| Kommentaarid: 92 loe/lisa |
Stabby
12.07.2008 12:06:49
| ja g80 seeria phys x drivereid pole ikka.
| Kommentaarid: 35 loe/lisa |
TruePlaya
12.07.2008 17:56:52
Millised oleks head drivud Vista64 jaoks Crysisele????
_________________ Puhastan, hooldan, parandan, uuendan ja koostan lauaarvuteid. Lisainfo PS-i teel! |
| Kommentaarid: 30 loe/lisa |
G80
12.07.2008 17:58:36
| TruePlaya kirjutas: |
| Millised oleks head drivud Vista64 jaoks Crysisele???? |
XP-l olid 175.80 head aga proovi ja testi.
210 |
TruePlaya
12.07.2008 18:00:20
Aga need viimased 177.41 on pasad??
G80
12.07.2008 18:05:09
| Aga need viimased 177.41 on pasad?? |
IMO need ainult GTX 280/260 jaoks tehtud, sest 8800GTS 512MB mul perf langes.
210 |
TruePlaya
12.07.2008 18:12:16
| G80 kirjutas: |
Siit saab 177.41-le moded inf-i:
http://forums.guru3d.com/showthread.php?p=2747773
Vantages skoorib hästi:
I'm just done with running a few tests on Vista x64, SP1:
Forceware 175.19: P8220 (CPU: 7282, GPU: 8589)
Forceware 175.51: P7750 (CPU: 7158, GPU: 7970)
Forceware 177.40: P7443 (CPU: 7118, GPU: 7558)
Forceware 177.41: P8727 (CPU: 7183, GPU: 9400) |
Veel juttu:
COD4
177.40 Max FPS 125fps >>>>>>> 177.41 Max FPS 132fps
Crysis
177.40 Max FPS 36.2fps >>>>>>> 177.41 Max FPS 34.6fps (min is 3fps higher than .40's)
Gears of War
177.40 60fps Very unstable, stuttering >>>>>>>>>> 177.41 silky smooth 60fps.
GRID
177.40 Max FPS 64FPS stuttering >>>>>>>>>> 177.41 Max FPS 63fps siky smooth.
Also Ive noticed that in 177.41 when I set the image quality to "High Performance" in GRID the cars look better than in "Quality" mode... which is a little strange. |
Seal sellelt foorumi lingilt lugedes:
Physix on g92 works with this driver and for me crysis runs much smoother dint have time to test any other things
G80
12.07.2008 18:50:52
TruePlaya, no ma ise testsin 177.41-ga oli AVG FPS 2FPS-i kehvem, mul jumala savi mis suvakas kuskil kirjutab.
210 |
MONX33
13.07.2008 11:55:18
tomorrow ok selge, ma seda ei teadnud ja kui läksin nvidia.com lehele uusi drivereid uurima siis tulin siia ka kiiruga postitama.
Need 175.19 driverid on mul vähemalt crysisisel päris palju perfi juurde annud kuskil 5-15 fps high settingutel 1280x1024 4xAA. Pluss cellfactoriga oli kuskil ~30-40 fps tõus
G80
13.07.2008 12:00:09
| MONX33 kirjutas: |
Need 175.19 driverid on mul vähemalt crysisisel päris palju perfi juurde annud kuskil 5-15 fps high settingutel 1280x1024 4xAA. Pluss cellfactoriga oli kuskil ~30-40 fps tõus  |
5-15FPS-i Crysis-es, esimene Aprill on läbi.
210 |
MONX33
13.07.2008 13:35:52
| G80 kirjutas: |
| MONX33 kirjutas: |
5-15FPS-i Crysis-es, esimene Aprill on läbi.  |
Tean See muidu ei ole mingi Aprillinali kahju et ma screene ei teinud
G80
13.07.2008 14:44:17
MONX33, no aga mis seal ikka paned vanad drivud tagasi ja lased testi ja teed skreeni ning siis jälle nende füüsika drivudega.Ja alles siis usun.Crysises ei anna see füüsika drivu midagi juurde, kuna Crysis ei toeta seda Ageia jura.
210 |
its2cold
174 |
14.07.2008 17:56:15
| Guru3d foorumis üks päss kirjutas: |
177.41
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX10 1680x1050, AA=No AA, Vsync=Disabled, 64 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: High
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 66.37s, Average FPS: 30.13
Min FPS: 21.24 at frame 1941, Max FPS: 37.57 at frame 986
Average Tri/Sec: -29327218, Tri/Frame: -973270
Recorded/Played Tris ratio: -0.94
!TimeDemo Run 1 Finished.
Play Time: 62.73s, Average FPS: 31.88
Average Tri/Sec: -30634406, Tri/Frame: -960878
Recorded/Played Tris ratio: -0.95
!TimeDemo Run 2 Finished.
Play Time: 63.52s, Average FPS: 31.49
Average Tri/Sec: -30241194, Tri/Frame: -960391
TimeDemo Play Ended, (3 Runs Performed)
Run #1- DX10 1680x1050 AA=No AA, 64 bit test, Quality: High ~~ Overall Average FPS: 31.685
177.66
Play Time: 65.56s, Average FPS: 30.51
Min FPS: 22.74 at frame 1937, Max FPS: 36.57 at frame 886
Average Tri/Sec: -29693478, Tri/Frame: -973347
Play Time: 61.99s, Average FPS: 32.26
Min FPS: 22.74 at frame 1937, Max FPS: 38.21 at frame 984
Average Tri/Sec: -30990310, Tri/Frame: -960572
Play Time: 62.16s, Average FPS: 32.18
Min FPS: 22.74 at frame 1937, Max FPS: 38.62 at frame 1007
Average Tri/Sec: -30896420, Tri/Frame: -960223
Run #1- DX10 1680x1050 AA=No AA, 64 bit test, Quality: High ~~ Overall Average FPS: 32.22 |
TruePlaya
14.07.2008 20:11:35
Kusjuures see uus ametlik driver ruulib...MP 1280/1024 XP High ja FPS Crysises alla 50 ei lange
Cb4
15.07.2008 10:13:37
Kusjuures see uus ametlik driver ruulib...MP 1280/1024 XP High ja FPS Crysises alla 50 ei lange  |
177.66?
Peaks vist ka proovima. On keegi veel selle peale väänanud?
_________________ Ma ei ole agressiivne juht, olen lihtsalt võistlushimuline.
Did i ever tell you the definition of "Insanity"? |
| Kommentaarid: 113 loe/lisa |
95 |
TruePlaya
15.07.2008 12:55:54
Ei see, mis on nvidia lehel, mis uuendati 9 juuli...
denis28
15.07.2008 14:56:41
| Cb4 kirjutas: |
177.66?
Peaks vist ka proovima. On keegi veel selle peale väänanud? |
hea drivu minuarust,stabiilsem sitaks kui 41
| Kommentaarid: 67 loe/lisa |
TruePlaya
15.07.2008 18:52:15
Crysis benchmark test 1280/1024 XP32 HIGH 175.19 Updaditud Drivudega
Renq
18.07.2008 02:59:39
ütleme nii, et kõik mängud ei tiirle crysise ümber. sest nba live näiteks ei suuda rohkem enam mitte hakkida näiteks viimast kvalifitseeritud draiverita. ja uutega on ka suht kehva.
TruePlaya
18.07.2008 03:03:43
Ise ka aru said, mida kirjutasid?
Renq
18.07.2008 09:49:30
sry sellise kehva teksti eest, oli jah veits kehva sõnastus. mõte on selles, et nende uuemate driveritega on nii (ka ametlikega) et a la crysis töötab normaalselt, a vähe vanemad mängud töötavad suht kehvasti (nba live 08, näiteks hakib kohutavalt ja uefa 08 talutavalt) mu küsimus oleks lihtsalt selline, et kas keegi teab vanemat driveri versiooni, mis töötaks korralikult selliste mängudega.
olen proovinud nii 175.19/175.16 kui ka 177.66 versiooni.
TruePlaya
18.07.2008 11:34:10
No mul endal on ka Live 08 ja töötab kõik perfektselt..ka viimase ametliku drivuga!!!
Cb4
18.07.2008 12:43:59
Köik peale crysise on nagunii nohu, vähemalt enamike masinate jaoks
Proovi "originaal" draivereid(need mis plaadiga kaasa)
175.80 on palju kiidetud exemplar
95 |
Le Inc
19.07.2008 15:56:36
x64 XP ja 175.16 draiverid andsid Crysises tulemuseks: Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 39,71. Kaardiks siis 8800 GTS 640.
177.66 -> Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: ~~ Overall Average FPS: 38,99
Huvitav miks ta ei lase 64bit reiimis testida? Ehk saaks buusti juurde? Mäng ise läheb 64bit käima küll.
Krt, mingi jama on. Nii 175.16 kui ka 177.66 viskab FEAR Perseus Mandate pelas pildi mustaks ja vsjoo. Siiski kõige uuema draiveriga sai ~20 min mängida, vanemaga ~2..3 mintsi ja pilt kotis. Müstika.
| Kommentaarid: 56 loe/lisa |
54 |
G80
210 |
denis28
23.07.2008 12:46:07
| ei julge panna rsk, 61 drivud on krdi stabiilsed praegu
G80
210 |
denis28
23.07.2008 21:56:19
kes peale lasi kommenteerigu
HDTanel
Overclocker
26.07.2008 00:42:18
Keegi neid 177.70 draivereid testinud on? Kuda on asjad? Lasen vist need peale kohe
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
G80
28.07.2008 00:23:34
GeForce 177.73 beta
Coming to end a very green week the GeForce 177.73 beta drivers have now made their way online. Sourced by the guys @ XFastest, the GeForce 177.73s are dated July 17 and feature support for the GeForce 6, 7, 8, 9 and GTX 200 series cards (GeForce FX support only in the Windows XP versions) and the GeForce 8100, 8200, 8300, nForce 730a, 750a and 780a IGPs. |
http://www.tcmagazine.com/comments.php?shownews=21024&catid=3
Platoon, kuidas 177.70 on?
edti:
Oki, here is some benchies
3DMark Vantage (AKA E-Peen):
177.70: P20498 H14196
177.73: P20036 H14263
Lost planet:
1650x1050 @ 16xQAA 16xAF 64 bit
177.41: Snow 71.0 Cave 71.7
177.70: Snow 72.0 Cave 75.7
177.73: Snow 69.4 Cave 72.2
3DMark06
175.19: 6125
177.66 XF: 6197
177.70 XF: 6197
177.70 modded by Side: 6203
177.73 XF: 6222
In Crysis benchmark there is increasing of 4 FPS in min and 3 FPS in avg FPS with 177.73
177.66
177.70
177.73
http://forums.guru3d.com/showthread.php?p=2786090
210 |
G80
29.07.2008 17:01:28
Vista x86
177.72
Play Time: 59.39s, Average FPS: 33.67
Min FPS: 24.50 at frame 1968, Max FPS: 50.72 at frame 992
Average Tri/Sec: 29532874, Tri/Frame: 877023
Recorded/Played Tris ratio: 1.05
Play Time: 50.94s, Average FPS: 39.27
Min FPS: 24.11 at frame 1959, Max FPS: 54.27 at frame 1014
Average Tri/Sec: 34502620, Tri/Frame: 878705
Recorded/Played Tris ratio: 1.04
Play Time: 50.86s, Average FPS: 39.32
Average Tri/Sec: 34540892, Tri/Frame: 878394
!TimeDemo Run 3 Finished.
Play Time: 50.79s, Average FPS: 39.38
Average Tri/Sec: 34577212, Tri/Frame: 878084
TimeDemo Play Ended, (4 Runs Performed)
__________________________________________________ _____________
177.79
Play Time: 57.45s, Average FPS: 34.81
Min FPS: 24.59 at frame 246, Max FPS: 50.76 at frame 985
Average Tri/Sec: 30554446, Tri/Frame: 877707
Play Time: 49.64s, Average FPS: 40.29
Min FPS: 24.59 at frame 246, Max FPS: 55.71 at frame 1012
Average Tri/Sec: 35408400, Tri/Frame: 878847
Play Time: 49.62s, Average FPS: 40.30
Average Tri/Sec: 35451144, Tri/Frame: 879593
Play Time: 49.66s, Average FPS: 40.27
Average Tri/Sec: 35392736, Tri/Frame: 878855
Päris kobe!
Kaardiks oli 9800GTX
Samas
DMC4 runs bad with those :/
Yes... Back to 177.66 |
Aga Crysise jaoks parimad hetkel!
http://forums.guru3d.com/showthread.php?p=2788190
210 |
denis28
29.07.2008 17:02:15
hakkab jälle pihta see aja vahemik vms kus tuleb iga päev uus drivu välja,neil vist käib seal kord kuus vms mingi targem vend tööl
Stabby
05.08.2008 15:18:45
Päris kiired lingid 75 KB/sec
viimati muutis Stabby 05.08.2008 15:19:05, muudetud 1 kord |
Stabby
05.08.2008 15:52:12
EDIT: Nii, installisin driveri ära ja sain aktiveerida physx, tegin 3dmark vantage kõik testid ära ja punktikasv oli ~1300 3dmarki.
Seega selline on tulemus:
[url] [/url]
05.08.2008 18:52:56
Normaalne 8) .Ainult pista pilt spoiler tag-de vahele kui saad .Kellel probleeme siis:
it didnt work before for me, but after drivercleaning , reinstalling the WHQL instead of beta , and reinstalling physics it worked.
weird thing was it said it was activated while it was not. had to choose no acceleration, accept , then enable gforce physics and accept.
MONX33
05.08.2008 20:21:59
Proovisin ka 177.79 vista drivereid ja neid uusi Physx drivereid ja mul läks see 9600GT tööle see Physx ja Warmongeris aktiveeris selle physx asja vähemalt seda ageia hoiatust ennem mängus ei annud
TruePlaya
05.08.2008 23:15:18
Igastahes need 177.79 on head XP'l..Crysises ka...keskmine FPS 47, millegagai viskan pildi varsti...
DeTHiCa.
06.08.2008 03:11:37
proovisin kaa oma 9600GT'ga
177.79 ja physx_systemsoftware
UT3 physX packi tõmbasin. seal kukkus fps peale minimaalset lammutamist 35-lt 5 peale.
vist siis ei tööta see asi veel.
140 |
ufo56
06.08.2008 11:02:07
ei tea eile töötas korra mul :S pidin restardi tegema ja kõik. Ei midagi enam
Lae pildid -> pilt.io |
| Kommentaarid: 79 loe/lisa |
67 |
profiil
06.08.2008 19:04:38
Mis jama on nende kuradi uute driveritega?!
.39 ja .79 ei lase mitte hz ka kellasid tõsta, ilma et pilti mustaks ei viska.
Vahet pole, mis programmiga proovin sagedusi tõsta, kohe kui test/ok vms vajutan, viskab pildi mustaks.
| Kommentaarid: 23 loe/lisa |
23 |
Nu
06.08.2008 19:20:09
mul 177.79 probleeme pole aga physx eriti ei taha töötada.
enableda laseb aga juurde midagi nagu ei anna.
väheste sp'de viga mul ilmselt.
_________________ DO you want it.. And if you had it would you flaunt it...
ss |
157 |
loser
06.08.2008 19:36:18
| Nu kirjutas: |
| mul 177.79 probleeme pole aga physx eriti ei taha töötada. |
Millega testisid? Vantage prose skoor tuli igatahes 2*suurem. Samas irooniline on muidugi see et PhysX demod kontrollpaneelis jooksevad ikka prose peal kuigi GPU füüsikatugi on sisse lülitatud.
| Kommentaarid: 17 loe/lisa |
16 |
Nu
06.08.2008 19:41:30
vantaget pole pragu võimalik proovida aga muid pisi demosid
nagu cubewall väiteks. seal soft ja hardware bench andsid sama tulemuse.
kahju, et seda hanger_of_doom_1.2.exe pole kuskilt saada.
ss |
157 |
MONX33
06.08.2008 22:34:41
Official Drivers released August 12!!
"On August 12, Nvidia will release new graphics drivers that will allow owners of most GeForce 8, GeForce 9, and GeForce GTX 200-series cards to use PhysX acceleration without spending a dime. Along with the drivers will come a downloadable PhysX software pack containing free Unreal Tournament 3 maps, the full version of NetDevil's Warmonger, a couple of Nvidia demos, and sneak peeks at Object Software's Metal Knight Zero and Nurien Software's Nurien social-networking service. Nvidia provided us with early access to the pack, and we've been testing it over the past couple of days."
Allikas
Lugemist Physx kohta
