[Pec]
06.02.2007 22:33:22
| softis kirjutas: |
| [Pec] kirjutas: |
| Miks ta ei peaks Eesti võrgus töötama? Hiina ja Eesti mobiilside võrk töötab samal sagedusel AFAIK. |
Ma ei pidanud sagedusi silmas, vaid võimalusi, mida telefon pakub. |
Minu postitus oli suunatud d3t-le
_________________ www.kolkbeer.ee |
| Kommentaarid: 19 loe/lisa |
18 |
Lemmy
14.07.2007 01:03:42
Praegu viimane disaini versioon peaks selline olema.
Suht korralik uudiste arhiiv: http://www.engadget.com/tag/minione
Foorum, kus nii asjalikku juttu, kui ka kõlakaid, kuid abiks lugeda: http://www.meizume.com/forums.php
Turule peaks jõudma 2007 lõpp - 2008 algus.
Ise igatahes ootan seda riista palju suurema huviga, kui "Õuna iiFööni".
Dimensions: 105mm x 58mm x 11.8mm (H x W x T)
Processor: ARM11 667MHz+
Display: 3.32", 16M color, 720x480 pixel resolution, Touchscreen TFT LCD
PC Interface: USB 2.0 Ultra Fast Data Transfer
Flash Memory: 4, 8 or 16GB of built-in basic Memory, 128MB DDR SDRAM
Operating System: Windows CE for Meizu M8 (Based on Windows CE6.0)
Video Playback: AVI, MPEG-2, RM(VB), Wmv, MPEG-4/H.263/H.264 at 30FPS
Camera: 0.3+ MPx camera on front, 3.0 MPx camera on back. Supports auto-focus, no flash.
Battery: 1500 mAh Li-ion (removable)
Support For:
GSM + SCDMA Networks
Bluetooth 2.0
Wi-Fi
DVB-H
TV-out
Line-out
Video Conferencing
USB Host / OTG
GPS (Add-on)
Additional Features:
Light sensor allowing the phone to automatically adjust screen brightness in accordance to the lightning in the environment.
Tilt and movement recognizing sensor that will allow it to auto-adjust screen orientation in accordance to tilting. It can also recognize movements (ie. shaking), a feature which can be used for games.
The MiniOne M8 model will pack GSM with EDGE data while the MiniOne M8 w ("w" for worldphone we presume) is said to go WCDMA/HSDPA/GSM/EDGE.
_________________ Vähem möla, pikem samm! |
| Kommentaarid: 41 loe/lisa |
38 |
purexpure
14.07.2007 01:13:14
| Aga hinnast pole juttu?
| Kommentaarid: 58 loe/lisa |
47 |
Lemmy
14.07.2007 12:43:22
Hindu on pakutud seinast seina..
4GB 260$, 16GB 450$. Need võivad mingil määral ka muutuda.
Seda 989$, mis neegripoes reklaamitud, seda mitte uskuda.
viimati muutis Lemmy 14.07.2007 13:11:14, muudetud 1 kord |
38 |
djkiller
14.07.2007 13:03:42
| enamvähem hinnad saab kas ebayst või made-in-china.com või alibaba.com ist.
| Kommentaarid: 223 loe/lisa |
202 |
d3t
15.07.2007 18:55:05
Mind aga huvitab, kas ma saan sinna Windows Mobile 6 peale lükata?
EDIT: Üks kloon veel, mis on lahe, aga sama küsimus: kas saab WM6 peale lükata?
http://youtube.com/watch?v=f_8wuVEYMZ8
_________________ next.Insiders - koht mängijatele ja tehnikahuvilistele toredaks ajaveetmiseks.
| Kommentaarid: 85 loe/lisa |
72 |
Herr Kurm
15.07.2007 19:00:13
kui sellele linuxi peale saaks orgunnida oleks päris käre. Mingit windowsisaasta ei taha nähagi enam (täna jälle n*ssisin cleartypega).
_________________ -logod, firmaidentiteet, küljendamine, flash-
-portfolio- |
| Kommentaarid: 25 loe/lisa |
19 |
d3t
15.07.2007 19:18:43
Herr Kurm, mulle sobiks ka symbain. Aga põhiline on see et oleks maksimaalselt suur out of the box support (tuhandetes rakendusi ja mänge...)
72 |
waux
15.07.2007 21:13:03
| 2 simmi ja microSD kaart,normaalne.aga cect-id jäävad ikka cect-ideks,heli kajab jne
| Kommentaarid: 598 loe/lisa |
495 |
Lemmy
16.07.2007 13:49:58
Noh, need vuffel "iPhone"id ei anna ikka kuidagi võrdlust välja. Seal ju iseenesest pole tehtud muud, kui odava hiina MP4 playeri ja puuteekraaniga telefoni hübriid.
Tehnilised andmed jäävad ikka korralikest iPhone'idest kaugelt maha. Turukaup ühesõnaga.
38 |
d3t
17.07.2007 07:03:48
Lemmy, turukaup või mitte, kui WiFi on ning Windows Mobile ka, siis rohkem pole vajagi...
72 |
Lemmy
17.07.2007 16:24:17
| d3t kirjutas: |
| Lemmy, turukaup või mitte, kui WiFi on ning Windows Mobile ka, siis rohkem pole vajagi... |
Näita mulle, kus on CECT'il wifi ja WM? Need ju täiesti tavalised mobiiltelefonid. Mingit OS'i (kui sellist) pole.
Kommentaaride järgi on isegi see "2Mpix" kaamera 1,3Mpix'line ja 2'te SIM kaarti ei saa korraga kasutada vaid tuleb ühelt-teisele ümber lülitada.
Edit:
Nii. Vahepeal on miniOne'i andmed vähe muutunud. Uus väljanägemine.
Enne: Dimensions: 105mm x 58mm x 11.8mm (H x W x T)
Nüüd: Dimensions: 108mm x 59mm x 11.8mm (H x W x T)
Enne: Display: 3.32"
Nüüd: Display: 3.41"
Kõlarite asetus külgedelt liigutatud otstesse.
- supports playback of APE files, but no CUE playback
- fixed the inaccuracy of clock
- added OTG function, but must be used with external battery case.
- added picture zoom function, enlargement of pictures.
- fixed the sound produced by long pressing of enter to stop voice recording in voice recording mode, changed to just tapping of the middle of the touchstrip to stop voice recording.
38 |
d3t
17.07.2007 17:32:44
Lemmy, ma mõtlein et kui need olemas siis mulle muud vaja ei ole. Aga see meizu on paljulubav...
72 |
kfl
| Kommentaarid: 111 loe/lisa |
107 |
