise kaa juba kätte
Kool Guy
aise
19.12.2008 22:30:22
| selline asi, et läpaka recovery CD visati ära (ärge küsige miks), kas ma saan sedasi asja aktiveeritud kui tirin vista basic plaadi ja installin sellega masinale peale ja pärast vahetan võtme arvuti all oleva vastu (arvutil oli enne ka basic peal)? läheb selline asi läbi?
KuriVaiM1
20.12.2008 12:02:44
ei tea milles võib jama olla et kui tahan arvutit väla lülitada "power" nupust siis lülitab välja aga peale ca 5sekki lülib arvuti uuesti tagasi sisse, control paneelist on power settingud ülevaadatud/paika pandud "power"" nupp - shut down, äkki oskab keegi hüva nõu anda millest selline jama võib tingitud olla?
"Mõtle kriitiliselt" |
20.12.2008 12:06:50
| KuriVaiM1 kirjutas: |
| ei tea milles võib jama olla et kui tahan arvutit väla lülitada "power" nupust siis lülitab välja aga peale ca 5sekki lülib arvuti uuesti tagasi sisse, control paneelist on power settingud ülevaadatud/paika pandud "power"" nupp - shut down, äkki oskab keegi hüva nõu anda millest selline jama võib tingitud olla? |
WOL - Wake On Lan on äkki sees BIOS-st?
KuriVaiM1
20.12.2008 12:09:12
WOL - Wake On Lan on äkki sees BIOS-st?  |
ei tahaks uskuda, paar päeva tagasi sai vista peale pandud, XP-s sellist probleemi ei olnud
smurfer
20.12.2008 12:16:06
ei tahaks uskuda, paar päeva tagasi sai vista peale pandud, XP-s sellist probleemi ei olnud |
Mul on sama jama olnud kahel puhul, need küll XP'ga - ükskord oli emaplaat peetis ja paar korda on olnud toitekas läbi. Lihtsam on ilmselt teist toitekat proovida
KuriVaiM1
20.12.2008 16:24:39
jep sul oli õigus ainult et endal BIOS-sis teistsugust tõugu termin "PME event wake up" WOL-i asemel - see sai maha keeratud ning nüüd enam auto käima ei lähe peale shut downi , tänud
* tundub et vista polegi nii kompakte, power seadeid BIOS-sis pole vajadust olnud ennem näppidagi, XP-ga sellist jama küll ei olnud
viimati muutis KuriVaiM1 20.12.2008 16:43:28, muudetud 1 kord |
X
20.12.2008 16:42:58
| Millega saaks vistat partitsoneerida? Partition manager ei oma vista toetust! Shrink drive on jama, kuna lubab ainult pool ketta mahust partitsoneerida!
o-u-t-r-o
20.12.2008 17:11:23
| vb PowerQuest PartitionMagic ?
ralph
20.12.2008 17:20:13
| kas mitte polnud seda pidi, et PartitionMagic ei töötand vista all, kuid Partition manager töötas?
KuriVaiM1
20.12.2008 18:00:12
jep sul oli õigus |
Mul oli õigus milleski? .Lähen joon ennast kohe täis  |
20.12.2008 20:39:05
>>FRAPS 2.9.7<<
2.9.7 - 19th Dec 2008
- Fixed 64-bit applications crashing soon after loading
- Fixed low quality sound recording with Left 4 Dead under Windows XP
- Fixed graphic corruption in X-Plane (and other OpenGL titles)
- Fixed crash when recording a DirectX 9 game and changing resolution
- Fixed Fraps not detecting games after being run at Windows startup
- Fixed hotkeys not responding when Alt held down
- Fixed monitoring of Vista DWM after a full-screen application has exited
- Fixed Fluidmark displaying a blank screen with Fraps loaded
- Fixed FS9 crashing when menu activated while recording
- Fixed DWMAPI error on some Windows XP installs
- Improved recording speed of DirectX9 games in Vista SP1 and SP2 beta
- Added warning if no sound recording device found under Windows 2000 or XP |
20.12.2008 21:38:10
| aise kirjutas: |
| selline asi, et läpaka recovery CD visati ära (ärge küsige miks), kas ma saan sedasi asja aktiveeritud kui tirin vista basic plaadi ja installin sellega masinale peale ja pärast vahetan võtme arvuti all oleva vastu (arvutil oli enne ka basic peal)? läheb selline asi läbi? |
Soovitavalt leia mõni puutumata versioon, osadel privaatsematel lehtedel on sellist korralikku kraami. Kiire otsing ühel suuremal avalikul lehel näitas et isegi kui kirjas on et asi on puutumata, siis kommentaaridest tuli midagi muud välja (kamaluga spyware'i sees).
Eraldi Basic plaati pole, Vista puhul on kõik versioonid ühel DVD'l koos ja erinevuse määrab litsentsivõti.
mati
21.12.2008 01:03:40
| Kas ID-kaarti saab 64-bit Vistaga kasutada või on probleeme?
siLc
21.12.2008 01:07:03
| mati kirjutas: |
| Kas ID-kaarti saab 64-bit Vistaga kasutada või on probleeme? |
Pole probleeme...
Aah
21.12.2008 03:32:25
| Oeh , naabrimees käib peale nagu uni. Ostis endale arvuti vistaga. Nüüd tahab seda eesti keelseks. Visake link kus midaiganes saab alla laadida et et see neetud vista eesti keelseks teha. Tänud.
prtv
21.12.2008 11:48:50
Aah, mis Vista versioon on? Business:?: ja Ultimate saab ainult keeli vahetada.
_________________ |
kaspir
21.12.2008 12:24:28
Kiire küsimus, mis ootaks kiiret vastust.
Kui installin Vista, kas siis failid jäävad alles, kui formatit ei tee? Praegu XP.
_________________ |
