Killhoven
OC`er
15.06.2007 21:30:33
Siin hiljuti oli ju jutt, et nendel Sparkle omadel kaunis kehva jahutus ning teiste tootjatega võrreldes ka temp nii kümme kraadi kõrgem.
_________________ Foorumis on ühe lolli kohta kümme tarka, nii et jõud on enam-vähem võrdsed.™ |
Kommentaarid: 399 loe/lisa |
345 |
One
15.06.2007 21:31:12
jahutused ju kõigil nvidia ref-id.
see tempide vahe tuleb pigem ventikast või siis sellest mögast mis
radika/gpu vahele jääb.. eks igaüks üritab kokku hoida.
Kommentaarid: 1009 loe/lisa |
728 |
Killhoven
OC`er
15.06.2007 21:37:15
jutt oli cooleritest.
345 |
der hammer
15.06.2007 23:49:18
Killhoven kirjutas: |
Siin hiljuti oli ju jutt, et nendel Sparkle omadel kaunis kehva jahutus ning teiste tootjatega võrreldes ka temp nii kümme kraadi kõrgem. |
Loll jutt.
_________________ Tere. |
Kommentaarid: 148 loe/lisa |
130 |
heretic666
16.06.2007 01:00:31
Totu user kirjutas: |
Loll jutt. |
Loll jutt jah, Sparkle paneb coolerile ainult oma kleepsu nVidia logo peale, muud midagi.
Kommentaarid: 72 loe/lisa |
Killhoven
OC`er
16.06.2007 08:15:20
link :: lugege veelkord
kopeerin laisematele paar rida kah:
But I have to face the fact that I also don't understand why they are using a Peltier cooler; besides the fact it's something with a different angle and thus great for marketing that is.
it makes as much noise as other coolers, it dumps the residual heat inside your PC, absorbs a little more power (although this was hardly measurable and neglectable) and in this test the card overclocks roughly equal or less compared to the standard reference cooled product. The sheer size also makes it block the more than one mainboard slot. If you for example have the 680i SLI mainboard ..
345 |
Le Inc
16.06.2007 10:25:33
it makes as much noise as other coolers, it dumps the residual heat inside your PC, absorbs a little more power (although this was hardly measurable and neglectable) and in this test the card overclocks roughly equal or less compared to the standard reference cooled product. The sheer size also makes it block the more than one mainboard slot. If you for example have the 680i SLI mainboard .. |
See on ju TEC jahuti, jutt käib ikka nvidia ref. jahutist. Nagu ka muud testid on näidanud võtavad nad rohkem voolu kuid jäävad üldjuhul heale heat-pipe jahutile alla ... suht mõttetu värk arvesades veel faktiga et asi on kallim kui muu toodang.
Kommentaarid: 56 loe/lisa |
54 |
One
16.06.2007 10:46:52
seal lihtsalt sellise GPU jaoks liialt lahja peltier.
oleks võimsam peltier siis oleks palju parem temp ka.
aga siis ei jahutaks toda elusees õhuga ära ja arvestada tuleks
vähemalt 200w peltieriga, et mingitki efekti saada, ehk siis
lisa elektrikulu...
728 |
muffello
16.06.2007 18:19:48
Probleem selline, et Colin McRae Dirt demos (rada oli asfaldi kiiruskatse) panin detailid low peale, kuid kõigil minu poolt proovitud resolutsioonidel (800x600, 1024x768, 1280x1024) oli fps 25-41. Imelik eks. Sama efekt oli bagirada, kus kõigil ülalpool nimetatud resodel oli fps 15 kanti. Alles 1280x1024 resol ultra detailidel langes fps asfaldi kiiruskatsel 11-20 peale ja bagikatsel 10 kanti.
Sarnast probleemi täheldasin 3dMark 06, kus default setingutega sain tulemuseks midagi üle 5000 punkti, millega kaasnes mõnus slaidiprogramm mõnes testis. Heakene küll, lasin reolutsiooni alla (kuni 800x600) kuid sellest slaidiprogrammist lahti ei sanudki. Testi ise lõpuni ei teinud, kuid oleks ju lkoogiline arvata, et fps peaks tõusma, kuid seda ei juhtunud. Prose testis põrusin täiega, sellist slaidiprogrammi pole näinudki - üks kaader 5 sekundi jooksul.
nVidia kontrollpaneelil on ka määratud, et pildikvaliteedi määrab 3D programm ise ehk siis mäng. Mõistus otsas. Oskab keegi äkki head nõu anda?
Arvuti konf on profiilis.
_________________ 80-ndate kung-fu filmid on tegijad.
viimati muutis muffello 16.06.2007 19:13:05, muudetud 1 kord |
Kommentaarid: 2 loe/lisa |
der hammer
16.06.2007 18:20:42
Prose on kehv lihtsalt..
130 |
soodent
16.06.2007 18:26:09
Prose võib kehv olla ent isegi kui core 2 panna 3,6ghz peale fps vaevalt 10 pealt üle 20 läheb mis pole ikka mängitav.
Kommentaarid: 822 loe/lisa |
19 :: |
6 :: |
564 |
voltc
16.06.2007 18:31:50
muffello kirjutas: |
Probleem selline, et Colin McRae Dirt demos (rada oli asfaldi kiiruskatse) panin detailid low peale, kuid kõigil minu poolt proovitud resolutsioonidel (800x600, 1024x768, 1280x1024) oli fps 25-41. Imelik eks. Sama efekt oli bagirada, kus kõigil ülalpool nimetaud resodel oli fps 15 kanti. Alles 1280x1024 resol ultra detailidel langes fps asfaldi kiiruskatsel 11-20 peale ja bagikatsel 10 kanti.
Arvuti konf on profiilis. |
üks konkreetne sõna on selle kohta: protsessor
Kommentaarid: 62 loe/lisa |
50 |
16.06.2007 19:55:21
Prose jah piduriks.Uuenda vähemalt mingi 2.5Ghz Dualcore peale(C2D ...või S939 X2 kui platvormi ei taha vahetada...S939 Opteronid liiguvad samuti suht talutava hinnaga )....isegi siis jääb teatud pidur aga see on palju vähemmärgatav 8)
Kommentaarid: 92 loe/lisa |
G80
16.06.2007 22:24:43
Testisin natuke 160.04 drivusid ja võrdlesin 158.45-ga.
Testisin Call of Juareze DX10 benchiga.
Nvidia control panel:16AF , 16QAA , High quality
E6700 2,66GHz def.
8800GTX 630/2000MHz
158.45 :
MIN - 6,8
MAX - 27,9
AVG - 16,9
1280x1024
Shadowmap size - 2048x2048
Shadows quality - 3
Super-sampling - ON (x4)
Multi-sampling - OFF
160.04 :
MIN - 6,7
MAX - 29,5
AVG - 17,6
1280x1024
Shadows quality - 3
Väike FPS-i tõus on siiski olemas.
3D Marke pole veel testinud.
Kommentaarid: 256 loe/lisa |
210 |
Zonerman
17.06.2007 13:53:13
G80 kirjutas: |
See bench ei näita täit tõde kui AA on peal (kasutab sel juhul software AA'd). Full mäng DX10 peal jookseb paremini. Seda arutati ka guru3d's.
Kommentaarid: 66 loe/lisa |
65 |
G80
17.06.2007 14:04:44
Zonerman kirjutas: |
G80 kirjutas: |
See bench ei näita täit tõde kui AA on peal (kasutab sel juhul software AA'd). Full mäng DX10 peal jookseb paremini. Seda arutati ka guru3d's. |
Väga hea,kui jookseb paremini.
210 |
excalibur
17.06.2007 19:55:17
G80 kirjutas: |
E6700 2,66GHz def.
8800GTX 630/2000MHz
158.45 :
MIN - 6,8
MAX - 27,9
AVG - 16,9
1280x1024
Shadows quality - 3
160.04 :
MIN - 6,7
MAX - 29,5
AVG - 17,6
1280x1024
Shadows quality - 3
3D Marke pole veel testinud. |
ei tea mis resoga tegid ma tegin siis enda max resoga mis kannatas.
panin catalystist kah kõik aa-ga seonduva põhja.
tulemus siis selline. Võrdluseks
Kommentaarid: 316 loe/lisa |
262 |
17.06.2007 20:19:30
mainime võrdluse osas ära, et super- ja multisamplingu vahe ei ole mitte just väga triviaalne.
_________________ - londiste
Kommentaarid: 241 loe/lisa |
215 |
excalibur
17.06.2007 20:20:38
teen ka supersamplinguga ära
262 |
Zonerman
17.06.2007 20:22:24
Esiteks oli tal hoopis super sampling kirjade järgi peal vastupidi sinu omale (multisampling). Teiseks see bench demo pidurdab nvidia AA'd tunduvalt erinevalt täisversioonist.
_________________ Sõim ja räuskamine läheb SIIA |
65 |
excalibur
17.06.2007 20:39:49
tõsi langes
min 8,1
max 51,3
avg 22,9
samadel setingutel
clock
e6400 @ 2900ghz
video
840-2120
262 |
anubis
18.06.2007 00:06:03
2900ghz :drool:
Kommentaarid: 326 loe/lisa |
277 |
Crz
18.06.2007 00:44:47
C2D E6600@3.3GHz 1,45V
GIGABYTE GA-965P-DS3
2x1GB APACER 366Mhz 5-5-5-15 1:1
Club3D GeForce 8800GTS 659/2048
kõik õhkjahutus ja 8800gts stock jahutusega, kusjuures nendel klokkidel pilt 100% puhas ja praegu lasen juba pool tundi sellega, cmr dirti mängib samuti puhtalt, rivatuneriga ei saanud rohkem panna, ei läbinud mignit testi vms
Kommentaarid: 90 loe/lisa |
10 :: |
60 |
angel
18.06.2007 00:46:15
viska parem 3Dmark06 ja 05 teste kah... keda see 01SE enam huvitab (see suht prose sõltlane)
Kommentaarid: 175 loe/lisa |
157 |
Crz
18.06.2007 00:47:07
angel kirjutas: |
viska parem 3Dmark06 ja 05 teste kah... keda see 01SE enam huvitab (see suht prose sõltlane) |
mai tea kas jõuan täna enam 3dmark06 ja 05 tõmmata, parem lasen jah neid kuna mul prose ja mälu jube lõdvad ka hetkel
10 :: |
60 |
