uus teema   vasta Raud »  Mängukonsoolid ja konsoolimängud »  [PS3] Haze märgi kõik teemad loetuks
mine lehele 1, 2  järgmine
Mercury
sõnum 17.05.2008 17:40:08 [PS3] Haze vasta tsitaadiga
Haze
  • Ametlik leht: Siin
  • Publisher: Ubisoft
  • Developer: Free Radical
  • Stiil: Modern First-Person Shooter
  • Väljalaske kuupäev: May 20, 2008
  • Kirjeldus:
    In the game, Mantel soldiers make use of Nectar, a performance-enhancing pharmaceutical drug that grants the user enhanced speed, accuracy and strength. Mantel uses this drug to control the minds of its soldiers. When administered, "Nectar" can control--among other things-- what a soldier sees, similar to the effects of a hallucinogenic drug. It makes enemies stand out against the darker grey background because "Nectar" causes soldiers to see the enemy combatants as an orange color, "Nectar" also drowns out the surrounding images of death and destruction. An overdose of Nectar is dangerous, with loss of mental control and death being its possible side-effects. A Mantel Solider experiencing an overdose is shown by a change in there armor, changing in color from yellow to red.
    As revealed in an E³ 2007 trailer, Rebel soldiers may go in to a Play Dead state just before they are killed, allowing them to regenerate health and 'disappear' from the Mantel soldiers' sight, since they can't see dead people while on Nectar. In addition, they have been given the capability to exploit Mantel's dependence on nectar by attacking the nectar injector, extracting nectar to use on throwing knives from dead Mantel troopers and using the injector to create nectar grenades. These nectar enhanced weapons will cause a Mantel trooper to overdose on nectar, as will attacking the nectar injector. They can also steal a Mantel trooper's gun, and bury grenades in the ground as mines.
  • Multiplayer: Jah
  • Videod: Gamespot
  • Screenshotid: Gamespot
Mängus saab mängida co-op ehk kahekesti "splitscreen". Mäng sarnaneb Crysisega ja on Exclusive ainult PS3 ! thumbs_up.gif
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 60
beastbeats
beastbeats
sõnum 17.05.2008 21:11:29 vasta tsitaadiga
Kommentaarid: 364 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 280
Mercury
sõnum 17.05.2008 21:33:08 vasta tsitaadiga
Jah, demo on seal olemas - Unustastin mainida seda. Ise mängisin demot ja thumbs_up.gif
Ostan kindlasti.
Sarin
Sarin
sõnum 18.05.2008 02:44:40 vasta tsitaadiga
kaesin ka üle, päris pask
Kommentaarid: 7 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 7
angel
angel
sõnum 18.05.2008 05:10:06 vasta tsitaadiga
oot.... keegi võiks nüüd mullegi seletada mis selles mängus erilist saab olema? Demo SP oli vähemalt küll paras hunnik bullshit 1.5Giga + 45 min istall ja siis sai kõiga klassikalisemat vanastiili fps'i proovida mis võiks vabalt olla nimega MoHAA. Füüsikat nagu ei olnud. Laheda "õhkulaskmise" osa näidati kah ära nagu "midagi lahedat on aga näed ei näita icon_razz.gif " Vastaste AI karvane (oma mees pani mu granaadi otsa teele thumbs_up.gif jne. Kindlasti minu PS3 viga aga graafika oli kah kuidagi karvane ja udune nagu osad PS2 pordid PC peal.
Crysis'ega sarnaneb vist niipalju et fps, püssiga saab lasta. Mingi nektar on mis väga kiiresti lõppeb ja mille kasu nagu demos veel tunda ei saa. Puid igatahes maha võtta ei saanud. Kuulidega lehtedesse laskmine ei pannud lehti liikuma. Kauguses olev ala oli 2D pilt vs crysis full 3d.
Ei ole mänguga kursis seega ehk keegi seletaks ära mis seal fullis siis tulemas
Mercury
sõnum 18.05.2008 10:07:02 vasta tsitaadiga
Ma ei öeldnud et ta on parem crysisest. Mäng sarnaneb Halo ja Crysisega.
CB Games: How destructible are the environments and how much of a factor will it play during shootouts?
Rob: There is a very thick layer of destructability in the game. We didn’t want people to feel like they couldn’t have an effect on the game world, so you can rest assured you’ll be able to smash the place up a bit. As for how that effects things tactically, well, if you’re hiding behind a corrugated iron barrier, don’t expect protection from a grenade.
Võime öelda et Haze sarnaneb Resistancega kus füüsikat ei ole eriti palju aga mängu gameplay on thumbs_up.gif
EvilKatarn
diivanilill
EvilKatarn
sõnum 18.05.2008 10:51:37 vasta tsitaadiga
Mercury kirjutas:
Halo on hea storyga õnnestunud FPS. Crysis on hea graafikaga FPS.
Haze pole kumbagi.
Mis neil sarnast on?
Võibolla tõesti vaid esimese isiku vaade.
Kommentaarid: 109 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 80
emm sii
emm sii
sõnum 18.05.2008 12:09:09 vasta tsitaadiga
Kus te teate kui hea storyga Haze on või ei ole, kui see mäng veel väljaski ei ole? icon_wink.gif
Kommentaarid: 17 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 14
Sarin
Sarin
sõnum 18.05.2008 12:24:08 vasta tsitaadiga
mida rohkem reklaami seda pasem mäng. viimasel ajal toimib kõik nii imo :I
Mercury
sõnum 18.05.2008 12:36:51 vasta tsitaadiga
Tahad nüüd öelda et kõik reklaamitud mängud on pasad. GT5 peaks siis päris pask olema, või gta iv.
Mida rohkem reklaami seda rohkem inimesi kutsub seda mängima. Milleks paska reklaamida.
Sarin
Sarin
sõnum 18.05.2008 13:40:32 vasta tsitaadiga
Mercury kirjutas:
Tahad nüüd öelda et kõik reklaamitud mängud on pasad. GT5 peaks siis päris piix olema, või gta iv.
gta4 reklaamis rahvas rohkem kui and ise.
hea mäng müüb ise ennast
beastbeats
beastbeats
sõnum 18.05.2008 15:58:21 vasta tsitaadiga
OT:
Sarin, "vaata" ikka Eestist kaugemale...
Mercury
sõnum 18.05.2008 16:29:22 vasta tsitaadiga
Sarin kirjutas:
Mercury kirjutas:
Keri palun allapoole kuni näed suuri GTA IV plakateid, särke ja igast stuffi veel...
http://www.gta4.net/fan-site-event/
Sarin
Sarin
sõnum 18.05.2008 17:16:14 vasta tsitaadiga
Mercury kirjutas:
Sarin kirjutas:
Mercury kirjutas:
panin veits mõõda jah. mõtlesin tegelt seda teemat, et ei näidata mängu videoid ja ei räägita kui hea kõik on.
haze-i videoid ma olen juba pool aastat näha saanud ja kuulnud kui äge see tuleb, isegi korn kiitis.
Loki
Loki
sõnum 18.05.2008 21:31:25 vasta tsitaadiga
Tõmbasin, mängisin ja pettusin odavalt.
Mõttetu FPS, selline tavaline point-and-shoot koos powerupiga (nectar).
Samas hmm..
Vaatasin GTst videoid praegu.
Selgus paljupalju asju.
Fullgames pooled vahetuvad ja saab inimene olla, siis on Co-op moded ja multiplayer.
Kui pappi jätkub siis arvatavasti muretsen selle ka endale.
Sulkin
sõnum 19.05.2008 23:04:38 vasta tsitaadiga
Nõus sinuga Loki, täitsa jura...ma ei näe seal Crysesiga mingeidki sarnasusi
PSN. SuloEST
Mängud: MT, UT3, R-FoM,Kain and Lync,COD4,AC ja kohe ka GTA4
xtriz
xtriz
sõnum 20.05.2008 11:35:11 vasta tsitaadiga
IGN review: http://ps3.ign.com/articles/875/875229p1.html
4.5/10
DODONPACHI
DODONPACHI
sõnum 20.05.2008 18:01:12 vasta tsitaadiga
xtriz kirjutas:
4.5/10
It is easier to imagine the end of the world than the end of capitalism. -- nüüd saadaval ka eesti keeles
Mercury
sõnum 20.05.2008 18:38:02 vasta tsitaadiga
Sarin
Sarin
sõnum 20.05.2008 18:38:14 vasta tsitaadiga
DODONPACHI kirjutas:
xtriz kirjutas:
4.5/10
Scart
Scart
sõnum 20.05.2008 18:54:05 vasta tsitaadiga
Rohvelkopter. Ja seda mängu karjuti alguses välja, kui Crysis'i killerit? Päris hea.
DODONPACHI
DODONPACHI
sõnum 20.05.2008 18:54:39 vasta tsitaadiga
Mercury kirjutas:
Eh? Mis? Ah?
Ei saa aru.
angel
angel
sõnum 20.05.2008 19:07:14 vasta tsitaadiga
demo järgi ja vaadates paari video + kuidas korn'i laulja üritab midagi rääkida head asja kohta (vaeseke) võiks öelda et totaalne jura.
kui keegi tasuta fulli laenutaks siis vist isegi teeks paar levelit huvipärast läbi.
PS3 peal ju vähe fps'e seega kõik negatiivsed kommentaarid haze kohta on pc, wii ja xbox fänboyde omad. ps ma olen kah pc/xbox360 fänboy sellepärast ps3 ostsingi 8)
xtriz
xtriz
sõnum 20.05.2008 22:22:45 vasta tsitaadiga
angel kirjutas:
sõnum 20.05.2008 22:50:09 vasta tsitaadiga
vaadates praeguseid ülevaateid, siis kuidagi kahtlaselt suurte vahedega need hinnangud icon_confused.gif ise prooviks küll Haze ära kui oleks võimalik... icon_smile.gif vähemalt trailerid suutsud asja minu jaoks piisavalt põnevaks teha. aga rohkem pole ma süvenend ka asjasse. icon_rolleyes.gif
6/4/2025, RFK Jr: "The most effective way to prevent the spread of measles is the MMR vaccines."
uus teema   vasta Raud »  Mängukonsoolid ja konsoolimängud »  [PS3] Haze mine lehele 1, 2  järgmine
