uus teema   vasta Uudised »  Ülevaated, kasutajate hinnangud »  Ülevaade: Sony Playstation Portable (PSP) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 13, 14, 15 ... 22, 23, 24  järgmine
Anti
sõnum 09.05.2006 17:19:55 vasta tsitaadiga
M@x kirjutas:
Nii, saan ma siis õieti aru.
Ainult 1.50 fireware versiooniga saab mängida netist tõmmatud .iso mänge? UMD Emulaatoriga.
ahvilõust
ahvilõust
sõnum 09.05.2006 18:43:17 vasta tsitaadiga
M@x kirjutas:
mis ka kõik ei tööta ja paljud juksivad. minu jaoks ainuke eelis on et saab palju mugavamalt homebrewd kasutada, need kommerts mängud on suurem osa saast.
Gdesainer
Final Aap
Final Aap
sõnum 10.05.2006 19:03:52 vasta tsitaadiga
Aga kas uuemate mängude jaoks on alati (kõige?) uuemat firmwaret vaja?
Kommentaarid: 7 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 6
Riivo
Riivo
sõnum 10.05.2006 19:53:32 vasta tsitaadiga
Final Aap kirjutas:
ei ole vaja
Final Aap
Final Aap
sõnum 29.05.2006 22:02:09 vasta tsitaadiga
Artikkel psp-hacks.com-ist:
The U.P. (Undiluted Platinum) is a flash replacement system for the PSP™ which allows the use of previous flash updates or custom firmware builds, opening up the possibility to run unsigned homebrew code on even the latest PSP systems. The U.P. contains 32MB NAND flash which is programmable from the PC via a high speed USB connection, using our user friendly software. You may boot the PSP from either its onboard flash or the flash contained on the U.P; the flash which is used is determined by a button press as the PSP is powered on (U.P. flash is used by default, hold L1 to use the PSP onboard flash). Since U.P. provides a secondary flash which the PSP can boot from, it can even be used to restore a PSP which has been “bricked”. Every effort has been made to make our flash updater software, which will be freely available for download, both as easy to use and reliable as possible. The software also contains diagnostics which can be used by installers to determine if an installation has been successful or not.
The U.P. has been designed to minimize installation difficulty and effort. A FPC (flexible printed circuit) cable is included which routes the essential signals from the PSP motherboard to the U.P. main board and U.P. USB connector. Copper enamel wire is included, which will provide the connection between the FPC cable and the motherboard signal traces. The FPC cable also helps by reducing the mechanical stress placed on the solder points, making a U.P. modified PSP shock resistant which is important for handheld systems. Installation aids are included, and installation diagrams for all PSP hardware revisions will be available for download, together with flasher software application, from our reseller’s websites. More about installation together with install pictures closer to release.
The FPC cable end to which the USB connector board attaches is routed into the battery compartment and sits above the battery. The battery cover can be replaced after flash updating and the cable remains safely in the compartment until the next update is required, whereupon the USB connector can be clipped in place within a few seconds. This means that the U.P. is completely contained within the PSP under normal usage and avoids any unsightly external modifications to your PSP. PSP is after all portable, let’s keep it that way!
In order to maximise the benefits that U.P. can provide its users, we have decided to take an open source approach with U.P and will be releasing source code for any software we release as well as full documentation for the U.P. hardware interface - including information on how to control U.P. from within PSP programs. This will allow anybody to create software which can take advantage of what U.P. has to offer. We have also sent a few prototype units away to some of the scene’s best software hackers in order to give them a headstart at working on custom flash replacements - cant wait to see what people will come up with!
Features Announced:
* Ultra reliable and feature rich Actel ProASIC Plus FPGA
* Full Speed USB 1.1 ASIC onboard
* Branded 32MB NAND flash onboard (same flash as used in PSP)
* Stable and reliable flashing software freely available for download
* Installation verification using flashing software
* Ultra compact four layer PCB
* High quality Japanese connectors
* USB cable included
* FPC cable included, reducing installation effort and improving shock resistance
* Copper enamel wire included
* Open platform development system for software developers
* Installation has been optimized to fit entirely inside PSP
* All PSP hardware versions/regions supported
* User updatable flash
* Low power consumption
* Flash select via button press
* Ultra compact PCB has been designed to avoid signal bounce
Bundled Stuff:
* U.P. MAIN MODULE x1
* U.P. USB BOARD x1
* USB CABLE x1
* INSTALLATION AIDS 1 SET
* COPPER ENAMEL WIRE 1 SPOOL
* FPC CABLE x1
It will be priced at ~ $90 (75 Euros)
hakatakse siis lõpuks psp-si modima. Esialgu tundub natuke kallis. Aga kui hind langeb (~1000.- oleksin nõus maksma) ja modchipiga kaasneb palju huvitavaid lahendusi, siis lasen om 2.6 firmware võibolla ära modida tulevikus :p
RaPTiLE
RaPTiLE
sõnum 29.05.2006 22:11:15 vasta tsitaadiga
Ise, olen ka mõnesid PSP mänge mänginud, näiteks MedEvil, WRC2006, ma arvan, et PSPga mängides, saab sama fiilingu, mis PS2ga mängides.
Kommentaarid: 60 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 55
garfield3
garfield3
sõnum 16.06.2006 19:30:43 vasta tsitaadiga
jaak-alo kirjutas:
selline küsimus et kas seda pihuarvutina oleks võimalik kasutada ?
st lasen exceli, wordi jms peale ?
Minuteada saab küll.
Siin samas foorumis keegi rääkis, et lasi WIN 98 PSPle peale ja pidi isegi töötama.
Ise seda juttu üldse ei usu, aga sa ju naljapärast võid järgi proovida icon_smile.gif
Kommentaarid: 35 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 30
Bumer
sõnum 16.06.2006 21:59:48 vasta tsitaadiga
minuteada seda ikka päris pihuarvutina kasutada ei saa, sest tegu ikkagi mängukonsooliga, mitte pihuarvutiga ja päris kõike asju ka selle jaoks välja ei mõelda.
Kommentaarid: 51 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 48
garfield3
garfield3
sõnum 17.06.2006 10:29:00 vasta tsitaadiga
Bumer kirjutas:
No jah, sest konsooliga raske kirjutada..
Riivo
Riivo
sõnum 19.06.2006 02:30:33 vasta tsitaadiga
Bumer kirjutas:
teoorias on see siiski võimalik. iseasi tõesti, kas keegi viitsib sellega vaeva näha. (backup) mängud on primaarsed ja need ju töötavad
Final Aap
Final Aap
sõnum 09.07.2006 01:30:59 vasta tsitaadiga
Kuulsin, et 2.6 downgrader on väljas. Nädala pärast saan koju asja uurima alles. Vastik töö...
alias
sõnum 24.07.2006 23:58:55 vasta tsitaadiga
garfield3 kirjutas:
jaak-alo kirjutas:
Ma muide nägin isegi sellest videot. See Windows laadis mingi mitu tundi. (psphacking-101.com vms lehekülg)
Edit: Kas ma olen siin ainuke, kes DevHooki kasutab? (Laed mingi Firmware (kuni 2.71) mälupulgale ja võid 1.50 PSP-ga selle laadida, et näiteks netis käia ja WMA faile kuulata)
Zooter
Zooter
sõnum 28.07.2006 07:28:51 vasta tsitaadiga
Keegi sellele modchipile plaanib oma PSPs koha leida? Euroopas ei paista teda saada olevat ja USAst on mõnus postikulu ja maksud...
Kommentaarid: 65 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 63
Marks123
sõnum 31.07.2006 17:52:00 vasta tsitaadiga
See downgrade võib PSP p*tsi ka keerata?Või on se ohutu icon_question.gif icon_wink.gif
Kommentaarid: 10 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 1
Riivo
Riivo
sõnum 31.07.2006 18:30:55 vasta tsitaadiga
Marks123 kirjutas:
see viimane peaks päris ohutu olema, kui ilusti õpetuse järgi teed
Marks123
sõnum 01.08.2006 15:36:49 vasta tsitaadiga
Kus on USB juhet müüa mida millega saab näiteks muusikast psp peale panna?
Ja kui palju maksab?
Seda USB juhet ei ole juu Value Pckiga kaasas?
henry111
sõnum 01.08.2006 15:38:34 vasta tsitaadiga
Value packiga seda kaasas ei ole, kuid osta saab seda pea kõigis elektroonika poodides ja hind peaks 100.- ümber jääma.
Kommentaarid: 97 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 89
Bumer
sõnum 01.08.2006 17:32:29 vasta tsitaadiga
k-arvutisalongis pidi olema 47.-
Riivo
Riivo
sõnum 01.08.2006 17:35:19 vasta tsitaadiga
mõni HV-lane võib selle tasuta ka ära anda, kui veab
Marks123
sõnum 01.08.2006 19:54:51 vasta tsitaadiga
Kas on võimalik kudagi seda filmide regiooni ära muuta?(multiregionaalseks) :=>
Riivo
Riivo
sõnum 01.08.2006 20:43:09 vasta tsitaadiga
Marks123 kirjutas:
downgrade ja töötas küll mingi emuga. kui soov võin täpsemalt järele uurida
Marks123
sõnum 02.08.2006 19:41:52 vasta tsitaadiga
Mul selline jama et PSP ei tööta koralikult ülesse ja alla nool, et nagu peab korralikult peale vajutama siis töötab. icon_confused.gif
Kas kudagi ise saab seda korda teha või peab parandusse viima?(Parandusse ma PSPga minema ei hakka sest see väike asi aga ikkagi tahaks et töötaks korralikult) icon_neutral.gif
-Distance
-Distance
sõnum 10.08.2006 06:43:18 vasta tsitaadiga
k6ige odavam koht kust psp endale osta on tevalo http://www.tevalo.ee/cgi-bin/web_store.cgi?artnr=!25-824-01
ainult 3675 eek
pole odavamat kohta n2inud veel
Kommentaarid: 38 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 35
M@x
M@x
sõnum 10.08.2006 11:06:39 vasta tsitaadiga
Kas mitte Enteris ei olnud ta 3490.-
Kommentaarid: 142 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 127
h62k
sõnum 10.08.2006 12:35:39 vasta tsitaadiga
Onoffi on psp 2999.-
link
Kommentaarid: 29 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 24
uus teema   vasta Uudised »  Ülevaated, kasutajate hinnangud »  Ülevaade: Sony Playstation Portable (PSP) mine lehele eelmine  1, 2, 3 ... 13, 14, 15 ... 22, 23, 24  järgmine
