ceemic
24/7@kalal
26.04.2006 16:57:01
3200+@2,7GHz
2*256MB@245MHz@2-2-2-5 1T
x300se 325/300@531/345
3375p
322 |
HDTanel
Overclocker
27.04.2006 12:15:50
AMD64 3000+ DEFAULT VOLT @ 2500MHz
4x256Mb PC3200 AM1 @ 178MHz
Epox 9NPA7I nForce4
HIS ATI Radeon X700 256Mb DDR default
SATA 160Gb Maxtor DiamondMax 10 7200\8
SATA 120Gb Samsung SpinPoint P80 7200\8
5,702p
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
WäntWõll
make.believe
29.04.2006 00:16:25
Vahelduseks midagi sellist
Opteron 144 @3.0 + Ac64
7900Gt gpu570+mem1600 jahutab Fatal1ty
300 |
Anti
03.05.2006 23:50:30
Lambirun.
Athlon64 3200+ @ 2650mhz
2x256 BH5 @ 241mhz 2-2-2-5
Sapphire x850xt (PE) @ 615/625 (stock cooling, vmode ei ole)
3DMark03 Score: 14711
240 |
margusser
167 |
Anti
04.05.2006 12:43:07
millega? Niiske sõrmega?
240 |
One
04.05.2006 21:15:16
CPU: Intel Pentium D 920 2,8GHz 2X2MB L2 cache @ 4,2GHz
MB: Asus Socket 775 P5WD2
RAM: 4 x 512MB Kingston DDR2 PC2-3200 400MHz @ 450MHz
GFX: HIS X1600XT 587/693 @ 650/800
julm - kokku ei jookse ja artefacte ei pane aga 3dmarkidel pole tekstuure
728 |
Anti
04.05.2006 23:48:59
Lambirun.
Sapphire x850xt (PE) @ 620/630 (stock cooling, vmode ei ole, PILT 100% PUHAS)
3DMark03 Score: 14873
240 |
DonNiger
06.05.2006 15:26:33
Tegin just mubole biose uuenduse, keerasin videokaardi kellad ka originaalasendisse. Ühesõnaga - kõik defis, CPU, RAM ja GPU. Lihtsalt mõni def jooks ka siia
EDIT: CPU panin 4 GHz peale (muud näitajad samad) ja tulemus on 9980.
116 |
Anti
06.05.2006 20:42:40
Minu 24/7 sätetel lastud test.
DFI LP NF4 Ultra-D
A64 3200+ "Winchester " @ def (2ghz)
2x256mb BH5 + 256mb M-TEC + 256mb PQI @ 200mhz 2,5-3-3-6
Sapphire X850XT PE @ 600/620
Catalyst 6.4
3DMark03 Score: 13479
240 |
Iron miki
06.05.2006 20:51:25
Lasin kah kähku ühe testi
Abit AL8-V
P4 530J @ 3.8GHz
4x256mb Apacer DDR2 pc4300 4-4-4-11
Sapphire x850xt @ 600/600
Catalyst 6.4
3Dmark03 Score: 14161
| Kommentaarid: 17 loe/lisa |
17 |
minunimi
06.05.2006 21:21:09
Abit KT7A
AMD Duron 750Mhz
256mb SDRAM PC133
GeForce2 MX 400
3Dmark03 Score: 93
Tbit
06.05.2006 22:47:27
| minunimi kirjutas: |
Abit KT7A
AMD Duron 750Mhz
256mb SDRAM PC133
GeForce2 MX 400
3Dmark03 Score: 93
kella natuke prose ja video ning 10k peaks mureta tulema 8)
|OSTAN|-> T43 pikk jahutus |
| Kommentaarid: 264 loe/lisa |
229 |
margusser
07.05.2006 09:17:50
jap 10k
167 |
One
08.05.2006 10:26:27
omg mingi XS-i vana tegigi mu X700 rekordi üle
peab millalgi paar kiiremat ringi tegema vist
728 |
HDTanel
Overclocker
08.05.2006 11:58:51
| Winterwind kirjutas: |
peab millalgi paar kiiremat ringi tegema vist  |
Mis seal imestada kellel viitsimist võib vabalt üle teha.. sa ei kasutanud ju mingeid ekstriim jahutusi Pane oma Pentium LN2 alla ja benchi
496 |
r4ido
09.05.2006 23:55:42
Tegin ka paar testi...
See esimene siis tehtud 3200+@2,1ghz, 768mb mälu ja ühe PC-2100 pulga pärast jooksis 140mhz'il asi, Video siis 550/1100 8890p
Teine aga 3200+@2,2ghz, 512 Dual DDR400@220mhz ja video 500/1000@559/1125 9056p
Varem sain siis:512 dual ja def CPU'ga sai 80xxp
ja: 768mb@140mhz ja CPU@2,1 sai 77xxp
| Kommentaarid: 74 loe/lisa |
68 |
der hammer
10.05.2006 23:46:10
Abit KT7A
AMD Duron 750Mhz
256mb SDRAM PC133
GeForce2 MX 400
3Dmark03 Score: 93
Hale. Mul oli sama conf ainult P4 1500mhz ja sain umbes 350 punkti 8)
_________________ Tere. |
130 |
razor
11.05.2006 04:57:46
GF2 MX400 peal oleks 350 maailmarekord
praegune
120 |
One
11.05.2006 20:21:18
GFX: PowerColor X1800GTO 500/500 @ 575/575
3DMark Score 15997
link: http://service.futuremark.com/compare?2k3=4782035
728 |
mcaff
11.05.2006 20:27:02
3DMark Score 15997
link: http://service.futuremark.com/compare?2k3=4782035 |
irw nõrk nagu ei ole we ma saan oma x800xl kellamata 11.5k ja kellatuna 13,8k kohe näha amd ja inteli jõudluse vahet ja rammi ka mul vähem kui sul
104 |
Anti
11.05.2006 20:28:24
| mcaff kirjutas: |
3DMark Score 15997
irw nõrk nagu ei ole we ma saan oma x800xl kellamata 11.5k ja kellatuna 13,8k kohe näha amd ja inteli jõudluse vahet ja rammi ka mul vähem kui sul |
ema on sul nõrk
Sa natuke vaata kah ja mõtle.
1. See klokkub nagu loom
2. See pole mõni 16 piibuline kaart, vaid 12 piibuga
240 |
vxpsv
| Kommentaarid: 4 loe/lisa |
HDTanel
Overclocker
11.05.2006 21:53:03
Kui kaine homme õhtu olen teen sama testi Opteron144-ga Mälu aint über pask Kingston
496 |
One
11.05.2006 21:55:20
prose klokk madal - ma saan 4200mhz peal pennuga ja X1800GTO-ha GT1 fpsi ka rohkem
dualcore ei anna juurde pigem mhz... üldiselt 03 on nvidiale mõeldud - seal läheb tekstuurijõudu vaja ja nvidial seda küllaga
728 |
