uus teema   vasta Uudised »  Hinnad »  Inteli hinnakärped teevad 4-tuumalise Q6600 taskukohaseks märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... , 15, 16, 17  järgmine
libe
kvaliteetne mees
libe
sõnum 14.06.2008 18:05:56 vasta tsitaadiga
siLc kirjutas:
Väidetavalt peaks 17. juunil GNT Soome lattu jõudma paras (300tk) ports Q9450 tray`si ~4k.- hinnaga. /me ostab koos P5Q-E`ga arvatavasti icon_smile.gif
G80
G80
sõnum 21.07.2008 12:18:22 vasta tsitaadiga
Intel Slashes the Prices of Several Core 2 Duo CPUs, Cuts the Price of C2Q6600
Pentium developer Intel, today slashed the prices of several Core 2 Duo processors, and most notably has slashed the price of its 65nm Core 2 Quad Q6600 CPU. The price of Core 2 Quad Q6600 drops 14%, from $224 to $193 in 1000 units tray quantity. In addition to making its most popular quad-core CPU cheaper, Intel has also slashed the prices of three 45nm dual-core Core 2 Duos. The Intel Core 2 Duo E8500 is now 31% cheaper, from $266 to $183. Intel's Core 2 Duo E8400 and E7200 CPUs are now 11% and 15% cheaper, fixed at $163 and $113 respectively.
http://www.techpowerup.com/66374/Intel_Slashes_the_Prices_of_Several_Core_2_Duo_CPUs_Cuts_the_Price_of_C2Q6600.html
Ära siia kliki
Kommentaarid: 256 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 210
WäntWõll
make.believe
WäntWõll
sõnum 21.07.2008 12:30:02 vasta tsitaadiga
http://www.arvutikeskus.ee/index.php?action=look&lookid=11996 E8500 2420.-
SurfData
SurfData
sõnum 21.07.2008 12:35:10 vasta tsitaadiga
G80 kirjutas:
on kukkunud see e8500 jah juba sinna 2,5k kanti
G80
G80
sõnum 22.07.2008 14:55:53 vasta tsitaadiga
Intel Gives Some Models of Xeon a Price-cut
Following price-cuts for some of the desktop offerings (covered here) , Intel has cut the prices of some models of the enterprise-segment Xeon processor, reports industry observer DigiTimes.
The Xeon X3220, X3210 and E3110 get a roughly 12% cut with the X3220 and X3210 both dropping from an original price of US $224 to US $198 with the E3110 price dropping from US $188 to US $167, according to the company.
http://www.techpowerup.com/66483/Intel_Gives_Some_Models_of_Xeon_a_Price-cut.html
Ära siia kliki
Piipz
Piipz
sõnum 29.07.2008 06:15:44 vasta tsitaadiga
G80 kirjutas:
3600MHz peal peaks jooksma saama panna ka lõdvalt, edasi on juba FSB sein vist, olene isendist muidugi. icon_wink.gif
tahtsingi küsida, mul on mälud mingid tavalised Kingstoni omad, 4x1gb, kas see hakkab väga segama, kui ma törtsu enda 9450'i klokkida tahaks?
mis selline "rahulik" klokk võiks olla ilma, et ma peaks mälude või jumalteab mille pärast muretsema hakkama.
Kommentaarid: 37 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 34
Le Inc
Le Inc
sõnum 29.07.2008 07:08:04 vasta tsitaadiga
Minimaalne FSB ja mälu suhe on uutel Inteli plaatidel 1:1. Egas see quad suurt üle 450 Mhz siini lähe, seega peaks su mälu vähemalt 450 Mhz üle elama.
Piipz
Piipz
sõnum 29.07.2008 07:20:03 vasta tsitaadiga
ok, kui masina kokku kruvin, siis küsin abi. pole kunagi klokkinud midagi, kuid huvi nagu oleks icon_smile.gif
sõnum 29.07.2008 08:12:59 vasta tsitaadiga
enda kingstoni valueramid töötavad hea meelega 400 -> 475 5-5-5-15
Vidget
Vidget
sõnum 29.07.2008 10:38:35 vasta tsitaadiga
Piip kirjutas:
Kui sul pole ühe tuumase pilliga kunagi jõudlusest puudu jäänud, siis nüüd 4-tuumasega jääb väheks? Ei kõla just selle moodi, et vaja klokkida, kuna raha pole oma vajaduste jaoks.
Edit: Ei pea kedagi idikaks, kui ta ei oska/taha klokkida. Minu point oli selles, et enamus klokkijaid on sellised, kes ise ei vaja klokkimist üldse. Rate's surfamisele ei anna klokitud masin mitte midagi juurde.
viimati muutis Vidget 29.07.2008 11:34:06, muudetud 1 kord
Kommentaarid: 148 loe/lisa Kasutajad arvavad:  :: 1 :: 4 :: 128
Piipz
Piipz
sõnum 29.07.2008 10:43:58 vasta tsitaadiga
panen siis 8 x 450 ja muud ei pea näppima?
G80
G80
sõnum 29.07.2008 10:50:50 vasta tsitaadiga
Vidget, miks mitte klokkida, see nii lihtne ju ja ega lisa powwast küll ära ei ütleks. icon_wink.gif
Ära siia kliki
sõnum 29.07.2008 11:00:15 vasta tsitaadiga
Vidget, kellates saavad single-threaded protsessid sellegipoolest kasu ju, samuti kiireneb andmevahetus mäluga jne
mul on näiteks kiirusekasv ikka väga kobe kui arvestada et FSB on 333 pealt tõstetud 475'le (43%)
Flavius
sõnum 29.07.2008 11:05:08 vasta tsitaadiga
Piip, volti pead ka v6ib-olla lisama
Kommentaarid: 126 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 118
Piipz
Piipz
sõnum 29.07.2008 11:09:27 vasta tsitaadiga
kahjuks/õnneks on mul mitu programmi mis oskavad reaalselt igat tuuma eraldi kasutada. see, et ma klokkida ei oska, ei tähenda et ma mingi täisidikas olen. aitäh icon_smile.gif
Marie
Marie
sõnum 29.07.2008 11:33:27 vasta tsitaadiga
Piip kirjutas:
Kõik sõltub emaplaadist, see Q9450 klokkub väga väheste emaplaatidega
Piipz
Piipz
sõnum 29.07.2008 11:43:52 vasta tsitaadiga
unustasin mainida, emaplaat on Asus Rampage Formula.
G80
G80
sõnum 29.07.2008 11:55:40 vasta tsitaadiga
Piip, X48 sobib Yorkfieldile küll, 450MHz FSB ei tohiks olla probleem, kui CPU just eriti saast pole.
Ära siia kliki
Piipz
Piipz
sõnum 29.07.2008 13:37:20 vasta tsitaadiga
dääm, 3 päeva veel, siis näeb. kui suitsu tuleb ja enam ei tööta, siis enne töötas suitsu peal icon_razz.gif
Cb4
Cb4
sõnum 30.07.2008 10:34:43 vasta tsitaadiga
Vidget kirjutas:
Piip kirjutas:
Klokkimine on hobi, vöiks isegi öelda et spordiala. Ning nagu G80 mainis, miks mitte lisada Powerit, kui saad selle tasuta. Pealegi vaevalt keegi omale Q9450 masinale paneb, kui ainult rate.ee-d kasutab. Ja isegu kui kasutab, siis nt vistale meeldib kiirem prose väge.
Päss q6600 2.4 lasta 3.5 peale(sellise oc juures ei ole veel ebastabiilsust tunda ka), on ikka mönusalt kiirem masin!
Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Kommentaarid: 113 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 95
heikis
sõnum 30.07.2008 15:34:07 vasta tsitaadiga
Cb4, mina sinu juttu ei usu, et 2.4 vs 3.5 on mingi tuntav vahe sees
see on enesepetmine, et oh nüüd aknad avanevad kiiremini
Kommentaarid: 338 loe/lisa Kasutajad arvavad:  :: 0 :: 4 :: 290
G80
G80
sõnum 30.07.2008 15:37:09 vasta tsitaadiga
heikis kirjutas:
Ära siia kliki
Flavius
sõnum 30.07.2008 16:39:59 vasta tsitaadiga
see, kas prose jookseb 3.5 peal, ei sega kedagi, samas m6nes rakenduses saab v6ita sekundeid ja kokkuv6ttes rohkemgi
(winrar, office, antivir jms sk2nnimised, adobe, devc, vdub, photoshop, m6ni faili-converter, m6ne programmi laadimisaeg jpm, kes mida kasutab)
ja yldse, kes ostab endale Q6600, selleks et aknad avaneksid kiiremini, msn k2iks k2hku ning IE's saaks m6nusamalt surfata?
sõnum 30.07.2008 18:39:35 vasta tsitaadiga
mina ostsin Q6600 endale serverisse, ei kellanud alguses ega kavatse ka edaspidi kellata
serverid pole selle jaoks
Marie
Marie
sõnum 30.07.2008 23:33:12 vasta tsitaadiga
heikis kirjutas:
Ise ka usud või, eriti on tuntav vahe kui on suured kettad ja need on pildifaile täis, ma olen seda katset paljudele soovitanud, pange oma arvuti üld otsingusse käsk *.jpg ja kui teil on vähemalt 1000+ pilti arvutis näete peatselt millise viivitusega pildid allapoole kerides eelvaates avanevad, mida aeglasem protsessor seda masendavam, aeglasem, kui mitte võimatu on pilte eelvaates vaadata, sama kehtib ka muude Ketaste majandamiseks vajalike toimingute kohta.
uus teema   vasta Uudised »  Hinnad »  Inteli hinnakärped teevad 4-tuumalise Q6600 taskukohaseks mine lehele eelmine  1, 2, 3 ... , 15, 16, 17  järgmine
