| Kas kavatsed peale järelvaatamise lõppemist tellida salvestusteenust 5€ kuus? |
| Jah |
9% |
[ 51 ] |
| Ei |
43% |
[ 228 ] |
| Mul juba olemas |
38% |
[ 202 ] |
| Kolin mujale |
9% |
[ 49 ] |
| hääli kokku : 530 |
õllekas
24.05.2007 12:34:24
taifunk, enam huvitaks route print väljund cmd-s
edit: oot oot, sul ip aliast polegi v? eiei nii ikka ei lähe... konfi võrgukaart nagu wiki õpetuses kirjas ja asi tahe.
GW siis 192.168.1.1 või mis ta sul oligi.
taifunk
24.05.2007 12:47:35
Tegelikult on nii, et sain nii iptv kui ka neti korraga jooksma
C:\Documents and Settings\Stefan>route print
Interface List
0x1 ........................... MS TCP Loopback interface
0x20002 ...00 02 b3 3c 80 20 ...... Intel(R) PRO/100 S Desktop Adapter - Packet
Scheduler Miniport
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 10.22.16.1 192.168.1.111 20
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.111 1
10.22.16.0 255.255.254.0 10.22.16.102 192.168.1.111 20
10.22.16.102 255.255.255.255 127.0.0.1 127.0.0.1 20
10.255.255.255 255.255.255.255 192.168.1.111 192.168.1.111 20
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
192.168.1.0 255.255.255.0 192.168.1.111 192.168.1.111 20
192.168.1.111 255.255.255.255 127.0.0.1 127.0.0.1 20
192.168.1.255 255.255.255.255 192.168.1.111 192.168.1.111 20
224.0.0.0 240.0.0.0 192.168.1.111 192.168.1.111 20
255.255.255.255 255.255.255.255 192.168.1.111 192.168.1.111 1
Default Gateway: 192.168.1.1
Persistent Routes:
None |
C:\Documents and Settings\Stefan>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : KODU-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Intel Pro:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) PRO/100 S Desktop Adapter
Physical Address. . . . . . . . . : 00-02-B3-3C-80-20
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 10.22.16.102
Subnet Mask . . . . . . . . . . . : 255.255.254.0
IP Address. . . . . . . . . . . . : 192.168.1.111
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
10.22.16.1
DNS Servers . . . . . . . . . . . : 194.126.115.18
194.126.101.34 |
_________________ Remember this day, men, for it will be yours for all time. |
| Kommentaarid: 45 loe/lisa |
36 |
loox
24.05.2007 14:41:34
| taifunk kirjutas: |
That's good news.
Kas see ruuter P660R-61 on vana tüüpi (pikerguse korpusega), või uus ruudukujuline, s.t. P660R-61C (Krdi Zyxel, numbrid said otsa vä?)?
Firmware versioon oleks ka huvitav.
taifunk
24.05.2007 15:06:26
Ruuter on kunagi Elioni stardikomplektiga jagatud see vanem ja pikerguse korpusega. Datasheet: http://www.zyxel.com/DownloadLibary_ShortName/P-660M-61/datasheet/P-660M-61_1.pdf
Täielik mudelinimetus on Zyxel Prestige 660R-61
Firmware:
Routing: IP/BRIDGE
ZyNOS F/W Version: V3.40(QG.6) | 3/9/2005
ADSL Chipset Vendor: TI AR7 03.02.06.00
Standard: Multi-Mode |
Kui aega saan, üritaks lähipäevil ka mingi juhendi kokku kirjutada muidu.
36 |
24.05.2007 17:19:43
teadmiseks, et töötavad nii vanad Zyxeli 660H-61, 660R-61 mudelid kui ka uued 660H-D1 ja 660R-D1 mudelid IPTVga.
660H-61 mudeli eeliseks on hetkel vähemalt see, et saab sarnaselt speedtouchile 4 pordi iptv jaoks keerata ning esimesed kolm väljastavad dhcpga internetti, D1 mudelil on telnetiga konfamine natuke keerukam ning pole veel sellisena tööle saanud, pildid jooksevad nii nagu eelnevalt juttu oli.
228 |
24.05.2007 19:40:26
| indu kirjutas: |
huvitav kas kortermaja paketi omanikud saavad varsti ülivõimsa ühenduse ?
Põlvas siin paigaldatakse nedesse majadesse valguskaablit.
Ma tahan ka  |
Nii panin ka seda tähele! Aga pull nüüd selles et kui igal pool ümberkaudsetes majades on see tore lahendus olemas siis minu majas seda pole. Aga täna nägin et askeldati mu maja nurga peal et ei tea kas mu majja topitakse see kah ikkagi sisse.
| Kommentaarid: 39 loe/lisa |
Metsjeesus
24.05.2007 20:06:14
Mingi probleem on tekkinud, mis jubedalt ajab närvi ja segab. Nimelt kaob absoluutselt koguaeg nett ära, vahets on kauem, aga vahest minuti-mõne tagant. Mõtlesin, et äkki on läpaka kaugus (7-8m) siis liig kauge ja integreeritud kaart jura, aga ka Trendneti kaardiga sama jura. Mitte ei koida. Ei tahaks nagu haamriga päris puru seda poksi peksta, aga aru ma ei saa, et mis jama nüüd hakanud on pihta.
Oskab keegi aidata?
_________________ Füsioteraapia alane hindamine & nõu ¤ treeningfilosoofia & toitumine ¤ kaela- ja õlavöötme lihaspingete leevendamine |
94 |
darkside
24.05.2007 20:22:58
salatoimik, ja miks ei kriba juba avaldust esinduses
Metsjeesus, ja kus plaaneedi peal sina netis käid endal probleeme küll pole....
ps! raudselt sõnasin ära !
| Kommentaarid: 72 loe/lisa |
71 |
p2ep
24.05.2007 21:15:20
| Metsjeesus kirjutas: |
| Nimelt kaob absoluutselt koguaeg nett ära, vahets on kauem, aga vahest minuti-mõne tagant. Mõtlesin, et äkki on läpaka kaugus (7-8m) siis liig kauge ja integreeritud kaart jura, aga ka Trendneti kaardiga sama jura. |
Keegi on läheduses veel speedtouchi omandanud. Vaheta kanalit.
| Kommentaarid: 32 loe/lisa |
28 |
a1
24.05.2007 21:39:20
| taavi kirjutas: |
| aminet 110 ei oska hdtv-ga midagi peale hakata. valus, kui kasutajad peavad hakkama sedameid vahetama. arvatavasti algab see asi muidugi mingi üksiku demokanaliga... |
Koksi võrgus pead sama moodi uue tuuneri muretsema ja HD kanal on lisapaketis. Ei midagi uut siin päikese all
| indu kirjutas: |
Põlvas siin paigaldatakse nedesse majadesse valguskaablit. |
Mis on ülivõimas? Korrusmaja kolmikpakett on juba tükk aega olemas. Ülivõrret ma ei kasutaks.
38 |
Aivar88
24.05.2007 21:59:46
| niih, sai siis võetud korrusmaja ühendus koos digitvga- oskab keegi öelda kuidas selle puhul seadistada et saaks ka digitv vaadata VLCga kui netis ka samal ajal olen ? seadmed nii et netijuhe -> switch -> linksys ruuter .
| Kommentaarid: 77 loe/lisa |
58 |
25.05.2007 12:23:49
| DyFendeX kirjutas: |
| niih, sai siis võetud korrusmaja ühendus koos digitvga- oskab keegi öelda kuidas selle puhul seadistada et saaks ka digitv vaadata VLCga kui netis ka samal ajal olen ? seadmed nii et netijuhe -> switch -> linksys ruuter . |
selle puhul peaks vist veel lihtsam olema, viska linksys vahelt ära, switchist arvutisse ja töötab IPTV, teed arvutis PPPoE ühenduse oma tunnus@korrusmaja passiga ja voilaa, internet ka olemas?
pole katsetanud aga ehk töötabki
228 |
Killzone88
25.05.2007 12:46:36
| Sooviks elioni poolt seadistatud (SpeedTouch 546(i) (v6) Firmware 6.1.9.6 user.ini)
| Kommentaarid: 20 loe/lisa |
Aivar88
25.05.2007 14:57:28
| indrekp kirjutas: |
pole katsetanud aga ehk töötabki  |
ei see ei ole nii lihtne, kui linksysi vahel pole ei saa netti mõlemasse arvutisse korraga, ja isegi siis pead disconnetima interneti et digitv saaks vahtida. linksys jääb vahele ja koos sellega vaja kuidagi saada,
58 |
Toomasx
25.05.2007 16:34:19
Sai siis kah soetatud digiTV, siin eelmistel lehtedel lugesin et ei tööta nagu peaks kohati jms.
Minul probleeme pole, ruuter peab vastu ka kõige raskema koormuse all, ning kui lülitan digiboksi välja, tõmbab FTP-dest ja igalpoolt, kus kiirusepiirangut pole, asju 1,17MB/s ehk 1117kb/s kiiruselanguseta, kui digiTV ja keegi teleka ees siis jääb kiirus sinna 550kb/s kanti.
Ainuke negatiivne asi on see, et nüüdsest kõik võrgumängud mida mängin, kaasaarvatud CS, conn lostivad 30s peale serverisse jõudmist, vana ühendusega seda ei olnud.
0 |
M8T0
25.05.2007 17:26:57
| Toomasx kirjutas: |
Ainuke negatiivne asi on see, et nüüdsest kõik võrgumängud mida mängin, kaasaarvatud CS, conn lostivad 30s peale serverisse jõudmist, vana ühendusega seda ei olnud. |
1) 1117kb/sec on 1,09mb/sec mul endal ca 1280 se stabiilne e. 1,15
2) minuteada peaks ainult CS olema see millel paarikümne sekundi jooksul asi ära kukub. teistegap probleeme ei ole (Q3, ET, jne).
3) üle wifi on aga nagunii koguaeg rõve lagimine ja hakkimine iga natukese aja tagant iga mänguga , sellepärast viskan alati läpparila kaabli taha kui mängin.
| Kommentaarid: 87 loe/lisa |
Zonerman
28.05.2007 19:43:54
Keegi teab kuidas Vista all saaks tööle interneti ja iptv korraga. Probleem selles, et kui mõlemad kaablid arvutiga ühendan, kukub internet ära ja jääb aint iptv. Win xp all töötas ideaalselt.
_________________ Sõim ja räuskamine läheb SIIA |
| Kommentaarid: 68 loe/lisa |
67 |
mks
| Kommentaarid: 11 loe/lisa |
9 |
Toomasx
29.05.2007 21:35:41
| InterFace kirjutas: |
| Toomasx kirjutas: |
1) minuteada peaks ainult CS olema see millel paarikümne sekundi jooksul asi ära kukub. teistegap probleeme ei ole (Q3, ET, jne).
ega sa ei tea kuidas sellest lahti saaks?
0 |
Aivar88
29.05.2007 21:39:12
| Toomasx kirjutas: |
| Toomasx kirjutas: |
ega sa ei tea kuidas sellest lahti saaks? |
saab väga kenasti, võta uus nett... ma võtsin: korrusmaja 1/1 mb... ping 5x parem, nagu tõsiselt, eesti servudes ping 5-10 ja ei mingit connection problem ..
58 |
Toomasx
29.05.2007 22:07:21
| Toomasx kirjutas: |
| Toomasx kirjutas: |
saab väga kenasti, võta uus nett... ma võtsin: korrusmaja 1/1 mb... ping 5x parem, nagu tõsiselt, eesti servudes ping 5-10 ja ei mingit connection problem ..  |
Ma arvan et see polnud eriti objektiivne vastus.
Kuidas ilma ühendust vahetamata sellest lahti saaks?
0 |
Aivar88
29.05.2007 22:10:07
| Toomasx kirjutas: |
| Toomasx kirjutas: |
| Toomasx kirjutas: |
Kuidas ilma ühendust vahetamata sellest lahti saaks? |
Võibolla isegi kuidagi saab aga ei tea ühtegi inimest kes sellest lahti oleks saanud. ise arvan et ei saagi
58 |
29.05.2007 22:24:14
Minul juhtub see asi nii 50/50 olukorras! See tähendab et vahel on selline jama CSis aga vahel pole jälle midagi viga!
29.05.2007 22:42:25
Võibolla isegi kuidagi saab aga ei tea ühtegi inimest kes sellest lahti oleks saanud. ise arvan et ei saagi |
Lihtsalt infoks, et mul töötab CS muretult Elioni IPTV ruuteriga.
147 |
Aivar88
29.05.2007 22:44:53
| Mark0 kirjutas: |
Lihtsalt infoks, et mul töötab CS muretult Elioni IPTV ruuteriga. |
järelikult saab asja kuidagi korda teha ilma et netti vahetama peaks... tõenäoliselt ümber kolida
58 |
