libe
kvaliteetne mees
14.06.2008 19:05:56
| siLc kirjutas: |
Väidetavalt peaks 17. juunil GNT Soome lattu jõudma paras (300tk) ports Q9450 tray`si ~4k.- hinnaga. /me ostab koos P5Q-E`ga arvatavasti  |
väga hea, peab siis ühe ära tellima
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
G80
21.07.2008 13:18:22
Intel Slashes the Prices of Several Core 2 Duo CPUs, Cuts the Price of C2Q6600
| Pentium developer Intel, today slashed the prices of several Core 2 Duo processors, and most notably has slashed the price of its 65nm Core 2 Quad Q6600 CPU. The price of Core 2 Quad Q6600 drops 14%, from $224 to $193 in 1000 units tray quantity. In addition to making its most popular quad-core CPU cheaper, Intel has also slashed the prices of three 45nm dual-core Core 2 Duos. The Intel Core 2 Duo E8500 is now 31% cheaper, from $266 to $183. Intel's Core 2 Duo E8400 and E7200 CPUs are now 11% and 15% cheaper, fixed at $163 and $113 respectively. |
http://www.techpowerup.com/66374/Intel_Slashes_the_Prices_of_Several_Core_2_Duo_CPUs_Cuts_the_Price_of_C2Q6600.html
210 |
WäntWõll
make.believe
300 |
SurfData
21.07.2008 13:35:10
| G80 kirjutas: |
http://www.techpowerup.com/66374/Intel_Slashes_the_Prices_of_Several_Core_2_Duo_CPUs_Cuts_the_Price_of_C2Q6600.html |
on kukkunud see e8500 jah juba sinna 2,5k kanti
| Kommentaarid: 84 loe/lisa |
74 |
G80
22.07.2008 15:55:53
Intel Gives Some Models of Xeon a Price-cut
Following price-cuts for some of the desktop offerings (covered here) , Intel has cut the prices of some models of the enterprise-segment Xeon processor, reports industry observer DigiTimes.
The Xeon X3220, X3210 and E3110 get a roughly 12% cut with the X3220 and X3210 both dropping from an original price of US $224 to US $198 with the E3110 price dropping from US $188 to US $167, according to the company.
http://www.techpowerup.com/66483/Intel_Gives_Some_Models_of_Xeon_a_Price-cut.html
210 |
Piipz
29.07.2008 07:15:44
| G80 kirjutas: |
3600MHz peal peaks jooksma saama panna ka lõdvalt, edasi on juba FSB sein vist, olene isendist muidugi.  |
tahtsingi küsida, mul on mälud mingid tavalised Kingstoni omad, 4x1gb, kas see hakkab väga segama, kui ma törtsu enda 9450'i klokkida tahaks?
mis selline "rahulik" klokk võiks olla ilma, et ma peaks mälude või jumalteab mille pärast muretsema hakkama.
| Kommentaarid: 37 loe/lisa |
34 |
Le Inc
29.07.2008 08:08:04
| Minimaalne FSB ja mälu suhe on uutel Inteli plaatidel 1:1. Egas see quad suurt üle 450 Mhz siini lähe, seega peaks su mälu vähemalt 450 Mhz üle elama.
| Kommentaarid: 56 loe/lisa |
54 |
Piipz
29.07.2008 08:20:03
ok, kui masina kokku kruvin, siis küsin abi. pole kunagi klokkinud midagi, kuid huvi nagu oleks
34 |
29.07.2008 09:12:59
| enda kingstoni valueramid töötavad hea meelega 400 -> 475 5-5-5-15
| Kommentaarid: 85 loe/lisa |
Vidget
29.07.2008 11:38:35
| Piip kirjutas: |
ok, kui masina kokku kruvin, siis küsin abi. pole kunagi klokkinud midagi, kuid huvi nagu oleks  |
Kui sul pole ühe tuumase pilliga kunagi jõudlusest puudu jäänud, siis nüüd 4-tuumasega jääb väheks? Ei kõla just selle moodi, et vaja klokkida, kuna raha pole oma vajaduste jaoks.
Edit: Ei pea kedagi idikaks, kui ta ei oska/taha klokkida. Minu point oli selles, et enamus klokkijaid on sellised, kes ise ei vaja klokkimist üldse. Rate's surfamisele ei anna klokitud masin mitte midagi juurde.
viimati muutis Vidget 29.07.2008 12:34:06, muudetud 1 kord |
128 |
Piipz
29.07.2008 11:43:58
| panen siis 8 x 450 ja muud ei pea näppima?
34 |
G80
29.07.2008 11:50:50
Vidget, miks mitte klokkida, see nii lihtne ju ja ega lisa powwast küll ära ei ütleks.
210 |
29.07.2008 12:00:15
Vidget, kellates saavad single-threaded protsessid sellegipoolest kasu ju, samuti kiireneb andmevahetus mäluga jne
mul on näiteks kiirusekasv ikka väga kobe kui arvestada et FSB on 333 pealt tõstetud 475'le (43%)
Flavius
29.07.2008 12:05:08
| Piip, volti pead ka v6ib-olla lisama
118 |
Piipz
29.07.2008 12:09:27
kahjuks/õnneks on mul mitu programmi mis oskavad reaalselt igat tuuma eraldi kasutada. see, et ma klokkida ei oska, ei tähenda et ma mingi täisidikas olen. aitäh
34 |
Marie
| Kommentaarid: 83 loe/lisa |
74 |
Piipz
29.07.2008 12:43:52
| unustasin mainida, emaplaat on Asus Rampage Formula.
34 |
G80
29.07.2008 12:55:40
Piip, X48 sobib Yorkfieldile küll, 450MHz FSB ei tohiks olla probleem, kui CPU just eriti saast pole.
210 |
Piipz
29.07.2008 14:37:20
dääm, 3 päeva veel, siis näeb. kui suitsu tuleb ja enam ei tööta, siis enne töötas suitsu peal
p.s. vidget, point taken
34 |
Cb4
30.07.2008 11:34:43
| Vidget kirjutas: |
| Piip kirjutas: |
Edit: Ei pea kedagi idikaks, kui ta ei oska/taha klokkida. Minu point oli selles, et enamus klokkijaid on sellised, kes ise ei vaja klokkimist üldse. Rate's surfamisele ei anna klokitud masin mitte midagi juurde. |
Klokkimine on hobi, vöiks isegi öelda et spordiala. Ning nagu G80 mainis, miks mitte lisada Powerit, kui saad selle tasuta. Pealegi vaevalt keegi omale Q9450 masinale paneb, kui ainult rate.ee-d kasutab. Ja isegu kui kasutab, siis nt vistale meeldib kiirem prose väge.
Päss q6600 2.4 lasta 3.5 peale(sellise oc juures ei ole veel ebastabiilsust tunda ka), on ikka mönusalt kiirem masin!
_________________ Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Did i ever tell you the definition of "Insanity"? |
| Kommentaarid: 113 loe/lisa |
95 |
heikis
30.07.2008 16:34:07
Cb4, mina sinu juttu ei usu, et 2.4 vs 3.5 on mingi tuntav vahe sees
see on enesepetmine, et oh nüüd aknad avanevad kiiremini
| Kommentaarid: 338 loe/lisa |
290 |
G80
30.07.2008 16:37:09
| heikis kirjutas: |
see on enesepetmine, et oh nüüd aknad avanevad kiiremini |
No proovi, on küll vahe sees, eriti vistaga.
210 |
Flavius
30.07.2008 17:39:59
see, kas prose jookseb 3.5 peal, ei sega kedagi, samas m6nes rakenduses saab v6ita sekundeid ja kokkuv6ttes rohkemgi
(winrar, office, antivir jms sk2nnimised, adobe, devc, vdub, photoshop, m6ni faili-converter, m6ne programmi laadimisaeg jpm, kes mida kasutab)
ja yldse, kes ostab endale Q6600, selleks et aknad avaneksid kiiremini, msn k2iks k2hku ning IE's saaks m6nusamalt surfata?
118 |
30.07.2008 19:39:35
mina ostsin Q6600 endale serverisse, ei kellanud alguses ega kavatse ka edaspidi kellata
serverid pole selle jaoks
Marie
31.07.2008 00:33:12
| heikis kirjutas: |
Ise ka usud või, eriti on tuntav vahe kui on suured kettad ja need on pildifaile täis, ma olen seda katset paljudele soovitanud, pange oma arvuti üld otsingusse käsk *.jpg ja kui teil on vähemalt 1000+ pilti arvutis näete peatselt millise viivitusega pildid allapoole kerides eelvaates avanevad, mida aeglasem protsessor seda masendavam, aeglasem, kui mitte võimatu on pilte eelvaates vaadata, sama kehtib ka muude Ketaste majandamiseks vajalike toimingute kohta.
74 |
