HDTanel
Overclocker
14.04.2008 23:21:12
GT5 huvitab mind nüüd ainult Vormeli olemasoleku pärast. Pole korralikku vormeli mängu sada aastat enam PC peale tehtud.
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
xeon
15.04.2008 07:34:11
see rikuks minu meelest mängu nn reputationi küll ära ei meeldi mulle kohe üldse see mõte
_________________ PSN: Kilitapja |
| Kommentaarid: 26 loe/lisa |
24 |
weasel
15.04.2008 18:50:13
Uus update jälle väljas:
Spec II Update Information
Starting on Tuesday, April 15th, we have provided an update for Gran Turismo 5 Prologue Spec II.
The main contents of this update are as follows:
Online play
- The award of race credits are now allocated at a fixed rate regardless of the number of race participants.
- The High Speed Ring course diagram has been fixed.
- Some online ID's were appearing in grey in the entry list, this has been amended.
- Some online opponents appeared to "blur", this has been amended.
Rankings
- Country and area information now appears next to the online ID in the ranking boards.
- Unusually high scores had been recorded in some Drift Trials, this has been rectified.
- When Drift Trial replays were saved, occasionally these appeared in the "Load as Ghost" option of Time Trials.
This has now been rectified.
Performance Points (PP)
- The method of calculating Performance Points has been revised, to balance vehicles in events with PP upper limits.
Miscellaneous
- LCD display has been added in the F2007 interior view.
- Some interiors and exteriors of some vehicle models have been revised.
- On occasion the Quick Tune gear ratio became impossible to reset in some cars, this has been amended.
- The manual has been updated.
Caution
- The button assignments will be reset when the update is applied.
- In line with the application of the update, all ranking data will also be reset.
* To update, you will need a Playstation 3 connected to the internet with a broadband connection, and "Gran Turismo 5 Prologue" (Either the Blu-ray disc version or downloaded version).
* All information listed in this website is for Japan. For information outside Japan, please refer to the website of your region.
_________________ PSN: weaselEST |
| Kommentaarid: 38 loe/lisa |
HDTanel
Overclocker
20.04.2008 00:35:11
Kuidas G25 rooliga seda mängu mängida on? peaks varsti testida saama, üks kodanik laenab PS3, rooli ostan niisama.
496 |
Bumer
20.04.2008 13:13:06
| PlatoonSgtElias kirjutas: |
| Kuidas G25 rooliga seda mängu mängida on? peaks varsti testida saama, üks kodanik laenab PS3, rooli ostan niisama. |
ikka sitaks etem kui selle puldiga. lisaks saab kasutada h-shifterit ja sõltuvalt autost ka sidurit (ei ole lihtsalt mõnel tööle saanud, vb minu viga). ainuke jama on selles, et menüüs ei ole seda rooli valikute all olemas, mis tähendab, et pöörderaadiust ei saa muuta. rool pöörab ma ei teagi täpselt, kuskil seal 400 kraadi pöördeulatuses, aga näiteks driftimiseks tahaks panna 900, muidu on väga super
| Kommentaarid: 51 loe/lisa |
48 |
v1per
20.04.2008 13:39:24
Siin oli juttu alajuhitavusest ja kuna ala -ja ülejuhitavus tekitab paljudel vahest segadust, et kumb on kumb, siis seletan igaksjuhuks lahti asja.
Alajuhitavus on see, kui sina keerad, aga auto kipub ikka otse minema. Aitab, kui näppida tiibu (auto on alajuhitav, kui tagatiiba on rohkem peal, kui esitiiba), aga ka understeer ja oversteer kontrolleritega saab ja ongi kõige tõhusam seda asja seadistada.
Ülejuhitavus on siis see, kui auto kurvi keerab, siis tagaots hakkab libisema, võib tekkida ka piruett, kui auto on liialt ülejuhitav.
Tavaliselt seadistatakse auto niimoodi, et ta oleks veidikene ülejuhitav, kui palju see sõltub juba sõidustiilist.
| Kommentaarid: 15 loe/lisa |
14 |
Sprocket
Aeg maha 60
26 |
xeon
09.05.2008 19:56:29
muide ...kas autosid ei saagi tuunida..vedrustus turbod mootor väljalase jne ei leia naq seda kohta
24 |
angel
09.05.2008 20:33:24
demoga ju tegemist... pealegi see tüünimine minuarust rikuks asja ära (kui saaks keresid jms muuta, tulukesi panna) nagu gta 4 öeldakse: võta mill maksev auto mis on proffide poolt disainitud... tüüni ära ja asja väärtus langes kohe poole võrra ...
157 |
xeon
09.05.2008 21:20:37
noh..esimeseks autoks sai valitud 4gen golf ja kuna tal minek on ikka väga saast siis oleks hea väike turboga teda tagant lükata 8)
24 |
angel
09.05.2008 22:35:01
eri klassi autod võikski erineva jõudlusega olla... muidu mis vahet sellel on kui kõik masinad pärast ühesugused... see kaotaks ju mängu mõtte. Siis parem arcade mängu taguda kus iga masin sõidab ühtemoodi. GTR2 oli kah sama värk et kui ikka pann oli all siis mingit erilist kiirust ei saavutanud v.a kergem oli juhtida.
157 |
xeon
11.05.2008 16:08:22
peaks mainima et see gt5 p online on suht hästi tehtud...et sõites saab raha... 8)
24 |
EvilKatarn
diivanilill
11.05.2008 17:28:01
| xeon kirjutas: |
| peaks mainima et see gt5 p online on suht hästi tehtud...et sõites saab raha... 8) |
Pole see midagi uudset. Forzas sama asi.
81 |
angel
11.05.2008 18:34:53
keegi ei öelnud et see midagu uutset on... lihtsalt MP tagumine ei ole niisama tühja sõit vaid saab mingit kasu kah
157 |
xeon
14.05.2008 15:32:31
| keegi ei öelnud et see midagu uutset on... lihtsalt MP tagumine ei ole niisama tühja sõit vaid saab mingit kasu kah |
kas on oodata lähimal ajal ka mingit updatei???
24 |
19.05.2008 21:47:43
Official Playstation Magazine: Which manufacturers do you still dream on including? Porsche?
Kazunori Yamauchi: I can't really go into detail at this point, but by the time GT5 comes out I think we'll have most - no, all of the major manufacturers.
OPM: SO, come on..Porsche?
KY: Probably.
OPM: Exciting! So how are you getting on with damage modelling so far?
KY: It's not actually difficult, but there are a lot of different factors, like how many cars are going to be able to race at the same time once we've included the damage. There's going to have to be adjustments made - when you crash at over a certain speed there's no way you can drive it anymore. So the level of damage applied to the car will be dampened so that you can still have fun.
313 |
xeon
05.06.2008 21:01:17
muide lugesin siis mängu siseseid uudiseid...(news) et tuleb 1 suur live sõitmine mängijate vahel...kõigepealt olid määratud teatud riigid millest iga riigist võetakse 20 parimat ..siis tehakse veel head-to-head sõidud..siis tuleb mingi finaal...mis on pärissõit gtr-iga ....ja võitja saab koolituse,sõitja litsentsi ja ära tehtud 350z...
uudis on kõva minu arvates ....
aga eesti ei kuulunud nedne riikide hulka mis tähendab siis seda et meie ei saagi osa võtta...
uurige ise lähemalt mängusiseselt...
parandage kui kuskil mööda panin...
24 |
Bumer
48 |
peppitina
12.06.2008 00:31:52
Sain ka nüüd GT5P'le näpud taha.
Autode juhtimine jääb lahjaks natukene, nagu oleks alajuhitav vms. Võiks äkkilisem olla... Ma ei näe eriti vaeva auto juhitavusega, kõik assistid ja veojõukontrollid maas aga külge on ikkagi raske libisema saada kurvis.
| Kommentaarid: 9 loe/lisa |
9 |
angel
12.06.2008 00:40:13
külge libisema saab küll kui osata kuigi seal ei ole sellist "über drift modi" nagu mõnes mängus. Päriselt ei tohiks see driftimine vms jura nii kergelt kah tulla... selleks peab ikka vaeva nägema mitte nii nagu mõnes arcade mängus et keerad rooli, virutad käsika peale natuke ja juba asi liugleb külg ees. Osta endale seal Ford GT ja siis näed alles kuidas "driftimine" pihta hakkab. Mina igatahes puldiga seda panni ei suutnud kaua teel hoida kui kiirused suureks läksid. Sama PIIX oli ka GTR2 kus lamboga sai suure kaarega võssa pandud kuna rool läks käest ära.
GTR2 oleks vast võrdne vastane sellele GT5 + seal damage olemas ja niipalju kui mänginud oli vägagi reaalne (esimest korda ei saanud kohalt minema aka 100% gaasiga + peale teist kurvi põletasin mootori maha)
157 |
HDTanel
Overclocker
12.06.2008 01:14:44
angel, mis rooliga pelad GT5? Kuda võrreldes GTR2-ga on? Ise pelan suht palju GTR2 G25-ga, ootan, et GT5 ka norm oleks.
496 |
peppitina
12.06.2008 08:46:29
| ot: Kui siin juba roolidele jutt läks, siis asjatundjatelt küsiks -> Playstation Shock 2 Ferrari Racing Wheel <- on normaalne lelu?
9 |
xeon
12.06.2008 10:57:01
muide saab driftida ja veel kuidas...tuleb panna see mingi drivingu värk professional ja siis pane veojõukontroll maha ja enam sa teda käes ei hoia...proovi
ise driftin koos sõbraga tavaliselt 2p mode'is ise sõidan m3-mega ja subaru(see lühem variant) on üks väga hea drifti auto...sellel norra rajal ikka...
24 |
henri200
12.06.2008 12:01:01
xeon, tee video
| Kommentaarid: 62 loe/lisa |
59 |
xeon
12.06.2008 14:05:26
kusjuures olen mõelnud jah muide mul hd conceptist ka 1 video alles jäänud aga sellega ei saa midagi teha...ta on game utility all....
24 |
angel
12.06.2008 19:24:42
| angel, mis rooliga pelad GT5? Kuda võrreldes GTR2-ga on? Ise pelan suht palju GTR2 G25-ga, ootan, et GT5 ka norm oleks. |
praegusel hetkel ei ole rooli (arvuti jaoks on mingi logitech force vms)... probleem selles et ei ole asja kuhugi paigutada ilma et rooli "force" lauda koos moluga minema ei viiks + endal mugav istuda oleks. Ehk siis plaanin vaikselt kuidas asja paigutada ja kui sellega hakkama saan siis ostan arvatavasti Logitechi rooli G25.
157 |
xeon
24 |
peppitina
23.06.2008 08:27:08
| Väike nostalgia oli küll, aga kui GT1 openingi kuulen, siis tulevad küll head ajad meelde!
9 |
friik1
171 |
xeon
24.06.2008 18:42:05
amm..minuteada oli minu variant õige..ei olnud minumeelest mingit tümmiremixi...on kellelgi gt2 veel alles??äkki viitsib vaadata..
olen ikkagi kindel et cardigans originaal oli...
24 |
rere252
24.06.2008 19:35:57
Minu mäletamist mööda oli see tümmiremix ikkagi õige.
Rajareits
24.06.2008 23:08:50
| Euroopa versioonil jep Rollo's mix. USA omal tavaline, japsil hoopis kolmas.
| Kommentaarid: 74 loe/lisa |
69 |
xeon
24.06.2008 23:23:11
ju siis oli usa oma...
24 |
wirx
27.06.2008 14:14:10
kas teil luges update ilusti alla, ma mingi 10x juba proovinud, muudkui katkeb ära, I update sain kätte, aga II tuleb juba mitu päeva...mul japsi versioon ka...arvatavasti jaapanist loeb...aga kiirus on vaevaline... :s
| Kommentaarid: 80 loe/lisa |
Eric80
27.06.2008 15:11:18
Kuramus jah ! Mul kah katkeb update ära ! 30% täis ja pang
| Kommentaarid: 31 loe/lisa |
30 |
weasel
27.06.2008 15:12:11
Mingi uus update väljas?
Eric80
27.06.2008 15:17:59
| weasel, Kui üldse esimest korda pela konsooli suskad , pakub kohe update ! Närvi ajab lihtsalt !
30 |
wirx
27.06.2008 16:04:20
kujutage ette nüüd, et error ja kogu jutt on jaapani keeles...vot siis ajab närvi
tegelikult pidi olema nii, et GT5 oskab ise jätkata poolikut downloadi, viimane update on 1.5gb ja sisaldab ikka väga nämmat kraami näiteks 34 uut autot(kokku nüüd 71), uus rada, driftimine, 2 mängijat korraga, tuunimine jpm
http://www.gran-turismo.com/en/gt5p/news/d2024.html#
muidugi võiks olla nii, et paned taustal downloadima ja saad muud ka vahepeal teha...sama asi võiks olla system updatega...1mbiti otsas kõõludes on booring see
emm sii
27.06.2008 16:53:29
Minu euroopa versioonil tuli see update mingi kuu aja eest juba! (nagu sealt lehelt lugesin on see lause märtsikuust pärit, niiet kui ma aprillis oma konsooli sain siis võttis ta selle update kohe, ehk siis üle kahe kuu on see update mul olnud )
Niiet ei peaks olema uus update, käisin ka ja tsekkisin igaks juhuks, mulle ei pakkunud hetkel midagi!
| Kommentaarid: 17 loe/lisa |
14 |
Eric80
27.06.2008 17:23:18
wirx, Lugesin kah kuskilt , et peaks jätkama poolikut faili aga paraku ei jätka pooleli jäänud kohast ! See ajabki närvi noh ! Seal need uued autod ja muu värk siis ongi .
30 |
iir
27.06.2008 20:42:39
Selline küss et kas onlines seda riigi tunnust kuidagi EST ei saa panna? Mul näitab et olen FIN.
| Kommentaarid: 90 loe/lisa |
emm sii
27.06.2008 20:52:52
Selle maa tunnus on kus sul Playstation Network registreeritud on, niiet arvatavasti ei saa jah!
Asi mida Polyphony võiks update-da on see kuradima penaltite värk, vahel ajab närvi küll kui sa isegi ise ei sõida kellelegi sisse ja kohe saad mingi 4 sekundit karistada, ja rohkem ajab isegi vihale kui teed sõiduvea ja sõidad PEALE kurvi välja siis saad shortcut penalti, nagu ma tegin endale krt kurvi pikemaks kuidas krt ma lõikasin seda, isegi läks nässu ja siis veel saad trahvi!
Vot!
14 |
iir
27.06.2008 21:53:47
Aga minuarust GRID näitab et olen eestlane?
SMP
28.06.2008 00:37:47
| Tänasest hakkasin minagi gran turismo 5 g25ega mängima, no ikka väga lõbus on.
Bumer
28.06.2008 01:03:32
| SMP kirjutas: |
| Tänasest hakkasin minagi gran turismo 5 g25ega mängima, no ikka väga lõbus on. |
mul on seda juba nii palju mängitud, et üks mootoritest läks suitsema. eks näeb kas saab roolist veel asja
48 |
emm sii
28.06.2008 01:23:08
Rääkiga GT5 mängijad, mis autoga te S klassi 10-nda sõidu ära tegite, mul ülejäänud kõik tehtud aga see üks sõit tegemata, juba oma nädal aega pusin vahelduva eduga, igasuguseid autosi olen proovinud. Tglt on muidugi probleem selles, et osavust jääb puudu. Mäletan et juba GT4 suzuka raskemate sõitudega sai kõvasti pusitud!
14 |
SMP
28.06.2008 02:04:51
| Bumer kirjutas: |
| SMP kirjutas: |
mul on seda juba nii palju mängitud, et üks mootoritest läks suitsema. eks näeb kas saab roolist veel asja |
garantii alles veel?
HDTanel
Overclocker
28.06.2008 02:41:57
| Bumer kirjutas: |
| SMP kirjutas: |
Tahaks ka juba Natuke veel peab kannatama
496 |
Bumer
28.06.2008 10:45:24
| SMP kirjutas: |
| Bumer kirjutas: |
| SMP kirjutas: |
garantii alles veel? |
ei usu, minu teada peaks see olema 1 aasta ja see on juba läbi
48 |
SMP
29.06.2008 00:23:56
| Bumer kirjutas: |
| SMP kirjutas: |
| Bumer kirjutas: |
| SMP kirjutas: |
ei usu, minu teada peaks see olema 1 aasta ja see on juba läbi |
logitech ise annab sellele 2 aasat garantiit, ka minul on 2 aastat garantiid lubatud
