G80
Kommentaarid: 256 loe/lisa |
210 |
SogegaTyyp
19.06.2008 20:17:31
Sellist tüüpi "naljade" pärast eelistaksingi sutsu oodata ja ühegigase HD4870 või X2 osta,mitte 512MB.
Kommentaarid: 54 loe/lisa |
51 |
G80
19.06.2008 20:55:58
See pilt näitab hästi, kui palju on RV770 RV670 parem:
210 |
portman
19.06.2008 21:05:44
ega jah,päris tore koomusk on ,kuna tabeli ja tulpade skaala ning mõõtmed on muljetavaldavad,siis loogiliselt võttes peaks kaart väga hea olema,mida laiem seda kiirem
SogegaTyyp usu mind,siin ei aita sind ei ükski giga ega mega,sellest suurest mälumahust pole mitte mingit kasu kui pole gpu-d mis seda tohutut informatsiooni hulka mõistliku kiirusega ära jõuaks töödelda ja r770 selleks kohe kindlasti võimeline pole
_________________ ..................  |
One
19.06.2008 21:09:39
Techpowerup-is review-d nüüd korralikult üleval.
http://www.techpowerup.com/reviews/Powercolor/HD_4850/1.html
tsitaat: |
AMD has certainly engineered a winner with their Radeon HD 4850 series. This card, positioned in the $199 segment, reaches unprecented performance levels thanks to its excellent architectural improvements. In most benchmarks it can beat the GeForce 9800 GTX which is almost $70 more expensive. As we expected, AMD's RV770 GPU can not take on the GeForce GTX 280, but sometimes it comes really close. Due to AMD's new AA design, enabling 4x Anti-Aliasing is basically free now, so there is no reason not to use AA. In my opinion the sweet spot for this card is around 1600x1200 4xAA - never before could you run all games with a $199 VGA card at this res.
Even though it offers lots of performance the HD 4850 is quiet, actually it is the quietest card we ever tested in idle. Under load the fan ramps up but noise stays within well acceptable levels. A small tradeoff of these fan control settings is that the GPU almost reaches 100°C under load, not critically high but a few °C less would be better. AMD has also kept the power consumption down, the card offers one of the best performance/watt ratios on the market.
Since recent price drops brought the Radeon HD 3850 down to a mere $120, there is no way AMD can beat that card's price/performance. On the other hand that price drop lets AMD have a very nice product stack going from lowest-end up to $199 ($299 with the Radeon HD 4870 which we will test soon). NVIDIA has taken measures and announced their GeForce 9800 GTX+ today which will have higher performance at a lower price.
Overall I think the Radeon HD 4850 is the best card on the market right now if you are on a limited budget, yet want to be able to play all the latest and greatest titles out there. |
9.8/10 8)
Kommentaarid: 1009 loe/lisa |
728 |
G80
19.06.2008 21:20:59
Sellele 4850-le paneks hea meelega mingi parema jahuti, suht kuumaks läheb ikka, eriti suvel veel.
Samas jahuti on suht vaikne küll.
210 |
19.06.2008 21:30:54
nii. 4870 on way to go ilmselt.
9800gtx+ whatever pannakse ilmselt 1:1 sinna 4850 vastu, aga 4870 vastast ma praegu ette ei kujuta. 280 sõidab sellest üle aga on ka tuntavalt kallim. 260 kohta kurat seda teab, ilmselt on minimaalselt parem kuid hetkeseisuga kallim.
kui ati sinna õigesse pricepointi saab, siis on vägev.
_________________ - londiste
Kommentaarid: 241 loe/lisa |
215 |
One
19.06.2008 21:41:39
vaevalt, et 260 kiirem on kui HD4870.
Viimasel siiski rohkem mälu(vähemalt 1024MB versioonil) ja tunduvalt suuremad klokid kui HD4850-l.
728 |
noonius
19.06.2008 21:43:30
tsitaat: |
Mingi paks pihv paugub siin
Kommentaarid: 8 loe/lisa |
19.06.2008 21:43:35
mälumaht ei ole piiraja ma pakuks. klokid on omaette küsimus.
215 |
angel
19.06.2008 21:49:00
wanawoll kirjutas: |
Alla 5k tuleb 4870 mis on veel huvitavam  |
tunduks nagu et rohkem 3-3.5k peaks tulema (kui just meile ei keerata). 4850 igatahes hea hinnaga kui just nVidia oma hindu alla ei lase (280 @8k igatahes tundub laus idiootsus) 8)
Aga jah... tundub et ATI/AMD is back (kuribanaantantsib)
ps: tore näha ikkagist kuidas crysis @ dx10 ikka ei jookse korralikult ühegi kaardiga (samas vaieldi et 8800GTX veab puhtalt enne kui mäng välja tuli)
Keegi mingit asjaliku infot omab kui kaugel 4850 ja 4870 kaartidel jahutuse kinnitus augud on? Kui sama mis X1900XT või 8800GT siis saaks Accelero S1/S2 peale virutada ja olekski probleem lahendatud
Kommentaarid: 175 loe/lisa |
157 |
One
19.06.2008 22:08:29
auguvahed on samad nagu HD38*0-il
728 |
angel
19.06.2008 22:28:28
seega kui see peale läheb siis peaks suht killer ju olema: http://arctic-cooling.com/vga2.php?idx=147
ei usu et ta nüüd X1900XT rohkem soojust eraldab...
157 |
One
728 |
19.06.2008 23:11:10
sitt ülevaade.
vahelduvad kaardid vahelduvate värvidega graafikul.
ülevaade puudub, võiks öelda.
215 |
angel
19.06.2008 23:59:29
selle lehe ülevaated on jah sageli suht piixus. Ükskord oli selline graafik kus iga kaardi kohta oli X tooni sinakas värv... piix viitsin jeh näpuga järge ajada mis värv millele kuulub.
aga nvidial on siiski rasked ajad ees... liiga kalli ja suure + vähevõimsa gpu tegid. ATi kütab vaikselt nüüd eest ära + kui tõesti asi tuleks nende hindadega müüki ka eestis (nu +200 elab üle) millega nad ülevaate lehtedel kirjas. nvidia peab siis kõvasti hindu kärpima (pole ka ime et ta nii vara oma kaardid turule tõi... lõik kartma vist).
157 |
Le Inc
20.06.2008 08:04:14
link :: Anandtech.com HD 4850 "eelvaade"
Anadtech'i vennad said revjuu õhtul nVidialt kirja kus väideti et kohe, kohe tullakse 219$ 9800 GTX+ (738MHz/1836MHz (core/SP)) välja:
Vanilla 9800 GTX hakkab ka, üla, ülla 199$ maksma.
Siiski tundub et HD 4850 on rohkem bängi kui (vanal) 9800 GTX'il.
Kommentaarid: 56 loe/lisa |
54 |
20.06.2008 08:32:28
Le Inc kirjutas: |
Siiski tundub et HD 4850 on rohkem bängi kui (vanal) 9800 GTX'il. |
Juba ülevaade tehtud sellest 4850 vastu: https://foorum.hinnavaatlus.ee/viewtopic.php?p=4467995#4467995
Kommentaarid: 92 loe/lisa |
20.06.2008 09:25:55
9800gtx+ ainukene muudatus 675->738 core.
peaks ilusasti 4850 vastu paigutuma.
tänu väiksemale protsessile ilmselt vajab veidi vähem voolu ka.
ootame 4870t.
215 |
erick
Kommentaarid: 105 loe/lisa |
95 |
20.06.2008 10:24:27
Vot mis juhtub kui inimesel on igav :
Le Inc
20.06.2008 10:29:38
Tubli et tegid lingi. Minu jutt on sutsu teise nurga alt ja teises teemas .. sellegi poolest võid tubli töö eest endale üks teha.
54 |
20.06.2008 10:31:07
Le Inc kirjutas: |
Tubli et tegid lingi. Minu jutt on sutsu teise nurga alt ja teises teemas .. sellegi poolest võid tubli töö eest endale üks teha.  |
:twisted:
heikis
20.06.2008 10:35:55
aga 8800GT-d selle 4850 vastu pole ikka mõtet vahetada.. eriti kui pead veel kilo otsa plekkima. et pigem 4870 siis oodata
Kommentaarid: 338 loe/lisa |
290 |
20.06.2008 10:48:58
lasin Vantage-ga ka:
_________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..."
Müüa: Xbox 360 E 500GB (UUS) |
Kommentaarid: 373 loe/lisa |
313 |
