heikis
25.07.2007 19:01:27
ei lähe otseselt teemasse, aga siiski...
Nvidia Geforce 9800GTX Specifications released!
Release date : November 2007. There will be TWO products at launch: The flagship GeForce 9800 GTX and the second fastest GeForce 9800 GTS. |
* price for the GeForce 9800 GTX will be 549-649 USD.
* price for the GeForce 9800 GTS will be 399-449 USD.
GeForce 9800 GTX will be over two times faster than a GeForce 8800 Ultra in real world games and applcations.
65nm process will allow for better yields and better power consumption. power consumption will be lower than that of a GeForce 8800 GTX.
tsitaat: |
"G92" GeForce 9800 GTX specs.
- 65nm process technology at TSMC.
- Over one billion transistors.
- Second Generation Unified Shader Architecture.
- Double precsion support (FP64).
- GPGPU native.
- Over one TeraFLOPS of shader processing power.
- MADD+ADD configuration for the shader untis (2+1 FLOPS=3 FLOPS per ALU)
- Fully Scalar design.
- 512-bit memory interface.
- 1024MB GDDR4 graphics memory.
- DirectX 10.1 support.
- OpenGL 3.0 Support.
- eDRAM die for "FREE 4xAA".
- built in Audio Chip.
- built in tesselation unit (in the graphics core"
- Improved AA and AF quality levels |
allikas: http://www.xbitlabs.com/discussion/3953.html
viimati muutis heikis 25.07.2007 19:04:13, muudetud 1 kord |
Kommentaarid: 338 loe/lisa |
290 |
WäntWõll
make.believe
25.07.2007 19:03:43
Kui ametlik (vähem-rohkem) info siis võiks G92 teema ära teha,muidugi olemas olevast läbu(spekulatsioonid) ära kustutada
Muidu olen veendunud et see teema läheb OT nahka 100km/h
viimati muutis WäntWõll 25.07.2007 19:05:07, muudetud 1 kord |
Kommentaarid: 374 loe/lisa |
300 |
heikis
290 |
libe
kvaliteetne mees
25.07.2007 19:05:17
kui emaplaadil niigi juba helikaart integreeritud poleks, siis oleks 9800GTX lausa päris bargain, muidugi juhul kui see audio chip ka any good on
_________________ ☠ |
Kommentaarid: 82 loe/lisa |
WäntWõll
make.believe
25.07.2007 19:05:40
heikis, edisin vähe posti,ei jõudnud niikiirelt reageerida
300 |
Kommentaarid: 234 loe/lisa |
200 |
HDTanel
Overclocker
25.07.2007 22:57:33
Kõik 8800 seeria kaarte maha müüma võileiva hinna eest nüüd Paistab, et mu rahakott läheb kergemaks Heal ajal tuleb Just kui head mängud tulevad
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
Kommentaarid: 635 loe/lisa |
496 |
25.07.2007 23:02:07
irw... pigem teeb see ATI seisu veel raskemaks, NV ei pea hetkel veel suurt kuhugi kiirustama
Aga muidu on nad varem ka rõhutanud, et iga aasta tagant uuendatakse oma tipp mudelirivi.
200 |
sakinaga
25.07.2007 23:05:45
Siis laseb nVidia 8800GTX hinna HD2600XT tasemele ja ATI on lukus. Kui Ati nüüd kiiresti midagi välja ei mõtle on küll vesi ahjus.
Kommentaarid: 159 loe/lisa |
151 |
26.07.2007 01:18:44
maatriks kirjutas: |
Siis laseb nVidia 8800GTX hinna HD2600XT tasemele ja ATI on lukus. Kui Ati nüüd kiiresti midagi välja ei mõtle on küll vesi ahjus. |
üldiselt mõtlemises polegi küsimus - vähemalt tsmc oleks valmis ka lähiajal 45nm kaarte tootma... pigem küsimus ATI rapsimises ja suutmatuses midagi ära teha. AMD oleks võinud ikka teha full 65nm launchi kasvõi hilinemisega - vähemalt oleksid kulud/tulud suht samad, aga PR oleks märksa ilusam.
Nüüd varsti tuleb 65nm ja siis väidetavalt 55nm ja äkki lõpuks ka 45nm, kui firmal enne raha otsa ei saa(nohh laojääke on ka pea pool vabast rahast, mis on müstiline kogus).
Nagu NV "naljavendade kokkutulekul" loe: tulemuste pressikas... eelmine kord öeldi - nemad võtavad asja rahulikult ja rapsima ei hakka, sest neil on ajaline eelis...nad ei taha FX seeria kordumist.
200 |
M-Reaper
26.07.2007 03:36:43
Sihuke küsimus, et kumba osta, kas GeForce 8800 GTS 320MB või GeForce 8800 GTS 640MB? Ses suhtes, et minu molu ei võimalda reso rohkem kui 1280x1024 ja nagu ma eelnevatest postitustest aru sain, siis ei ole nagu mõtet seda 640 MB varianti osta. Samas olen vaadanud mõningaid teste netis, ja mõnigatel mängudel on 320 ja 640 päris märgatav vahe. Teiseks tahaks veel teada, et kuidas ta mu süsteemil jooksma hakkab, kui arvuti on üle 2 aasta vanune (Prose: AMD Athlon 3000+ 1,81GHz, Emme: LanParty UT NF4 SLI-DR, Mälud: 2x512MB PC-3200 400MHz DDRAM, Toitekas 550W, Kõvaketas 200GB SATA), et kas nagu on mõtet sellist kaarti sellisesse arvutisse üldse toppima hakata.
_________________ The Reaper is Back!!! |
CoiL
26.07.2007 03:44:51
emaplaat on sul hea ning kui suudad siit HV-st või kuskilt mujalt parema prose sellele muretseda siis ei tohiks prose blokkima hakata perfi.
Hetkel on natukene nõrgukene sinu prose selle graafika jaoks imo Lükka prosele kellad peale Palju 640Mb ja 320Mb hinnavahe on muidu? Ilmselt mõttekam 320Mb võtta.
Kommentaarid: 95 loe/lisa |
83 |
26.07.2007 06:44:19
Sellel resol toesti mottekam 320MB votta ja nagu CorsairX utles siis prose jaab hetkel toesti veits norgaks.Nt kahetuumalised X2 voi Opteron socket 939 prosed ei maksa kellegi kaest HV-st ostes vaga palju.Mis toitega tegu on kui kusida voib...huvitaks just tootjafirma ja toiteka kuljel olevad 12V taga olevad numbrid...uldiselt peaks ilusti sobima sulle.
320MB ja 640MB hinnavahe on hetkel u.1000 krooni(3900kr vs 4900kr)
Kommentaarid: 92 loe/lisa |
Erik_Est
26.07.2007 07:06:52
Minul on 550w gembirdi (odav)toide ja toidab ära nii et jääb ülegi....Nii et sinu oma peaks sobima küll mis ta ka iganes ei oleks... Ja sis veel.... kui sa endale ostad suurema resoga monitori siis ostad suurema mäluga kaardi?
Kommentaarid: 41 loe/lisa |
34 |
26.07.2007 10:53:56
tomorrow kirjutas: |
320MB ja 640MB hinnavahe on hetkel u.1000 krooni(3900kr vs 4900kr) |
milleks socket 939? Kui vaid natukese lisa eest saad märksa pikema tulevikuga inteli süsteemi
Ja see resu teema on nii ja naa... osad tulevad mängud ilmselt oskavad ka enda suure detailsusega nii 320 kui 640 GTS'i suht kooma tõmmata...1000kr hinnavahet muidugi ei õigusta ennast, seega 320 ikka etem.
200 |
CoiL
26.07.2007 14:09:05
ot: |
Soc. 939 äkki sellepärast et see tuleb odavam ja kiirem lahendus? Ja kuna tal korralik plate siis kahetuumalisest korralikust prosest täiesti piisab!
Kui inteli peale kolida siis ootavad teda ees uue prose, plate ja mälude vahetus. Ise ostaksin küll pigem uue või kasutatud soc.939 prose. Pealegi Inteli hinnad langevad ilmselt veelgi aja möödudes ning oma soc.939 kraami eest ei saa ta erilist hinda ka. IMO |
83 |
M-Reaper
26.07.2007 14:38:12
Ok, aga kui ma peaks omale uue prose ostma, siis milline see "hea" oleks 939 pesale?
Anti
26.07.2007 14:39:12
Oleneb sellest, palju sul raha on. Hea on ikka kõige kallim.
Kommentaarid: 314 loe/lisa |
240 |
CoiL
26.07.2007 14:44:42
ot: |
Näiteks SIIN maksab kahetuumaline soc.939 prose ~1570.- mis on vägagi odav imo ning kui kellad ka peale lükata siis peaks kindlasti piisama sellest. Pead ise uurima kuidas eestis hindade ja saadavusega on. Ilmselt kuskilt välismaa netipoest tellides läheks selline maksama umb. 1900-2000.- koos postiga. |
83 |
M-Reaper
26.07.2007 15:03:59
Nujah, aga kas näiteks Opteron 170, 175 või 180 on ka pandavad we, või on see 4200+ parem?
CoiL
26.07.2007 15:52:14
ot: |
Opteron peaks üldiselt parem olema kuna tal L2 cache 2MB. Erilist suurt vahet tegelikult pole... opterone on suht raske saada ning üldiselt kallimad ka.
Sellest X2-st peaks sulle piisama. Uuri siit: https://www.hinnavaatlus.ee/products/Arvutiriistvara/Protsessorid/?TypeID=603 ...vast mõnel firmal siin eestis on veel laos mõni opteron või siis annab tellida. Btw oleks tore kui pöörduksid soc.939 küsimustega vastavasse teemasse |
83 |
M-Reaper
26.07.2007 15:57:18
Ok, tnx abi eest, eks ma vaatan siis millise ma ostan. Aga sihuke loll küsimus veel, et see K&M Elektronik lehekülg mis sa välja pakkusid, et kas sealt saab ka Eestisse tellida we, sest kui ma seal ära tahtsin regada, ei olnud Eestit kui elukohta nimekirjas...
CoiL
26.07.2007 16:01:01
ot: |
peaks vist saama küll aga arvesta et saksast tellimine läheb maksma 30-35EUR mis on kallis! Vaata netis ringi rohkem... kindlasti on paremaid kohti kust tellida. Aga kõigepealt uuri kõik eesti poed läbi. Aitab OT-st! |
83 |
Inim
27.07.2007 10:40:12
Tere! Küsimus sain 3dmark06 punne 7000 mis mul plokki paneb? (arvuti profiilis). Mõned saavad siin 9000 punni oma gts-idega. Ise arvan et prose ja mälud ole just kõige paremad.
Kommentaarid: 4 loe/lisa |
G80
27.07.2007 10:45:50
Inim, prose on sul saast.
Osta mingi E6750 või E6550 ja saad normaalse skoori.
Kommentaarid: 256 loe/lisa |
210 |
