aise
| Kommentaarid: 189 loe/lisa |
172 |
tjj
20.07.2006 18:22:08
Core 2 Duo processor's weak point - processing in 64bit mode?
The tests of new processors, based on the CORE microarchitecture, showed their overwhelming advantage in regards to the competitior's offerings. Working on the same clock speed, CPUs with a CORE microarchitecture overtake Athlon 64 X2 by a margin of appromaximately 20%, leaving no chances to AMD's production being a leader. The given conclusion has been made by a distinguishly big quantity of reviews, which have invaded the Internet for a week by now. However, regardless of the overall happiness of INTEL's fans, we will take the courage to pointout the fact, that in the future, such optimistic predictions will have to be reduced. The thing is, that the information about Conroe's lower performance in 64-bit mode has been unexpectedly confirmed.
Cutouts from an application optimisation manual for new Core 2 Duo processors, which were published by a japanese site called PCWatch, indicate, that when a 64-bit mode is enabled (64-bit Long Mode), which is supported in the new processors thanks to EM64T (Enhanced Memory 64 Technology), Core microarchitecture loses it's advantages. In other words, new INTEL's processors turn out to be better optimised for running 32-bit applications. Because of that, after the release of Windows Vista family and massive occurance of 64-bit software, Cure 2 Duo might not be getting such enthusiastic feedback already.
Firstly, INTEL reports, that in 64-bit mode Intel Core 2 Duo processors do not support a technology called Macrofusion. As our readers recall, this technology is pointed towards the increase of commands processing per clock and consists of a number of consistently connected (among themselves) x86 instructions, such as, in example, a comparision between the next undergoing conditional transition, is represented inside the processor by one microinstruction. In result, processors with a Core microarhitecture lose the ability to process five x86-64 instructions at the same time. By the experts analysation, the disablement of this technology can cause a decrease in performance with Core microarchitecture by a margain, reaching 10%.
Fak, rohkem ei saa.. Kasutage babelfish vms -
http://www.overclockers.ru/hardnews/22814.shtml
| Kommentaarid: 161 loe/lisa |
6 :: |
117 |
One
20.07.2006 18:28:32
jah sama kiired per takt aga kes oc-d tahab see ei pea eriti mõtlema ~4ghz conroe vs 3ghz amd ja polegi miskit muud öelda
728 |
Ho Ho
87 |
tjj
20.07.2006 18:41:46
| Winterwind kirjutas: |
jah sama kiired per takt aga kes oc-d tahab see ei pea eriti mõtlema ~4ghz conroe vs 3ghz amd ei pane eriti mõtlema  |
Tõesti, jah, aga hind pole samuti kõige madalam, pealegi informatsiooni järgi, selle aasta jooksul mingeid muutusi ei tule.
E6600 @ 350 EUR.. ehm.
Üldiselt 4GHz pole nii lihtne Conroe-ga saavutada kah..
Ho Ho,
Tegelikult kõik pole nii lootustandvalt nagu steptzer ütles. Loe mis seal lingis on ja saad aru.
6 :: |
117 |
HDTanel
Overclocker
20.07.2006 18:45:45
tjj, kle sa ehk viitsid kunagi mu privadele ka vastata?
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
Anti
20.07.2006 18:54:54
| keegi võlgu ei viitsi anda nats?`
240 |
heikis
20.07.2006 18:59:10
| velsa kirjutas: |
| keegi võlgu ei viitsi anda nats?` |
palju vaja ? mis intress?
| Kommentaarid: 338 loe/lisa |
290 |
Anti
20.07.2006 19:02:25
| heikis kirjutas: |
| velsa kirjutas: |
palju vaja ? mis intress? |
no anna palju rahakott lubab, intressidest ei taha väga teiste nähes rääkida
240 |
Sponge
20.07.2006 20:29:42
By Fuad Abazovic sellel mehel on ikka väga igab et peab koguaeg midagi välja imema [/b]
| Kommentaarid: 398 loe/lisa |
323 |
stepzter
21.07.2006 02:35:43
tjj, soovitan lugeda vähem sensatsioonihimulisi allikaid. Aceshardware selle teemaline thread oleks hea alustus. Core 2 64-bit probleemid on suhteliselt tühised.
Peale selle, olulisim probleem avaldub ainult kohtades, kus Core 2 ei ole enam võimeline 5 käsku korraga dekodeerima ning peab 4'ga leppima. AMD dekodeerimisvõime piirdub kolme käsuga, seega Core 2 on nendes situatsioonides suure tõenäosusega niikuinii juba oluliselt kiirem.
| Kommentaarid: 26 loe/lisa |
26 |
tjj
21.07.2006 09:11:21
stepzter,
Esiteks see on päris austatud ja korrektne allikas (soovitan sellega tutvuda kah), mis eksisteerib juba tunduvalt palju aega. Mitte midagi seal ei toimu sensatsiooni pärast.
Samuti ma ei saa öelda, et Conroe 64-bit probleemid on nii tühised. Vähemalt nii ei tundu.
"Peale selle, olulisim probleem avaldub ainult kohtades, kus Core 2 ei ole enam võimeline 5 käsku korraga dekodeerima ning peab 4'ga leppima."
Macrofusion tehnoloogia üldse ei tööta, kui 64-bit mode on aktiveeritud. Kas see ei tähenda, et praktiliselt kõikides 64-bit programides sellised probleemid peavad ilmuma? Põhimõtteliselt mitte probleemid, vaid eripärasused. Conroe's üleolek märgatavalt väheneb 64-bitis:
Eriti selline pilt ei näe nii hästi välja, arvestades seda, et Vista ja 64-bit software on juba lähedal.
Pealegi räägitakse, et teine probleem on seotud lisaregistritega (acehardware-is on sellest ka jutt), kui EM64T on aktiveeritud. Istruktsioonide pikkus suureneb (+1byte), mis raskendab koodi algoritmide lahtivõttu (mis on kasutusel esimesel dekodeerimise faasil) - kuigi see enam-vähem avaldab raskusi ainult programmerijatele.
6 :: |
117 |
mcaff
21.07.2006 10:16:36
Kas mida suurem seda paerm (tabel)
104 |
Revage
21.07.2006 10:47:39
Jaan, Kas need inteli plaadid mida dr.peep müüb on rev. 304 ?
| Kommentaarid: 80 loe/lisa |
6 :: |
10 :: |
54 |
HDTanel
Overclocker
21.07.2006 10:56:14
Hmm kas mõttekam poleks mitte oodata DFI Lanparty plaati? Augustis pidi tulema.
496 |
lamp
21.07.2006 11:11:53
| PlatoonSgtElias kirjutas: |
| Hmm kas mõttekam poleks mitte oodata DFI Lanparty plaati? Augustis pidi tulema. |
too infinity juba näitab ilmekalt ära, et dfi suudab endiselt intelile vaid saasta toota
samas kui peaks mingi parem mobo tulema läbi miski ime ja veel augustis, siis xs'i japsid ja hiinlased
oleks ammu kas uudiseid pasundanud või juba katki testinud.
btw sul pidi DFIs tuttav(naine) olema, mis tema kostab, äkki lanparty on oopis rd600 tsipsetiga?
169 |
HDTanel
Overclocker
21.07.2006 11:54:19
Mõlema chipsetiga pidi tulema.
Enivei mai tea... seda Deluxe plaati keegi hankida saaks mulle? Ma ei leia kusagilt.
HuhHuh:
Intel Pentium 4 D805 1850.-
ASUS P5W DH Deluxe 3150.-
2x1Gb Corsair TWIN2X2048-6400 800MHz 3400.-
700W Fortron 2200.-
Oh yeah ja siis veel Conroe peale ka raha 5000.- vaja
496 |
robin
21.07.2006 11:57:53
| mcaff kirjutas: |
Kas mida suurem seda paerm (tabel) |
mida väiksem, seda parem.
| Kommentaarid: 55 loe/lisa |
51 |
stepzter
21.07.2006 16:10:17
| tjj kirjutas: |
| Macrofusion tehnoloogia üldse ei tööta, kui 64-bit mode on aktiveeritud. Kas see ei tähenda, et praktiliselt kõikides 64-bit programides sellised probleemid peavad ilmuma? Põhimõtteliselt mitte probleemid, vaid eripärasused. |
Väga valdavas enamuses softis ei anna "macro-op fusion" (ehk võrdlus ja tingimuslike siirdekäskude eeldekodeerimisel ühitamine) eriti suurt effekti. Macro-op fusion mõjub jõudlusele kahes kohas: järjekorra välise täitmise plaanuri otsingu aken mahutab ~10% rohkem käske ja teatud tingimustel õnnestub 4 käsu asemel 5 dekodeerida. Esimene neist avaldab mõju siis kui juhuslikult õnnestub selle lisa 10% seest leida mõni käsk, mida saab teistest ette tõsta vabades täitmisüksustest täitmiseks (enamasuses koodis võrdlemisi ebatõenäoline). Teine avaldab põhiliselt mõju siirdekäskude ennustamise ebaõnnestumisele järgneval plaanuri puhvri 25% kiiremal täitmisel ja sellisel juhul kui protsessor suudab maksimaalset käskude täitmise kiirust hoida mitmeid takte üleval (keskmine on 3-5 korda madalam). Kõhutunde järgi pakuks, et enamuses softis jääb nende kogueffekt paari-kolme protsendi piiresse. Loomulikult esineb ka patoloogilisi juhtumeid, aga need on igal protsessoril olemas.
Eks tuleb mingeid põhjalikkumaid võrdlusi oodata. Siin esialgu mingis jaapani tekstiredaktoris hiiglasliku search-replace tegemisest natukene tuntum benchmark:
PS: 64bitine kood enamustel arhitektuuridel ongi aeglasem. Koodi suurus suureneb, andmestruktuuride suurused suurenevad jne. x86 on üks vähestest arhitektuuridest, kus 64biti peale minek on jõudluse paranemist toonud. Põhiliselt tänu sellele, et enne 64biti laiendusi oli x86 kasutatavate registrite arv täiesti kiviaegne 7.
26 |
Jaan
21.07.2006 18:10:20
| stepzter kirjutas: |
| ...PS: 64bitine kood enamustel arhitektuuridel ongi aeglasem. Koodi suurus suureneb, andmestruktuuride suurused suurenevad jne. x86 on üks vähestest arhitektuuridest, kus 64biti peale minek on jõudluse paranemist toonud. Põhiliselt tänu sellele, et enne 64biti laiendusi oli x86 kasutatavate registrite arv täiesti kiviaegne 7. |
vene ixbt.com on teinud teste 64bit windoosas:
http://www.digit-life.com/articles2/cpu/intel-core2-duo-x6800.html
kokkuvõtteks niipalju, et 64bit winni all olid tulemused tõesti kehvemad, lisaks sellele tuli huvitav asi ilmseks-
inbox cooleriga ja piisavalt soojas toas saab prose throtlima.
Tuletan meelde, et see cooler on mõeldud kuumade netburst prosedele, mille soojuseraldus on kuni 150W...
Siinkohas mainin omaltpoolt et need xbitlabsi voolutarve testid on imho valesti tehtud-
a64 tarbib 2x vähem idles ja x6800 tarbimine on sinna 100W kanti tegelikult.
Need on minu oletused, üritan järgmisel nädalal seda ise uurida.
123 |
313 |
Anti
21.07.2006 19:16:49
| Odavaim vb jah, aga mina võtaks ennem Asus P5V-VM DH/WIFI-AP. Sellel wifi ja ikkagi Asus, olgu OC võimalustega kuidas on.
240 |
HDTanel
Overclocker
21.07.2006 20:07:38
Irw, Skeptik... võta Jaaniga ühendust ja las testib korra AGP kaartide WR-id tulevad
496 |
libe
kvaliteetne mees
21.07.2006 22:20:39
selle peaks esialgu vist võtmagi
saab 6-7k hakkama
mälu kannatab natukene veel küll
päris 1000MHz ddr ei kannata
aga saan oma tööd küll kiiremini tehtud kui praeguse tbred 1700+
| Kommentaarid: 82 loe/lisa |
razor
22.07.2006 11:55:51
miks mitte, kui sinna peale visata BH5ed koos boosteriga 8)
01'es kindlasti kiirem, kui DDR2
120 |
lamp
22.07.2006 12:32:48
| razor kirjutas: |
01'es kindlasti kiirem, kui DDR2 |
ära unusta seda, et kiirusekasvuga latents väheneb
ma väidan, et 500 peal 5-5-5 ram on ka kiirem kui 3-2-2 400 peal ja mõlemad kiiremad kui misiganes bh5.
isegi kui sa kuidagi suudad 300 peal 2-2-2 teha
aga jah.. too asrock.. väike ime oleks kui too 300 fsb ära teeb
169 |
erick
96 |
lamp
22.07.2006 12:53:47
too anandtechis on via tsipiga oxe, eespool mainitud on 965.
muidugi see via oma on veelgi lõbusam porn, pciex4, agp, ddr1 ddr2 kõik yhel plaadil
169 |
libe
kvaliteetne mees
Illu
One
22.07.2006 16:09:24
peekivil nii saast toiteahel, et voltmod isegi ei aita suuremat oc-d saada ja max fsb jääb sinna ~300mhz kanti.
300mhz on aga selgelt vähe kui kõige odavama conroe ostad - need raisad jookseks 450mhz peal ka kui mobo lubaks
728 |
libe
kvaliteetne mees
22.07.2006 16:27:02
esimene laks selle asrockiga annab def kelladel e6600'ga tunda ikka, kui 1700+ tbredilt üle minna
siis paar palgapäeva ja on mälud, videokaart ka ostetud, ehk isegi uus emaplaat ja pole siinikiirus enam probleem, lisaks on selleks ajaks ehk suurem valik emaplaate turul
ja ehk isegi kui viitsib oodata siis uue põlvkonna GPU'd
_________________ ☠ |
22.07.2006 17:59:50
Winterwind, milline kellaja ostab üldse ~700.- eeguse ääsroki plaadi
mis seal ikka tahta, niigi odav ju.
viimati muutis SKG 22.07.2006 18:42:46, muudetud 2 korda |
313 |
22.07.2006 18:02:34
300mhz on aga selgelt vähe kui kõige odavama conroe ostad - need raisad jookseks 450mhz peal ka kui mobo lubaks |
Inteli plaadid niipalju kehvemad ?
AMD-st rääkides:
mul igatahes oli selle pekikiviga kõige lihtsam oc eales - HTT kordaja maha ja fsb 320 peale ja sinna see jäänud on
Aga jah nüüd paar päeva hiljem juba tunnen peentimmingutest puudust
lisaks: 1000.- eest on plaati vähemalt AM2 puhul küllaga
201 |
der hammer
22.07.2006 19:43:33
On see ASRock väga pasa millele AGP ja pci-e siin on ? Mõtlen ,et päris mõnus oleks vaikselt niimoodi areneda ,et mobot ei pea vahetama . Aga tootja nimi hirmutab ja ega need "two in one" tooted on suht ebakvaliteetsed olnud..
_________________ Tere. |
| Kommentaarid: 149 loe/lisa |
130 |
One
22.07.2006 19:54:04
| Skeptik kirjutas: |
mis seal ikka tahta, niigi odav ju.  |
ostad 700.- mobo ja 3.5k prose?
728 |
lamp
22.07.2006 20:38:45
| Totu user kirjutas: |
On see ASRock väga pasa millele AGP ja pci-e siin on ? Mõtlen ,et päris mõnus oleks vaikselt niimoodi areneda ,et mobot ei pea vahetama . Aga tootja nimi hirmutab ja ega need "two in one" tooted on suht ebakvaliteetsed olnud.. |
muropaketti foorumis sommid kiidavad, win pidi ikka peale minema.
hiljem muidugi panged ja bsodid lambist on suht tavalised.
169 |
Rutz
| Kommentaarid: 410 loe/lisa |
354 |
One
22.07.2006 20:54:53
Rutz, need 2mb Conroed saavutavadki suurema FSB kui need 4mb mudelid..
ehk siis 2mb Conroe läheks teiste mobode peal ka suht kõrgele.
samas see Gigabyte on suht ok plaat jah aga nagu seal kuskil teemas kirjas ka oli siis
Asus ja E6600 bootisid palju kõrgemal mhz-il kui Gigabyte ja E6600
mis sest, et Gigabyte saavutas E6300-ga suurema FSB
728 |
Rutz
22.07.2006 21:01:11
Lugesin jah, et tollele gigale meeldivad pisikese kordajaga prosed.
Aga siis ju sobibki just hästi kokku low budget kompotiks odavama prosega.
Ennast mind küll 975 koos oma CF ja muude lisavõimalustega ei tõmba.
Ootab/Vaatab ära mis see Asuse P5B ka endast kujutama hakkab.
354 |
22.07.2006 21:02:35
| Gigabyte siis on kehvema CPU toiteahelaga?
201 |
mcaff
104 |
23.07.2006 16:56:37
| Seda ei lasta niipea turule... Intel lüpsab stockis AMD juba hetke mudelitega, nii et ma oleks üllatunud kui kasumiahne firma nagu Intel on laseks selle poole aasta jooksul välja.
201 |
lamp
23.07.2006 16:59:07
see on niisama klokitud x6800..
nagu ma olen aru saanud, on järgmine X prose oopis kentsfield..
niiet kunagi tuleb E6900, mitte X..
169 |
heikis
290 |
lamp
23.07.2006 17:04:25
eks ta hetke parim mobo ole.. a kui sügisel ostad prose alles, miks mitte moboga sygiseni oodata?
asusel tuleb WS ka, mis on veel parem kui see dh
169 |
23.07.2006 17:07:25
mobode hinnad on küll jubedaks aetud... selge see, et ~1K on seal lihtsalt conroe pärast otsa laotud
201 |
One
23.07.2006 20:19:11
pole nende mobode hinnad nii hullud miskit..
kellelegi P5W DH Deluxe omanikest veel mobo kellates sirisema hakkab?
mu oma hakkab, proset klokid ja siis koormust lased hakkavad poolid vms sirisema.
õnneks mitte väga kõvasti
728 |
23.07.2006 20:42:09
| Magic, ASUS-e tipp mobod (vähemalt Intelile) on koguaeg üle 3K maksnud
313 |
23.07.2006 21:16:57
Algul on nad olnud jah päris kena "kattega"... samas näiteks mulle on 3,4K juba ikka liialt palju
201 |
