Psych0
20.08.2006 11:42:30
lolol, sa selle mikk36 ftp-st ei taha tõmmata ?
| Kommentaarid: 61 loe/lisa |
57 |
kjaups
MeesKesTuliMetsast
20.08.2006 12:03:53
Minu mõistus on otsas. Sierrast mul patche tirida ei lase. Fileshackist või mida inganes selle koha nimi nüüd oligi, sealt mulle ükski patch peale ei hakka. Ei globalid, ei us, ei en ... Närv juba must ...
Mulle põhimõtteliselt läksid kõik patchi kuni 1.05-ni peale en , kuid nüüd essugi
M: 3D Touch V3.2 15€
M: KIA Sportage 2023a |
| Kommentaarid: 170 loe/lisa |
139 |
Mart352
20.08.2006 12:07:24
| kjaups kirjutas: |
Mulle põhimõtteliselt läksid kõik patchi kuni 1.05-ni peale en , kuid nüüd essugi |
neile kes linki ei viitsinud klikkida
This patch prepares F.E.A.R. to be compatible with the upcoming release of F.E.A.R. Combat. 1.07 also features multiplayer functionality upgrades including the addition of three new maps.
Please Note: For a fraction of the current owners of F.E.A.R. PC videogame, there is a known incompatibility between the F.E.A.R. Patch 1.07 and original copies of F.E.A.R. that were purchased via direct download sites such as Direct 2 Drive. If you or anyone you know digitally downloaded versions of the original F.E.A.R. videogame, you may not be able to upgrade your copies of F.E.A.R. to 1.07 at this time. All though this will only affect a fraction of our F.E.A.R. community, we do apologize for the inconvenience and are currently working on a solution to this problem and expect to release a fully compatible patch shortly. In the meanwhile, you will soon be able to download the free version of F.E.A.R. Combat and enjoy the features of the 1.07 patch at http://www.joinfear.com. Once the full patch is available, the download will be available at http://www.fearfans.com. Once again we apologize for the inconvenience and are making every effort for all F.E.A.R. fans to enjoy the multiplayer component F.E.A.R.Combat. |
teisel lingil on üks workaround, et saada viimane patch peale
_________________ Imperfection is perfect |
| Kommentaarid: 54 loe/lisa |
51 |
KrikU
20.08.2006 12:07:38
Mul oli FULL feariga nende patchidega sama jama, et ei töötanud ükski (ütles et vaja ingliskeelset versiooni mis ongi mul).
Aga Gamelandi serveris oli praegu küll kõik ok, rahvast paksult täis ja action käib. Ilmselt oli tüüpiline serveri ülekoormus eile õhtul, seal masinas jookseb hetkel ka Maleva CSS server ja mingi server oli veel jooksma pandud millest ma midagi ei teadnud
Esimesel võimalusel kolib serveri teise kasti jooksma!
119 |
kjaups
MeesKesTuliMetsast
20.08.2006 15:51:43
Mart352, sorry, uurisin ennist ainult ülemist linki, ning see viis vist sierra lehele, kust ma midagi ei saanud.
Tänud, panin pragu teiselt lingilt jooksma, 10 minuti pärast saab teada
KrikU, peale kella 15 on mul täna ka vaba aega (kui tüdrukud taga ei hakka ajama ), oleks endalgi suur thatmine tagasi tulla vanu häid aegu meenutama. Gameland.ee , here i come 8)
[EDIT]
Sai patchitud. Praegu pean ainult ära minema natukeseks ajaks ning pärast tagasitulle teztin ka, kas ikka hakkas tööle
[EDIT2] Sai siis üks pisipehme pela tehtud ning 13 minutit enne maailma lõpu (factory) mängitud.
Paistab, et ma ei olegi nii roostes ja üllatavalt hea oli mängida. Ainult, et mul arvuti uimerdas suht palju , peab vist defragmentima kettaid ja saastapuhastust korraldama
Kirkut nägin seal ja siis keegi pisipoisu. Kes veel olid Kahjuks läks screen nässu, ei jõudnud nupu vajutada, kuid lõpus olin ma vist 2 kohal
Keegi sellest suurest tournamendist on ka juba mõelnud osa võta. Ma võin kampa tulla, kuid kooliga seonduvalt ma ei pruugi alati suuta osa võta, kuid kui saan, siis oleksin vast suureks abiks
[EDIT3] No ikka mõnus rist ja viletsus on see uus patch minu jaoks. Kui tulin tagasi mängima, siis arvuti hakkas eriti jõhkralt kiiluma. FSB oli pidevalt 30-40 ümber, kuid arvuti jooksis iga 5 sekundi tagant 2 sekiks kinni ... Sai siis oma setingud low peale pandud ja taskmanageriga kõikvõimalikud tegurid killitud ning kuidagi talutavamaks muutus küll, kuid kui kokku said mingi 5 matsi ja kuulid vihisesi, siis oli arvuti taas koomas ... Mis seal selle 1.07 siis viga on, seda ma ei tea, kuid minu arvutil ta enam joosta ei taha.
Lisaks teises maailmas kadus mul pärast esimese granaadi pauku hääl ära ja nii ma siis pidingi ilma mängima. Vahepeal küll käisid mingid ulmelised pininad ja hääled, kuid see oli ka kõik...
Pisike screen ka: http://img204.imageshack.us/my.php?image=untitled1dy1.jpg
139 |
Dominus
20.08.2006 16:49:50
ehh mul pole Fear Combatis häält,muidu tundub et jookseb paremini ja graafika veab isegi normilt välja
Desktopil ja teistes mängudes on sound olemas.
edit : mängu optionist juba proovitud,ei miskit.
viimati muutis Dominus 20.08.2006 17:17:10, muudetud 1 kord |
76 |
Cheetah
20.08.2006 16:55:04
| Mängu optionsist ei anna midagi muuta ?
| Kommentaarid: 91 loe/lisa |
84 |
madness
20.08.2006 17:04:18
meh..mäng crashis ja enam käima ei lähe :/
eriti lahe
| Kommentaarid: 13 loe/lisa |
dexter666
20.08.2006 19:22:34
| kas keegi viitsiks siia üles panna EN versiooni viimase patchi lingi?
| Kommentaarid: 93 loe/lisa |
85 |
kjaups
MeesKesTuliMetsast
20.08.2006 20:28:37
[quote="Mart352"]
Mässa ja loe neid linke.
Kurat, gameland.ee servu on ikka jubedalt ebastabiilne. Ja otse factory mapil ka
Kes see --j-- seal oli, mõnusalt lammutab
139 |
ebardkonn
20.08.2006 21:06:36
| njah sai kah läägamas käidud seal gaylandi serveris. Aga see gametype on täielik waste of time..so enamus ajast vedelen soome servudes.
| Kommentaarid: 6 loe/lisa |
UrmoZ
20.08.2006 21:18:23
ebardkonn, mida jörised... no offence... kellele meeldib, kellele mitte... ise pelan SloMo-d kuna "rig" võimaldab heade sättetega mängida ja grafa on mõnus "eye-candy", kui slowmo peale lükatakse
pealegi ühendus on servul ikka pole laggi
_________________ Amazon - will not buy!
12VHPWR or 12V2x6 GPU power connector - will not touch. |
| Kommentaarid: 225 loe/lisa |
205 |
rajur
20.08.2006 21:49:18
Kurat, gameland.ee servu on ikka jubedalt ebastabiilne. Ja otse factory mapil ka  |
Jeap, ühtegi mapi pole võimalik otsast lõpuni, vahepeal lihsalt kaob ühendus.
| Kommentaarid: 30 loe/lisa |
30 |
KrikU
20.08.2006 23:09:36
Mul endal katkes ühendus kah 1 kord, aga muidu on ilusti toiminud... ju siis on linuxi serveripool ikka veel bugine Muidu jooksis küll ilusti
119 |
Ramones
20.08.2006 23:36:28
Sai kah täna veidi gameland servus lammutamas käidud. Dominiust nägin kah Oleks kauem pelanud, aga pidi minema ära Toilasse Matveret ja Peebot vaatama
| Kommentaarid: 76 loe/lisa |
75 |
Jürks
21.08.2006 09:34:22
| kjaups kirjutas: |
Kes see --j-- seal oli, mõnusalt lammutab  |
Nu ega ma palju ei lammutand sa ise panid factorys veel hullemini
Tea endal küll ühtegi korda ühendust ei kadund gamelandis,kuigi mul on mingi jama wifi ühendus.
Küll aga mäng freezis
ebardkonn
21.08.2006 10:48:27
| tell me about it , minimum configa ja hetkel 512MB mäluga ning vähemalt mapi alguses laggab ikka like hell. Muidugi eks see m2ng olegi suht lagg contest natuke vanema raua omanikele.
piraat262
21.08.2006 10:55:17
| hmm, ma laggan ikka hullult seal. ping pidevalt +3000. gameland ee pole leidnudki veel
| Kommentaarid: 74 loe/lisa |
68 |
Killzone88
21.08.2006 15:54:42
| piraat262 kirjutas: |
| hmm, ma laggan ikka hullult seal. ping pidevalt +3000. gameland ee pole leidnudki veel |
Mine http://www.game-monitor.com seal kõik servud üleval!!! Mul on ka mälu 512 MB ja saan pelada mediumi peal , laggi ei ole !!!
| Kommentaarid: 20 loe/lisa |
kjaups
MeesKesTuliMetsast
21.08.2006 16:44:03
Jürks, no factory ja facility my lemmikumad maailmad üldse. Seal on minust väga raske jagu saada ...
Aga sa panid ikka suht julmalt. Nii kui korraks valvuse kaotasin olid sina kohe platsis ja tirisid hetkega maha
139 |
Mirkel
21.08.2006 21:07:38
| ebardkonn kirjutas: |
| tell me about it , minimum configa ja hetkel 512MB mäluga ning vähemalt mapi alguses laggab ikka like hell. Muidugi eks see m2ng olegi suht lagg contest natuke vanema raua omanikele. |
Say what?
Minimum configa on väga smooth. Võta varjud maha ja saad ka mediumiga vabalt mängida.
Mina olen enda systeemi suutlikusega feari puhul ikka väga rahul.
| Kommentaarid: 63 loe/lisa |
57 |
Dominus
21.08.2006 21:30:28
| tee mis tahad,FEAR'is häält sisse ei saa...
76 |
Cheetah
21.08.2006 22:43:30
| Ava Fearcombati folderis config.exe sealt options ja kõik linnud eest ära, kui mõni lind on siis eemalda.
84 |
softis
22.08.2006 08:25:36
Endal on mingi kala installeriga. Tirisin selle esmalt estpakist. Jõudis kohale, üritasin avada. Arvuti hakkab roppu moodi ragistamaja ja jääbki ragistama, aga installerit lahti ei tee. Ootasin mingine 20 minti, ikka ei midagi.
Sama jama ka joinfear kaudu tõmmatud isendiga. Any ideas?
EDIT
25 minti ootasin ja sain tööle
| Kommentaarid: 21 loe/lisa |
21 |
mutabor
22.08.2006 09:44:00
softis, viirusetõrje ragistab exe faili kallal nii kaua ehk.
_________________ /allkiri |
| Kommentaarid: 24 loe/lisa |
22 |
