uus teema   vasta Uudised »  Varia »  Mis saab (arvuti)maailmast, kui naftakriis reaalsuseks muutub? märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 223, 224, 225 ... 548, 549, 550  järgmine
sõnum 23.07.2008 18:29:31 vasta tsitaadiga
Winterwind kirjutas:
Ho Ho kirjutas:
Oled täiesti õigesti aru saanud. Lihtsalt mu jutu point oli, et praktiliselt kõigis maardlates jääb naftat järjest vähemaks kuid uusi arvestatava suurusega maardlaid pole leitud aastakümneid.
http://abcnews.go.com/Business/wireStory?id=3840469
8 miljardit barrelit = vähem kui 100 päevane maailma naftatarbimine
Pealegi tuleks sealt maardlast esimesed tilgad naftat alles 3-5 aasta jooksul.
Scart kirjutas:
Ei, Saudi Araabia ei ole üks neist, samuti mitte ka SRÜ. Nad mõlemad on saavutanud oma tootmise lae.
ei usu elusees, et näiteks venemaa pumpab täisvõimsusega.
ega putin loll ole
Küsimus pole, kas on putin on loll või mitte, kuid fakt on see, et Venemaa praegune tootmine on peakinud.
Seadmed ja puuraugud on vanad ja olemasolevad maardlad ammenduvad.
Loe ise:
But many experts have long pointed out that Russia’s petroleum industry is working under serious constraints:
Most Russian oil fields were discovered in the 1950s, 1960s and 1970s. During those energy-rich times, the then-Soviet developers skipped over all but the largest deposits. Later on, the smaller fields were developed, but these fields cannot make up for the fading giants of the past. New discoveries of any size are quite rare, even in the vastness of Russia.
Much of the equipment and technology in the Russian oil patch is outdated. In recent years, Russia has imported large amounts of Western equipment. Russia has also brought in Western personnel to help maintain oil output. Western oil service firms like Schlumberger and Baker Hughes have a large presence in Russia.
The private parties who acquired many energy Russian assets after the collapse of the Soviet Union made little in the way of long term investment. All along, there was serious doubt about the sanctity or security of the property rights these tycoons acquired in the wake of the collapse of the Soviet state. Hence there was a “boom” mentality that led to rapid exploitation of the easiest resources, with little thought for the long term.
The Russian government imposes confiscatory levels of taxation on the oil industry, with some marginal rates approaching 90%. Thus the high world prices for oil benefit the Russian treasury, but leave little in the hands of oil developers for new investment.
Despite all of this, Russian oil output has been growing at impressive rates for the past ten years or so — in the nature of 5% to 10% per year in some years. But in 2008 that growth has stopped abruptly. Output figures have actually reversed. In absolute erms, Russian oil output is down in the first four months of 2008. Russia may have reached its own “Peak Oil” point, much as the US did in 1970. This has grave implications for the growth of the Russian energy sector, and the larger Russian economy.
If Russian oil output has peaked, we can expect new kinds of both rhetoric and behavior from Russia in its domestic policies, as well as in its dealings with other nations. In all cases, you can expect to see Russia pursue its own security and national interests with a strong hand, if not with a vengeance.
Allikas: http://www.energyandoil.com/russian-oil-under-serious-constraints
One
sõnum 23.07.2008 18:32:47 vasta tsitaadiga
Tanel kirjutas:
sellegipoolest oli tegu märkimisväärse leiuga ning väide, et aastakümneid midagi leitud pole on vale.
loomulikult on venemaa ja teiste tootmine peakinud aga ainult loll usuks, et kõik toodavad TÄISVÕIMSUSEGA
nagu mõni siin väita üritab
sõnum 23.07.2008 18:33:13 vasta tsitaadiga
Tanel, eee... kust see info, et venemaa olemasolevad maardlad ammenduvad? kasutamata maardlaid peaks seal päris mitu olema.
lisaks siis tore majanduspoliitiline olukord, umbestäpselt see, mis su tsitaadis kirjutatud icon_smile.gif
- londiste
sõnum 23.07.2008 18:36:40 vasta tsitaadiga
doh.gif ära topi sõnu suhu, keegi pole seda väitnudki, et midagi leitud pole, väidetud on, et uute leiukohtade arv väheneb aasta-aastalt ja suurimad leiud tehti 60-ndatel
defineeri palun, mis asi on üldse täisvõimsusel tootmine sinu arust?
Elof
Elof
sõnum 23.07.2008 18:37:23 vasta tsitaadiga
Võibolla mõned vaidlejad ei tee vahest sellel, kas vaielda selle üle et käes on "peak oil" või selle üle, et vaatamata sellele et käes on "peak oil" ei pumbata kõiki naftamaardlaid tühjaks nii kiiresti kui võimalik, vaid nii kiiresti kui on kasu(m)lik.
Peak oil on. Aga võimalik ja kasu(m)lilk on erinevad mõisted.
viimati muutis Elof 23.07.2008 18:44:41, muudetud 4 korda
sõnum 23.07.2008 18:40:02 vasta tsitaadiga
Naftamaardlad ammenduvad keskeltläbi 6% aastas ja ega Venemaagi maardlad põhjatud pole.
Loe ülaltpoolt tsiteeritud kokkuvõtet.
Kui mõnes maardlas tootmine suureneb ja teises väheneb ja kokkuvõttes tootmine püsib sama mis aasta tagasi, siis tegemist on peakimisega ja
kui selles esimeses tootmine enam nii palju ei kasva või teises väheneb rohkem, siis juba kokkuvõttes tootmislangus.
sõnum 23.07.2008 18:41:00 vasta tsitaadiga
urr... miks uuemaid graafikuid ei ole?
- londiste
sõnum 23.07.2008 18:44:24 vasta tsitaadiga
Venemaal varusid küll, aga päris palju kohtades kus neid tasuks alles nüüd puurima hakata... samas venemaa kohta tervikliku pilti raske saada.
sõnum 23.07.2008 18:44:28 vasta tsitaadiga
Eks neid tuleb otsida...
HV-s ID-kaardiga autentimine
HV valuutakursid
One
sõnum 23.07.2008 18:45:42 vasta tsitaadiga
Tanel kirjutas:
ma ei ole kellelegi sõnu suhu toppinud, viitasin vaid sellele, et uusi leiukohti ikka leitakse
ja osad neist on ikka suht märkimisväärsed. loogiline, et nii suuri kui 60ndatel enam ei avastata.
loll oleks vist mõelda, et keegi homme ameerika suuruse tundmatu "saare" avastab?
aga noh, mõttetu vaielda..
londiste kirjutas:
nendega on sama asi kui uute leiukohtadega.. enamus avastati 60ndatel
sõnum 23.07.2008 18:45:49 vasta tsitaadiga
HV valuutakursid
sõnum 23.07.2008 18:49:27 vasta tsitaadiga
Tanel kirjutas:
olen sama meelt, mõttetu tõesti :D (y)
Tuletaks siinkohal meelde vaidlejatele, et te tegelete maailmatasemel poliitiliste, geoloogiliste ja sotsioloogiliste otsuste analüüsimise, langetamisega ning ümberlükkamisega. Kas see tiba suur tükk pole?
Jah, see on retooriline küsimus.
sõnum 23.07.2008 18:53:28 vasta tsitaadiga
Mark0 kirjutas:
Tanel kirjutas:
kas sa pole siis veel aru saanud, et me siin HV-s otsustame maailmaasjade üle? icon_eek.gif
Aga üldiselt aitab lahmimisest, ei pea sõna võtma, kui midagi asjalikku pole teemasse lisada icon_idea.gif
Scart
Scart
sõnum 23.07.2008 19:02:42 vasta tsitaadiga
Praegu on vist jälle see faas, kui paar uljast kasutajat lendab kohale, loobib ammu teada-tuntud valed faktid ja "teadmised" letti ja jääb oma kõrgel hobusel ootama, et meie siin hakkaks neid JÄLLE ümber lükkama. Ei, ei hakka. Use The Fucking Google, nagu öeldakse.
Brasiilia väljade kohta ei ole teada ei flow rate, ei kogumaht ega reaalne maksumus ja aeg. Hetkel käivad jutud 10st aastast ja 300 miljardist taalast, nagu ka enne mainitud. 8 miljardit barrelit on mõnus kääbus reaalselt suurte väljade kõrval, seda aga muidugi ju meie vaprad kasutajad ei tea.
Dakotas on uhke ja vägev ning väga suur Bakkeni väli, kus on miljardeid ja miljardeid barreleid. Guess what? Maksimaalne flow rate on 200k barrelit päevas.
SRÜ on peakinud, see on nagu teada-tuntud fakt ja mitte mingi onu Putja tahtmine ja soovimine ei mängi siin mitte mingit rolli. Peak Oil ole hetk inimkonna ajaloos, kus kari inimesi otsustab, et: "nüüd me enam tootmismahte ei tõsta ja jääbki nii". Geoloogia. Learn it.
Ho Ho
Ho Ho
sõnum 23.07.2008 19:10:14 vasta tsitaadiga
Tanel kirjutas:
100 päeva ei ole just eriti märkimisväärne. Võrdle seda nonde maardlatega millest saudi-araabia rikkaks sai.
Too väli oli suurim leid üle väga mitme aasta ning eeldusel et sealt tõesti midagi kätte saadakse on see siiski köömes. Kui palju on leitud naftat viimase 10a jooksul? Et normaalselt edasi elada peaks leidma aastas 2-3 taolist välja mida sa näiteks tõid.
Scart
Scart
sõnum 23.07.2008 19:40:06 vasta tsitaadiga
Lähema mõne tunni jooksul Freddi ja Fänni saatuse üle hääletus USAs. Hetkel antakse selle Billi pihta turmtuld nii Bloombergis kui kodanike poolt ja loodame, et ei lähe läbi.
sõnum 23.07.2008 19:40:49 vasta tsitaadiga
Scart, on sul selle kohta mingit asjakohast linki anda?
(live ülekanne vms)
HV valuutakursid
Scart
Scart
sõnum 23.07.2008 19:43:21 vasta tsitaadiga
link :: kae siit
Tanel kirjutas:
(live ülekanne vms)
Hetkel see.
Bloombergis öeldi otse välja, et Paulson on valetaja ja kaabakas ning laseb kogu riigi põhja., kui teda ei peatata. Euroopa CNBC teeb laivis kah ülekannet.
namstoop
namstoop
sõnum 23.07.2008 22:22:28 vasta tsitaadiga
Scart kirjutas:
võibolla on see sulle üllatus, aga kogu maailma tarkus ei asugi tingimata internetis. Ja paraku on ka nii, et kõva enamik internetis asuvast tõest on pigem vale kui tõde. Või heal juhul pooltõde, mis baseerub kellegi fantaasiatel. Aga kolmandala viitamisel see väike kurb tõsiasi kipub ära ununema ja asi muutub "teada-tuntuks".
Ma ei tea kas see on mingi igand vanast ajast või misasi, kui kirja pandi ainult olulisi ja kontrollitus asju ja võis tõesti olla, et kui ikka ajaleht kirjutas, siis on tõde. Nüüd on see uskumus miskipärast kandunud üle internetikasutusse, et UTFG ja saadki tõe teada.
Scart kirjutas:
irw@teada-tuntud FAKT. Ma söön oma mütsid, nii palju kui mul neid on, ära, kui Venemaa maavarade reaalse varu kohta saab FAKTE esitada. Einotõesti... icon_rolleyes.gif
Esiteks on üsna tõenäoline, et nad ei tea neid numberid isegi. Kui ei suudetud (ei olnud vaja) nõuka ajal kogu territooriumit läbi kammida, siis pole selleks suurt lootust ka sellele ajale järgnenud paari dekaadi jooksus.
Teiseks on üsna tõenäoline, et ka tänane Venemaa jätkab sama rida, mida NL - ehket ära kunagi näita oma trumpe vaid parem annan väärinfot, mida tõe pähe võetakse. Ja ongi "teada-tuntud faktid" sündinud...
Huvitav millest on tulnud näiteks see luul, et Eesti ei saa tuumereaktori jaoks vajaliku materjal toota. Ikka sellest, et nõuka ajal avaldati ametliku numbrina kõvasti väikesem, kui tegelik oli. Aga sellest olen ma juba n-aega tagasi siin teemas ka kirjutanud, pole minu asi neid vanu asju üles otsida icon_lol.gif 8) Ja nii oli see ju kõikides sfäärides.
Ei näe küll põhjust, miks peaks midagi olema muutunud. Muidugi on hetkel Venemaale kasulik näidata, et oi-oi, meil saab ka nafta kohe otsa. Ei tea mis rahal küll nende majandus vaikselt tiksub... Ja siis, kui mõnel pool võibolla tõesti on mõne maardlaga hambad ja hind laksab veel kõrgemale, saab ju kenasti veel rohkem teenida... Jah, ilmselt on Venemaal palju ka tehnilise baasi taga, aga kui mujal maailmas "rauda" hakkab ülejääma, külla hakkavad siis igasugused eksklusiivlepingud ka liikuma. Ja ripubki kogu maailm Venemaa "nisa" otsas.
Ja erinevalt vist sinust, Scart, olen ma teiste distsipliinide kõrval ka veidi geoloogiat õppinud ja suhtlen igapäevatöös päris geoloogidega (sic!), mitte kusagil netis tekkinud isehakanud spetsialistide ja guugliteadlastega. icon_exclaim.gif
verba volant, scripta manent
Scart
Scart
sõnum 23.07.2008 22:40:42 vasta tsitaadiga
namstoop kirjutas:
www.theoildrum.com
www.peakoil.com
www.latoc.com
Kui sinu arvates on need saidid rajatud mingile fantaasiale ja muule sellisele, palju õnne. Mul on täiesti siiber sellest, et tõestatud infole rajatud ülevaadete ja järelduste ning oma ala täielike spetsialistide poolt avaldatud arvamuste lugemise asemel käiakse siin vingumas, kuidas meie ei tea, millest räägime. Newsflash kulla sõber, 2005. aastal alustatud threadi algsed "paranoiast kantud umbluud" on tänapäeva reaalsus, nagu sai ka siis öeldud. Ja need sinu geoloogid teavad asjast täpselt sama palju, kui minu poolt spetsialistideks peetavad nagu näiteks mister Simmons. Ma kahtlen sügavalt, et sinu spetsialistidel on otseliin Saudi Araabia printside lossidesse, et nad S-A toodangumahte teavad.
namstoop kirjutas:
Otsi oma mütsid välja siis ja näljuta end natuke enne, sest Vene loodusvarade ministri sõnad on: "see aasta on nafta kogutoodang väiksem, kui eelmisel aastal. Järgmine aasta peaksime seda olema võimelised tõstma." Rõhk sõnal: "peaksime". Veel üks newsflash kulla sõber, see ongi PO - protsent kuni 2 toodangumahte üles ja alla, ilma et tekiks reaalselt suurenevad toodangumahud nagu on mitte peakinud riikide puhul tavaline.
namstoop
namstoop
sõnum 23.07.2008 22:47:49 vasta tsitaadiga
Scart, sa vist loed, aga ei saa aru mida kirjutatakse (ehket täpselt sellest, kui tõsiseltvõetav on mingi vene ministri väljaütlemine, ma ju kirjutasin)? Ja kus ma Saudi Araabia varudest rääkisin? icon_eek.gif
Ja samas loomulikult usud sa kõike, mida näiteks Eesti ministrid suust välja ajavad? Okkaline on su tee püha tõe poole. thumbs_up.gif
Ah heaküll jätan mõneks ajaks selle teema jälle rahule. Eks mõne aja pärast peab missioonitundes mõne sõnavõtu paanikakülvamisele jälle vahele kirja panema. Et veidi tasakaalustada või umbes nii.
Zajats
sõnum 23.07.2008 22:55:49 vasta tsitaadiga
Yldiselt on ikka Vene teinud oma naftatootmise tipu. See oli pohiline CCCP-i lagunemise pohjuseid. Samal ajal surus Reagan hindasid labi SA alla. Peale langust jaeti koik unarusse, mingi aja parast taastati. Hetkel ongi taastamise lopp, ehk 2. peak. Tootmine on oluliselt madalam kui noukaaja lopus kus pigistati viimast valja.
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 15
Scart
Scart
sõnum 23.07.2008 23:09:28 vasta tsitaadiga
namstoop kirjutas:
Sa ise ikka saad üldse aru, millest sa jahud, herr nanstoop? Tundub vist, et eriti mitte. Sa nagu selle peale ei tule, et riikide kohta on olemas toodangunumbrid läbi aastakümnete, kogu liikumine on teada nende mahtudega - on teada, mis uued väljad on töösse tulemas, millised ära langemas ja mis on üleüldine seis mingis riigis? (ainus spioonimeetoditega saadav info on S-A kohta) Sinu jaoks on ilmselgselt see üllatus, kui sellist seosetut iba jahud. Mis puutub siia Saudi-Araabia? Sinu jutu põhjal on sul olemas toredad geoloogidest sõbrad, kes lükkavad täiesti ümber absoluutselt kõik netis olema PO kohta (eriti selle, et Vene väljad pole saavutanud tootmislage), sest nemad on elukutselised ja netis on kari amatööre. Küsi neilt, mis seis on S-Aga ja kuidas on nende toodanguga lood ja mis suhe on magusa ja hapu nafta vahel näiteks praegusel hetkel - mind südamest huvitaks nende vastus.
namstoop kirjutas:
Loe ülevalt ja järgmine kord mõtle, enne postitama hakkamist. Ja ei, ei ole minu asi sulle linke otsida. Siin threadis on neid sadu ja üleval tõin ka kolm väga head URLi, loe ja mõtle ise kaasa - peaksid ju võimeline selleks olema küll.
Elof
Elof
sõnum 23.07.2008 23:19:34 vasta tsitaadiga
Tegelikult oli vist algselt selle teema ellu jätmise põhjus selles, et teavitada sellisest globaalsest jamast?
Aga kui koguaeg tuua välja ainult seda, et 'kohe läheb kõik põhja', siis informatiivsuse asemel leiab teemast muu suunitluse.
Sealjuures ei arva, et peaks mingit erilist roosade klaasidega sinisilmsust harrastama, ent objektiivsus ei pruugi alati väljenduda negativismis. Negativism kainestab kindlasti, ent kuni mingi piirini ehk.
Ma hakkan ennast vist kordama, no pole midagi teha, midagi "reaalselt" informatiivset mõne interneti-allika näol pole välja tuua, seega minugi poolest võib postituse OT'ks sildistada.
sõnum 23.07.2008 23:31:54 vasta tsitaadiga
Negativismi mina kindlasti ei harrasta, kuid pigem tuleks inimesi teavitada sellest, et lähitulevik ei pruugi nii roosiline olla.
Hetkel veel elame roosas mullis ja kirume valitsust, kuid varsti ei aita seegi 8)
HV valuutakursid
uus teema   vasta Uudised »  Varia »  Mis saab (arvuti)maailmast, kui naftakriis reaalsuseks muutub? mine lehele eelmine  1, 2, 3 ... 223, 224, 225 ... 548, 549, 550  järgmine
