uus teema   vasta Raud »  Mängukonsoolid ja konsoolimängud »  [PS3] Gran Turismo 5 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 7, 8, 9 ... 105, 106, 107  järgmine
HDTanel
Overclocker
HDTanel
sõnum 14.04.2008 23:21:12 vasta tsitaadiga
GT5 huvitab mind nüüd ainult Vormeli olemasoleku pärast. Pole korralikku vormeli mängu sada aastat enam PC peale tehtud.
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
xeon
xeon
sõnum 15.04.2008 07:34:11 vasta tsitaadiga
see rikuks minu meelest mängu nn reputationi küll ära icon_sad.gif ei meeldi mulle kohe üldse see mõte icon_smile.gif
PSN: Kilitapja
Kommentaarid: 26 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 24
weasel
weasel
sõnum 15.04.2008 18:50:13 vasta tsitaadiga
Uus update jälle väljas:
“Spec II” Update Information
Starting on Tuesday, April 15th, we have provided an update for “Gran Turismo 5 Prologue Spec II”.
The main contents of this update are as follows:
Online play
- The award of race credits are now allocated at a fixed rate regardless of the number of race participants.
- The High Speed Ring course diagram has been fixed.
- Some online ID's were appearing in grey in the entry list, this has been amended.
- Some online opponents appeared to "blur", this has been amended.
Rankings
- Country and area information now appears next to the online ID in the ranking boards.
- Unusually high scores had been recorded in some Drift Trials, this has been rectified.
- When Drift Trial replays were saved, occasionally these appeared in the "Load as Ghost" option of Time Trials.
This has now been rectified.
Performance Points (PP)
- The method of calculating Performance Points has been revised, to balance vehicles in events with PP upper limits.
Miscellaneous
- LCD display has been added in the F2007 interior view.
- Some interiors and exteriors of some vehicle models have been revised.
- On occasion the Quick Tune gear ratio became impossible to reset in some cars, this has been amended.
- The manual has been updated.
Caution
- The button assignments will be reset when the update is applied.
- In line with the application of the update, all ranking data will also be reset.
* To update, you will need a Playstation 3 connected to the internet with a broadband connection, and "Gran Turismo 5 Prologue" (Either the Blu-ray disc version or downloaded version).
* All information listed in this website is for Japan. For information outside Japan, please refer to the website of your region.
PSN: weaselEST
HDTanel
Overclocker
HDTanel
sõnum 20.04.2008 00:35:11 vasta tsitaadiga
Kuidas G25 rooliga seda mängu mängida on? peaks varsti testida saama, üks kodanik laenab PS3, rooli ostan niisama.
Krüpto
Bumer
sõnum 20.04.2008 13:13:06 vasta tsitaadiga
PlatoonSgtElias kirjutas:
ikka sitaks etem kui selle puldiga. lisaks saab kasutada h-shifterit ja sõltuvalt autost ka sidurit (ei ole lihtsalt mõnel tööle saanud, vb minu viga). ainuke jama on selles, et menüüs ei ole seda rooli valikute all olemas, mis tähendab, et pöörderaadiust ei saa muuta. rool pöörab ma ei teagi täpselt, kuskil seal 400 kraadi pöördeulatuses, aga näiteks driftimiseks tahaks panna 900, muidu on väga super
Kommentaarid: 51 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 48
v1per
sõnum 20.04.2008 13:39:24 vasta tsitaadiga
Siin oli juttu alajuhitavusest ja kuna ala -ja ülejuhitavus tekitab paljudel vahest segadust, et kumb on kumb, siis seletan igaksjuhuks lahti asja.
Alajuhitavus on see, kui sina keerad, aga auto kipub ikka otse minema. Aitab, kui näppida tiibu (auto on alajuhitav, kui tagatiiba on rohkem peal, kui esitiiba), aga ka understeer ja oversteer kontrolleritega saab ja ongi kõige tõhusam seda asja seadistada.
Ülejuhitavus on siis see, kui auto kurvi keerab, siis tagaots hakkab libisema, võib tekkida ka piruett, kui auto on liialt ülejuhitav.
Tavaliselt seadistatakse auto niimoodi, et ta oleks veidikene ülejuhitav, kui palju see sõltub juba sõidustiilist.
Sprocket
Aeg maha 60
sõnum 04.05.2008 21:23:22 vasta tsitaadiga
Gran Turismo 5 Prologue Review HD
http://www.gametrailers.com/player/33540.html
Kommentaarid: 33 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 26
xeon
xeon
sõnum 09.05.2008 19:56:29 vasta tsitaadiga
muide ...kas autosid ei saagi tuunida..vedrustus turbod mootor väljalase jne ei leia naq seda kohta
PSN: Kilitapja
angel
angel
sõnum 09.05.2008 20:33:24 vasta tsitaadiga
demoga ju tegemist... pealegi see tüünimine minuarust rikuks asja ära (kui saaks keresid jms muuta, tulukesi panna) nagu gta 4 öeldakse: võta mill maksev auto mis on proffide poolt disainitud... tüüni ära ja asja väärtus langes kohe poole võrra ... icon_lol.gif
xeon
xeon
sõnum 09.05.2008 21:20:37 vasta tsitaadiga
noh..esimeseks autoks sai valitud 4gen golf ja kuna tal minek on ikka väga saast siis oleks hea väike turboga teda tagant lükata 8)
PSN: Kilitapja
angel
angel
sõnum 09.05.2008 22:35:01 vasta tsitaadiga
eri klassi autod võikski erineva jõudlusega olla... muidu mis vahet sellel on kui kõik masinad pärast ühesugused... see kaotaks ju mängu mõtte. Siis parem arcade mängu taguda kus iga masin sõidab ühtemoodi. GTR2 oli kah sama värk et kui ikka pann oli all siis mingit erilist kiirust ei saavutanud v.a kergem oli juhtida.
xeon
xeon
sõnum 11.05.2008 16:08:22 vasta tsitaadiga
peaks mainima et see gt5 p online on suht hästi tehtud...et sõites saab raha... 8)
PSN: Kilitapja
EvilKatarn
diivanilill
EvilKatarn
sõnum 11.05.2008 17:28:01 vasta tsitaadiga
xeon kirjutas:
Pole see midagi uudset. Forzas sama asi.
Kommentaarid: 110 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 81
angel
angel
sõnum 11.05.2008 18:34:53 vasta tsitaadiga
keegi ei öelnud et see midagu uutset on... lihtsalt MP tagumine ei ole niisama tühja sõit vaid saab mingit kasu kah icon_neutral.gif
xeon
xeon
sõnum 14.05.2008 15:32:31 vasta tsitaadiga
kas on oodata lähimal ajal ka mingit updatei???
PSN: Kilitapja
sõnum 19.05.2008 21:47:43 vasta tsitaadiga
Official Playstation Magazine: Which manufacturers do you still dream on including? Porsche?
Kazunori Yamauchi: I can't really go into detail at this point, but by the time GT5 comes out I think we'll have most - no, all of the major manufacturers.
OPM: SO, come on..Porsche?
KY: Probably.
OPM: Exciting! So how are you getting on with damage modelling so far?
KY: It's not actually difficult, but there are a lot of different factors, like how many cars are going to be able to race at the same time once we've included the damage. There's going to have to be adjustments made - when you crash at over a certain speed there's no way you can drive it anymore. So the level of damage applied to the car will be dampened so that you can still have fun.
xeon
xeon
sõnum 05.06.2008 21:01:17 vasta tsitaadiga
muide lugesin siis mängu siseseid uudiseid...(news) et tuleb 1 suur live sõitmine mängijate vahel...kõigepealt olid määratud teatud riigid millest iga riigist võetakse 20 parimat ..siis tehakse veel head-to-head sõidud..siis tuleb mingi finaal...mis on pärissõit gtr-iga ....ja võitja saab koolituse,sõitja litsentsi ja ära tehtud 350z...
uudis on kõva minu arvates ....
aga eesti ei kuulunud nedne riikide hulka mis tähendab siis seda et meie ei saagi osa võtta...
uurige ise lähemalt mängusiseselt...
parandage kui kuskil mööda panin...
PSN: Kilitapja
Bumer
sõnum 05.06.2008 21:20:30 vasta tsitaadiga
võistluse nimeks GT Academy
http://www.granturismoworld.com/en/gt_academy/language/index.htm
peppitina
peppitina
sõnum 12.06.2008 00:31:52 vasta tsitaadiga
Sain ka nüüd GT5P'le näpud taha.
Autode juhtimine jääb lahjaks natukene, nagu oleks alajuhitav vms. Võiks äkkilisem olla... Ma ei näe eriti vaeva auto juhitavusega, kõik assistid ja veojõukontrollid maas aga külge on ikkagi raske libisema saada kurvis.
angel
angel
sõnum 12.06.2008 00:40:13 vasta tsitaadiga
külge libisema saab küll kui osata kuigi seal ei ole sellist "über drift modi" nagu mõnes mängus. Päriselt ei tohiks see driftimine vms jura nii kergelt kah tulla... selleks peab ikka vaeva nägema mitte nii nagu mõnes arcade mängus et keerad rooli, virutad käsika peale natuke ja juba asi liugleb külg ees. Osta endale seal Ford GT ja siis näed alles kuidas "driftimine" pihta hakkab. Mina igatahes puldiga seda panni ei suutnud kaua teel hoida kui kiirused suureks läksid. Sama PIIX oli ka GTR2 kus lamboga sai suure kaarega võssa pandud kuna rool läks käest ära.
GTR2 oleks vast võrdne vastane sellele GT5 + seal damage olemas ja niipalju kui mänginud oli vägagi reaalne (esimest korda ei saanud kohalt minema aka 100% gaasiga + peale teist kurvi põletasin mootori maha)
HDTanel
Overclocker
HDTanel
sõnum 12.06.2008 01:14:44 vasta tsitaadiga
angel, mis rooliga pelad GT5? Kuda võrreldes GTR2-ga on? Ise pelan suht palju GTR2 G25-ga, ootan, et GT5 ka norm oleks.
Krüpto
peppitina
peppitina
sõnum 12.06.2008 08:46:29 vasta tsitaadiga
ot: Kui siin juba roolidele jutt läks, siis asjatundjatelt küsiks -> Playstation Shock 2 Ferrari Racing Wheel <- on normaalne lelu?
xeon
xeon
sõnum 12.06.2008 10:57:01 vasta tsitaadiga
muide saab driftida ja veel kuidas...tuleb panna see mingi drivingu värk professional ja siis pane veojõukontroll maha ja enam sa teda käes ei hoia...proovi
ise driftin koos sõbraga tavaliselt 2p mode'is ise sõidan m3-mega ja subaru(see lühem variant) on üks väga hea drifti auto...sellel norra rajal ikka...
PSN: Kilitapja
henri200
sõnum 12.06.2008 12:01:01 vasta tsitaadiga
xeon
xeon
sõnum 12.06.2008 14:05:26 vasta tsitaadiga
kusjuures olen mõelnud jah icon_smile.gif muide mul hd conceptist ka 1 video alles jäänud aga sellega ei saa midagi teha...ta on game utility all....
PSN: Kilitapja
angel
angel
sõnum 12.06.2008 19:24:42 vasta tsitaadiga
praegusel hetkel ei ole rooli (arvuti jaoks on mingi logitech force vms)... probleem selles et ei ole asja kuhugi paigutada ilma et rooli "force" lauda koos moluga minema ei viiks + endal mugav istuda oleks. Ehk siis plaanin vaikselt kuidas asja paigutada ja kui sellega hakkama saan siis ostan arvatavasti Logitechi rooli G25.
xeon
xeon
sõnum 23.06.2008 02:12:42 vasta tsitaadiga
http://www.youtube.com/watch?v=e701QHyCr0o&amp;feature=related
et teil vahepeal natuke silm puhkaks...tuletage vanu häid aegu meelde 8)
PSN: Kilitapja
peppitina
peppitina
sõnum 23.06.2008 08:27:08 vasta tsitaadiga
Väike nostalgia oli küll, aga kui GT1 openingi kuulen, siis tulevad küll head ajad meelde!
friik1
friik1
sõnum 24.06.2008 17:53:40 vasta tsitaadiga
http://www.youtube.com/watch?v=oasvs0W8iwM - õige GT2 intro, eelmine on vale mixiga.
Kusjuures, leidsin paar päeva tagasi sahtlist GT1 orika.
Kommentaarid: 195 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 170
xeon
xeon
sõnum 24.06.2008 18:42:05 vasta tsitaadiga
amm..minuteada oli minu variant õige..ei olnud minumeelest mingit tümmiremixi...on kellelgi gt2 veel alles??äkki viitsib vaadata.. icon_smile.gif
olen ikkagi kindel et cardigans originaal oli...
PSN: Kilitapja
rere252
rere252
sõnum 24.06.2008 19:35:57 vasta tsitaadiga
Minu mäletamist mööda oli see tümmiremix ikkagi õige.
Rajareits
Rajareits
sõnum 24.06.2008 23:08:50 vasta tsitaadiga
Euroopa versioonil jep Rollo's mix. USA omal tavaline, japsil hoopis kolmas.
Kommentaarid: 74 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 69
xeon
xeon
sõnum 24.06.2008 23:23:11 vasta tsitaadiga
PSN: Kilitapja
wirx
wirx
sõnum 27.06.2008 14:14:10 vasta tsitaadiga
kas teil luges update ilusti alla, ma mingi 10x juba proovinud, muudkui katkeb ära, I update sain kätte, aga II tuleb juba mitu päeva...mul japsi versioon ka...arvatavasti jaapanist loeb...aga kiirus on vaevaline... :s
Eric80
Eric80
sõnum 27.06.2008 15:11:18 vasta tsitaadiga
Kuramus jah ! icon_evil.gif Mul kah katkeb update ära ! 30% täis ja pang thumbs_down.gif
weasel
weasel
sõnum 27.06.2008 15:12:11 vasta tsitaadiga
Mingi uus update väljas?
PSN: weaselEST
Eric80
Eric80
sõnum 27.06.2008 15:17:59 vasta tsitaadiga
weasel, Kui üldse esimest korda pela konsooli suskad , pakub kohe update ! Närvi ajab lihtsalt !
wirx
wirx
sõnum 27.06.2008 16:04:20 vasta tsitaadiga
kujutage ette nüüd, et error ja kogu jutt on jaapani keeles...vot siis ajab närvi icon_biggrin.gif
tegelikult pidi olema nii, et GT5 oskab ise jätkata poolikut downloadi, viimane update on 1.5gb ja sisaldab ikka väga nämmat kraami näiteks 34 uut autot(kokku nüüd 71), uus rada, driftimine, 2 mängijat korraga, tuunimine jpm
http://www.gran-turismo.com/en/gt5p/news/d2024.html#
muidugi võiks olla nii, et paned taustal downloadima ja saad muud ka vahepeal teha...sama asi võiks olla system updatega...1mbiti otsas kõõludes on booring see
emm sii
emm sii
sõnum 27.06.2008 16:53:29 vasta tsitaadiga
Minu euroopa versioonil tuli see update mingi kuu aja eest juba! icon_smile.gif (nagu sealt lehelt lugesin on see lause märtsikuust pärit, niiet kui ma aprillis oma konsooli sain siis võttis ta selle update kohe, ehk siis üle kahe kuu on see update mul olnud icon_biggrin.gif )
Niiet ei peaks olema uus update, käisin ka ja tsekkisin igaks juhuks, mulle ei pakkunud hetkel midagi!
Kommentaarid: 17 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 14
Eric80
Eric80
sõnum 27.06.2008 17:23:18 vasta tsitaadiga
wirx, Lugesin kah kuskilt , et peaks jätkama poolikut faili aga paraku ei jätka pooleli jäänud kohast ! See ajabki närvi noh ! Seal need uued autod ja muu värk siis ongi . icon_cry.gif
iir
iir
sõnum 27.06.2008 20:42:39 vasta tsitaadiga
Selline küss et kas onlines seda riigi tunnust kuidagi EST ei saa panna? Mul näitab et olen FIN.
emm sii
emm sii
sõnum 27.06.2008 20:52:52 vasta tsitaadiga
Selle maa tunnus on kus sul Playstation Network registreeritud on, niiet arvatavasti ei saa jah! icon_sad.gif
Asi mida Polyphony võiks update-da on see kuradima penaltite värk, vahel ajab närvi küll kui sa isegi ise ei sõida kellelegi sisse ja kohe saad mingi 4 sekundit karistada, ja rohkem ajab isegi vihale kui teed sõiduvea ja sõidad PEALE kurvi välja siis saad shortcut penalti, nagu ma tegin endale krt kurvi pikemaks kuidas krt ma lõikasin seda, isegi läks nässu ja siis veel saad trahvi!
iir
iir
sõnum 27.06.2008 21:53:47 vasta tsitaadiga
Aga minuarust GRID näitab et olen eestlane?
SMP
sõnum 28.06.2008 00:37:47 vasta tsitaadiga
Tänasest hakkasin minagi gran turismo 5 g25ega mängima, no ikka väga lõbus on.
Bumer
sõnum 28.06.2008 01:03:32 vasta tsitaadiga
SMP kirjutas:
mul on seda juba nii palju mängitud, et üks mootoritest läks suitsema. eks näeb kas saab roolist veel asja
emm sii
emm sii
sõnum 28.06.2008 01:23:08 vasta tsitaadiga
Rääkiga GT5 mängijad, mis autoga te S klassi 10-nda sõidu ära tegite, mul ülejäänud kõik tehtud aga see üks sõit tegemata, juba oma nädal aega pusin vahelduva eduga, igasuguseid autosi olen proovinud. Tglt on muidugi probleem selles, et osavust jääb puudu. Mäletan et juba GT4 suzuka raskemate sõitudega sai kõvasti pusitud! icon_razz.gif
SMP
sõnum 28.06.2008 02:04:51 vasta tsitaadiga
Bumer kirjutas:
SMP kirjutas:
garantii alles veel?
HDTanel
Overclocker
HDTanel
sõnum 28.06.2008 02:41:57 vasta tsitaadiga
Bumer kirjutas:
SMP kirjutas:
Krüpto
Bumer
sõnum 28.06.2008 10:45:24 vasta tsitaadiga
SMP kirjutas:
Bumer kirjutas:
SMP kirjutas:
ei usu, minu teada peaks see olema 1 aasta ja see on juba läbi
SMP
sõnum 29.06.2008 00:23:56 vasta tsitaadiga
Bumer kirjutas:
SMP kirjutas:
Bumer kirjutas:
SMP kirjutas:
logitech ise annab sellele 2 aasat garantiit, ka minul on 2 aastat garantiid lubatud
uus teema   vasta Raud »  Mängukonsoolid ja konsoolimängud »  [PS3] Gran Turismo 5 mine lehele eelmine  1, 2, 3 ... 7, 8, 9 ... 105, 106, 107  järgmine
