uus teema   vasta Raud »  Protsessorid »  Socket AM2 overclocking ! märgi kõik teemad loetuks
mine lehele 1, 2, 3 ... 26, 27, 28  järgmine
Anti
sõnum 19.07.2006 18:54:03 Socket AM2 overclocking ! vasta tsitaadiga
Natuke infot ka AM2 kohta:
Wikipedia kirjutas:
The Socket AM2, renamed from Socket M2, is a CPU socket designed by AMD for desktop processors, including the performance, mainstream and value segments. Although it has 940 pins, it is incompatible with Socket 940, as the older Socket 940 does not support dual channel DDR2 RAM. Socket 939 equivalents with most applications about 2% faster , despite having over 30% greater memory bandwidth due to DDR2 support.
Hetkel saadaolevad AM2 protsessorid:
AMD Sempron 64 3600+
AMD Sempron 64 3500+
AMD Sempron 64 3400+ EE (35W)
AMD Sempron 64 3200+ EE (35W)
AMD Sempron 64 3000+ EE (35W)
AMD Sempron 64 2800+
AMD Athlon 64 FX-62
AMD Athlon64 X2 5200+
AMD Athlon 64 X2 5000+
AMD Athlon 64 X2 4600+
AMD Athlon 64 X2 4400+
AMD Athlon 64 X2 4200+
AMD Athlon 64 X2 3800+
AMD Athlon64 X2 3600+ EE (65W)
AMD Athlon 64 3800+
AMD Athlon 64 3500+
AMD Athlon 64 3200+
AMD Athlon 64 3000+
AM2 protsessorite OC rekordid:.
Xtremesystems.org foorum kirjutas:
FX-62: OPPAINTER - 3635.9 MHz http://www.xtremesystems.org/forums/showthread.php?t=100443
X2 4600+: JuanFlatier - 3000.1 MHz http://www.xtremesystems.org/forums/...d.php?t=100742
X2 4200+: Cole Riemer - 2915.17 MHz http://valid.x86-secret.com/show_oc?id=107317
X2 4000+: DrJay - 3137Mhz http://valid.x86-secret.com/show_oc.php?id=112440
X2 3800+: anaboliss - 3102,92MHz http://valid.x86-secret.com/show_oc?id=106039
X2 3000+: Amiteriver - 3022.6 MHz http://www.xtremesystems.org/forums/...d=11543992 89
3500+: Kiner - 3150.11 MHz http://valid.x86-secret.com/show_oc.php?id=93986
3000+: andre X-X - 3215.07 MHz http://valid.x86-secret.com/show_oc?id=110890
Sempron64 3400+ (Manila): Ozzimark - 3119.6mhz http://valid.x86-secret.com/show_oc?id=97360
Sempron64 3000+ (Manilla): QSS - 2669.33 MHz http://valid.x86-secret.com/show_oc?id=106505
Sempron64 2800+ (Manilla): QSS - 2747.59 MHz http://valid.x86-secret.com/show_oc?id=107555
8)
viimati muutis Anti 29.01.2007 02:10:12, muudetud 5 korda
Sponge
Sponge
sõnum 19.07.2006 18:58:43 vasta tsitaadiga
23 juuli hinna drop, siis oleks väga kick ass võta endale 2k eest 3800+ korralik mobo jne , conroe tuleks liiga kalliks, eriti neile kellel võimalusi pole .
Kommentaarid: 398 loe/lisa Kasutajad arvavad:  :: 4 :: 4 :: 323
Auron
Auron
sõnum 19.07.2006 20:04:57 vasta tsitaadiga
Kickass OC mobo tahab ka kickass DDR2 mälusid ja need pole sugugi niiväga odavad icon_razz1.gif
Ho Ho
Ho Ho
sõnum 19.07.2006 21:32:07 vasta tsitaadiga
Anti
sõnum 19.07.2006 21:41:21 vasta tsitaadiga
Ho Ho kirjutas:
ei ole midagi parandada, ju siis XS-ist maha võetud see asi... icon_rolleyes.gif
EDIT: tänud vermont thumbs_up.gif
viimati muutis Anti 19.07.2006 21:51:26, muudetud 1 kord
Flavius
sõnum 19.07.2006 21:44:29 vasta tsitaadiga
X2 4600+: JuanFlatier - 3000.1 MHz http://www.xtremesystems.org/forums/showthread.php?t=100742
X2 4000+: JuanFlatier - 3050.2 MHz http://www.xtremesystems.org/forums/showthread.php?t=100742
Kommentaarid: 126 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 118
mcaff
mcaff
sõnum 19.07.2006 22:01:27 vasta tsitaadiga
Mh küsiks palju oleks max voldid nii cpu kui ka ddr2 jaoks icon_rolleyes.gif
Kommentaarid: 130 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 104
Anti
sõnum 19.07.2006 22:03:25 vasta tsitaadiga
Niipalju kui nüüd mina olen DDR2 kasutanud olen aru saanud, et 2,4v on juba selline suhteliselt korralik pinge. Imo võrduks 2,4V DDR1-e 3-3,1V-ga icon_rolleyes.gif CPU on vist nagu AMD64-l ikka. 1,7 normaalsuse piires max.
WW mcaff tahtis kuulda kuidas võrrelda DDR1 ja DDR2 pingeid. Et mis liiga kõrge, mis liiga madal jne.
viimati muutis Anti 19.07.2006 22:19:07, muudetud 2 korda
One
sõnum 19.07.2006 22:03:48 vasta tsitaadiga
mcaff kirjutas:
oleneb mälust ja prosest... või millist vastust sa kuulda lootsid?
mcaff
mcaff
sõnum 20.07.2006 10:17:48 vasta tsitaadiga
Ega eriti ei julge 1,7v sisse littida kuna am2 def v madalam kui soc 939 NT:soc939 on 1,4def v ning soc am2 on 1,3def v aga see vist ei tohiks mõjutada icon_rolleyes.gif
Anti
sõnum 20.07.2006 10:43:45 vasta tsitaadiga
No see soc939 def on ka nii nagu ta on. Mõnel prose 1,35, mõnel 1,4. Kui korralik jahutus, ei ole häda midagi.
ceemic
24/7@kalal
ceemic
sõnum 20.07.2006 11:08:43 vasta tsitaadiga
mcaff, sa ju ei saandki üle 1,5v anda?
heikis
sõnum 20.07.2006 11:53:24 vasta tsitaadiga
rääkige, siis millised on korralikumad OC mobod AM2 peale
Kommentaarid: 339 loe/lisa Kasutajad arvavad:  :: 0 :: 4 :: 291
sõnum 20.07.2006 11:55:41 vasta tsitaadiga
nonii mul siis järgmine kooslus: AM2 Sempron 3000+@8X320 (1,35V - olude sunnil)... plaadiks ASRock AM2XLI-eSATA2.
Eelkõige ootan, kas voltmodi saaks prosele(loe. emaplaadile) teha, mälule võiks ka muidugi midagi olla, aga see jääb teisejärguliseks huviks icon_razz.gif
Emaplaat on igatahes oma raha eest aus ja üldse ei kahetse, et paremat proset peale ei ostnud... plaadi fsb/HTT taluvus on muljetavaldav icon_smile.gif
mcaff
mcaff
sõnum 20.07.2006 13:45:48 vasta tsitaadiga
ceemic kirjutas:
Ma ei ole midagi rääkind ma saan panna küll aga mul kütab prosa liiga kuumaks kuna originaal jahutus küljes icon_sad.gif Pealegi toide vaja ära vahetdada, paneb pange provisin siis 1,56v panna ja pilt taskus, madalama v asi töötab eks mul see toide ole ka suht nadi icon_lol.gif Imestan, et ta mul üldse töötab icon_biggrin.gif
sõnum 20.07.2006 13:53:00 vasta tsitaadiga
pole sel org. häda midagi - vähemalt semproni jaoks icon_smile.gif s754 peal sain parimad oc tulemused just org. radikaga...2,88GHz SuperPI'tav(see oli metsiku pingega..>1,8V minu meelest)
hetkel 2,65GHz tuleb 1,35V peal ka ära, aga ilmselt jääb ikka voolu väheks... suure koormusega saab pildi tasku icon_biggrin.gif
Revage
Keelatud avatar
sõnum 20.07.2006 13:58:01 vasta tsitaadiga
Keegi teab mil rd580 am2 plaadid tulevad ?
Kommentaarid: 80 loe/lisa Kasutajad arvavad:  :: 6 :: 10 :: 54
sõnum 20.07.2006 14:08:39 vasta tsitaadiga
See istub ikka ATI taga kinni... lubatud ju suht pikalt.
Tundub, et RD580 või miskit teist kivi ei suudeta piisavalt tarnida... epox ju enda plaadiga suht pikka aega eputanud, aga lubatud ajal realease'i pole tulnud
Revage
Keelatud avatar
sõnum 20.07.2006 14:16:08 vasta tsitaadiga
Magic kirjutas:
ise just ootangi epoxit .
mcaff
mcaff
sõnum 20.07.2006 14:50:38 vasta tsitaadiga
Magic kirjutas:
Sponge
Sponge
sõnum 20.07.2006 16:44:56 vasta tsitaadiga
Magic kirjutas:
sõnum 20.07.2006 16:52:47 vasta tsitaadiga
Nii kehv tulemus tuleb, et pole mõtet üles panna (võrreldes omaaja s754 31,9-ga) icon_biggrin.gif
36,7 on seni parim olnud... avastamisrõõmu peaks vast 35,X lihvimiseni jätkuma... aga eks näis... prosele jääb see 1,35V ikka väga väheseks.
mcaff
mcaff
sõnum 20.07.2006 17:18:06 vasta tsitaadiga
Mis sa said 36,7sec @2,88ghz we icon_question.gif ma oma amd athlon 64 3500@2600mhz 31sec
korndog412
korndog412
sõnum 20.07.2006 17:22:52 vasta tsitaadiga
ei, 36.7 sai ta AM2 sempron64 @ 8x320 peal
31.9 sai ta 2.88ghz sempron64 s754 peal
Kommentaarid: 120 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 99
sõnum 20.07.2006 18:13:33 vasta tsitaadiga
korndog412 kirjutas:
Kahju, et miskit fsb killerit plaati veel AM2 peal pole... oki see AsRock on... sellega saadud 390MHz isegi, aga ega täisväärtuslik loom see pole icon_razz.gif
edit: krt alla 36,2 ei saa ikka kuidagi icon_razz.gif
Sponge
Sponge
sõnum 20.07.2006 20:30:27 vasta tsitaadiga
Magic kirjutas:
milles probleem, nagu ma aru saan siis cpule ei saa pinget anda ? icon_rolleyes.gif
sõnum 20.07.2006 20:40:33 vasta tsitaadiga
jep.. CPU pinge puudub... kui saaks anda siis ka vaid 1,4ni... krt ei teagi miks minu bioses seda võimalust pole icon_confused.gif
Loodan, et siiski saab modida... plaat ikka üsna uus veel ja mode silma pole jäänud.
mcaff
mcaff
sõnum 20.07.2006 20:55:57 vasta tsitaadiga
Magic kirjutas:
sõnum 20.07.2006 21:06:37 vasta tsitaadiga
biosis pole võimalust... proovisin kõik ametlikud biosi versioonid ära ja neis pole ei voldi ega kordaja muutmist icon_wink.gif
eks jääb miskit uuendust oodata... samas ega pea 1000MHz lisa ka paha pole icon_razz.gif
Sponge
Sponge
sõnum 21.07.2006 01:48:01 vasta tsitaadiga
http://www.realworldtech.com/page.cfm?ArticleID=RWT060206035626
Alari A.
sõnum 24.07.2006 21:44:01 vasta tsitaadiga
mida sellest prosest arvata
http://classic.hinnavaatlus.ee/product.php?product_id=43329&group_id=1614
kannatavad ka kellamist?
+pakkuge mammit samale prosele max 1.5k eest
Kommentaarid: 681 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 554
korndog412
korndog412
sõnum 24.07.2006 21:45:43 vasta tsitaadiga
Alari A.
sõnum 24.07.2006 21:52:27 vasta tsitaadiga
selline mammi? http://classic.hinnavaatlus.ee/product.php?product_id=42196&group_id=1617
käis mõte läbi,et äkki müüks mammi+630 inteli maha ja koliks amd peale tagasi
sõnum 24.07.2006 22:40:56 vasta tsitaadiga
asus pidi kahtlane olema, aga mark küll kui jälle low-end venna ehk asrocki käest pähe saaks icon_smile.gif
mina jätsin nii msi kui asuse välja just algsete kõlakate tõttu, et ei ole väga hea fsb taluvusega
korndog412
korndog412
sõnum 24.07.2006 22:46:12 vasta tsitaadiga
selle plate SLI versioon pidavat 360 taluma.
Sponge
Sponge
sõnum 27.07.2006 21:38:06 vasta tsitaadiga
MSI K9 plaadid on huvitavad loomad, nimelt sa pead kõik asjad käsitsi paika panema, mälu timmid absull kõik, kui sa selle plaadi jooksma saad on ta väga hea, aga raske on jooksma saada. ise tellisin endale asuse M2L vms iganes , 1400.- , sama plaat mis SLI delux aga teist PCIE siini pole, vmodid siga lihtsad icon_razz.gif thumbs_up.gif
mcaff
mcaff
sõnum 30.07.2006 11:21:31 vasta tsitaadiga
sõnum 30.07.2006 11:29:01 vasta tsitaadiga
looda sa icon_smile.gif AMD'l see asi venib... ei riskita ju seni hästi toimiva asja lammutamisega... kõige lollikindlam on ju päris uues tehases 65nm tootma hakata, aga AMD'l seda võimalust paraku pole... hetke uusim tehas teeb ka ju 90nm tehnoloogiat.
mcaff
mcaff
sõnum 30.07.2006 11:54:10 vasta tsitaadiga
Damm netis kolades leidsin, et need 65nm prosad tulevad kusagil 2006aasta väga lõpus icon_neutral.gif
ragface
ragface
sõnum 31.07.2006 12:19:52 vasta tsitaadiga
tegin inital proovi peale karpite avamist:
a64 3200+ am2
asus m2n32-sli we
2 x 1gb ocz pc2-8000 xtc
protsessor läks vaevata 3 GHzi õhuga (normaalne leitsak oli toas) (1.51v)
mäluga oli probleeme 1T-l ei taha kuidagi üle DDR2-800 protsessoriga koos klokkuda - peab veel uurima, kas protsessori (mälukontrolleri) v emaplaadi süül. Lähiajal peaks läbi käima veel paar 3200+ siis saab väikese võrdlusmomendi ka ehk tuleb veel pisut mämmerdada ja tweakida õhtuti, siis panen paar skriinshotti ka üles.
\R
Kommentaarid: 18 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 16
Sponge
Sponge
sõnum 02.08.2006 15:08:58 vasta tsitaadiga
a64 x2 3800+
MSI k9l platinum
2x512 corsairi ddr 800 pulgad
2,85 GHz 1,45v DUALCORE thumbs_up.gif õhk jahutus (freezer64 )
AGA MA VIHASTASIN SELLE MSI RONDI PEALE, SEE EI KANNATA ÜLE 285 MHZ HTT icon_evil.gif icon_evil.gif icon_evil.gif icon_evil.gif icon_evil.gif icon_evil.gif icon_evil.gif icon_evil.gif
One
sõnum 02.08.2006 15:29:15 vasta tsitaadiga
Sponge Bob kirjutas:
AGA MA VIHASTASIN SELLE MSI RONDI PEALE, SEE EI KANNATA ÜLE 285 MHz
AM2 nvidia chipset on suht "õnnestunud"
s939 peal klokkusid msi/asus jne ikka tiba paremini icon_rolleyes.gif
Sponge
Sponge
sõnum 02.08.2006 15:30:21 vasta tsitaadiga
Winterwind kirjutas:
homme saan asus m32 vms iganes 590 chipihga, eks näis mis see suudab
One
sõnum 02.08.2006 15:33:00 vasta tsitaadiga
Sponge
Sponge
sõnum 02.08.2006 15:33:38 vasta tsitaadiga
kui ei siis ma lään kedagi... sest prose teeb 1,37v peal kah 2,85 GHz icon_lol.gif
mcaff
mcaff
sõnum 02.08.2006 15:33:39 vasta tsitaadiga
Ei tea krt see AMD päris lolliks läinud ma vaatan jummala tumbud on nad pole sõnu lihtsalt icon_neutral.gif
Sponge
Sponge
sõnum 02.08.2006 15:35:25 vasta tsitaadiga
mcaff kirjutas:
mis see amd siia praegu nagu puutus ? icon_eek.gif seleta lollile inimesele kah? kuidas on amd süüdi et nvidia kiipi ei osanud teha icon_eek.gif või seda et miks MSI ei osanud normaalset plaati teha icon_lol.gif
mcaff
mcaff
sõnum 02.08.2006 15:36:04 vasta tsitaadiga
Vaata kuidas AMD soc vahetab sihuke tamp on taga, mis siin häid tulemusi saada loota asi ei jõuta korralikult valmis teha kui juba AMD hiilgab jälle uuega icon_lol.gif
Gljukats
sõnum 02.08.2006 20:32:23 vasta tsitaadiga
A64 X2 3800+ 22 nadal
ABIT KN9 SLI 570-SLI BIOS V1.3
2x512 DDR2-667 Corsair pulgad
LEGO, LEGO, LEGO ...
Kommentaarid: 147 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 129
vambola
sõnum 02.08.2006 21:35:17 vasta tsitaadiga
590 klokkubki paremini. 570 puhul kahtlustatakse kunstlikku piiratust.
mcaff kirjutas:
Ja millal see viimane vahetus oli ka? See, et mõni mees alles hiljuti läks s939 peale, ei tähenda et see mingi jube-uus platvorm oleks.
Kommentaarid: 128 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 120
uus teema   vasta Raud »  Protsessorid »  Socket AM2 overclocking ! mine lehele 1, 2, 3 ... 26, 27, 28  järgmine
