Anti
09.05.2006 17:19:55
M@x kirjutas: |
Nii, saan ma siis õieti aru.
Ainult 1.50 fireware versiooniga saab mängida netist tõmmatud .iso mänge? UMD Emulaatoriga. |
TÄPSELT
Kommentaarid: 314 loe/lisa |
240 |
ahvilõust
09.05.2006 18:43:17
M@x kirjutas: |
mis ka kõik ei tööta ja paljud juksivad. minu jaoks ainuke eelis on et saab palju mugavamalt homebrewd kasutada, need kommerts mängud on suurem osa saast.
_________________ Gdesainer
M: MSI RTX 3070 Gaming Trio |
Kommentaarid: 8 loe/lisa |
Final Aap
10.05.2006 19:03:52
Aga kas uuemate mängude jaoks on alati (kõige?) uuemat firmwaret vaja?
Vaatasin, et mingi silent hill tuleb psp peale
Kommentaarid: 7 loe/lisa |
Riivo
10.05.2006 19:53:32
Final Aap kirjutas: |
Vaatasin, et mingi silent hill tuleb psp peale  |
ei ole vaja
Kommentaarid: 233 loe/lisa |
221 |
Final Aap
29.05.2006 22:02:09
Artikkel psp-hacks.com-ist:
tsitaat: |
The U.P. (Undiluted Platinum) is a flash replacement system for the PSP which allows the use of previous flash updates or custom firmware builds, opening up the possibility to run unsigned homebrew code on even the latest PSP systems. The U.P. contains 32MB NAND flash which is programmable from the PC via a high speed USB connection, using our user friendly software. You may boot the PSP from either its onboard flash or the flash contained on the U.P; the flash which is used is determined by a button press as the PSP is powered on (U.P. flash is used by default, hold L1 to use the PSP onboard flash). Since U.P. provides a secondary flash which the PSP can boot from, it can even be used to restore a PSP which has been bricked. Every effort has been made to make our flash updater software, which will be freely available for download, both as easy to use and reliable as possible. The software also contains diagnostics which can be used by installers to determine if an installation has been successful or not.
The U.P. has been designed to minimize installation difficulty and effort. A FPC (flexible printed circuit) cable is included which routes the essential signals from the PSP motherboard to the U.P. main board and U.P. USB connector. Copper enamel wire is included, which will provide the connection between the FPC cable and the motherboard signal traces. The FPC cable also helps by reducing the mechanical stress placed on the solder points, making a U.P. modified PSP shock resistant which is important for handheld systems. Installation aids are included, and installation diagrams for all PSP hardware revisions will be available for download, together with flasher software application, from our resellers websites. More about installation together with install pictures closer to release.
The FPC cable end to which the USB connector board attaches is routed into the battery compartment and sits above the battery. The battery cover can be replaced after flash updating and the cable remains safely in the compartment until the next update is required, whereupon the USB connector can be clipped in place within a few seconds. This means that the U.P. is completely contained within the PSP under normal usage and avoids any unsightly external modifications to your PSP. PSP is after all portable, lets keep it that way!
In order to maximise the benefits that U.P. can provide its users, we have decided to take an open source approach with U.P and will be releasing source code for any software we release as well as full documentation for the U.P. hardware interface - including information on how to control U.P. from within PSP programs. This will allow anybody to create software which can take advantage of what U.P. has to offer. We have also sent a few prototype units away to some of the scenes best software hackers in order to give them a headstart at working on custom flash replacements - cant wait to see what people will come up with!
Features Announced:
* Ultra reliable and feature rich Actel ProASIC Plus FPGA
* Full Speed USB 1.1 ASIC onboard
* Branded 32MB NAND flash onboard (same flash as used in PSP)
* Stable and reliable flashing software freely available for download
* Installation verification using flashing software
* Ultra compact four layer PCB
* High quality Japanese connectors
* USB cable included
* FPC cable included, reducing installation effort and improving shock resistance
* Copper enamel wire included
* Open platform development system for software developers
* Installation has been optimized to fit entirely inside PSP
* All PSP hardware versions/regions supported
* User updatable flash
* Low power consumption
* Flash select via button press
* Ultra compact PCB has been designed to avoid signal bounce
Bundled Stuff:
* U.P. MAIN MODULE x1
* U.P. USB BOARD x1
* USB CABLE x1
* INSTALLATION AIDS 1 SET
* COPPER ENAMEL WIRE 1 SPOOL
* FPC CABLE x1
It will be priced at ~ $90 (75 Euros) |
hakatakse siis lõpuks psp-si modima. Esialgu tundub natuke kallis. Aga kui hind langeb (~1000.- oleksin nõus maksma) ja modchipiga kaasneb palju huvitavaid lahendusi, siis lasen om 2.6 firmware võibolla ära modida tulevikus :p
RaPTiLE
29.05.2006 22:11:15
Ise, olen ka mõnesid PSP mänge mänginud, näiteks MedEvil, WRC2006, ma arvan, et PSPga mängides, saab sama fiilingu, mis PS2ga mängides.
Kommentaarid: 60 loe/lisa |
55 |
garfield3
16.06.2006 19:30:43
jaak-alo kirjutas: |
selline küsimus et kas seda pihuarvutina oleks võimalik kasutada ?
st lasen exceli, wordi jms peale ? |
Minuteada saab küll.
Siin samas foorumis keegi rääkis, et lasi WIN 98 PSPle peale ja pidi isegi töötama.
Ise seda juttu üldse ei usu, aga sa ju naljapärast võid järgi proovida
Kommentaarid: 35 loe/lisa |
30 |
Bumer
16.06.2006 21:59:48
minuteada seda ikka päris pihuarvutina kasutada ei saa, sest tegu ikkagi mängukonsooliga, mitte pihuarvutiga ja päris kõike asju ka selle jaoks välja ei mõelda.
Kommentaarid: 51 loe/lisa |
48 |
garfield3
17.06.2006 10:29:00
Bumer kirjutas: |
minuteada seda ikka päris pihuarvutina kasutada ei saa, sest tegu ikkagi mängukonsooliga, mitte pihuarvutiga ja päris kõike asju ka selle jaoks välja ei mõelda. |
No jah, sest konsooliga raske kirjutada..
30 |
Riivo
19.06.2006 02:30:33
Bumer kirjutas: |
teoorias on see siiski võimalik. iseasi tõesti, kas keegi viitsib sellega vaeva näha. (backup) mängud on primaarsed ja need ju töötavad
221 |
Final Aap
09.07.2006 01:30:59
Kuulsin, et 2.6 downgrader on väljas. Nädala pärast saan koju asja uurima alles. Vastik töö...
alias
24.07.2006 23:58:55
garfield3 kirjutas: |
Ise seda juttu üldse ei usu, aga sa ju naljapärast võid järgi proovida  |
Ma muide nägin isegi sellest videot. See Windows laadis mingi mitu tundi. (psphacking-101.com vms lehekülg)
Edit: Kas ma olen siin ainuke, kes DevHooki kasutab? (Laed mingi Firmware (kuni 2.71) mälupulgale ja võid 1.50 PSP-ga selle laadida, et näiteks netis käia ja WMA faile kuulata)
Zooter
28.07.2006 07:28:51
Keegi sellele modchipile plaanib oma PSPs koha leida? Euroopas ei paista teda saada olevat ja USAst on mõnus postikulu ja maksud...
Kommentaarid: 65 loe/lisa |
63 |
Marks123
31.07.2006 17:52:00
See downgrade võib PSP p*tsi ka keerata?Või on se ohutu
Kommentaarid: 10 loe/lisa |
Riivo
31.07.2006 18:30:55
Marks123 kirjutas: |
See downgrade võib PSP p*tsi ka keerata?Või on se ohutu  |
see viimane peaks päris ohutu olema, kui ilusti õpetuse järgi teed
221 |
Marks123
01.08.2006 15:36:49
Kus on USB juhet müüa mida millega saab näiteks muusikast psp peale panna?
Ja kui palju maksab?
Seda USB juhet ei ole juu Value Pckiga kaasas?
henry111
01.08.2006 15:38:34
Value packiga seda kaasas ei ole, kuid osta saab seda pea kõigis elektroonika poodides ja hind peaks 100.- ümber jääma.
Kommentaarid: 97 loe/lisa |
89 |
Bumer
01.08.2006 17:32:29
k-arvutisalongis pidi olema 47.-
48 |
Riivo
01.08.2006 17:35:19
mõni HV-lane võib selle tasuta ka ära anda, kui veab
221 |
Marks123
01.08.2006 19:54:51
Mõni mäng ei lähe juu 2.00 veriga tööle (nt. Daxter)
Kas on võimalik kudagi seda filmide regiooni ära muuta?(multiregionaalseks) :=>
Riivo
01.08.2006 20:43:09
Mõni mäng ei lähe juu 2.00 veriga tööle (nt. Daxter) |
downgrade ja töötas küll mingi emuga. kui soov võin täpsemalt järele uurida
221 |
Marks123
02.08.2006 19:41:52
Mul selline jama et PSP ei tööta koralikult ülesse ja alla nool, et nagu peab korralikult peale vajutama siis töötab.
Kas kudagi ise saab seda korda teha või peab parandusse viima?(Parandusse ma PSPga minema ei hakka sest see väike asi aga ikkagi tahaks et töötaks korralikult)
-Distance
Kommentaarid: 38 loe/lisa |
M@x
10.08.2006 11:06:39
Kas mitte Enteris ei olnud ta 3490.-
Kommentaarid: 142 loe/lisa |
127 |
h62k
10.08.2006 12:35:39
Onoffi on psp 2999.-
link
Kommentaarid: 29 loe/lisa |
24 |
