17.02.2003 23:23:18
RADEON 9000 seeria videokaartide tehniliste parameetrite võrdlus |
link :: Raf's Hardware
Et kas selline info on adekvaatne ja tõene?
RADEON 9000: R250 core, 4 rendering pipelines with 1 TMU per each, 1 Vertex Shader processor, DirectX 8.1
RADEON 9000 PRO:R250 core, 4 rendering pipelines with 1 TMU per each, 1 Vertex Shader processor, DirectX 8.1,
RADEON 9100: R200 core, 4 rendering pipelines with 2 TMU per each, 1 Vertex Shader processor, 1 T&L unit, DirectX 8.1
RADEON 9500 64MB: R300 core, 4 rendering pipelines with 1 TMU per each, 4 Vertex Shader processors, DirectX 9.0, memory bus: 128 bit
RADEON 9500 128MB: R300 core 4 rendering pipelines with 1 TMU per each, 4 Vertex Shader processors, DirectX 9.0, memory bus: 256 bit
RADEON 9500 PRO 128MB: R300 core, 8 rendering pipelines with 1 TMU per each, 4 Vertex Shader processors, DirectX 9.0, memory bus: 128 bit
RADEON 9700: R300 core, 8 rendering pipelines with 1 TMU per each, 4 Vertex Shader processors, DirectX 9.0, memory bus: 256 bit
RADEON 9700 PRO: R300 core, 8 rendering pipelines with 1 TMU per each, 4 Vertex Shader processors, DirectX 9.0, memory bus: 256 bit
...(keegi võiks siia panna ka 8500 ja tulevase R350 andmed)
viimati muutis Tanel 18.02.2003 09:20:46, muudetud 1 kord |
| Kommentaarid: 472 loe/lisa |
13 :: |
7 :: |
359 |
Telempe
17.02.2003 23:25:39
mis oleks esimene graafikakaart millega ma saaksin üle 10 000 3DMark02 punkti?
_________________ ORLY? I hardly know her! |
| Kommentaarid: 22 loe/lisa |
21 |
sumpz
18.02.2003 01:03:23
| misajast R9500/pro R250 core kasutab?
| Kommentaarid: 36 loe/lisa |
36 |
Beanladen
18.02.2003 13:17:53
R9500 kasutab ikka R300 coret!
Boot
18.02.2003 14:17:25
| Radeon 9000 ja Pro on RV250 mitte R250..
| Kommentaarid: 27 loe/lisa |
Deep Fury
20.02.2003 13:53:03
Radeon8500 core on sama mis 9100-l ehk r200, Rendering Pipelines 4 jms ka sama. Nimi on muidugi teine
Asja kohta selline teade ka http://www.theinquirer.net/?article=6641
Lühidalt nipp a la nVidia GF2-->GF4MX
marko
20.02.2003 23:34:35
| Deep Fury kirjutas: |
Lühidalt nipp a la nVidia GF2-->GF4MX |
gf3 ikka mitte gf2?
| Kommentaarid: 176 loe/lisa |
159 |
One
20.02.2003 23:50:36
To Marko: ei,ei ikka geforce 2=geforce 4mx
mitte geforce 3
728 |
me_
21.02.2003 00:01:37
| zilwer kirjutas: |
| mis oleks esimene graafikakaart millega ma saaksin üle 10 000 3DMark02 punkti? |
r9100/r8500
Ja GF4mx on siiski kastreeritud 'päris GF4' mitte täiustatud GF2 :]
| Kommentaarid: 64 loe/lisa |
62 |
Dumb(_;_)
21.02.2003 00:29:10
| me_ kirjutas: |
| ...GF4mx on siiski kastreeritud 'päris GF4' mitte täiustatud GF2 :] |
No sel juhul on tal küll lisaks ka kurgumandlid ja pimesool eemaldatud
| Kommentaarid: 60 loe/lisa |
55 |
marko
21.02.2003 01:12:47
mis te jamate, GF4mx'id on gf3'med mitte gf4ti'd. lugege näit. artiklit siit: http://accelenation.com/?ac.id.123.8
There were the three titanium versions (codenamed NV25): the GeForce4 Ti4200 clocked at 250/250; the Ti4400 at 275/275; and the GeForce4 Ti4600 clocked at 300/325. In addition there were also three entry-level MX versions (codenamed NV17), which unfortunately were GeForce4 chips in name only, having inherited none of the programmable technology introduced since the GeForce3 line. Cards based on these newer MX chips performed no better than the GeForce2 Ultra released some 18 months earlier.
[/quote]
159 |
marko
21.02.2003 01:13:57
| voltc kirjutas: |
mitte geforce 3  |
siis ei saa ma su võrdlusest aru.
159 |
wicked
21.02.2003 01:19:01
marko, sinu oma quote:
| There were the three titanium versions (codenamed NV25): the GeForce4 Ti4200 clocked at 250/250; the Ti4400 at 275/275; and the GeForce4 Ti4600 clocked at 300/325. In addition there were also three entry-level MX versions (codenamed NV17), which unfortunately were GeForce4 chips in name only, having inherited none of the programmable technology introduced since the GeForce3 line. Cards based on these newer MX chips performed no better than the GeForce2 Ultra released some 18 months earlier |
ja:
| The GF4 naming of this card is very misleading due to one simple fact; the card has no DX8 support, whereas even the GF3 lineup did |
http://nexushardware.com/reviews/index.php?reviewnumber=28&page_number=1
samuti:
| Time passed, and the GeForce2 MX (MX 200/400) family, which is just a version of GeForce2 with limited 3D, was succeeded by GeForce4 MX--a wild architectural cocktail of several chip generations from GeForce2 through GeForce4 |
http://www.xbitlabs.com/video/gf4-mx/
See ongi vast täpseim seletus gf4mx kohta - segu gf2-st 4ni
_________________ I prepared Explosive Runes this morning |
| Kommentaarid: 68 loe/lisa |
63 |
marko
21.02.2003 01:36:28
| eks suurem osa kaarte kasutab eelnevate tehnoloogiat.
159 |
thunderz
21.02.2003 01:42:38
| zilwer kirjutas: |
minuteada pole 3Dmark02 üldse olemaski. on 2001(se) ja 2003 ja siis veel vanemad , aga 2002 nagu ju polnudki ?
| Kommentaarid: 47 loe/lisa |
46 |
Beanladen
21.02.2003 08:26:40
| programmable technology introduced since the GeForce3 line. |
õpi natuke inglise keelt enne kui tuled põrkama
siin kirjas et midagi pole kaasa võetud alates GF3 kaartidest.
me_
21.02.2003 08:45:28
| Beanladen kirjutas: |
õpi natuke inglise keelt enne kui tuled põrkama :evil:
siin kirjas et midagi pole kaasa võetud alates GF3 kaartidest. |
tegelt seal kirjas, et "programmable features" esindajaid ei ole kaasa võetud, sõna 'midagi' kasutamine on käesolevas kontekstis ebakorrektne.
62 |
marko
21.02.2003 18:10:26
oot, oli see nüüd mulle suunatud? ega ma jah vist hästi ei oska, elu aeg küll õpitud ja kuus aastad ameeriklaste seaski veedetud...aga mida see ka annab.
159 |
marko
21.02.2003 18:15:55
| ja kirja mõte seal on, et midagi uut, mis välja tulnud peale gf3'me "progetava tehnoloogia vallas" pole lisatud. tähendab, et sisuliselt on gf4mx gf3 tasandile toppama jäänud ja mittte "cut-down" versioon gf4ti'dest.
159 |
me_
23.02.2003 15:38:12
| marko kirjutas: |
| ja kirja mõte seal on, et midagi uut, mis välja tulnud peale gf3'me "progetava tehnoloogia vallas" pole lisatud. tähendab, et sisuliselt on gf4mx gf3 tasandile toppama jäänud ja mittte "cut-down" versioon gf4ti'dest. |
lol
Halvasti oled need õpingute ja väljamaalaste seltsis veedetud aastad kasutand.
GF4mx ple siiski mitte GF3 tasandile 'toppama jäänud' vaid praktiliselt ple sinna kunagi jõudnudki :PP
62 |
Telempe
23.02.2003 16:01:54
vabandust, jah, mõtlesin 2001 SE-d
21 |
marko
23.02.2003 18:55:42
| me_ kirjutas: |
| marko kirjutas: |
lol
GF4mx ple siiski mitte GF3 tasandile 'toppama jäänud' vaid praktiliselt ple sinna kunagi jõudnudki P |
rofl, paistab et sul arusaamisega tõsiseid probleeme. või oled lihtsalt mingi vaidluse armastaja siidisepp. ok, ma teen asja sulle siis lihtsamaks. GF4 on võimsam kui GF3, sellest ikka saad aru? Nii, kui nüüd tuleb välja kaart nimega GF4(mx) siis mida sellelt kaardilt oodata? Et on lahjem kui GF3??? Aga seda ta on, ja gf4'ja võimsusest ja uuest progetavast tehnoloogiast pole jälgegi. Seda, et kaart on füüsiliselt GF3'ga võrreldav, pole keegi väitnud. [/u]
159 |
traks
304 |
