| Kas kavatsed peale järelvaatamise lõppemist tellida salvestusteenust 5€ kuus? |
| Jah |
9% |
[ 51 ] |
| Ei |
42% |
[ 225 ] |
| Mul juba olemas |
38% |
[ 201 ] |
| Kolin mujale |
9% |
[ 48 ] |
| hääli kokku : 525 |
31.08.2008 17:34:37
| fernanlora kirjutas: |
| Hi there, I have Elion Internet Connection (which works very well, no problems) but the digiTV starts saying it needs to restart for updating, It updates after a few minutes with the message: "upgrading, do not disconnect", when it finishes updating it restart again but then it starts updating and so on. I've updated it many times and no changes arise, any idea? I'm calling Elion now but I guess I'll have to wait a million years to have them repairing that at home... |
This IPTV box probably needs replacement, if it has warranty call 6069966 again and tell them about this problem, they will come to you and replace it when needed. If it has no warrany, go to Elion's shop and buy a new amino box.
| Kommentaarid: 261 loe/lisa |
227 |
lurr
31.08.2008 19:26:18
and have prepared talk to people, who dont understand one word english
| Kommentaarid: 124 loe/lisa |
112 |
31.08.2008 19:31:26
| lurr kirjutas: |
and have prepared talk to people, who dont understand one word english  |
ot: how's that? Elion's technicans speak as much english as anyone in estonia. We are in Europe and more like Western people who's second language is English.
aga see selleks
227 |
jyrisa
31.08.2008 23:51:11
| Killzone88 kirjutas: |
Pärnu !
"Network Problem" Sama jama eile öösel.. |
Siis ma polnudki ainuke.
| jyrisa kirjutas: |
Ja miks ma üldse kirjutama hakkasin? Sest praegu ei ole mul üldse digiTV-d. Vahin aga mingit "Network problem" errorit keset sinist ekraani. |
See siis ööst vastu laupäeva.
| Kommentaarid: 76 loe/lisa |
72 |
ärihai
01.09.2008 13:49:44
mul säärane küsimus, et kuidas ma uue modem ruuteriga arvutis Dtv tööle saan?
sellel jookseb Dtv kõigist neljast august.
_________________ Ütle siis mõtle  |
| Kommentaarid: 141 loe/lisa |
135 |
airm
01.09.2008 15:02:04
| ärihai kirjutas: |
Ära nüüd pahanda, aga probleem on esitatud nii, nagu keegi tundmatu aru saaks:
Et mina tean kuidas kõigist neljast august digitv jookseb, aga kuidas ma ikkagi tööle saan...
Vastus on: plug and play
| Kommentaarid: 56 loe/lisa |
50 |
ärihai
01.09.2008 17:26:37
digi poxiga nääb kõigist neljast aga arvutiga ei näe ühegist
135 |
fernanlora
01.09.2008 17:29:18
| indrekp kirjutas: |
This IPTV box probably needs replacement, if it has warranty call 6069966 again and tell them about this problem, they will come to you and replace it when needed. If it has no warrany, go to Elion's shop and buy a new amino box. |
They said they'd be coming half an hour ago.. I guess they are in their way here. I hope the IPTV Box is still in guarantee, I think I joined Elion over a year ago, I hope the guarantee covers two year at least.. anyway, I'll write back to say how all ends...
By the way, in 4 of the 6 times I called, the spoke good English enough to understand each other, the last two times, they didn't but I managed in Estonian.. anyway, no communication problems so far, I'm looking forward to finding out if I'll be able to watch TV today or not (ever)...
ärihai
01.09.2008 18:11:44
Mis moodi ma ikka läbi arvuti Dtv nääksin
135 |
01.09.2008 18:47:57
| ärihai kirjutas: |
Mis moodi ma ikka läbi arvuti Dtv nääksin  |
no god damit, võta esimene postitus ette ja loe läbi kõik kokku koondatud andmed, seal on peensusteni kirjas mida ja kuidas teha.
227 |
ärihai
01.09.2008 19:19:48
| indrekp kirjutas: |
| ärihai kirjutas: |
no god damit, võta esimene postitus ette ja loe läbi kõik kokku koondatud andmed, seal on peensusteni kirjas mida ja kuidas teha. |
no ei aita uue modemruuteri puhul
135 |
01.09.2008 19:36:23
| ärihai kirjutas: |
| indrekp kirjutas: |
| ärihai kirjutas: |
no ei aita uue modemruuteri puhul  |
tõsi, ei pannud tähele, et uuest seadmest räägid, aga kui käpa seadmele peale saan siis kirjeldan wikisse ära. Niipalju on teada, et seamel on praegu automaatne seadistus vastavalt sellele mida porti lükatakse, arvutiga netti, digiboxiga pilti.
227 |
ärihai
01.09.2008 19:51:27
huvitav seda maha ei anna võtta?
või kuidagi käsitsi ip?
135 |
fernanlora
01.09.2008 20:14:07
Thanks to all how answered and helped. Eventually one guy came to my house and used a software to update that of the modem and then he also updated the TV Box, then It worked perfectly and didn't have to actually change the TV Box or throw anything away.
Anyway, just to inform you, thanks again
wad
01.09.2008 22:26:42
| indrekp kirjutas: |
| ärihai kirjutas: |
| indrekp kirjutas: |
| ärihai kirjutas: |
tõsi, ei pannud tähele, et uuest seadmest räägid, aga kui käpa seadmele peale saan siis kirjeldan wikisse ära. Niipalju on teada, et seamel on praegu automaatne seadistus vastavalt sellele mida porti lükatakse, arvutiga netti, digiboxiga pilti. |
kui st naeb amino maci siis annabki sellele vastava ip
_________________ Kaevurite ehitamis, seadistamis, j2lgimisteenused... Linuxi administreerimisteenused... kysi lisa... |
| Kommentaarid: 96 loe/lisa |
72 |
ärihai
01.09.2008 22:30:53
| wad kirjutas: |
| indrekp kirjutas: |
| ärihai kirjutas: |
| indrekp kirjutas: |
| ärihai kirjutas: |
kui st naeb amino maci siis annabki sellele vastava ip  |
oot selle uuega siis ei näegi enam arvutist Dtv-d okse
135 |
Lemmy
02.09.2008 01:13:15
| ärihai kirjutas: |
| wad kirjutas: |
oot selle uuega siis ei näegi enam arvutist Dtv-d okse |
Proovi arvutile digibox'i MAC kloonida, vaata mis teeb.
_________________ Vähem möla, pikem samm! |
| Kommentaarid: 41 loe/lisa |
38 |
02.09.2008 10:02:02
| ärge veel paanitsege, see oleneb täiesti sellest mis konfiguratsioon sees on,kui vanade seadistustega teha peaks kõike vanaviisi nägema.
227 |
ärihai
02.09.2008 13:42:07
| indrekp kirjutas: |
| ärge veel paanitsege, see oleneb täiesti sellest mis konfiguratsioon sees on,kui vanade seadistustega teha peaks kõike vanaviisi nägema. |
ma kardan, et uue seadme puhul see ei kehti aga nuh loodame, et mõni tark leiutab ka selle vastu midagi välja
ise olen loll leiutaja
Lemmy, sellest poleks kasu ju, sest siis ei nääks kahes erinevas kohas pilti.
135 |
DigeBeni
02.09.2008 15:11:34
| ... keegi TG585 ruuterit 2 vaatajakohaga kah kasutab ? kuidas toimib, pole probleeme ?
| Kommentaarid: 194 loe/lisa |
160 |
darkside
02.09.2008 15:37:21
| DigeBeni kirjutas: |
| ... keegi TG585 ruuterit 2 vaatajakohaga kah kasutab ? kuidas toimib, pole probleeme ? |
selle ruuteri ja teise vaatajakohaga on mingi kamm, läbi elioni veebi seda seadistada ei saa. proovitakse 1. oktoobriks probleem lahendada...
02.09.2008 15:59:08
Väidetavalt pidi probleem olema nokia jaama taga kahe vaatajakohaga, samas panin ise ühe tööle, helpdesk konfas eemalt teise vaatajakoha peale, sarnaselt teistele seadmetele. Pildid ees kenasti
227 |
Lemmy
02.09.2008 16:44:35
| ärihai kirjutas: |
| indrekp kirjutas: |
Lemmy, sellest poleks kasu ju, sest siis ei nääks kahes erinevas kohas pilti. |
Seda tingimust ma eespool nagu tähele ei pannud..
Kahele amino boxile korraga pilti ei anta, kui pole vastavat teenust tellitud? Kui antakse, siis peaks piisama kui MAC näitab välja, et on digibox, ei pea ju 1-1'le klappima olemasoleva seadmega.
38 |
ärihai
02.09.2008 17:10:45
hmm on see tõsi, et teist vaataja kohta ei saa siis tellida, kui pole digipoxi
Paide Elioni mammi väitis nii
135 |
õllekas
02.09.2008 17:16:26
No idee järgi peaks arvutist telku vahtimise asi nii toimima, et lisad võrgukaardi mac adre iptv dynvlan-i. Kuidas see täpsemalt peaks välja nägema pole õrna aimugi hetkel.
ärihai, viska oma ruuteri konf kuskile üles, uurib nats seda värki.
