uus teema   vasta Raud »  Protsessorid »  Intel Core 2 Duo/Quad overclocking märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 6, 7, 8 ... 592, 593, 594  järgmine
aise
aise
sõnum 20.07.2006 17:37:56 vasta tsitaadiga
ATI's RD 600 will be better overclocker than Intel's i975
http://www.theinq.com/default.aspx?article=33148
Kommentaarid: 189 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 172
tjj
tjj
sõnum 20.07.2006 18:22:08 vasta tsitaadiga
Core 2 Duo processor's weak point - processing in 64bit mode?
The tests of new processors, based on the CORE microarchitecture, showed their overwhelming advantage in regards to the competitior's offerings. Working on the same clock speed, CPUs with a CORE microarchitecture overtake Athlon 64 X2 by a margin of appromaximately 20%, leaving no chances to AMD's production being a leader. The given conclusion has been made by a distinguishly big quantity of reviews, which have invaded the Internet for a week by now. However, regardless of the overall happiness of INTEL's fans, we will take the courage to pointout the fact, that in the future, such optimistic predictions will have to be reduced. The thing is, that the information about Conroe's lower performance in 64-bit mode has been unexpectedly confirmed.
Cutouts from an application optimisation manual for new Core 2 Duo processors, which were published by a japanese site called PCWatch, indicate, that when a 64-bit mode is enabled (64-bit Long Mode), which is supported in the new processors thanks to EM64T (Enhanced Memory 64 Technology), Core microarchitecture loses it's advantages. In other words, new INTEL's processors turn out to be better optimised for running 32-bit applications. Because of that, after the release of Windows Vista family and massive occurance of 64-bit software, Cure 2 Duo might not be getting such enthusiastic feedback already.
Firstly, INTEL reports, that in 64-bit mode Intel Core 2 Duo processors do not support a technology called Macrofusion. As our readers recall, this technology is pointed towards the increase of commands processing per clock and consists of a number of consistently connected (among themselves) x86 instructions, such as, in example, a comparision between the next undergoing conditional transition, is represented inside the processor by one microinstruction. In result, processors with a Core microarhitecture lose the ability to process five x86-64 instructions at the same time. By the experts analysation, the disablement of this technology can cause a decrease in performance with Core microarchitecture by a margain, reaching 10%.
Fak, rohkem ei saa.. icon_lol.gif Kasutage babelfish vms -
http://www.overclockers.ru/hardnews/22814.shtml
Kommentaarid: 161 loe/lisa Kasutajad arvavad:  :: 6 :: 0 :: 117
One
sõnum 20.07.2006 18:28:32 vasta tsitaadiga
jah sama kiired per takt aga kes oc-d tahab see ei pea eriti mõtlema ~4ghz conroe vs 3ghz amd ja polegi miskit muud öelda icon_lol.gif
Ho Ho
Ho Ho
sõnum 20.07.2006 18:29:29 vasta tsitaadiga
tjj, https://foorum.hinnavaatlus.ee/viewtopic.php?p=2908495#2908495
tjj
tjj
sõnum 20.07.2006 18:41:46 vasta tsitaadiga
Winterwind kirjutas:
jah sama kiired per takt aga kes oc-d tahab see ei pea eriti mõtlema ~4ghz conroe vs 3ghz amd ei pane eriti mõtlema icon_lol.gif
Tõesti, jah, aga hind pole samuti kõige madalam, pealegi informatsiooni järgi, selle aasta jooksul mingeid muutusi ei tule.
E6600 @ 350 EUR.. ehm.
Üldiselt 4GHz pole nii lihtne Conroe-ga saavutada kah..
Ho Ho,
Tegelikult kõik pole nii lootustandvalt nagu steptzer ütles. Loe mis seal lingis on ja saad aru.
HDTanel
Overclocker
HDTanel
sõnum 20.07.2006 18:45:45 vasta tsitaadiga
tjj, kle sa ehk viitsid kunagi mu privadele ka vastata? icon_rolleyes.gif icon_confused.gif
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
Anti
sõnum 20.07.2006 18:54:54 vasta tsitaadiga
keegi võlgu ei viitsi anda nats?`
heikis
sõnum 20.07.2006 18:59:10 vasta tsitaadiga
velsa kirjutas:
palju vaja icon_biggrin.gif ? mis intress?
Kommentaarid: 338 loe/lisa Kasutajad arvavad:  :: 0 :: 4 :: 290
Anti
sõnum 20.07.2006 19:02:25 vasta tsitaadiga
heikis kirjutas:
velsa kirjutas:
no anna palju rahakott lubab, intressidest ei taha väga teiste nähes rääkida
Sponge
Sponge
sõnum 20.07.2006 20:29:42 vasta tsitaadiga
aise kirjutas:
By Fuad Abazovic sellel mehel on ikka väga igab et peab koguaeg midagi välja imema icon_rolleyes.gif [/b]
Kommentaarid: 398 loe/lisa Kasutajad arvavad:  :: 4 :: 4 :: 323
stepzter
stepzter
sõnum 21.07.2006 02:35:43 vasta tsitaadiga
tjj, soovitan lugeda vähem sensatsioonihimulisi allikaid. Aceshardware selle teemaline thread oleks hea alustus. Core 2 64-bit probleemid on suhteliselt tühised.
Peale selle, olulisim probleem avaldub ainult kohtades, kus Core 2 ei ole enam võimeline 5 käsku korraga dekodeerima ning peab 4'ga leppima. AMD dekodeerimisvõime piirdub kolme käsuga, seega Core 2 on nendes situatsioonides suure tõenäosusega niikuinii juba oluliselt kiirem.
tjj
tjj
sõnum 21.07.2006 09:11:21 vasta tsitaadiga
stepzter,
Esiteks see on päris austatud ja korrektne allikas (soovitan sellega tutvuda kah), mis eksisteerib juba tunduvalt palju aega. Mitte midagi seal ei toimu sensatsiooni pärast.
Samuti ma ei saa öelda, et Conroe 64-bit probleemid on nii tühised. Vähemalt nii ei tundu.
"Peale selle, olulisim probleem avaldub ainult kohtades, kus Core 2 ei ole enam võimeline 5 käsku korraga dekodeerima ning peab 4'ga leppima."
Macrofusion tehnoloogia üldse ei tööta, kui 64-bit mode on aktiveeritud. Kas see ei tähenda, et praktiliselt kõikides 64-bit programides sellised probleemid peavad ilmuma? Põhimõtteliselt mitte probleemid, vaid eripärasused. Conroe's üleolek märgatavalt väheneb 64-bitis:
Eriti selline pilt ei näe nii hästi välja, arvestades seda, et Vista ja 64-bit software on juba lähedal.
Pealegi räägitakse, et teine probleem on seotud lisaregistritega (acehardware-is on sellest ka jutt), kui EM64T on aktiveeritud. Istruktsioonide pikkus suureneb (+1byte), mis raskendab koodi algoritmide lahtivõttu (mis on kasutusel esimesel dekodeerimise faasil) - kuigi see enam-vähem avaldab raskusi ainult programmerijatele.
mcaff
mcaff
sõnum 21.07.2006 10:16:36 vasta tsitaadiga
Kas mida suurem seda paerm icon_rolleyes.gif(tabel)
Kommentaarid: 130 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 104
Revage
Keelatud avatar
sõnum 21.07.2006 10:47:39 vasta tsitaadiga
Jaan, Kas need inteli plaadid mida dr.peep müüb on rev. 304 ?
Kommentaarid: 79 loe/lisa Kasutajad arvavad:  :: 6 :: 10 :: 53
HDTanel
Overclocker
HDTanel
sõnum 21.07.2006 10:56:14 vasta tsitaadiga
Hmm kas mõttekam poleks mitte oodata DFI Lanparty plaati? Augustis pidi tulema.
Krüpto
lamp
lamp
sõnum 21.07.2006 11:11:53 vasta tsitaadiga
PlatoonSgtElias kirjutas:
too infinity juba näitab ilmekalt ära, et dfi suudab endiselt intelile vaid saasta toota icon_smile.gif
samas kui peaks mingi parem mobo tulema läbi miski ime ja veel augustis, siis xs'i japsid ja hiinlased
oleks ammu kas uudiseid pasundanud või juba katki testinud.
btw sul pidi DFIs tuttav(naine) olema, mis tema kostab, äkki lanparty on oopis rd600 tsipsetiga?
eriti julm
Kommentaarid: 191 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 168
HDTanel
Overclocker
HDTanel
sõnum 21.07.2006 11:54:19 vasta tsitaadiga
Mõlema chipsetiga pidi tulema.
Enivei mai tea... seda Deluxe plaati keegi hankida saaks mulle? Ma ei leia kusagilt.
HuhHuh:
Intel Pentium 4 D805 1850.-
ASUS P5W DH Deluxe 3150.-
2x1Gb Corsair TWIN2X2048-6400 800MHz 3400.-
700W Fortron 2200.-
Krüpto
robin
robin
sõnum 21.07.2006 11:57:53 vasta tsitaadiga
mcaff kirjutas:
mida väiksem, seda parem.
Kommentaarid: 55 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 51
stepzter
stepzter
sõnum 21.07.2006 16:10:17 vasta tsitaadiga
tjj kirjutas:
Väga valdavas enamuses softis ei anna "macro-op fusion" (ehk võrdlus ja tingimuslike siirdekäskude eeldekodeerimisel ühitamine) eriti suurt effekti. Macro-op fusion mõjub jõudlusele kahes kohas: järjekorra välise täitmise plaanuri otsingu aken mahutab ~10% rohkem käske ja teatud tingimustel õnnestub 4 käsu asemel 5 dekodeerida. Esimene neist avaldab mõju siis kui juhuslikult õnnestub selle lisa 10% seest leida mõni käsk, mida saab teistest ette tõsta vabades täitmisüksustest täitmiseks (enamasuses koodis võrdlemisi ebatõenäoline). Teine avaldab põhiliselt mõju siirdekäskude ennustamise ebaõnnestumisele järgneval plaanuri puhvri 25% kiiremal täitmisel ja sellisel juhul kui protsessor suudab maksimaalset käskude täitmise kiirust hoida mitmeid takte üleval (keskmine on 3-5 korda madalam). Kõhutunde järgi pakuks, et enamuses softis jääb nende kogueffekt paari-kolme protsendi piiresse. Loomulikult esineb ka patoloogilisi juhtumeid, aga need on igal protsessoril olemas.
Eks tuleb mingeid põhjalikkumaid võrdlusi oodata. Siin esialgu mingis jaapani tekstiredaktoris hiiglasliku search-replace tegemisest natukene tuntum benchmark:
PS: 64bitine kood enamustel arhitektuuridel ongi aeglasem. Koodi suurus suureneb, andmestruktuuride suurused suurenevad jne. x86 on üks vähestest arhitektuuridest, kus 64biti peale minek on jõudluse paranemist toonud. Põhiliselt tänu sellele, et enne 64biti laiendusi oli x86 kasutatavate registrite arv täiesti kiviaegne 7.
Jaan
sõnum 21.07.2006 18:10:20 vasta tsitaadiga
stepzter kirjutas:
...PS: 64bitine kood enamustel arhitektuuridel ongi aeglasem. Koodi suurus suureneb, andmestruktuuride suurused suurenevad jne. x86 on üks vähestest arhitektuuridest, kus 64biti peale minek on jõudluse paranemist toonud. Põhiliselt tänu sellele, et enne 64biti laiendusi oli x86 kasutatavate registrite arv täiesti kiviaegne 7.
vene ixbt.com on teinud teste 64bit windoosas:
http://www.digit-life.com/articles2/cpu/intel-core2-duo-x6800.html
kokkuvõtteks niipalju, et 64bit winni all olid tulemused tõesti kehvemad, lisaks sellele tuli huvitav asi ilmseks-
Tuletan meelde, et see cooler on mõeldud kuumade netburst prosedele, mille soojuseraldus on kuni 150W...
Siinkohas mainin omaltpoolt et need xbitlabsi voolutarve testid on imho valesti tehtud-
a64 tarbib 2x vähem idles ja x6800 tarbimine on sinna 100W kanti tegelikult.
Need on minu oletused, üritan järgmisel nädalal seda ise uurida.
Kommentaarid: 143 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 123
sõnum 21.07.2006 19:00:40 vasta tsitaadiga
selline asjandus ka eestis olemas, AGP siiniga ja DDR-I pesadega, vist odavaim viis upgardeda... icon_biggrin.gif
http://www.asrock.com/product/775i65G.htm
Anti
sõnum 21.07.2006 19:16:49 vasta tsitaadiga
Odavaim vb jah, aga mina võtaks ennem Asus P5V-VM DH/WIFI-AP. Sellel wifi ja ikkagi Asus, olgu OC võimalustega kuidas on.
HDTanel
Overclocker
HDTanel
sõnum 21.07.2006 20:07:38 vasta tsitaadiga
Irw, Skeptik... võta Jaaniga ühendust ja las testib korra icon_biggrin.gif AGP kaartide WR-id tulevad icon_razz1.gif
Krüpto
libe
kvaliteetne mees
libe
sõnum 21.07.2006 22:20:39 vasta tsitaadiga
Skeptik kirjutas:
saab 6-7k hakkama
mälu kannatab natukene veel küll
aga saan oma tööd küll kiiremini tehtud kui praeguse tbred 1700+ thumbs_up.gif
razor
sõnum 22.07.2006 11:55:51 vasta tsitaadiga
miks mitte, kui sinna peale visata BH5ed koos boosteriga 8)
01'es kindlasti kiirem, kui DDR2
Kommentaarid: 132 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 120
uus teema   vasta Raud »  Protsessorid »  Intel Core 2 Duo/Quad overclocking mine lehele eelmine  1, 2, 3 ... 6, 7, 8 ... 592, 593, 594  järgmine
