raul.
17.09.2006 00:48:58
K: x800rx |
Küsimus siis selline, et mul on Club3D ATi x800rx (GT) R423 corega. Kas un sellisel isendil v6imalik weel piibusid avada w??
Orginaalis on 8 piipu. Otsisin googelist natuke aga otsest õpetus küll ei leinud.
| Kommentaarid: 96 loe/lisa |
spikhoff
17.09.2006 08:47:19
| Ei saa!
| Kommentaarid: 59 loe/lisa |
54 |
raul.
17.09.2006 10:14:32
selge tänan
One
17.09.2006 10:20:57
proovida võib aga vast lahti ei saa jah..
mingi imeväike võimalus on, et saab
728 |
raul.
17.09.2006 10:28:17
| Winterwind kirjutas: |
mingi imeväike võimalus on, et saab |
aa aga on sul selle koha peal mingeid õpetusi pakkuda w??
WäntWõll
make.believe
300 |
One
728 |
raul.
17.09.2006 10:47:10
Riva tuner räägis mulle sellist asja:
Northbridge information
$0400000000 Description : unknown
$0400000001 Vendor ID : 8086 (Intel)
$0400000002 Device ID : 277c
$0400000003 AGP bus : not supported
Display adapter information
$0000000000 Description : RADEON X800GT
$0000000001 Vendor ID : 1002 (ATI)
$0000000002 Device ID : 554b
$0000000003 Location : bus 6, device 0, function 0
$0000000004 Bus type : PCIE
$000000000f PCIE link width : 16x supported, 16x selected
$0000000009 Base address 0 : d0000000 (memory range)
$000000000a Base address 1 : none
$000000000b Base address 2 : ff9f0000 (memory range)
$000000000c Base address 3 : none
$000000000d Base address 4 : 0000c800 (I/O range)
$000000000e Base address 5 : none
ATI specific display adapter information
Graphics core : R423 (8pp)
Memory bus : 256-bit
Memory type : DDR3 SGRAM
Memory amount : 256MB
Core clock : 472.500MHzM
Memory clock : 492.750MHz (985.500MHz effective)
Reference clock : 27.000MHz
Memory timings
WR latency : 1.5
CAS latency : 4
CMD latency : 0.0
STR latency : 1.5
tRCDRD, RAS to CAS read : 7
tRCDWR, RAS to CAS write : 4
tRP , Row precharge : 6
tRAS , Row active : 6
tRRD , Row active to row active command : 6
tR2W , Read to write turnaround : 6
tWR , Write recovery : 7
tW2R , Write to read turnaround : 1
tW2R , Write to read turnaround / same bank : 7
tR2R , Read to read turnaround : 3
One
17.09.2006 10:48:56
| jahutuse alla pole vaadanud siis?
728 |
raul.
17.09.2006 11:03:32
Mälu kiipide peal oli selline text:
Samsung 519
K4J55323QF- GC16
AWC926AAS
Rohkemat ei osanud ma vaadata. Öelge kust vaja vaadata un eks ma siis sealt vaatan.
One
17.09.2006 11:04:41
core pealt vaata kirja, kas R480 või R423.
pakun, et R480 ja 99% võimalus, et underlock ei õnnestu
728 |
raul.
17.09.2006 11:09:15
pakun, et R480 ja 99% võimalus, et underlock ei õnnestu |
aa seda ma ju vist ütlesin esimeses postituses juba, et R423
PS. muuseas ma olen seda kaarti jooksutanud clockidel 575/575. 3dmark05'es artifacte ei loopinud. ja seda k6ike orginaal jahutusega
One
17.09.2006 11:11:37
kas see R423 oli siis corele kirjutatud või väidad seda everesti järgi?
728 |
raul.
17.09.2006 11:15:08
see oli riva tuneri j2rgi aga nuh ma v6in corele ka vaadata oot natuke
One
17.09.2006 11:20:39
X800GT ja X800GTO on kõik R423 rivatuneri/everesti/atitooli järgi. neile lihtsalt antakse biosiga see id.
pakun, et su kaardil siiski R480 kuna klokkub suht palju ja mem ka 1.6ns
728 |
raul.
17.09.2006 11:36:36
pakun, et su kaardil siiski R480 kuna klokkub suht palju ja mem ka 1.6ns |
Njah pühkisin kaardi oma AS5'st puhtax ja oligi R480 peale kirjutatud. Nuh aga kas näiteks sellisel juhul mingist teist biosi annab peale panna näiteks x850xt vms?? Kuna m2lud paistavad head olema. Ja kui palju v6iks biosi vahetusest sel puhul kasu tulla??
One
17.09.2006 11:39:15
| tee selle GTO2 õpetuse järgi, vaata äkki saad lahti miskit aga ega eriti loota pole
728 |
WäntWõll
make.believe
17.09.2006 11:41:18
Proovida võid ikka ja kasu saad niipalju,et saad default kellad kõrgemaks
Mida muidu saab ka biose mudijaga teha(ei oel vaja OC progesid jooksutada)
300 |
raul.
17.09.2006 14:48:52
Selge, eks ma siis vaatan, mis toimuma hakkab.
Edit: benchisin natuke seda kaarti. peal un mul hetkel orginaal jahutus
Pilt
