uus teema   vasta Hinnavaatlus »  Microsoft »  Windows Vista märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 164, 165, 166 ... 188, 189, 190  järgmine
sulomile
sulomile
sõnum 12.12.2008 15:11:18 vasta tsitaadiga
tomorrow kirjutas:
AJ kirjutas:
Windows Vista SP2 beta performance
http://www.bit-tech.net/bits/2008/12/10/windows-vista-sp2-beta-performance/
Adds new capabilities to DirectX Graphic display reliability. The graphics experience has been greatly improved for users, such as gamers, running applications that require a lot of graphics processing.
Improves audio and video performance for streaming high definition content
Small file performance on the previous page showed that read times were slightly down and that appears to have directly impacted Windows Vista SP2 beta's boot time - it's around two seconds or three percent slower than our SP1 installation.
Interestingly, our Crysis level load time was also impacted by this as well - and to a much greater extent - with our test taking on average almost five percent longer.
A pair of Radeon HD 4870 1GB cards running in CrossFire seem to benefit from some pretty significant improvements in Crysis with the Service Pack 2 beta installed - we witnessed a 9.2 percent increase, which is going to be fairly noticeable in real world gaming scenarios at the frame rates we're seeing here.
Huvitav, et Dell D630-l peale SP2-te ja Delli kodukalt kõige uuemate videokaardi draiverite allalaadimist, muutus sees kasutajakogemuse indeks 3,0 pealt 2,8-ks just Aero jõudluse osas, muud jäid samaks.
Samas ka peale SP2 installi tulid järgmine päev juba uued Security Updeted SP2-le, nii et ikka leitakse üha uusi auke süsteemis
Oleks mina näinud, kuis sind tehti, oleks öelnud: ärge tehke.
Firefly
Firefly
sõnum 13.12.2008 12:09:51 vasta tsitaadiga
sulomile, halb oleks kui ei leitaks uusi auke ja see, et töö käib kiiresti on ju ainult hea näitaja.
apelsin16
apelsin16
sõnum 13.12.2008 17:44:23 vasta tsitaadiga
tere siuke probleem et viimasel aja kui windowsi käima panen viskab bluescreeni ja annab sellise veateate icon_neutral.gif
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6001.2.1.0.256.1
Locale ID: 1061
Additional information about the problem:
BCCode: a
BCP1: 0000428C
BCP2: 00000002
BCP3: 00000000
BCP4: 820882AA
OS Version: 6_0_6001
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\Mini121308-02.dmp
C:\Users\t0x1c\AppData\Local\Temp\WER-157826-0.sysdata.xml
C:\Users\t0x1c\AppData\Local\Temp\WERAAAF.tmp.version.txt
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
äkki keegi oskab aidata
sõnum 13.12.2008 23:34:01 vasta tsitaadiga
apelsin16 kirjutas:
tere siuke probleem et viimasel aja kui windowsi käima panen viskab bluescreeni ja annab sellise veateate...
Kasuta startup repairi
diizel
diizel
sõnum 16.12.2008 00:53:14 vasta tsitaadiga
Tahaks kasutada speech recognitioni, aga kuna on eesti keele pakk peal, siis ta seda ei luba. Ütleb, et praeguses keeles kõnetuvastust ei toetata.
Kas oleks kuidagi võimalik kasutada inglise keelest kõnetuvastust, ilma et peaksin eesti keele maha laskma?
der hammer
der hammer
sõnum 17.12.2008 01:25:25 vasta tsitaadiga
Ostsin uue ketta mille tahaks teha windowsi kettaks. Win aga aktiveeritud juba ühel kettal. Kas ta lubab kütta sama cd-key kui intallin wini uue kettale ? Ilma ,et ta black listi läheks vms.
Tere.
sõnum 17.12.2008 02:01:00 vasta tsitaadiga
saab ikka, ei juhtu midagi halba
softis
softis
sõnum 17.12.2008 05:29:41 vasta tsitaadiga
Probleem:
Helitugevus muutub laule kuulates ja vahel ka filme vaadates. Päris ajaliselt ta ei toimu, mingis mõttes nagu järgiks biiti, et kui on kiire, siis on kõvem ja kui siis tempomuutus toimub, siis läheb vaiksemaks.
Mis kuramuse kala see on? Ja kuidas seda muuta?
HighEnd
HighEnd
sõnum 17.12.2008 08:04:04 vasta tsitaadiga
softis, äge süsteem icon_biggrin.gif Mis kõlaritega kuulad? kontrolli juhtmed üle. Vb on Op sys power saves vms. icon_rolleyes.gif
Trinity
sõnum 17.12.2008 09:26:22 vasta tsitaadiga
softis kirjutas:
Probleem:
Rumal küsimus, aga codekid ikka up to date ? Ja helikaarti driverid?
softis
softis
sõnum 17.12.2008 14:31:56 vasta tsitaadiga
Kõik kuramuse driverid on up-to-date ja juhe on ka klappidel-kõlaritel terve.
Selles see paganama probleem ongi, et justkui oleks kõik korras, aga tegelikult saad ikka mingit intelligentset rütmidiskot icon_biggrin.gif
Opsüsteem power save modes küll pole. Sai archicadiga mütatud ja siis kulub iga elektron ära.
sõnum 17.12.2008 18:54:30 vasta tsitaadiga
softis kirjutas:
Tundub nagu mingi proge möllab(a`la monitorudel dynamic contrast)
aise
aise
sõnum 17.12.2008 20:38:55 vasta tsitaadiga
mure, tuttava arvuti paneb sinist pidevalt, peale restarti saab 3-4min kasutada ja pämm kinni. 0x0000007E, solution finder arvab sama mis mina, et on mingi viirusepede sees, arvutil puudus viirusetõrje icon_lol.gif kas on mingit viirusetõrje programmi mida saaks CD pealt käima lasta? safe mode pealt teeb samuti ja ka last good gonfiguration teeb samuti...
apelsin16
apelsin16
sõnum 17.12.2008 20:50:31 vasta tsitaadiga
aise kirjutas:
viiruste kohta küsi Lord Ami
sõnum 17.12.2008 21:00:50 vasta tsitaadiga
aise kirjutas:
0x0000007E võib viidata ka tervele reale probleemidele.Kõik uuendused ja SP1 peal ikka?
aise
aise
sõnum 18.12.2008 00:47:21 vasta tsitaadiga
[quote="tomorrow"]
aise kirjutas:
0x0000007E võib viidata ka tervele reale probleemidele.Kõik uuendused ja SP1 peal ikka?[/quote
vist on peal jah, aga ega midagi ei jõua installida ka kui pole kuna 100% paneb sinist peale 3-4min win´s olemist. startupi jõudsin puhtaks teha, mingi .dll oli kahtlane ja videodriverid kiskusin ka maha aga sellest kasu polnud, peab siis format tegema ikka icon_neutral.gif
miq1988
miq1988
sõnum 18.12.2008 01:37:11 vasta tsitaadiga
aise kirjutas:
Ema arvutil oli mingi aeg sarnased sümptomid.
Peale restarti natuke aega ja ekraan sinine.. Ja mõne aja pärast see odav codegeni toitekas maha põleski.
I don't need anger management. I need people to stop pissing me off !
sulomile
sulomile
sõnum 18.12.2008 16:07:27 vasta tsitaadiga
Samad sümptomid ja lahendus: toiteka vahetus
aise
aise
sõnum 18.12.2008 17:21:50 vasta tsitaadiga
sulomile kirjutas:
tegemist on läpakaga, millel on praeguseks uus Vista peal ja kõik korras, tegin format.
X
X
sõnum 19.12.2008 15:47:30 vasta tsitaadiga
Tere!
Miks vistal on mingi eraldi paritisioon, system partition vms, ca 2GB? Lisaks tavalisele C kettale? Olgu öeldud, et tegemist on eelinstallitud windowsiga Lenovo T400-le?
sõnum 19.12.2008 15:49:37 vasta tsitaadiga
see on recovery partitsioon, sest installiplaate sulle ju kaasa ei tulnud
Jann1
Jann1
sõnum 19.12.2008 16:11:44 vasta tsitaadiga
Nii sõbrad.
Tuttava läpakale läheb vista peale (ultimate)
Kuidas saaks selle eestikeelseks muuta, et võhik saaks midagigi aru mida arvuti räägib talle?
erxx
erxx
sõnum 19.12.2008 16:16:38 vasta tsitaadiga
Jann1 kirjutas:
Nii sõbrad.
Vaata uuenduste alt, seal peaks olemas olema, vähemalt mul on icon_rolleyes.gif
Jann1
Jann1
sõnum 19.12.2008 16:18:58 vasta tsitaadiga
Jah sealt saab sikutada omale eestikeelse paketi aga küsimus kuidas muuuta!
sõnum 19.12.2008 16:23:49 vasta tsitaadiga
Jann1 kirjutas:
erxx
erxx
sõnum 19.12.2008 16:24:09 vasta tsitaadiga
Jann1 kirjutas:
No control panel, seal mingi language värk ja siis sellest aknast mis tuleb sealt võtad "keyboards and languages" ja vast sealt suudad ise ära tuvastada koha, aga enne pead alla laadima uuendusega.
Jann1
Jann1
sõnum 19.12.2008 16:24:20 vasta tsitaadiga
ok proovin.
erxx
erxx
sõnum 19.12.2008 16:26:41 vasta tsitaadiga
Jann1 kirjutas:
ok proovin.
tutorial: icon_biggrin.gificon_biggrin.gif
http://www.youtube.com/watch?v=vMhMfUWkTdA
Jann1
Jann1
sõnum 19.12.2008 16:31:04 vasta tsitaadiga
aise
aise
sõnum 19.12.2008 22:30:22 vasta tsitaadiga
selline asi, et läpaka recovery CD visati ära (ärge küsige miks), kas ma saan sedasi asja aktiveeritud kui tirin vista basic plaadi ja installin sellega masinale peale ja pärast vahetan võtme arvuti all oleva vastu (arvutil oli enne ka basic peal)? läheb selline asi läbi?
KuriVaiM1
KuriVaiM1
sõnum 20.12.2008 12:02:44 vasta tsitaadiga
ei tea milles võib jama olla et kui tahan arvutit väla lülitada "power" nupust siis lülitab välja aga peale ca 5sekki lülib arvuti uuesti tagasi sisse, control paneelist on power settingud ülevaadatud/paika pandud "power"" nupp - shut down, äkki oskab keegi hüva nõu anda millest selline jama võib tingitud olla?
icon_arrow.gif "Mõtle kriitiliselt"
sõnum 20.12.2008 12:06:50 vasta tsitaadiga
KuriVaiM1 kirjutas:
KuriVaiM1
KuriVaiM1
sõnum 20.12.2008 12:09:12 vasta tsitaadiga
tomorrow kirjutas:
ei tahaks uskuda, paar päeva tagasi sai vista peale pandud, XP-s sellist probleemi ei olnud
smurfer
smurfer
sõnum 20.12.2008 12:16:06 vasta tsitaadiga
KuriVaiM1 kirjutas:
tomorrow kirjutas:
Mul on sama jama olnud kahel puhul, need küll XP'ga - ükskord oli emaplaat peetis ja paar korda on olnud toitekas läbi. Lihtsam on ilmselt teist toitekat proovida thumbs_up.gif
KuriVaiM1
KuriVaiM1
sõnum 20.12.2008 16:24:39 vasta tsitaadiga
tomorrow kirjutas:
jep sul oli õigus ainult et endal BIOS-sis teistsugust tõugu termin "PME event wake up" WOL-i asemel - see sai maha keeratud ning nüüd enam auto käima ei lähe peale shut downi thumbs_up.gif , tänud
* tundub et vista polegi nii kompakte, power seadeid BIOS-sis pole vajadust olnud ennem näppidagi, XP-ga sellist jama küll ei olnud
viimati muutis KuriVaiM1 20.12.2008 16:43:28, muudetud 1 kord
X
X
sõnum 20.12.2008 16:42:58 vasta tsitaadiga
Millega saaks vistat partitsoneerida? Partition manager ei oma vista toetust! Shrink drive on jama, kuna lubab ainult pool ketta mahust partitsoneerida!
o-u-t-r-o
o-u-t-r-o
sõnum 20.12.2008 17:11:23 vasta tsitaadiga
vb PowerQuest PartitionMagic ?
ralph
ralph
sõnum 20.12.2008 17:20:13 vasta tsitaadiga
kas mitte polnud seda pidi, et PartitionMagic ei töötand vista all, kuid Partition manager töötas?
sõnum 20.12.2008 17:51:23 vasta tsitaadiga
KuriVaiM1 kirjutas:
jep sul oli õigus
Mul oli õigus milleski? icon_eek.gif .Lähen joon ennast kohe täis icon_lol.gif thumbs_up.gif
KuriVaiM1
KuriVaiM1
sõnum 20.12.2008 18:00:12 vasta tsitaadiga
tomorrow kirjutas:
KuriVaiM1 kirjutas:
jep sul oli õigus
sõnum 20.12.2008 20:39:05 vasta tsitaadiga
>>FRAPS 2.9.7<<
2.9.7 - 19th Dec 2008
- Fixed 64-bit applications crashing soon after loading
- Fixed low quality sound recording with Left 4 Dead under Windows XP
- Fixed graphic corruption in X-Plane (and other OpenGL titles)
- Fixed crash when recording a DirectX 9 game and changing resolution
- Fixed Fraps not detecting games after being run at Windows startup
- Fixed hotkeys not responding when Alt held down
- Fixed monitoring of Vista DWM after a full-screen application has exited
- Fixed Fluidmark displaying a blank screen with Fraps loaded
- Fixed FS9 crashing when menu activated while recording
- Fixed DWMAPI error on some Windows XP installs
- Improved recording speed of DirectX9 games in Vista SP1 and SP2 beta
- Added warning if no sound recording device found under Windows 2000 or XP
sõnum 20.12.2008 21:38:10 vasta tsitaadiga
aise kirjutas:
Soovitavalt leia mõni puutumata versioon, osadel privaatsematel lehtedel on sellist korralikku kraami. Kiire otsing ühel suuremal avalikul lehel näitas et isegi kui kirjas on et asi on puutumata, siis kommentaaridest tuli midagi muud välja (kamaluga spyware'i sees).
Eraldi Basic plaati pole, Vista puhul on kõik versioonid ühel DVD'l koos ja erinevuse määrab litsentsivõti.
mati
mati
sõnum 21.12.2008 01:03:40 vasta tsitaadiga
Kas ID-kaarti saab 64-bit Vistaga kasutada või on probleeme?
sõnum 21.12.2008 01:06:13 vasta tsitaadiga
mati kirjutas:
Peaks nagu saama
siLc
sõnum 21.12.2008 01:07:03 vasta tsitaadiga
mati kirjutas:
Pole probleeme...
Aah
Aah
sõnum 21.12.2008 03:32:25 vasta tsitaadiga
Oeh , naabrimees käib peale nagu uni. Ostis endale arvuti vistaga. Nüüd tahab seda eesti keelseks. Visake link kus midaiganes saab alla laadida et et see neetud vista eesti keelseks teha. Tänud.
prtv
sõnum 21.12.2008 11:48:50 vasta tsitaadiga
Aah, mis Vista versioon on? Business:?: ja Ultimate saab ainult keeli vahetada.
sõnum 21.12.2008 11:57:10 vasta tsitaadiga
Aah kirjutas:
http://www.froggie.sk/ icon_wink.gif thumbs_up.gif
kaspir
kaspir
sõnum 21.12.2008 12:24:28 vasta tsitaadiga
Kiire küsimus, mis ootaks kiiret vastust.
Kui installin Vista, kas siis failid jäävad alles, kui formatit ei tee? Praegu XP.
š
sõnum 21.12.2008 12:25:59 vasta tsitaadiga
kaspir kirjutas:
Jah.
Siiski kui vähegi võimalik soovitaks clean installi formatiga.See upgrade install võib pärast igasugu anomaaliatega lagedale tulla icon_rolleyes.gif
uus teema   vasta Hinnavaatlus »  Microsoft »  Windows Vista mine lehele eelmine  1, 2, 3 ... 164, 165, 166 ... 188, 189, 190  järgmine
