uus teema   vasta Raud »  Protsessorid »  Socket AM2 overclocking ! märgi kõik teemad loetuks
mine lehele 1, 2, 3 ... 53, 54, 55  järgmine
Anti
sõnum 19.07.2006 17:54:03 Socket AM2 overclocking ! vasta tsitaadiga
Natuke infot ka AM2 kohta:
Wikipedia kirjutas:
The Socket AM2, renamed from Socket M2, is a CPU socket designed by AMD for desktop processors, including the performance, mainstream and value segments. Although it has 940 pins, it is incompatible with Socket 940, as the older Socket 940 does not support dual channel DDR2 RAM. Socket 939 equivalents with most applications about 2% faster , despite having over 30% greater memory bandwidth due to DDR2 support.
Hetkel saadaolevad AM2 protsessorid:
AMD Sempron 64 3600+
AMD Sempron 64 3500+
AMD Sempron 64 3400+ EE (35W)
AMD Sempron 64 3200+ EE (35W)
AMD Sempron 64 3000+ EE (35W)
AMD Sempron 64 2800+
AMD Athlon 64 FX-62
AMD Athlon64 X2 5200+
AMD Athlon 64 X2 5000+
AMD Athlon 64 X2 4600+
AMD Athlon 64 X2 4400+
AMD Athlon 64 X2 4200+
AMD Athlon 64 X2 3800+
AMD Athlon64 X2 3600+ EE (65W)
AMD Athlon 64 3800+
AMD Athlon 64 3500+
AMD Athlon 64 3200+
AMD Athlon 64 3000+
AM2 protsessorite OC rekordid:.
Xtremesystems.org foorum kirjutas:
FX-62: OPPAINTER - 3635.9 MHz http://www.xtremesystems.org/forums/showthread.php?t=100443
X2 4600+: JuanFlatier - 3000.1 MHz http://www.xtremesystems.org/forums/...d.php?t=100742
X2 4200+: Cole Riemer - 2915.17 MHz http://valid.x86-secret.com/show_oc?id=107317
X2 4000+: DrJay - 3137Mhz http://valid.x86-secret.com/show_oc.php?id=112440
X2 3800+: anaboliss - 3102,92MHz http://valid.x86-secret.com/show_oc?id=106039
X2 3000+: Amiteriver - 3022.6 MHz http://www.xtremesystems.org/forums/...d=11543992 89
3500+: Kiner - 3150.11 MHz http://valid.x86-secret.com/show_oc.php?id=93986
3000+: andre X-X - 3215.07 MHz http://valid.x86-secret.com/show_oc?id=110890
Sempron64 3400+ (Manila): Ozzimark - 3119.6mhz http://valid.x86-secret.com/show_oc?id=97360
Sempron64 3000+ (Manilla): QSS - 2669.33 MHz http://valid.x86-secret.com/show_oc?id=106505
Sempron64 2800+ (Manilla): QSS - 2747.59 MHz http://valid.x86-secret.com/show_oc?id=107555
8)
viimati muutis Anti 29.01.2007 01:10:12, muudetud 5 korda
Sponge
Sponge
sõnum 19.07.2006 17:58:43 vasta tsitaadiga
23 juuli hinna drop, siis oleks väga kick ass võta endale 2k eest 3800+ korralik mobo jne , conroe tuleks liiga kalliks, eriti neile kellel võimalusi pole .
Kommentaarid: 398 loe/lisa Kasutajad arvavad:  :: 4 :: 4 :: 323
Auron
Auron
sõnum 19.07.2006 19:04:57 vasta tsitaadiga
Kickass OC mobo tahab ka kickass DDR2 mälusid ja need pole sugugi niiväga odavad icon_razz1.gif
Kommentaarid: 155 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 132
Ho Ho
Ho Ho
sõnum 19.07.2006 20:32:07 vasta tsitaadiga
Anti
sõnum 19.07.2006 20:41:21 vasta tsitaadiga
Ho Ho kirjutas:
ei ole midagi parandada, ju siis XS-ist maha võetud see asi... icon_rolleyes.gif
EDIT: tänud vermont thumbs_up.gif
viimati muutis Anti 19.07.2006 20:51:26, muudetud 1 kord
Flavius
sõnum 19.07.2006 20:44:29 vasta tsitaadiga
X2 4600+: JuanFlatier - 3000.1 MHz http://www.xtremesystems.org/forums/showthread.php?t=100742
X2 4000+: JuanFlatier - 3050.2 MHz http://www.xtremesystems.org/forums/showthread.php?t=100742
Kommentaarid: 126 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 118
mcaff
mcaff
sõnum 19.07.2006 21:01:27 vasta tsitaadiga
Mh küsiks palju oleks max voldid nii cpu kui ka ddr2 jaoks icon_rolleyes.gif
Kommentaarid: 130 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 104
Anti
sõnum 19.07.2006 21:03:25 vasta tsitaadiga
Niipalju kui nüüd mina olen DDR2 kasutanud olen aru saanud, et 2,4v on juba selline suhteliselt korralik pinge. Imo võrduks 2,4V DDR1-e 3-3,1V-ga icon_rolleyes.gif CPU on vist nagu AMD64-l ikka. 1,7 normaalsuse piires max.
WW mcaff tahtis kuulda kuidas võrrelda DDR1 ja DDR2 pingeid. Et mis liiga kõrge, mis liiga madal jne.
viimati muutis Anti 19.07.2006 21:19:07, muudetud 2 korda
One
sõnum 19.07.2006 21:03:48 vasta tsitaadiga
mcaff kirjutas:
oleneb mälust ja prosest... või millist vastust sa kuulda lootsid?
mcaff
mcaff
sõnum 20.07.2006 09:17:48 vasta tsitaadiga
Ega eriti ei julge 1,7v sisse littida kuna am2 def v madalam kui soc 939 NT:soc939 on 1,4def v ning soc am2 on 1,3def v aga see vist ei tohiks mõjutada icon_rolleyes.gif
Anti
sõnum 20.07.2006 09:43:45 vasta tsitaadiga
No see soc939 def on ka nii nagu ta on. Mõnel prose 1,35, mõnel 1,4. Kui korralik jahutus, ei ole häda midagi.
ceemic
24/7@kalal
ceemic
sõnum 20.07.2006 10:08:43 vasta tsitaadiga
mcaff, sa ju ei saandki üle 1,5v anda?
heikis
sõnum 20.07.2006 10:53:24 vasta tsitaadiga
rääkige, siis millised on korralikumad OC mobod AM2 peale
Kommentaarid: 338 loe/lisa Kasutajad arvavad:  :: 0 :: 4 :: 290
sõnum 20.07.2006 10:55:41 vasta tsitaadiga
nonii mul siis järgmine kooslus: AM2 Sempron 3000+@8X320 (1,35V - olude sunnil)... plaadiks ASRock AM2XLI-eSATA2.
Eelkõige ootan, kas voltmodi saaks prosele(loe. emaplaadile) teha, mälule võiks ka muidugi midagi olla, aga see jääb teisejärguliseks huviks icon_razz.gif
Emaplaat on igatahes oma raha eest aus ja üldse ei kahetse, et paremat proset peale ei ostnud... plaadi fsb/HTT taluvus on muljetavaldav icon_smile.gif
mcaff
mcaff
sõnum 20.07.2006 12:45:48 vasta tsitaadiga
ceemic kirjutas:
Ma ei ole midagi rääkind ma saan panna küll aga mul kütab prosa liiga kuumaks kuna originaal jahutus küljes icon_sad.gif Pealegi toide vaja ära vahetdada, paneb pange provisin siis 1,56v panna ja pilt taskus, madalama v asi töötab eks mul see toide ole ka suht nadi icon_lol.gif Imestan, et ta mul üldse töötab icon_biggrin.gif
sõnum 20.07.2006 12:53:00 vasta tsitaadiga
pole sel org. häda midagi - vähemalt semproni jaoks icon_smile.gif s754 peal sain parimad oc tulemused just org. radikaga...2,88GHz SuperPI'tav(see oli metsiku pingega..>1,8V minu meelest)
hetkel 2,65GHz tuleb 1,35V peal ka ära, aga ilmselt jääb ikka voolu väheks... suure koormusega saab pildi tasku icon_biggrin.gif
Revage
Keelatud avatar
sõnum 20.07.2006 12:58:01 vasta tsitaadiga
Keegi teab mil rd580 am2 plaadid tulevad ?
Kommentaarid: 78 loe/lisa Kasutajad arvavad:  :: 6 :: 10 :: 52
sõnum 20.07.2006 13:08:39 vasta tsitaadiga
See istub ikka ATI taga kinni... lubatud ju suht pikalt.
Tundub, et RD580 või miskit teist kivi ei suudeta piisavalt tarnida... epox ju enda plaadiga suht pikka aega eputanud, aga lubatud ajal realease'i pole tulnud
Revage
Keelatud avatar
sõnum 20.07.2006 13:16:08 vasta tsitaadiga
Magic kirjutas:
ise just ootangi epoxit .
mcaff
mcaff
sõnum 20.07.2006 13:50:38 vasta tsitaadiga
Magic kirjutas:
Sponge
Sponge
sõnum 20.07.2006 15:44:56 vasta tsitaadiga
Magic kirjutas:
sõnum 20.07.2006 15:52:47 vasta tsitaadiga
Nii kehv tulemus tuleb, et pole mõtet üles panna (võrreldes omaaja s754 31,9-ga) icon_biggrin.gif
36,7 on seni parim olnud... avastamisrõõmu peaks vast 35,X lihvimiseni jätkuma... aga eks näis... prosele jääb see 1,35V ikka väga väheseks.
mcaff
mcaff
sõnum 20.07.2006 16:18:06 vasta tsitaadiga
Mis sa said 36,7sec @2,88ghz we icon_question.gif ma oma amd athlon 64 3500@2600mhz 31sec
korndog412
korndog412
sõnum 20.07.2006 16:22:52 vasta tsitaadiga
ei, 36.7 sai ta AM2 sempron64 @ 8x320 peal
31.9 sai ta 2.88ghz sempron64 s754 peal
Kommentaarid: 120 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 99
sõnum 20.07.2006 17:13:33 vasta tsitaadiga
korndog412 kirjutas:
Kahju, et miskit fsb killerit plaati veel AM2 peal pole... oki see AsRock on... sellega saadud 390MHz isegi, aga ega täisväärtuslik loom see pole icon_razz.gif
edit: krt alla 36,2 ei saa ikka kuidagi icon_razz.gif
uus teema   vasta Raud »  Protsessorid »  Socket AM2 overclocking ! mine lehele 1, 2, 3 ... 53, 54, 55  järgmine
