uus teema   See teema on lukus, sa ei saa siin muuta postitusi või vastata teemale! Tarkvara »  Linux & UNIX »  Küsimused/vastused seoses Ubuntu linuxiga märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 73, 74, 75, 76  järgmine
note1
note1
sõnum 01.01.2008 14:34:06 vasta tsitaadiga
GParted Live CD saab kenasti hakkama- miks üldse probleemit teha? ntfs, fat16, fat32, ext, swap, reiserfs- kõik töötab ilusasti.
Mingi 30 korda olen eelmist kõvakettast partitsioneerinud.
Kommentaarid: 3 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 1
Overkilla
sõnum 04.01.2008 21:15:50 vasta tsitaadiga
Ei saa digiallkirja anda, SignApplet jääb halli kastina vahtima. Kasutusel IcedTea, kuna 64bitisel sun6-java'l ei ole Mozilla nn. pistikut.
GCJ PLUGIN: thread 0x6195a0: NP_Initialize
GCJ PLUGIN: thread 0x6195a0: plugin_test_appletviewer
GCJ PLUGIN: thread 0x6195a0: plugin_test_appletviewer return
GCJ PLUGIN: thread 0x6195a0: NP_Initialize: using /usr/lib/jvm/java-7-icedtea/jre/lib/amd64/../../bin/pluginappletviewer
GCJ PLUGIN: thread 0x6195a0: NP_Initialize return
GCJ PLUGIN: thread 0x6195a0: GCJ_New
GCJ PLUGIN: thread 0x6195a0: plugin_data_new
GCJ PLUGIN: thread 0x6195a0: plugin_data_new return
GCJ PLUGIN: thread 0x6195a0: plugin_get_documentbase
GCJ PLUGIN: thread 0x6195a0: plugin_get_documentbase return
GCJ PLUGIN: thread 0x6195a0: GCJ_New: creating input fifo: /home/erki/.gcjwebplugin/gcj-instance-9515-0-appletviewer-to-plugin
GCJ PLUGIN: thread 0x6195a0: GCJ_New: created input fifo: /home/erki/.gcjwebplugin/gcj-instance-9515-0-appletviewer-to-plugin
GCJ PLUGIN: thread 0x6195a0: GCJ_New: creating output fifo: /home/erki/.gcjwebplugin/gcj-instance-9515-0-plugin-to-appletviewer
GCJ PLUGIN: thread 0x6195a0: GCJ_New: created output fifo: /home/erki/.gcjwebplugin/gcj-instance-9515-0-plugin-to-appletviewer
GCJ PLUGIN: thread 0x6195a0: plugin_start_appletviewer
GCJ PLUGIN: thread 0x6195a0: plugin_start_appletviewer return
GCJ PLUGIN: thread 0x6195a0: GCJ_New: got confirmation that appletviewer is running.
GCJ PLUGIN: thread 0x6195a0: plugin_out_pipe_callback
GCJ PLUGIN: thread 0x6195a0: plugin_out_pipe_callback: appletviewer has stopped.
GCJ PLUGIN: thread 0x6195a0: plugin_out_pipe_callback return
GCJ PLUGIN: thread 0x6195a0: plugin_in_pipe_callback
GCJ PLUGIN: thread 0x6195a0: appletviewer has stopped.
GCJ PLUGIN: thread 0x6195a0: plugin_in_pipe_callback return
GCJ PLUGIN: thread 0x6195a0: GCJ_Destroy
GCJ PLUGIN: thread 0x6195a0: plugin_send_message_to_appletviewer
GCJ PLUGIN: thread 0x6195a0: plugin_send_message_to_appletviewer return
GCJ PLUGIN: thread 0x6195a0: plugin_stop_appletviewer
GCJ PLUGIN: thread 0x6195a0: plugin_stop_appletviewer return
GCJ PLUGIN: thread 0x6195a0: plugin_data_destroy
GCJ PLUGIN: thread 0x6195a0: GCJ_New: deleting output fifo: /home/4/.gcjwebplugin/gcj-instance-8961-0-plugin-to-appletviewer
GCJ PLUGIN: thread 0x6195a0: GCJ_New: deleted output fifo: /home/4/.gcjwebplugin/gcj-instance-8961-0-plugin-to-appletviewer
GCJ PLUGIN: thread 0x6195a0: GCJ_New: deleting input fifo: /home/4/.gcjwebplugin/gcj-instance-8961-0-appletviewer-to-plugin
GCJ PLUGIN: thread 0x6195a0: GCJ_New: deleted input fifo: /home/4/.gcjwebplugin/gcj-instance-8961-0-appletviewer-to-plugin
GCJ PLUGIN: thread 0x6195a0: plugin_data_destroy return
GCJ PLUGIN: thread 0x6195a0: GCJ_Destroy return
GCJ PLUGIN: thread 0x6195a0: NP_Shutdown
GCJ PLUGIN: thread 0x6195a0: NP_Shutdown return
note1
note1
sõnum 06.01.2008 18:25:01 vasta tsitaadiga
Overkilla kirjutas:
Oled proovinud http://estobuntu.org
raido357
sõnum 06.01.2008 20:32:27 vasta tsitaadiga
Oo@ Estobuntu.
Alari A.
sõnum 07.01.2008 23:42:49 vasta tsitaadiga
kellelgi on õnnestunud paigaldada 7.10 firewire kettale?
krt mul desktop installi aeh jookseb kokku u. 12% peale.
server installi plaadilt ei saa korralikult bootidagi. scanning cdrom ja selleg piirdub.
Kommentaarid: 674 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 549
physics
sõnum 09.01.2008 22:03:46 vasta tsitaadiga
selline teema siis.
32-bit live cd-ga läheb asi normaalselt tööle sülearvutil, ainult et klaver ei tööa icon_eek.gif ning 64-bit live cd-ga asi ei jõuagi kuhugi eriti ning ei tunne ära ka videokaarti mille tõttu resolutsioon on maksimaalselt 800x600.
protsessor on täiesti c2d 64 bitine olemas, aga 64-bit Ubuntu live cd ei tööta, ning kuradi pärast mu klaver ei tööta 32-bit Ubuntuga icon_question.gif
Alari A.
sõnum 10.01.2008 11:24:29 vasta tsitaadiga
physics,
n:vga
physics
sõnum 10.01.2008 12:59:03 vasta tsitaadiga
digweed kirjutas:
physics,
n:vga
video Nvidia Geforce 8600m GT, ja Ubuntu ei tunne ainult seda 64-bit versiooniga ära, 32bitisel töötab kenasti, ja klaveri mitte töötamist oskab keegi seletada?
Alari A.
sõnum 10.01.2008 13:02:56 vasta tsitaadiga
kirjutab xorgi ilmselt vesa. võid proovida nv ja Xle restart teha- juhul kui live cd peal asi häirib.
peale ubuntu paigaldamist installi nvidia drivud ikka ka.
kuidas? selleks juba googlest leidun milj.kanti õpetusi
physics
sõnum 10.01.2008 13:06:07 vasta tsitaadiga
digweed kirjutas:
eks ma selle proovin ära. mind hetkel huvitab miks klaver ei tööa icon_eek.gif
Overkilla
sõnum 11.01.2008 20:49:13 vasta tsitaadiga
Kuidas Ubuntus .ddoc (digidoc XML) dokumenti avada?
o-u-t-r-o
o-u-t-r-o
sõnum 11.01.2008 22:49:01 vasta tsitaadiga
open office ei ava?
Riivo
Riivo
sõnum 12.01.2008 00:05:43 vasta tsitaadiga
Overkilla kirjutas:
Ehk mõtled hooopis formaati docx?
http://www.google.ee/search?q=ubuntu+docx
Edit: ju mõtlesid ikka digidoc'i. Selle kohta pajatab ka google mõndagi
http://www.google.ee/search?q=ubuntu+digidoc
viimati muutis Riivo 12.01.2008 01:57:31, muudetud 1 kord
entusiast
entusiast
sõnum 12.01.2008 00:21:31 vasta tsitaadiga
kuidas teha ubuntuga nii, et saaks kustutada ja uninstallida windowsi all olevaid programme.
nimelt sai midagi valesti installitud catalyst 7.12 packiga, ning nüüd ei saa enam windowsi alt sisse, kuid ubuntu live cdga olen arvutis, kuid kustutada kovalt kettalt ei saa midagi tahaks ka uninstallida, kuid sedagi ei luba ubuntu.
JÖUDU!
Kommentaarid: 104 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 102
jnt
jnt
sõnum 12.01.2008 00:23:50 vasta tsitaadiga
entusiast, sa windowsisse safe mode'is üritasid minna?
Kommentaarid: 116 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 107
entusiast
entusiast
sõnum 12.01.2008 00:25:37 vasta tsitaadiga
kriban siis siia ka mis juhtus.
juhtus selline asi, et installisin siis kogu selle 7.12 packi peale, alguses ei tahtnud seda catalyst control centerit peale lasta, kuna ütles, et .NET frame wor 2.0 pole, siis lasi nagu ainult display driverid peale , kuid siis vist hakkas ka veel .net frameworki peale laskma ja control centerit, mina muidugi kogemata vajutasin, peale dislplay driverite 'ra installimist kohe restart, ning n[[d ongi nii, et arvuti laheb toole ning kuni selle welcome screenini bootib ennast, valge kursor tuleb ka, kuid pilt on must, sama lugu ka safe modes.
ehk oskab keegi ;elda, mis tegema peaks et asja korda saaks.
kaardiks 1950 gt
praegu olen sees k[ll ubuntuga, kuid muuta ju windowsi all sellega midagi ei saa v saab
JÖUDU!
Valdars
Valdars
sõnum 12.01.2008 01:13:08 vasta tsitaadiga
Kas command prompt safe mode ka tööle ei lähe?
chntpw peaks lubama registrit muuta.
Kommentaarid: 48 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 45
entusiast
entusiast
sõnum 12.01.2008 01:32:31 vasta tsitaadiga
command promt ka mitte.
aga kui teha nii, et käivitada teise kövakaga win, ning siis teiselt kövakettalt köik ati failid ära kustutada, kas siis peaks miskit paranema, või vöib hoopis asja metsa keerata?
JÖUDU!
Alari A.
sõnum 12.01.2008 02:18:01 vasta tsitaadiga
vabandused OT pärast:
lehm2
sõnum 16.01.2008 19:58:04 vasta tsitaadiga
Tekkis väike probleem, et kuidas Pidgini-s saaks näha Personal message(see mis on tavaliselt Wini Msni-s nime taga). Kas on võimalik panna mingi plugin selle jaoks, või tuleb minna aMsn-le üle. icon_question.gif
Piilu siia, progreja!
Vajad abi Node.JS-ga ?
Võta ühendust !
Hardi
Hardi
sõnum 16.01.2008 20:44:25 vasta tsitaadiga
Pidgini asemel võid ka emesene proovida. Suhtkoht windowsi msn messengeri sarnane...
Kommentaarid: 84 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 70
asjameez
asjameez
sõnum 16.01.2008 21:54:38 vasta tsitaadiga
Kas keegi siit amsn0.97-final versiooni ka kasutab? Mul ei lähe see käima. Viskab laadides ette akna kus kirjas "Loading TkCximage failed!".
Googlest leidsin paar trikki aga need ei aidanud...
amsn0.97RC töötab aga ilusti.
Kommentaarid: 63 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 61
alecoqprem
alecoqprem
sõnum 17.01.2008 10:32:15 vasta tsitaadiga
ka on ka kuidagi v6imalik avada .rar l6puga faile?
hetkel viskab sellise errori ette, kui tahan pakki extractida
Could not open "pack.rar"
Archive type not supported.
Kommentaarid: 29 loe/lisa Kasutajad arvavad:  :: 2 :: 1 :: 24
Alari A.
sõnum 17.01.2008 10:37:37 vasta tsitaadiga
apt-get install rar unrar
aga jah selle lingi võiks siin foorumis teha kleepsuks
http://ubuntuguide.org/wiki/Ubuntu:Gutsy
sõnum 17.01.2008 10:37:55 vasta tsitaadiga
alecoqprem kirjutas:
sudo apt-get install unrar
lillexxx
sõnum 17.01.2008 11:15:19 vasta tsitaadiga
Selline probleem: peal Ubuntu 7.10 mitmel arvutil, meiliprogrammiks Evolution. Kui panen uusi meile kontrollima, siis saab igalt kontolt 3 meili kätte ja peale seda tuleb viga :Error while Fetching Mail.Cannot get message fc91aee9819272c84386e3848419f807: Connection timed out. Panen Cancel all ja uuesti, saab kolm järgmist meili ja jälle viga.
Kõikide Ubuntu arvutitega sama asi, Outlook toimib ilusti.
lauripoiss
sõnum 21.01.2008 15:52:50 vasta tsitaadiga
Mul on aga selline küsimus... nimelt panin enda arvutile peale Ubuntu 7 kuid mure on monitori ja graafika kaardiga. Nimelt ei saa molu resoks panna 100Hz näitab ainult 60.
Graafika kaartiks Radeon 9600 Pro ja Monitor Samsung Syncmaster 959NF
Kas ma pean driverid uuendama või kust ma need saan?
Kommentaarid: 13 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 11
Alari A.
sõnum 21.01.2008 16:06:21 vasta tsitaadiga
vaata 3 postitust ülesse
raitm
raitm
sõnum 22.01.2008 15:04:17 vasta tsitaadiga
Kububntu 7.10 ei lase installeerida Firefoxi. adept manageris on Firefoxi valik hall. Source listi muutnud igat pidi. kas viga võib olla, et on tegemata:
wget -q http://packages.medibuntu.org/medibuntu-key.gpg -O- | sudo apt-key add -
tundub, et see on vajalik et "autoriseerida" ligipääs pakkidele?
Kommentaarid: 60 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 52
Vincenzo
sõnum 22.01.2008 15:18:36 vasta tsitaadiga
raitm kirjutas:
FF peaks olema juba vaikimisi paigaldatud Kubuntus? Repode jaoks vaata siia
raitm
raitm
sõnum 22.01.2008 15:28:40 vasta tsitaadiga
aga ei ole...
Repositooriumitest uue juhendi järgi http://ubuntuguide.org/wiki/Ubuntu:Gutsy#How_to_add_extra_repositories:
sudo gedit /etc/apt/sources.list
"edit file"
Save the edited file
sudo apt-get update
Vincenzo viidatud lingil on vanaviisi:
"edit file"
Salvestage muudetud fail
sudo apt-get update
See on ka ainus loogiline seletus, miks ma ei saa Firefoxi installida...lihtsalt ei lasta enne autoriseerimist pakkidele ligi
Vincenzo
sõnum 22.01.2008 15:43:59 vasta tsitaadiga
raitm kirjutas:
aga ei ole...
Kummaline.. Aga võti annab errorit või?
Aga mis ta selle peale üteb?
sudo apt-get install mozilla-firefox
raitm
raitm
sõnum 22.01.2008 15:50:37 vasta tsitaadiga
ma selle võtme avastasin täna, õhtul saan proovida, eile unise peaga jäi see rida kahe silma vahele
ja apt get install ütleb, et ei leia firefoxi sellest pakist. õhtul saan logisid postidada, kuigi loodan, et see võti lahendab probleemi.
Aeg maha 1p
sõnum 22.01.2008 15:53:49 vasta tsitaadiga
Kas kuidagi saab Ubuntusse ka sellise "favourite programs" riba kuskile tekitada nagu gOS'il on?
Vincenzo
sõnum 22.01.2008 16:02:51 vasta tsitaadiga
carlking kirjutas:
Paigalda Enlightment aknahaldur.
http://ubuntuforums.org/showthread.php?t=97199&highlight=E17+cvs
raitm
raitm
sõnum 23.01.2008 10:15:46 vasta tsitaadiga
raitm kirjutas:
ja mina arvasin, et kubuntu pakihaldur on intelligentsem
lehm2
sõnum 24.01.2008 23:02:24 vasta tsitaadiga
Tere, tekkis probleem aMsn-ga. Sai ta peale lastud aga kui programm käivitub jääb liivakell(bounce effect linuxis) peale ja rohkemat midagi ei juhtu. Alla paneeli peale tuleb ikoon, kuid peagi kaob see sealt. Kas tegu võib olla, sellega, et mõni package on installimata ?
Võta ühendust !
AMD
AMD
sõnum 24.01.2008 23:20:01 vasta tsitaadiga
lehm2, käivita konsoolist, äkki ütleb midagi.
From now on, the forum is owned by AMD.That means that you are NO LONGER allowed to talk about, or even mention *ntel.
Kommentaarid: 335 loe/lisa Kasutajad arvavad:  :: 145 :: 3 :: 12
Ramones
Ramones
sõnum 25.01.2008 00:07:23 vasta tsitaadiga
uh, nüüdseks juba oma 3h jamanud, et saada 5.1 heli tööle aga ei midagi. Kaardiks SBLive 24-bit. Mängivad ainult kaks esimest kõlarit ja seda isegi siis, kui heliallikaks on 5.1 fail. Tahaks asja tööle saada nii õigete 5.1 helidega kui ka stereo upmixi. Ehk teab keegi õiget teed näidata, sest minul on mõistus igatahes täiesti otsas.
asjameez
asjameez
sõnum 26.01.2008 18:55:28 vasta tsitaadiga
Arvutis on Kubuntu Gutsy ja 256MB RAM. Ilge swappimine käib ja arvuti on sigaaeglane.
Kas on võimalik kuidagimoodi mälukasutust vähemaks teha (mingeid asju startupis keelates jne)?
Kohe saan uue mälu aga huvitav oleks siiski teada.
Alari A.
sõnum 26.01.2008 18:57:24 vasta tsitaadiga
bum abiks
ps.vanadele masinatel tasub ubuntu paigaldada server insall cdga
asjameez
asjameez
sõnum 26.01.2008 19:03:43 vasta tsitaadiga
Paigaldasin Alternate CD pealt.
Live'i ei saanud üldse kasutada. Desktoppigi ei laadinud ära korralikult.
Alari A.
sõnum 26.01.2008 19:09:41 vasta tsitaadiga
Alternate CD minu teada teeb ikka full installi.
server installi plaat paigaldab sulle min. süsteemi ilma gnome, X`i jms. kolata.
edasi juba vaatad sie mida võtta ja mida jätta. oluline on, et gnomet paigaldades teeks apt-get install gnome asemel apt-get install gnome-core
bueno
sõnum 27.01.2008 00:44:42 vasta tsitaadiga
sooviks ka proovida ubuntut. live cd lt bootides jõuab sinna kus saab valida et käivita või installi, valin selle ja siis lihtsalt ei lae ülesse. vahepeal on üheks sekundiks ka kiri: cannot allocate resourse region 0 of device 0000.00.09.0 (seda pidin pildistama et lugeda jõuaks icon_biggrin.gif ) oskab keegi aidata.
Riivo
Riivo
sõnum 27.01.2008 01:25:20 vasta tsitaadiga
asjameez, ära kasuta KDE'd. Parem Xfce, Openbox, Enlightenment jne
bueno, proovi alternate CD'd.
bueno
sõnum 27.01.2008 13:00:43 vasta tsitaadiga
proovisin ka altrnate cd ga. esiteks oli jõudsin nii kaugele et jäi seisma kirja juures "Starting systemlog daemon: syslogd, klagd. proovisin uuesti aga enne installi vajutasin f6 ja selle quiet või midagi sellist kustutasin ära ja üritasin installida siis oli seal logi lõpus selline rida "ACPI exception (acpi_proccessor-0677): ae_not_found, Protsessot device is not present(20060707).
kaabakas
kaabakas
sõnum 27.01.2008 15:44:08 vasta tsitaadiga
Lisaks single kustutamisele kirjuta sinna rea lõppu noacpi ja vaata kuidas siis boodib.
bueno
sõnum 27.01.2008 16:57:02 vasta tsitaadiga
kaabakas kirjutas:
kui see oli mulle siis see ei muutnud midagi. kas tõesti pean jääma edasi windoosaga.
note1
note1
sõnum 27.01.2008 17:57:21 vasta tsitaadiga
bueno kirjutas:
kaabakas kirjutas:
Mis arvuti sul on?
bueno
sõnum 27.01.2008 18:39:25 vasta tsitaadiga
Ordi Enduro 5320B Black
Intel Core 2 Duo T5300, 2GB DDR2, 12,1" WXGA, HDD 160GB, DVDRW, int. VGA, kõlarid+mikrofon, klaviatuur EST või US, Wifi, LAN 10/100,3x USB,veebikaamera, kaal 1,9kg, aku kuni 1,5 tundi, Bluetooth
uus teema   See teema on lukus, sa ei saa siin muuta postitusi või vastata teemale! Tarkvara »  Linux & UNIX »  Küsimused/vastused seoses Ubuntu linuxiga mine lehele eelmine  1, 2, 3 ... 73, 74, 75, 76  järgmine
