monty11
25.01.2008 11:24:56
Kui inglise keelega probleeme pole, siis Windowsi ja RAMi suhete kohta saab lugeda siit.
_________________ Both the universe and stupidity are infinite. I'm not so sure about the former. - A. Einstein
Tule ja kiika minu fotomaailma. |
Kommentaarid: 4 loe/lisa |
erick
25.01.2008 12:40:14
Ega sealtki artiklist eriti midagi uut välja ei tule.
EDIT: Here you go:
tsitaat: |
This computer supports a maximum of 4 GB of memory when you use four 1-GB DIMMs or two 2-GB DIMMs. Current operating systems, such as Microsoft® Windows® XP, can only use a maximum of 4 GB of address space; however, the amount of memory available to the operating system is less than 4 GB. Certain components within the computer require address space in the 4-GB range. Any address space reserved for these components cannot be used by computer memory.
The following components require memory address space:
* System ROM
* APIC(s)
* Integrated PCI devices, such as network connectors and SCSI controllers
* PCI cards
* Graphics card
* PCI Express cards (if applicable)
At start-up, the BIOS identifies the components that require address space. The BIOS dynamically calculates the amount of reserved address space required. The BIOS then subtracts the reserved address space from 4 GB to determine the amount of usable space.
If the total installed computer memory is less than the usable space, all installed computer memory is available for use only by the operating system.
If the total installed computer memory is equal to or greater than the usable address space, a small portion of installed memory is available for use by the operating system.
Mida suurema mäluhulgaga graafikakaart, seda vähem RAM'i saavad Windowsi programmid kasutada.
Kommentaarid: 105 loe/lisa |
95 |
Volum
28.01.2008 20:03:30
Krt raisk küll. 3GB recommended Esimest korda näen mängu mis tahab sellist raali
_________________ Tellin originaal A-varuosasi saksast. 15-70% soodsamalt kui esindustes!
Teostan diagonstikat tehasetasemel: BMW, VAG (Audi, VW, Seat, Skoda ja kaubikud), Volvo (sõiduautod), Scania - Tartus, Põlvas ja lisatasu eest Võrus. |
Kommentaarid: 18 loe/lisa |
16 |
Romanov
28.01.2008 20:37:16
Ma ei soovita seda eriti tõsiselt võtta
_________________ Autokool Hakka Juhiks - Autokool Tallinna külje all Laagris ja Keilas!
www.hakkajuhiks.ee |
Kommentaarid: 17 loe/lisa |
17 |
Gap
30.01.2008 01:09:44
njaa... noo Andrico näitab nüüd Assasins Creedi orienteeruvat Eestisse jõudmise aega 28 märts see aasta ... raisad lükkasid jälle mängu väljalaskmis kuupäeva edasi pidi ju alguses mingi 12 veebruar tulema ja nüüd jälle mingi kuu aega edasi lükatud.... ma ei saa aru mida see annab et niimoodi koguaeg edasi lükata? :S krdi affikari
Kommentaarid: 21 loe/lisa |
17 |
ufo56
30.01.2008 01:13:44
tsitaat: |
ma ei saa aru mida see annab et niimoodi koguaeg edasi lükata? :S krdi affikari icon_lol.gif
See annab seda , et sa ei saaks siia vinguma tulla , et OMG miks mu extra über 1337 masinal see ei jookse. Nad teevad seda selleks , et võimalikult hea ikka tuleks välja, mitte pooltoores kraam.
Lae pildid -> pilt.io |
Kommentaarid: 78 loe/lisa |
67 |
xtriz
30.01.2008 01:16:54
ufo56 kirjutas: |
tsitaat: |
See annab seda , et sa ei saaks siia vinguma tulla , et OMG miks mu extra über 1337 masinal see ei jookse. Nad teevad seda selleks , et võimalikult hea ikka tuleks välja, mitte pooltoores kraam. |
Algselt pidi üldse tulema samal ajal, kui konsooli väljaanded.
Arvan, et neil on olnud aega optimiseerimiseks küll ja küll.
Kommentaarid: 9 loe/lisa |
9 |
Romanov
30.01.2008 03:06:51
Mina pigem ootan aasta ja mängin normaalset asja, kui saan ruttu mängu kätte ning avastan et see on täielik kräpp.
17 |
monty11
30.01.2008 17:35:10
Tegelikult pole vahet, kas mängu tuleb välja õigeaegselt, varem või hiljem.
Neid, kes kusagilt probleeme leiavad on ikka küllaga.
Kui selle väljalaskmist edasi lükatakse, ju on siis mingid tõsisemad probleemid, millest pole lahti saadud. Ma sügavalt kahtlen, et nad oma kasumisaamist edasi lükkavad pelgalt tarbijatele närvikõdi tekitamiseks. Võib oletada, et edasilükkamisest tingitud pahameel ei ole võrreldav olemasoleval kujul väljalastud mängu suunas tekkiva pahameelega.
angel
30.01.2008 17:38:00
võibolla parandatakse ära need "vastane jääb seina värisema" ära... selliseid jamasid ju terve net täis ja vaevalt et keegi seda sama jama PC peal tahab näha.... tegemist ju suht rõveda bugiga.
+ optimiseeritakse ehk seekord mäng PC peale korralikult ära..
samas võimalus kah olemas et niisama narritakse PC rahvast ja siis visatakse mingi beta käntsakas järamiseks ette
Kommentaarid: 175 loe/lisa |
157 |
andres1221
30.01.2008 18:51:15
28 märts nüüd siis
Kommentaarid: 3 loe/lisa |
EvilKatarn
diivanilill
Kommentaarid: 109 loe/lisa |
80 |
angel
07.02.2008 20:33:25
tore kuulda et midagi lisatakse... aga selle lause peale ütleks ubisofti jms sarnaste firmade kohta otse: -> "Despite the recent sales slump of big-name action titles on the PC" <- lõpetage siis saasta tootmine
Huvitav kas enim "pilatud" asi eemaldatakse kah mängust et ei pea nende kärvanud laipade lõpmatut juttu pealt kuulama? Esimest korda vast on asi normul aga kui pärast uuesti mängu mängida siis viskaks arvatavasti asi üle.
157 |
xtriz
15.02.2008 02:16:32
Vist uued nõuded tulid.
tsitaat: |
Supported OS: Windows® XP/Windows Vista® (only)
Processor: Dual core processor 2.6 GHz Intel® Pentium® D or AMD Athlon 64 X2 3800+ (Intel Core® 2 Duo 2.2 GHz or AMD Athlon 64 X2 4400+ or better recommended)
RAM: 1 GB Windows Xp / 2 GB Windows Vista
Video Card: 256 MB DirectX® 10.0compliant video card or DirectX 9.0compliant card with Shader Model 3.0 or higher (see supported list)*
Sound Card: DirectX 9.0 or 10.0compliant sound card (5.1 sound card recommended)
DirectX Version: DirectX 9.0 or10.0 libraries (included on disc)
DVD-ROM: DVD-ROM dual-layer drive
Hard Drive Space: 8 GB
Peripherals Supported: Keyboard, mouse, optional controller (Xbox 360® Controller for Windows recommended)
Supported Video Cards at Time of Release:
ATI® RADEON® X1600*/1650*-1950/HD 2000/3000 series
NVIDIA GeForce® 6800*/7/8/9 series
http://forums-de.ubi.com/eve/forums/a/tpc/f/9341034934/m/1971020236
Vähemalt nüüd tunduvad nõuded normaalsed ning enam seda 3GB recommended jama pole, on 1GB XP, 2GB Vista
9 |
Scart
15.02.2008 02:16:42
Sõltub, palju see pagana mäng reaalselt tahab. Hellgate on näiteks täiesti surm 2 giga peal, sest mängu enda protsess hoggib rahumeeli 1600+ mega mälu enda alla ära - ma ei hakka arvamagi, midamoodi seda 1 gigase masinaga lastakse.
Kommentaarid: 119 loe/lisa |
101 |
Gap
22.02.2008 21:34:10
ee minu arusaamise järgi lükati jah veebruarist märtsi lõppu väidab selline lk nagu IGN.COM et meie eurooplased saame märtsi lõpus nagu nad väidavad ja jänkid saavad aprilli alguses mingi 8 vms kui see värk seal tõele vastab... aga jah ootan ise ka täiega seda mängu juba konsooli omanikud väidavad et ei ole midagi erilist aga ise arvan et natuke ikka on
17 |
Titaniumon
23.02.2008 17:32:46
nojah hea füüsika= majalt lööd 3 tala ära, jääb püsti? tunnen kaasa. Ma olen ise seda mängu pelanud, mitte demot, full versiooni nii sp-s kui mp-s. Ainbuke osa mis meeldis oli see erinevate kestade süsteem (nähtamayus jne) ja metsatasemed (dzunglid). lejäänu oli täielik pettumus. AC-ga on olen X360 peal saanud mängida u. tunni, peale 10 minutit xbxi controlleriga harjumist olin sellest mängust lummatud. AC on ikkagi saanud GT-lt 9.4 punkti. see on GS ja IGNi süü et neil sitad reviw'd on.
Scart
23.02.2008 17:47:39
Titaniumon kirjutas: |
nojah hea füüsika= majalt lööd 3 tala ära, jääb püsti? tunnen kaasa. Ma olen ise seda mängu pelanud, mitte demot, full versiooni nii sp-s kui mp-s. Ainbuke osa mis meeldis oli see erinevate kestade süsteem (nähtamayus jne) ja metsatasemed (dzunglid). lejäänu oli täielik pettumus. AC-ga on olen X360 peal saanud mängida u. tunni, peale 10 minutit xbxi controlleriga harjumist olin sellest mängust lummatud. AC on ikkagi saanud GT-lt 9.4 punkti. see on GS ja IGNi süü et neil sitad reviw'd on. |
Einojah. Enamike mängurite käest korralikult rapsida saanud täiesti ühe ja sama asja kordamisest koosnev AC on siis lummav seiklus ja Crysis on utter BS? Terve.
101 |
HDTanel
Overclocker
29.02.2008 16:08:32
Oi, Assassins Creed on väljas
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
Kommentaarid: 635 loe/lisa |
496 |
andres1221
29.02.2008 16:14:58
Xbox'ile ja ps'ile tuli ta juba päris mitu kuud tagasi välja.
HDTanel
Overclocker
29.02.2008 16:21:46
andres1221 kirjutas: |
Xbox'ile ja ps'ile tuli ta juba päris mitu kuud tagasi välja. |
I know, mul suur Assassins Creedi kuju veel alles Collectors Editionist Saab võrrelda kuda konsooliga on... panen max graafika ja aa peale
496 |
andres1221
29.02.2008 16:28:30
a okei, pc versioon on välja lekkinud : D
ametlikult siiski tuleb 28 Märts Euroopasse.
HDTanel
Overclocker
29.02.2008 16:31:11
See ei pruugi küll tõele vastata
496 |
Volum
29.02.2008 16:44:41
PlatoonSgtElias kirjutas: |
See ei pruugi küll tõele vastata  |
Mis vastab tõele ikka küll
16 |
andres1221
29.02.2008 16:49:54
paistab küll nii, huvitav, et nad hoivad mängu kinni märtsi lõpuni kui mäng on tegelikult valmis...
Või see mingi beta?
