Mercury
17.05.2008 17:40:08
[PS3] Haze |
Haze
- Ametlik leht: Siin
- Publisher: Ubisoft
- Developer: Free Radical
- Stiil: Modern First-Person Shooter
- Väljalaske kuupäev: May 20, 2008
- Kirjeldus:
In the game, Mantel soldiers make use of Nectar, a performance-enhancing pharmaceutical drug that grants the user enhanced speed, accuracy and strength. Mantel uses this drug to control the minds of its soldiers. When administered, "Nectar" can control--among other things-- what a soldier sees, similar to the effects of a hallucinogenic drug. It makes enemies stand out against the darker grey background because "Nectar" causes soldiers to see the enemy combatants as an orange color, "Nectar" also drowns out the surrounding images of death and destruction. An overdose of Nectar is dangerous, with loss of mental control and death being its possible side-effects. A Mantel Solider experiencing an overdose is shown by a change in there armor, changing in color from yellow to red.
As revealed in an E³ 2007 trailer, Rebel soldiers may go in to a Play Dead state just before they are killed, allowing them to regenerate health and 'disappear' from the Mantel soldiers' sight, since they can't see dead people while on Nectar. In addition, they have been given the capability to exploit Mantel's dependence on nectar by attacking the nectar injector, extracting nectar to use on throwing knives from dead Mantel troopers and using the injector to create nectar grenades. These nectar enhanced weapons will cause a Mantel trooper to overdose on nectar, as will attacking the nectar injector. They can also steal a Mantel trooper's gun, and bury grenades in the ground as mines. |
Multiplayer: Jah
Videod: Gamespot
Screenshotid: Gamespot
Mängus saab mängida co-op ehk kahekesti "splitscreen". Mäng sarnaneb Crysisega ja on Exclusive ainult PS3 !
| Kommentaarid: 61 loe/lisa |
60 |
beastbeats
17.05.2008 21:11:29
Demo PS-Stores saadaval
M: Cannondale Tract MIPSkiiver (uus; Polar White; Large) - 40€ |
284 |
Mercury
17.05.2008 21:33:08
Jah, demo on seal olemas - Unustastin mainida seda. Ise mängisin demot ja
Ostan kindlasti.
60 |
Sarin
18.05.2008 02:44:40
kaesin ka üle, päris pask
| Kommentaarid: 7 loe/lisa |
angel
18.05.2008 05:10:06
oot.... keegi võiks nüüd mullegi seletada mis selles mängus erilist saab olema? Demo SP oli vähemalt küll paras hunnik bullshit 1.5Giga + 45 min istall ja siis sai kõiga klassikalisemat vanastiili fps'i proovida mis võiks vabalt olla nimega MoHAA. Füüsikat nagu ei olnud. Laheda "õhkulaskmise" osa näidati kah ära nagu "midagi lahedat on aga näed ei näita " Vastaste AI karvane (oma mees pani mu granaadi otsa teele jne. Kindlasti minu PS3 viga aga graafika oli kah kuidagi karvane ja udune nagu osad PS2 pordid PC peal.
Crysis'ega sarnaneb vist niipalju et fps, püssiga saab lasta. Mingi nektar on mis väga kiiresti lõppeb ja mille kasu nagu demos veel tunda ei saa. Puid igatahes maha võtta ei saanud. Kuulidega lehtedesse laskmine ei pannud lehti liikuma. Kauguses olev ala oli 2D pilt vs crysis full 3d.
Ei ole mänguga kursis seega ehk keegi seletaks ära mis seal fullis siis tulemas
157 |
Mercury
18.05.2008 10:07:02
Ma ei öeldnud et ta on parem crysisest. Mäng sarnaneb Halo ja Crysisega.
CB Games: How destructible are the environments and how much of a factor will it play during shootouts?
Rob: There is a very thick layer of destructability in the game. We didnt want people to feel like they couldnt have an effect on the game world, so you can rest assured youll be able to smash the place up a bit. As for how that effects things tactically, well, if youre hiding behind a corrugated iron barrier, dont expect protection from a grenade. |
Võime öelda et Haze sarnaneb Resistancega kus füüsikat ei ole eriti palju aga mängu gameplay on
60 |
EvilKatarn
diivanilill
18.05.2008 10:51:37
| Mercury kirjutas: |
| Ma ei öeldnud et ta on parem crysisest. Mäng sarnaneb Halo ja Crysisega. |
Halo on hea storyga õnnestunud FPS. Crysis on hea graafikaga FPS.
Haze pole kumbagi.
Mis neil sarnast on?
Võibolla tõesti vaid esimese isiku vaade.
81 |
emm sii
18.05.2008 12:09:09
Kus te teate kui hea storyga Haze on või ei ole, kui see mäng veel väljaski ei ole?
| Kommentaarid: 17 loe/lisa |
14 |
Sarin
18.05.2008 12:24:08
mida rohkem reklaami seda pasem mäng. viimasel ajal toimib kõik nii imo :I
Mercury
18.05.2008 12:36:51
Tahad nüüd öelda et kõik reklaamitud mängud on pasad. GT5 peaks siis päris pask olema, või gta iv.
Mida rohkem reklaami seda rohkem inimesi kutsub seda mängima. Milleks paska reklaamida.
60 |
Sarin
18.05.2008 13:40:32
| Mercury kirjutas: |
Tahad nüüd öelda et kõik reklaamitud mängud on pasad. GT5 peaks siis päris piix olema, või gta iv.
Mida rohkem reklaami seda rohkem inimesi kutsub seda mängima. Milleks paska reklaamida. |
gta4 reklaamis rahvas rohkem kui and ise.
hea mäng müüb ise ennast
beastbeats
18.05.2008 15:58:21
OT:
Sarin, "vaata" ikka Eestist kaugemale...
284 |
Mercury
18.05.2008 16:29:22
| Sarin kirjutas: |
| Mercury kirjutas: |
hea mäng müüb ise ennast |
Keri palun allapoole kuni näed suuri GTA IV plakateid, särke ja igast stuffi veel...
http://www.gta4.net/fan-site-event/
60 |
Sarin
18.05.2008 17:16:14
| Mercury kirjutas: |
| Sarin kirjutas: |
| Mercury kirjutas: |
http://www.gta4.net/fan-site-event/ |
panin veits mõõda jah. mõtlesin tegelt seda teemat, et ei näidata mängu videoid ja ei räägita kui hea kõik on.
haze-i videoid ma olen juba pool aastat näha saanud ja kuulnud kui äge see tuleb, isegi korn kiitis.
Loki
18.05.2008 21:31:25
Tõmbasin, mängisin ja pettusin odavalt.
Mõttetu FPS, selline tavaline point-and-shoot koos powerupiga (nectar).
Samas hmm..
Vaatasin GTst videoid praegu.
Selgus paljupalju asju.
Fullgames pooled vahetuvad ja saab inimene olla, siis on Co-op moded ja multiplayer.
Kui pappi jätkub siis arvatavasti muretsen selle ka endale.
| Kommentaarid: 6 loe/lisa |
Sulkin
19.05.2008 23:04:38
Nõus sinuga Loki, täitsa jura...ma ei näe seal Crysesiga mingeidki sarnasusi
PSN. SuloEST
Mängud: MT, UT3, R-FoM,Kain and Lync,COD4,AC ja kohe ka GTA4
xtriz
| Kommentaarid: 9 loe/lisa |
9 |
DODONPACHI
| Kommentaarid: 23 loe/lisa |
22 |
Mercury
20.05.2008 18:38:02
Mingi xboxi vännboy kommenteeris seda
60 |
Sarin
20.05.2008 18:38:14
| DODONPACHI kirjutas: |
Scart
20.05.2008 18:54:05
| Rohvelkopter. Ja seda mängu karjuti alguses välja, kui Crysis'i killerit? Päris hea.
101 |
DODONPACHI
22 |
angel
20.05.2008 19:07:14
demo järgi ja vaadates paari video + kuidas korn'i laulja üritab midagi rääkida head asja kohta (vaeseke) võiks öelda et totaalne jura.
kui keegi tasuta fulli laenutaks siis vist isegi teeks paar levelit huvipärast läbi.
PS3 peal ju vähe fps'e seega kõik negatiivsed kommentaarid haze kohta on pc, wii ja xbox fänboyde omad. ps ma olen kah pc/xbox360 fänboy sellepärast ps3 ostsingi 8)
157 |
xtriz
20.05.2008 22:22:45
| angel kirjutas: |
Nad tegid laulu kah selle mängu järgi
9 |
20.05.2008 22:50:09
vaadates praeguseid ülevaateid, siis kuidagi kahtlaselt suurte vahedega need hinnangud ise prooviks küll Haze ära kui oleks võimalik... vähemalt trailerid suutsud asja minu jaoks piisavalt põnevaks teha. aga rohkem pole ma süvenend ka asjasse.
313 |
vabarna
20.05.2008 23:11:42
| demo sux
| Kommentaarid: 14 loe/lisa |
14 |
Mercury
21.05.2008 16:07:49
Demo ei ole just kõige parem. Aga full game on kindlasti parem. Youtubes mitmeid intervjuu videosi kus räägitakse full featureitest
60 |
Sulkin
21.05.2008 16:20:17
Kahtlen et full game ägedam on, kes ostab see näeb.
_______________
PSN: SuloEST
pronto
21.05.2008 16:21:48
| Mercury kirjutas: |
Demo ei ole just kõige parem. Aga full game on kindlasti parem. Youtubes mitmeid intervjuu videosi kus räägitakse full featureitest  |
Ma ei ole kumbagi vaadanud (ei demo, ega riliisi), kuid kui täismängu skoor metacritikus on 54%, siis ma ei taha teada, milline pidi demo tase olema. Iiik!
_________________ Magento arendused |
Mercury
21.05.2008 18:55:17
| Story on lühike suht jama. Lootsin et tuleb midagi Resistance moodi kus saaks keheksti pelada.
60 |
emm sii
14 |
NekoRobin
26.05.2008 20:34:56
Kuulsin, et see mäng oli väga suur pettumus..
_________________ M: Heavenly Sword, Eternal Sonata (PS3), Legaia 2: Dual saga, Blazblue Continuum Shift (Limited Edition, PS3), Golden Sun: The Lost Age, Final Fantasy X-2 |
| Kommentaarid: 16 loe/lisa |
angel
26.05.2008 21:20:37
igas reviews kirjutab kuidas tegemist suht hunniku haisva junniga. Mängida pidavat aitama aga graafika ja gameplay pidi suht jura olema. Ehk siis tõestus väitele: mida rohkem mõttetut hype'i ja kuulsaid onusid asja kiitmas seda suurem võimalus et sitt mäng tuleb.
157 |
Mercury
27.05.2008 17:11:59
Jah mule valmistas kah pettumust.
Juba ammu jääd silma. angel, miks sa alati virised nagu üksi asi maailmas sulle ei meeldi. Mõned inimesed on kasvõi õnnelikud, et neile üldse antakse süüa kord päevas või tüki leiba.
60 |
EvilKatarn
diivanilill
27.05.2008 17:21:16
| Mercury kirjutas: |
Juba ammu jääd silma. angel, miks sa alati virised nagu üksi asi maailmas sulle ei meeldi. Mõned inimesed on kasvõi õnnelikud, et neile üldse antakse süüa kord päevas või tüki leiba. |
Ok.. maksame siis shita eest edasi. Vinguda on igatahes parem, kui pimedalt ülistada mingit suurt haisvat kangi.
Ja see möla, et keegi on rõõmus tüki leiva eest..... noo on jama küll, aga mina sellises maailmas ei ela, ning ei saa aru kuidas selline väide siia vahele sobis.
81 |
Mercury
27.05.2008 17:48:54
| Võbolla väide ei sobinud aga viriseda ei pea iga asja peale - Pessimist.
60 |
EvilKatarn
diivanilill
27.05.2008 17:53:01
| Mercury kirjutas: |
| Võbolla väide ei sobinud aga viriseda ei pea iga asja peale - Pessimist. |
Mõiste mida sa otsid on pedant. Ning virisetakse ju ainult halbade asjade pärast.
81 |
angel
27.05.2008 18:26:22
| Mercury kirjutas: |
Avaldasin lihtsalt arvamust mis muud... asi on käkk ja tore on lihtsalt näha kuidas see hype hunnik kokku lagunes ja vana hea väide et mida rohkem hype'i ja kuulsad inimesed seda reklaamivad seda suurem võimalus et käkk tuleb. Asi on suunatud noortele jõmmidele kes ostavad kõike millel X logo peal. Nende pealt on kerge teenida + kergest ka igasugu infot ja õigusi neilt lüpsta. Au nendele kes nõnda teevad
mingi new age jeebuse komme et ole õnnelik et hingata lubatakse? aka annan vasta molli tõmba teine pool kah et mõlemad ühesugused oleks
157 |
vabarna
31.05.2008 12:08:55
| Ei ole just väga põrutav uudis, et mõni mäng on keskpärane või lausa kehv. Õlakehitus on piisavalt adekvaatne reaktsioon, ma arvan.
14 |
Ivokewok
13.06.2008 07:02:09
| Olen Angel ga nõus.Täis käkk.Sama graff mis resistancil või mis iganes junn mäng see oligi....mõttetud mesilased jooksevad ringi ja võitlevad.Resistance-i olid vahepeal väheamlt oma vahe klippid huvitav.Aga see läheb mul resycle bin-i nagu pooled mängud mis toodetakse.Õnneks Dev-idel on lollid japsid ja usakad kes seda kraami põhiliselt omale hangivad.Tegelt tuleb meeletult mänge välja aga eestlased ju vaatavad ainult exclusive variante.Ma üks selline ja õnneks pole midagi muud ostnud:P
Mercury
13.06.2008 15:46:10
Sa mingi Xboxi fänn. Resitance on väga hea mäng . Graafika Super! Gameplay Super! Kõik Super! Tuntud parima mänguna PS3.
60 |
Sarin
13.06.2008 17:18:58
keegi on ostnud ka selle mängu endale ? : p
Mercury
14.06.2008 15:50:44
Haze? Vist mitte.
60 |
kbryant8
14.06.2008 23:24:02
Ja mina veel pettusin, et xboxile seda mängu ei tulegi, nüüd vast võib öelda, et vahet ei ole ka..
Treileri järgi tundus võimas mäng
_________________ XBox360 Gamertag:M2TU24
O: Xbox360 mänge! |
| Kommentaarid: 10 loe/lisa |
10 |
Ivokewok
14.06.2008 23:36:01
xboxi fänn ei ole aga lihtsalt see mäng ei ole midagi erilist.Ma olen ikka ps3 omanik ja xboxi fänn ma olla ei saa ja pole seda kunagi kasutanud nii,et jään vastuse võlga.
Eric80
15.06.2008 19:04:22
demol on reso kah mingi 576p ainult treilerid on jah kõik maru kõvad ja ilusad nii , et ilasta või ennast täis
| Kommentaarid: 31 loe/lisa |
30 |
Mercury
15.06.2008 23:52:37
| Demo oli 720p ja mäng on ise 720p max vist.
60 |
16.06.2008 00:14:00
| Mercury kirjutas: |
| Demo oli 720p ja mäng on ise 720p max vist. |
1024x576 & 30FPS kõigest
313 |
