loser
25.09.2008 16:59:32
GeForce Release 178.13 WHQL
Single GPU increases up to 11% in 3DMark Vantage (performance preset)
Single GPU increases up to 11% in Assassin's Creed DX10
Single GPU increases up to 15% in Bioshock DX10
Single GPU increases up to 15% in Call of Duty 4
Single GPU increases up to 8% in Enemy Territory: Quake Wars
2-way SLI increases up to 7% in Bioshock DX10
2-way SLI increases up to 10% in Company of Heroes: Opposing Fronts DX10
2-way SLI increases up to 12% in Enemy Territory: Quake Wars
2-way SLI increases up to 10% in World in Conflict DX10
Warheadi kohta paraku veel mitte sõnakestki aga muidu kenad protsendid.
| Kommentaarid: 17 loe/lisa |
16 |
Nu
25.09.2008 17:17:31
need % on vist võrreldes eelmise whql'ga.
kellel 177.9x juba peale nendel ilmselt ei muutu suurt midagi.
huvitav kas need whql nüüd FM approvali ka saavad, physix ju sees
_________________ DO you want it.. And if you had it would you flaunt it...
ss |
157 |
loser
25.09.2008 17:21:35
| Nu kirjutas: |
kellel 177.9x juba peale nendel ilmselt ei muutu suurt midagi. |
Tõsi ta on,kuna aHVid on tublid beetatestijad siis paljude jaoks ei tarvitse märgatavat vahet olla.
16 |
Cb4
26.09.2008 06:45:01
177.92 sureb mul crysis warheadis kogu aeg, aga ainult xp 32 all. Vista 32 all jookseb väga hästi!
Peab 177.92 WHQL-i ära proovima!
_________________ Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Did i ever tell you the definition of "Insanity"? |
| Kommentaarid: 113 loe/lisa |
95 |
G80
210 |
denis28
30.09.2008 17:12:02
| üüü,alienware 8)
| Kommentaarid: 67 loe/lisa |
30.09.2008 18:13:21
| denis28 kirjutas: |
| üüü,alienware 8) |
so?
| Kommentaarid: 92 loe/lisa |
Goldec
30.09.2008 18:19:08
| Branding is everything.
| Kommentaarid: 9 loe/lisa |
G80
210 |
denis28
04.10.2008 13:02:53
Edit: Warhead runs great. Then I get to the icey part and FPS drops below 10! Same story with the previous drivers as well but not as bad as this.
see ei ole ju drivude probleem?vaid crysise...minuteada
G80
04.10.2008 13:15:41
denis28, jah X2-ga langeb ka seal ice levelis mingi 20 peale kohati, see level jooksis väga kahtlaselt...
210 |
ronn
05.10.2008 08:22:21
| abi oleks vaja. GForceWare 177.98 Vista (64-bit)driverid peal ja jamab digital vibrance mis on pidevalt põhjas kui keerad 0 peale siis peale restarti on see jälle 100% peal, üldsielt ei jäta oma eelmist väärtust meelde.
| Kommentaarid: 6 loe/lisa |
G80
210 |
Cb4
05.10.2008 16:46:54
178.15 Xp-le ei ole veel? Kiire google ei andnud vähealt...
Kompan gts-i piire 32 bit Xp all erinevate draiveritega. Ning vista all võimutsenud(üli stabiilne kõrgete kelladega) 177.98, on Xp alla täielik saast
Siiani parim on 175.16
Kohe proovin 178.13 WHQL
95 |
MONX33
murjam
10.10.2008 09:28:05
Panin siis peale 178.13_geforce_winvista_32bit_english_whql draivereid.
Scalingu osas asi ikka muutumatu, õigemini nüüd on scalingu muutmise võimalus üldse maha võetud. Samas vahet ei ole enne ta niikuinii ka ei töötanud.
| Kommentaarid: 10 loe/lisa |
10 |
14.10.2008 14:16:31
Forceware 180.10 is "Big Bang II" drivers?
Version:180.10
Date: 01/10/2008
Products Supported:
NVIDIA_G92.DEV_0604.1 = "NVIDIA GeForce 9800 GX2"
NVIDIA_G92.DEV_0612.1 = "NVIDIA GeForce 9800 GTX/9800 GTX+"
NVIDIA_G92.DEV_0613.1 = "NVIDIA GeForce 9800 GTX+"
NVIDIA_GT200.DEV_05E1.1 = "NVIDIA GeForce GTX 280"
NVIDIA_GT200.DEV_05E2.1 = "NVIDIA GeForce GTX 260" |
Varsti peaks siis tulema.Muidugi tuleb enamusel moditud .inf ära oodata
Nu
14.10.2008 14:27:26
kuna performance bangi sealt oodata ei ole siis nagu polegi midagi oodata
ss |
157 |
14.10.2008 14:38:04
| Nu kirjutas: |
kuna performance bangi sealt oodata ei ole siis nagu polegi midagi oodata  |
Kui vastavat rauda ei oma siis muidugi mitte (Dual Monitor SLI FTW ).Võimalik ka,et see lisab X58 Software SLI toe
omgwtf
137 |
16.10.2008 14:44:12
GeForce v.180.10 Preview
Sellest on siiski kahju:
Indeed, SLI + multi-monitor feature is available on this set of drivers. However, we found that this feature has a few limitations for now and hopefully it can fix in the later versions :
1. SLI main focus screen cannot be set to run on the secondary monitor yet.
2. If the 3D application is running for eg. 1280x1024 resolution, the secondary display will also be changed to 1280x1024 automatically.
3. It cannot do 1680x(1050+1050) in 3D and cannot stretch 3D rendering mode into both screens
4. So far only clone mode is working properly with some drop in performance as shown in the vantage scores coming up next page
Seega hetkel võin ära unustada 1680x1050+1280x1024 SLI kahe monitori peal
Nu
16.10.2008 19:28:21
Millegipärast on nendes viimastes WHQL driverites kasutusel nview, nvshell, nvwdmcpl.dll (vana?) versioon 111.94
varem on kaua aega olnud 120.xx
ss |
157 |
G80
17.10.2008 19:07:45
Parimad drivud GTX 280-le? Need uued 178.24WHQL-id?
210 |
