uus teema   vasta Tarkvara »  Arvutimängude foorum »  Grand Theft Auto IV märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 211, 212, 213 ... 589, 590, 591  järgmine
prtv
sõnum 05.12.2008 20:22:41 vasta tsitaadiga
makaron111 kirjutas:
gan3b kirjutas:
täpselt sama kala mis gan3bil, peaks küll net framework peal olema...
Rockstari järgi peaks asi olema mitte korralikult installitud driverites (vana pole cleanitud ära, proovin mis juhtub)
Anna teada, endal ka vanad cleanimata.
makaron111
sõnum 05.12.2008 20:24:40 vasta tsitaadiga
Rockstari tugi leht:http://www.rockstargames.com/support/req_support_detail.php?product=275%2C3%2CGrand+Theft+Auto+IV%2CPC%2CRockstar_Games%2Cgta4&submit=SubmitJutt Rockstari abifailist:
GTA IV PC – Performance Tuners / Driver Issues
Users Experiencing Issues With Textures Not Loading In
There has been a reported issue of textures not loading in.  If you are experiencing visuals that resemble the screenshot below it may be associated with third party graphical performance tuners, recently switching Video Cards, and/or not uninstalling the previous drivers properly.
We recommend that users follow the steps below to resolve this:
Step 1) Go to “Add and Remove Programs” within the Control Panel.  Scroll through the list of installed programs and look for any third-party driver performance tuners that may have been installed previously.
Step 1a) If you find any of these performance tuners open the application and reset driver values back to default.  This is very important!  Do not uninstall this program before you revert the changed values.
Step 1b) Now close the program and uninstall it.
Step 2) Go to “Add and Remove Programs” within the Control Panel.  Scroll down the list of programs and remove any program with NVIDIA or ATI in the name.
Step 3) Reboot your machine.
Step 4) Download and install the latest drivers for your graphics card from one of the following locations: http://www.nvidia.com/Download/index.aspx?lang=en-us  or http://ati.amd.com/support/driver.html and save them to your computer.
Step 5) Run GTA IV
If your textures are still not loading in then you may have residual files from uninstalled drivers left on your machine.  In order to fix the former, we recommend that you take the following steps:
Step 1) Find a reputable tool that is known to clean files leftover from driver tuners.  You can search for these on the Internet.
Step 2) Uninstall your display drivers again.
Step 3) Reboot your machine.  While booting up, hold F8 until prompted with the Windows Advanced Options menu.  Choose to enter Safe Mode. (Newer computers may require you to press F8 multiple times before being prompted).
Step 4) Once in Safe Mode, setup the program found in Step 1 to search for display drivers. Run the appropriate cleaning option.  Reopen the tool and make sure that no other display driver files are found.
Step 5) Install the latest drivers that you downloaded earlier.
Step 6) Reboot your machine and load Windows up normally.
Step 7) Play Grand Theft Auto IV.
We do not come in Peace. We come ahead of Peace- Kane
madness
madness
sõnum 05.12.2008 20:26:45 vasta tsitaadiga
peeter90
peeter90
sõnum 05.12.2008 20:33:56 vasta tsitaadiga
Suht lahe. Kaks autot suht kõrvuti. Üks plahvatab ja siis teisel on pool külge lömmis. Päris tugevad lööklained on plahvatustel. Nagu pomm oleks sees icon_lol.gif
Fuz
Fuz
sõnum 05.12.2008 20:43:35 vasta tsitaadiga
Mul ka jubedalt kalab. Ostsin eile Klickist originaali, loodsin, et töötab korralikult. Aga koju tulles hakkas jama pihta.
Lõpuks siis sain mängu tööle alles täna peale lõunat. Alguses oli XP pro sp3 peal, selle peal piirdus kogu pidu ainult installiga. Mängu tööle ei saanudki.
Lõin käega ja täna hommikul panin Vista Ultimate sp1 peale, mängu sain tööle ja järgmine jama hakkas pihta. Graafika kõik ujub kahtlaselt, saan mängida natuke - 5-10 minutit, siis lööb pildi osaliselt ruuduliseks ja terve kast jookseb kokku.
Videokaardi driverid on kõige uuemad, 8.11 vist olid ja videokaardiks Sapphire ATI HD4870 512MB GDDR5 PCIE16.
Loodan, et mingi patch ikka tuleb, aga kahtlane on see, et terve arvuti paneb kokku, järsku on viga milleski muus.
Kommentaarid: 55 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 54
Rudolf112
Rudolf112
sõnum 05.12.2008 20:45:04 vasta tsitaadiga
Kõige funnim on sõita Hummeriga täiskiirusel kellelegi laupa. icon_biggrin.gif
Kommentaarid: 57 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 55
omgwtf
omgwtf
sõnum 05.12.2008 20:47:15 vasta tsitaadiga
Corvetist ronib mõnusalt üle hummer 8)
Nu
Nu
sõnum 05.12.2008 20:47:20 vasta tsitaadiga
madness kirjutas:
mul pole üldse mingeid probleeme välja arvatud paar korda olen musta ekraani saanud. aga kuna seda mul ka bf2'ga juhtub siis pigem kaardi või draiverite viga.
Mainiti siin sa+reality modi, siis otsisin googlest huvipärast, et milline välja näeb. suht masendav tegelt mis graafika tookord oli.
Edasiminek detailides on ikka tohutu. "nagu päris" fiiling tekib isegi kohati. 8)
Sellesmõttes ma annan isegi andeks praeguse sita performance.
DO you want it.. And if you had it would you flaunt it...
ss
Kommentaarid: 177 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 157
DeTHiCa.
DeTHiCa.
sõnum 05.12.2008 20:49:02 vasta tsitaadiga
hummer tõesti sõidab kõigest üle, sõna otseses mõttes. vanu ameerika autosid sellega retsida ei saa, aga uuemad papist autod sõidab enamasti ühe laksuga põlema... või siis sõidab üle.
Kommentaarid: 144 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 136
makaron111
sõnum 05.12.2008 20:52:02 vasta tsitaadiga
selline asi, et nvidia nTune ei taha maha minna, lihtsalt delete nupp talle ei aita?
Mario153
Mario153
sõnum 05.12.2008 20:55:44 vasta tsitaadiga
Mul jookseb küll korralikult ja kordagi pole kalanud. 35-50fps-i on ilusti mängus. 1600reso ja detail 100....varjud 3 ja visibility oli vist 50.
Tohutult on ikka vaeva selle mänguga nähtud....isegi kui mingisse korterisse minna saab seal kõik sodiks lasta.....füüsika ka toimib nagu peab thumbs_up.gif
Lähed poodi näitad müüjale relva....see paneb jooksu ja siis kassa tühjaks icon_biggrin.gif
Lähed interneti kohvikusse....surfad netis....leiad omale mõne huvitava ferrari....helistad ja lähed ostma
Võimatu kõike kirjaldadagi....aga kõigele on mõeldud ja võib juba öelda, et mitte GOTY aga kõigi aegade parim saavutus thumbs_up.gif
viimati muutis Mario153 05.12.2008 21:03:56, muudetud 6 korda
Kommentaarid: 56 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 50
prtv
sõnum 05.12.2008 20:57:12 vasta tsitaadiga
Mul puhtad driverid ei aidanud igatahes.
asjameez
asjameez
sõnum 05.12.2008 21:11:19 vasta tsitaadiga
Kas mõttekam on kasutada GTA mängimiseks video draiverit mis tuli mu eksootilise läpatsiga kaasa või tirida nvidia kodulehelt uuem versioon icon_question.gif Nvidia lehel on 8700M GT draiveri juurde märgitud ainult Alienwarede ning mõne Dell XPS-i toetus.
Kommentaarid: 63 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 61
Ahf
Ahf
sõnum 05.12.2008 21:28:10 vasta tsitaadiga
Ned "friend" missioone,kus lihtsalt läheb sõbraga välja kuskile,jääbki tulema või saavad need otsa ka millalgi ?
Kommentaarid: 57 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 54
makaron111
sõnum 05.12.2008 21:34:04 vasta tsitaadiga
ei tööta see värk, mis teha. Ideid välismaa foorumitest?
Edit: Noh kirjutasin Rockstarile, vaatab mis vastavad. Päris kindlasti midagi stiilis: Do a clean install to your drivers.
viimati muutis makaron111 05.12.2008 21:53:38, muudetud 1 kord
miq1988
miq1988
sõnum 05.12.2008 21:47:11 vasta tsitaadiga
@ 1680*1050
texture medium (ei saa kõrgemale panna)
render higest
Viev Distance 35 (Üle selle hakkab hoiatama)
Detail Distance 100
Vechicle Density 100
Shadow Density 16
Keskmiselt 30 fps
vahepeal langeb 24 vms peale. ei sega mängimist ega midagi.
Mängu poole pealt: Vahepeal mõni näitab suunda ühele poole aga samas ise pöörab teisele poole.
Ning kummi põletades hakkab maha jääv must kummiriba täpselt keset ratast või kummi, kuidagi jube kahtlaselt...
Ja sõbrannaga väljas olles on sõbranna vähemalt viisakas icon_biggrin.gif Lülitab telefoni välja.
I don't need anger management. I need people to stop pissing me off !
viimati muutis miq1988 05.12.2008 22:03:54, muudetud 2 korda
Pätu
Pätu
sõnum 05.12.2008 21:48:49 vasta tsitaadiga
Eriti kõva on tuletõrje autoga mööda linna täie lauluga lasta icon_razz.gif Mitte ükski väike auto ei hakka blokkima. Keegi rääkis, et mängus pole busse vms ? Endal õnnestus täna kaks korda näha liiklemas bussi.
woo456
woo456
sõnum 05.12.2008 21:50:32 vasta tsitaadiga
Kas cross-platform multiplayer on (Xbox 360 ja PC vahel) ?
Anna tooli
sõnum 05.12.2008 21:51:46 vasta tsitaadiga
woo456 kirjutas:
Ei ole. Kuigi võiks.
Kommentaarid: 361 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 298
HDTanel
Overclocker
HDTanel
sõnum 05.12.2008 21:52:39 vasta tsitaadiga
Markuu kirjutas:
Mario153 kirjutas:
tahaks juba täiega kätte saada seda mängu...
71.3% done.
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
jyrisa
sõnum 05.12.2008 21:54:22 vasta tsitaadiga
Alguses vist isegi sahistati sellest cross-platform MP-st...
Ja busse leiate alati Star Junctionilt.
Traf
sõnum 05.12.2008 22:00:07 vasta tsitaadiga
hommikuks oli mäng laetud, jube tahtmine oli mitte tööle minna. icon_biggrin.gif
nüüd aga sai juba paarkümmend minutit mängitud, ja esimesed muljed on väga head! thumbs_up.gif
jah, jõudlusega on probleeme kohati aga olen kindel, et paranduseta see ei jää, arvestades, et osad 8800GT vennad siin 50fps tegid. kindlasti pole olukord nii hull, kui mulle siinsest hirmujutust tundus. E8400 ja HD4850 ja midagi tegemata ei jää.
seekordne GTA on veidi erinev, aga mitte rohkem kui SA seda Vice Cityst oli. vajab veidi sisseelamist, usun.
eriti meeldib mulle seni mängus, kuidas on tunda, et autodel reaalselt mass on ja inerts mõjub. tegin tee peal suure hoo juures käsipiduri abil 360-kraadise pöörde ja liikusin edasi, varasemate GTA'de puhul lõpetasin teeservas reeglina. nagu päris värk kohe! icon_biggrin.gif
mulle meeldib. võin kõlada fanboyna, aga asi oli ootamist väärt ja saab ainult paremaks minna. thumbs_up.gif
edit: GTASA's oli inimeste alla ajamine raskendatud, kuna see tõi üsna suure kiirusepenalti. GTAIV's on esimesed ketšupisõidud teeservas tehtud ja tuleb tunnistada, et on päris hea siiski, et peale igat killi uuesti kiirust koguma ei pea.
libe
kvaliteetne mees
libe
sõnum 05.12.2008 22:01:07 vasta tsitaadiga
Mario153 kirjutas:
SibulonHEA
SibulonHEA
sõnum 05.12.2008 22:05:35 vasta tsitaadiga
MP töötab juba?
Kas Q6600 on mõtet klokkida et paremini seda mängu mängida?
Täielik Noob.
HDTanel
Overclocker
HDTanel
sõnum 05.12.2008 22:18:49 vasta tsitaadiga
Mai saa aru, otsin mänge MP-s aga mitte kui midagi ei leia thumbs_down.gif icon_evil.gif
Krüpto
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Grand Theft Auto IV mine lehele eelmine  1, 2, 3 ... 211, 212, 213 ... 589, 590, 591  järgmine
