Psych0
20.08.2006 12:42:30
lolol, sa selle mikk36 ftp-st ei taha tõmmata ?
| Kommentaarid: 61 loe/lisa |
57 |
kjaups
MeesKesTuliMetsast
20.08.2006 13:03:53
Minu mõistus on otsas. Sierrast mul patche tirida ei lase. Fileshackist või mida inganes selle koha nimi nüüd oligi, sealt mulle ükski patch peale ei hakka. Ei globalid, ei us, ei en ... Närv juba must ...
Mulle põhimõtteliselt läksid kõik patchi kuni 1.05-ni peale en , kuid nüüd essugi
_________________ M: korter Mustamäel
YAGA müügiputka |
| Kommentaarid: 174 loe/lisa |
143 |
Mart352
20.08.2006 13:07:24
| kjaups kirjutas: |
Mulle põhimõtteliselt läksid kõik patchi kuni 1.05-ni peale en , kuid nüüd essugi |
neile kes linki ei viitsinud klikkida
This patch prepares F.E.A.R. to be compatible with the upcoming release of F.E.A.R. Combat. 1.07 also features multiplayer functionality upgrades including the addition of three new maps.
Please Note: For a fraction of the current owners of F.E.A.R. PC videogame, there is a known incompatibility between the F.E.A.R. Patch 1.07 and original copies of F.E.A.R. that were purchased via direct download sites such as Direct 2 Drive. If you or anyone you know digitally downloaded versions of the original F.E.A.R. videogame, you may not be able to upgrade your copies of F.E.A.R. to 1.07 at this time. All though this will only affect a fraction of our F.E.A.R. community, we do apologize for the inconvenience and are currently working on a solution to this problem and expect to release a fully compatible patch shortly. In the meanwhile, you will soon be able to download the free version of F.E.A.R. Combat and enjoy the features of the 1.07 patch at http://www.joinfear.com. Once the full patch is available, the download will be available at http://www.fearfans.com. Once again we apologize for the inconvenience and are making every effort for all F.E.A.R. fans to enjoy the multiplayer component F.E.A.R.Combat. |
teisel lingil on üks workaround, et saada viimane patch peale
_________________ Imperfection is perfect |
| Kommentaarid: 54 loe/lisa |
51 |
KrikU
20.08.2006 13:07:38
Mul oli FULL feariga nende patchidega sama jama, et ei töötanud ükski (ütles et vaja ingliskeelset versiooni mis ongi mul).
Aga Gamelandi serveris oli praegu küll kõik ok, rahvast paksult täis ja action käib. Ilmselt oli tüüpiline serveri ülekoormus eile õhtul, seal masinas jookseb hetkel ka Maleva CSS server ja mingi server oli veel jooksma pandud millest ma midagi ei teadnud
Esimesel võimalusel kolib serveri teise kasti jooksma!
119 |
kjaups
MeesKesTuliMetsast
20.08.2006 16:51:43
Mart352, sorry, uurisin ennist ainult ülemist linki, ning see viis vist sierra lehele, kust ma midagi ei saanud.
Tänud, panin pragu teiselt lingilt jooksma, 10 minuti pärast saab teada
KrikU, peale kella 15 on mul täna ka vaba aega (kui tüdrukud taga ei hakka ajama ), oleks endalgi suur thatmine tagasi tulla vanu häid aegu meenutama. Gameland.ee , here i come 8)
[EDIT]
Sai patchitud. Praegu pean ainult ära minema natukeseks ajaks ning pärast tagasitulle teztin ka, kas ikka hakkas tööle
[EDIT2] Sai siis üks pisipehme pela tehtud ning 13 minutit enne maailma lõpu (factory) mängitud.
Paistab, et ma ei olegi nii roostes ja üllatavalt hea oli mängida. Ainult, et mul arvuti uimerdas suht palju , peab vist defragmentima kettaid ja saastapuhastust korraldama
Kirkut nägin seal ja siis keegi pisipoisu. Kes veel olid Kahjuks läks screen nässu, ei jõudnud nupu vajutada, kuid lõpus olin ma vist 2 kohal
Keegi sellest suurest tournamendist on ka juba mõelnud osa võta. Ma võin kampa tulla, kuid kooliga seonduvalt ma ei pruugi alati suuta osa võta, kuid kui saan, siis oleksin vast suureks abiks
[EDIT3] No ikka mõnus rist ja viletsus on see uus patch minu jaoks. Kui tulin tagasi mängima, siis arvuti hakkas eriti jõhkralt kiiluma. FSB oli pidevalt 30-40 ümber, kuid arvuti jooksis iga 5 sekundi tagant 2 sekiks kinni ... Sai siis oma setingud low peale pandud ja taskmanageriga kõikvõimalikud tegurid killitud ning kuidagi talutavamaks muutus küll, kuid kui kokku said mingi 5 matsi ja kuulid vihisesi, siis oli arvuti taas koomas ... Mis seal selle 1.07 siis viga on, seda ma ei tea, kuid minu arvutil ta enam joosta ei taha.
Lisaks teises maailmas kadus mul pärast esimese granaadi pauku hääl ära ja nii ma siis pidingi ilma mängima. Vahepeal küll käisid mingid ulmelised pininad ja hääled, kuid see oli ka kõik...
Pisike screen ka: http://img204.imageshack.us/my.php?image=untitled1dy1.jpg
YAGA müügiputka |
143 |
Dominus
20.08.2006 17:49:50
ehh mul pole Fear Combatis häält,muidu tundub et jookseb paremini ja graafika veab isegi normilt välja
Desktopil ja teistes mängudes on sound olemas.
edit : mängu optionist juba proovitud,ei miskit.
viimati muutis Dominus 20.08.2006 18:17:10, muudetud 1 kord |
76 |
Cheetah
20.08.2006 17:55:04
| Mängu optionsist ei anna midagi muuta ?
| Kommentaarid: 91 loe/lisa |
84 |
madness
20.08.2006 18:04:18
meh..mäng crashis ja enam käima ei lähe :/
eriti lahe
| Kommentaarid: 13 loe/lisa |
dexter666
20.08.2006 20:22:34
| kas keegi viitsiks siia üles panna EN versiooni viimase patchi lingi?
| Kommentaarid: 93 loe/lisa |
85 |
kjaups
MeesKesTuliMetsast
20.08.2006 21:28:37
[quote="Mart352"]
Mässa ja loe neid linke.
Kurat, gameland.ee servu on ikka jubedalt ebastabiilne. Ja otse factory mapil ka
Kes see --j-- seal oli, mõnusalt lammutab
YAGA müügiputka |
143 |
ebardkonn
20.08.2006 22:06:36
| njah sai kah läägamas käidud seal gaylandi serveris. Aga see gametype on täielik waste of time..so enamus ajast vedelen soome servudes.
| Kommentaarid: 6 loe/lisa |
UrmoZ
20.08.2006 22:18:23
ebardkonn, mida jörised... no offence... kellele meeldib, kellele mitte... ise pelan SloMo-d kuna "rig" võimaldab heade sättetega mängida ja grafa on mõnus "eye-candy", kui slowmo peale lükatakse
pealegi ühendus on servul ikka pole laggi
_________________ Amazon - will not buy!
12VHPWR or 12V2x6 GPU power connector - will not touch.
Müügiteemale PS pakkumisi ei aktsepteeri! |
| Kommentaarid: 226 loe/lisa |
206 |
rajur
20.08.2006 22:49:18
Kurat, gameland.ee servu on ikka jubedalt ebastabiilne. Ja otse factory mapil ka  |
Jeap, ühtegi mapi pole võimalik otsast lõpuni, vahepeal lihsalt kaob ühendus.
| Kommentaarid: 30 loe/lisa |
30 |
KrikU
21.08.2006 00:09:36
Mul endal katkes ühendus kah 1 kord, aga muidu on ilusti toiminud... ju siis on linuxi serveripool ikka veel bugine Muidu jooksis küll ilusti
119 |
Ramones
21.08.2006 00:36:28
Sai kah täna veidi gameland servus lammutamas käidud. Dominiust nägin kah Oleks kauem pelanud, aga pidi minema ära Toilasse Matveret ja Peebot vaatama
| Kommentaarid: 76 loe/lisa |
75 |
Jürks
21.08.2006 10:34:22
| kjaups kirjutas: |
Kes see --j-- seal oli, mõnusalt lammutab  |
Nu ega ma palju ei lammutand sa ise panid factorys veel hullemini
Tea endal küll ühtegi korda ühendust ei kadund gamelandis,kuigi mul on mingi jama wifi ühendus.
Küll aga mäng freezis
ebardkonn
21.08.2006 11:48:27
| tell me about it , minimum configa ja hetkel 512MB mäluga ning vähemalt mapi alguses laggab ikka like hell. Muidugi eks see m2ng olegi suht lagg contest natuke vanema raua omanikele.
piraat262
21.08.2006 11:55:17
| hmm, ma laggan ikka hullult seal. ping pidevalt +3000. gameland ee pole leidnudki veel
| Kommentaarid: 75 loe/lisa |
69 |
Killzone88
21.08.2006 16:54:42
| piraat262 kirjutas: |
| hmm, ma laggan ikka hullult seal. ping pidevalt +3000. gameland ee pole leidnudki veel |
Mine http://www.game-monitor.com seal kõik servud üleval!!! Mul on ka mälu 512 MB ja saan pelada mediumi peal , laggi ei ole !!!
| Kommentaarid: 20 loe/lisa |
kjaups
MeesKesTuliMetsast
21.08.2006 17:44:03
Jürks, no factory ja facility my lemmikumad maailmad üldse. Seal on minust väga raske jagu saada ...
Aga sa panid ikka suht julmalt. Nii kui korraks valvuse kaotasin olid sina kohe platsis ja tirisid hetkega maha
YAGA müügiputka |
143 |
Mirkel
21.08.2006 22:07:38
| ebardkonn kirjutas: |
| tell me about it , minimum configa ja hetkel 512MB mäluga ning vähemalt mapi alguses laggab ikka like hell. Muidugi eks see m2ng olegi suht lagg contest natuke vanema raua omanikele. |
Say what?
Minimum configa on väga smooth. Võta varjud maha ja saad ka mediumiga vabalt mängida.
Mina olen enda systeemi suutlikusega feari puhul ikka väga rahul.
| Kommentaarid: 63 loe/lisa |
57 |
Dominus
21.08.2006 22:30:28
| tee mis tahad,FEAR'is häält sisse ei saa...
76 |
Cheetah
21.08.2006 23:43:30
| Ava Fearcombati folderis config.exe sealt options ja kõik linnud eest ära, kui mõni lind on siis eemalda.
84 |
softis
22.08.2006 09:25:36
Endal on mingi kala installeriga. Tirisin selle esmalt estpakist. Jõudis kohale, üritasin avada. Arvuti hakkab roppu moodi ragistamaja ja jääbki ragistama, aga installerit lahti ei tee. Ootasin mingine 20 minti, ikka ei midagi.
Sama jama ka joinfear kaudu tõmmatud isendiga. Any ideas?
EDIT
25 minti ootasin ja sain tööle
| Kommentaarid: 21 loe/lisa |
21 |
mutabor
22.08.2006 10:44:00
softis, viirusetõrje ragistab exe faili kallal nii kaua ehk.
_________________ /allkiri |
| Kommentaarid: 24 loe/lisa |
22 |
softis
22.08.2006 11:46:46
| mutabor kirjutas: |
| softis, viirusetõrje ragistab exe faili kallal nii kaua ehk. |
See oleks esimene kord kui NOD32 mul mingit faili nii kaua ragistab. Teisi, isegi suuremaid, installereid ta küll veel vägistanud pole niimodi.
21 |
Mirkel
22.08.2006 12:01:11
| kas gamelandi servu on alati tühi?
57 |
Ramones
22.08.2006 12:10:12
| Mirkel kirjutas: |
| kas gamelandi servu on alati tühi? |
Vahepeal oli täiega täis... eile õhtul oli täitsa tühi
75 |
Dominus
22.08.2006 18:39:08
KrikU, hetkel igatahes ei leia mina Gameland.ee serverit.
häält pole siiamaani,config.exe's ammu vaadatud,kõik linnukesed eest :/
edit : nüüd leidsin,vahest vist kui Disconnectib siis kaob listist ning tuleb mingi aja pärast tagasi.
76 |
23.08.2006 00:28:11
| feari installer + nod32 siin kiire, ei mingit jama
| Kommentaarid: 85 loe/lisa |
KrikU
23.08.2006 11:14:36
| ma lisasin serveri favorites alla, seal jah kaob ka aegajalt ära kuid kui hiirega serveri peal klikkida siis ta teeb nö. refresh ja tavaliselt siis saab kätte asja.
119 |
madex
23.08.2006 12:43:05
| mikk36 kirjutas: |
| feari installer + nod32 siin kiire, ei mingit jama |
Mul esialgu ragistas kõvaketast oma pool tundi,kuid midagi ette ei tulnud ja panin kinni. Tõmbasin uuesti,jälle see sama jama.Kuni mõned päevad hiljem softise postitust lugesin,siis ootasin umbes 5-10 min ja käima ta läkski.
| Kommentaarid: 14 loe/lisa |
Mirkel
23.08.2006 15:23:26
| KrikU kirjutas: |
| ma lisasin serveri favorites alla, seal jah kaob ka aegajalt ära kuid kui hiirega serveri peal klikkida siis ta teeb nö. refresh ja tavaliselt siis saab kätte asja. |
täna oli väga viis
absull 0 pangestumist.
57 |
Marduuhin
108 |
ebardkonn
28.08.2006 17:09:44
Gamelandi servule nüüdsest pass peal. Passwordi teadasaamiseks oleks soovituslik serveri nime uurida natuke . Btv täna õhtul võiks väiksema sõja teha.
aht0
28.08.2006 19:49:01
kui peaks arvutisse olema installitud ACE Mega Codecs pack ja FEAR käima ei lähe, ainult viskab ekraani tumedaks siis on soovitatav võtta ette codec packi Dashboard ja lülitada koodekid Minimal peale.. see aitab.. see on Readme failis ka Known Issues all ära toodud.. mõistatasin ise kaks tundi peale esmainstalli milles võib probleem olla..
| Kommentaarid: 82 loe/lisa |
71 |
dexter666
03.09.2006 01:44:54
| Äkki kellelgi kuskil fail, mis muutis fear en versiooni us versiooniks? FEARA.Arc000 fail peaks olema.
85 |
Celos
11.09.2006 11:44:11
Mänguga selline jama, et ei kuule tegelaste hääli. Kõik muud helid (sammud, muusika jne.) on olemas, aga tegelaste juttu ei kuule. Eriti imelik on see, et kui salvestatud mäng avada, siis ~ühte lauset kuuleb ja siis jäävad jälle kõik vait.
Siin juba mõnda asja soovitatud, aga need kah ei töötanud.
Mõni aeg sai probleemi guugeldatud kaa. Tulemusteta. Audio draiverid uued, WMA codec 1. prioriteediga, EAX maas. Üritasin knowledgebase'ist saadud varianti, et installida WMA audio codec (WMFAdist.exe) manuaalselt, aga see viskab ette "error registering OCX C:\WINDOWS\System32\3codeca.acm". Sellele probleemile samuti netist lahendust ei leidnud. Kõik muud helid arvutis korras, probleem ainult selle mänguga.
Äkki kellelgi on olnud sarnane jama või on ideid kuidas seda lahendada. Ei tahaks eriti mängima hakata nii, et juttu ei kuule.
| Kommentaarid: 17 loe/lisa |
16 |
angel
11.09.2006 15:11:48
vana mure... loe readme faili ja installi see codec. Üldiselt saad sa teada sealt failist et mingi X heli värk vaja installida (installer on plaadil) ja kõik. AGA vahest (vähemalt minul) juhtub nõnda et installer annab lõpus ERROR i. Seega see fail millega see error seotud on tuleb ümber nimetada .dll lõpuga failiks (selleks et seda teha peab mudugi windowsis olema faili laiendi näitamine sees: tööribalt valid Tools>Folder Options> View>Hide extensions for known file types <<<< selle eest võta linnuke ära ja vajuta OK) . Ja siis uuesti installer käima lasta ja ongi kõik korras. Vähemalt ma sain asja nii tööle.
157 |
Fhlouz
12.09.2006 13:06:05
võiks eestis FEARi kommuuni arendada ja kraami kuna tegemist on ju ikkagi väga hea mänguga ja mis on veel tasuta, clanne pole juba eestis? quakenetis võiks chat olla jne nagu wolf ET arenes võiks ka FEAR areneda.
muidu mis arvate kui kuulsaks FEAR üldse saab ja kas teda ka hakatakse mängima näiteks WCG, CPL või mõnel muul sellisel suurel lanil?
quakenetis on samuti olemas juba #fear.wars kust saab sõdu otsida nii et kõik waritama
kas fearis mingi confimise teema ka on et, konsooli igast käsud ja kraam et siis paremini jookseks ja ping oleks parem nagu q3, codis jne, teab keegi neid käske?
_________________ Wordpress/Woocommerce kodulehed/epoed. |
Mario153
| Kommentaarid: 56 loe/lisa |
50 |
softis
13.09.2006 20:39:11
Hetkel tirib 400 kilo per sekund. Vaatab, mis kiiruseni langeb
500 mega pole kõige hullem suurus.
21 |
purexpure
13.09.2006 20:41:46
softis, Millest sa räägid? Extraction Pointist ?
| Kommentaarid: 58 loe/lisa |
47 |
softis
13.09.2006 20:43:10
Jah. Nüüd juba 120 kilo sekundis
fearxp_spdemo.exe
21 |
purexpure
13.09.2006 20:51:26
| Äkki saaks linki? Tänud.
47 |
softis
13.09.2006 20:53:37
whatisfear.com
Pole tänu väärt. Aitäh, et 50 kilo sekis veelgi alla läheb sinu pärast
21 |
217 |
angel
13.09.2006 23:05:28
mnjah demo jube lühike.
Mõnusalt 2 suuremat ruumi igatahes demos oli. Ei tea kas full is rohkem suuri ruume leiduma hakkab. Ja see verise ruumi kollid olid lahedad. Algul ei saanud aru kes kurat mind torgib siis andsin jalaga ja mingi tahma kogu jäi õhku ainult....
Samas suured ruumid söövad fps i 60 pealt 20 peale seega 7800GT on fear i jaoks nüüd suht kutu kui max grafaga tahta pelada (ilma aa ta ja 2xaf iga)
Kurb et graafiliselt mindagi uuendatud või parandatud ei ole. Siiani ei ole plahvatavatel tünnidel neil leekidel mis jäävad dünaamilist valgus efekti jms pisi vead.
157 |
Iron miki
14.09.2006 13:09:05
Mulle tundus selle demo graafika veel hullem kui kui ta enne oli, paljud asjad olid kuidagi kandilisemad ja efektid kuidaginõrgema või üldse puudusid
17 |
Mario153
14.09.2006 20:59:15
| Iron miki kirjutas: |
Mulle tundus selle demo graafika veel hullem kui kui ta enne oli, paljud asjad olid kuidagi kandilisemad ja efektid kuidaginõrgema või üldse puudusid  |
Kui su profiili järgi otsustada siis - esiteks ei toeta su kaart SM3-megi ja graafilist maximumi ei areta sa elusees sealt välja. Ja hull ei saa FEAR-i graafika kohta mitte mingist otsast öelda. Võmaste masinate ja põhjas graafikaga näeb FEAR väga hea välja.
50 |
