uus teema   vasta Tarkvara »  Arvutimängude foorum »  Guild Wars märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 13, 14, 15, 16, 17, 18  järgmine
Mario.
sõnum 26.02.2006 02:54:28 vasta tsitaadiga
http://img527.imageshack.us/my.php?image=gw0998fj.jpg selline asi tuleks küll nüüd ara muuta...isegi kollide nimetused on asendatud ---- :S
h62k
sõnum 26.02.2006 12:09:35 vasta tsitaadiga
Eternal Estonian oli mingi 2nädalat tagasi väga active koguaeg minig 10 inimest sees. Nüüd on kuidagi vaikseks jäänud aga ma usun et varsti jälle elavnub. Ühtlasi on see ka guild warsi esimene eesti guild. Kui tahad liituda siis mo IGN on Kuri Hunt
Kommentaarid: 29 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 24
ahvilõust
ahvilõust
sõnum 27.02.2006 02:58:48 vasta tsitaadiga
Milliste questide eest sai lisa attribuute?
Gdesainer
un3v3n
sõnum 27.02.2006 18:04:55 vasta tsitaadiga
ahvilõust kirjutas:
tahaks veel küsida ,et mis itemitega saaks ma oma fire magicut üles bootida
praegu runega ja selle flame eyega 16 :S aga tahaks ikka rohkem ... ja palju need itemid maksta võiks
leidsin gw foorumist
There are two quests that give 15 attribute points.
The first is called "Forgotten Wisdom" and it is received from the Quest NPC that completes "the Forgotten Ones" quest. You must first receive "the Forgotten Ones" from Annelle Fipps in Destiny's Gorge. After completing "the Forgotten Ones", you will receive "Forgotten Wisdom" from the snake that talks to you at the end of it. The end of this quest is in the Arid Sea, due south. You must approach the cliffs in the southern portion of the Arid Sea from the East side.
The second is called "Hero's Challenge". To receive this quest, you have to first complete the "Hero's Journey". To do this quest, you have to talk to Vanyi in Droknar's Forge after ascending. You complete the quest by going to each of the non-mission outpost towns (it is in your quest log). Then you must complete one of the secondary class changing quests in those outpost towns. Note that you do NOT have to change your class, just complete the quest that is offered. After completing "Hero's Journey" and the secondary class changing quest of your choice, Vanyi will offer you "Hero's Challenge". You must go meet her sister Sanyi in Frozen Forest just outside of Copperhammer Mines. Most folks run out to Copperhammer Mines
Kommentaarid: 346 loe/lisa Kasutajad arvavad:  :: 0 :: 4 :: 305
h62k
sõnum 27.02.2006 18:49:09 vasta tsitaadiga
rohkem kui 16 ei saagi 1 attribute olla
eShelobik
eShelobik
sõnum 07.03.2006 18:25:09 vasta tsitaadiga
kas keegi teab, kas kuidagi saab accoundile nö reseti ka teha? et kõik opened skills /runes jne nullida
Kommentaarid: 296 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 263
lawrey
lawrey
sõnum 07.03.2006 20:49:09 vasta tsitaadiga
Ei tea, et selline asi võimalik oleks...
Ostsid kasutatud accoundi ja tahad korralikult nullist alustada? icon_smile.gif
-bash: chpwn: command not found
Kommentaarid: 39 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 36
eShelobik
eShelobik
sõnum 09.03.2006 11:43:47 vasta tsitaadiga
lawrey kirjutas:
nujah, ei teadnud, et miskid faction pointsid ka sisse toodud
edit: müüsin accoundi maha ja ostsin uue mängu icon_biggrin.gif
edit: Kas keegi teab mõnda eestlast kes on pvp guildis mis aktiivselt pvp'ga tegeleb. ei pea olema eesti keelt rääkiv guild
salde
sõnum 12.03.2006 13:36:46 vasta tsitaadiga
[quote="Inimen3"]panen siis oma GW acci müüki. PM[/q
Müüd ikka veel guildwarsi? ma sooviks osta..
Lisa mind oma msni: rauavanne@hotmail.com
un3v3n
sõnum 13.03.2006 21:22:14 vasta tsitaadiga
minu GW acc ka siis müügiks..
300eeksi ... saatke ps kes huvitatud on
h62k
sõnum 21.03.2006 12:13:29 vasta tsitaadiga
Keegi on juba Chapter 2-e ära tellinud?
lawrey
lawrey
sõnum 21.03.2006 19:10:15 vasta tsitaadiga
Õnneks guildi leader lubas mulle kuskilt 1$ eest pre-order packi muretseda, niiet pre-order item ja early access on tagatud icon_wink.gif
eShelobik
eShelobik
sõnum 21.03.2006 20:46:34 vasta tsitaadiga
mis guildis oled? teete gvg'd ka?
lawrey
lawrey
sõnum 21.03.2006 21:31:51 vasta tsitaadiga
BOYD (Bring Out Your Dead). GvG'd oleme kaks mängu teinud, sügisel vist kunagi proovisime. Meil rahvas tegeleb rohkem PvE'ga. Ise rahuldan oma PvP vajadusi random arenas icon_biggrin.gif
coolmode
coolmode
sõnum 24.03.2006 20:55:53 vasta tsitaadiga
Pidime sõbraga ka Eesti guildi tegema kui keegi on huvitatud andke teada.Aga enne pean weel mängu muretsema kui kellelgi on soovi vahetada wowi täisekomplekt Gw täiskomplekti vastu siis andke teada.
h62k
sõnum 24.03.2006 22:34:06 vasta tsitaadiga
kle sul pole mõtet jälle uut eesti guildi teha, neid on juba küllaldgi.
Parem tule meie guildi.
coolmode
coolmode
sõnum 25.03.2006 14:39:33 vasta tsitaadiga
Meil pidi päris palju rahvast tulema sinna guildi
lawrey
lawrey
sõnum 25.03.2006 16:28:54 vasta tsitaadiga
Mõningaid muljeid varsti juba kahjuks poole peale jõudvast FPE'st
Assassin/Monk praegu nii kaugele arendatud:
Full set of Nightstalker's Kurzick Armor, all dyed silver. Skillpointe olen praeguseks 7 saanud, kuigi kui vaatama hakata, siis assassinil kõik suht jurad skillid. Kohe algusest peale peab hakkama skillide kombodele mõtlema, üksikutena pole neist mingit kasu. Praegu kasutan Impale + Black Lotus Strike + Repeating Strike (5-6 korda) ja lõpuks Twisting Fangs. Enamustel level 20+ kollidel võtab ligi 50-60% elusid silmagi pilgutamata maha icon_biggrin.gif
Üldmulje Factions'ist on igatahes väga hea, proovisime guildiga just Alliance Battle'it, 12v12 pvp, päris kreisi igatahes, a õnneks võitsime 500:200 icon_biggrin.gif
coolmode
coolmode
sõnum 30.03.2006 18:07:41 vasta tsitaadiga
Mul küsimus kas see factions on siis lisapakett et pean ostma alguses Guild Warsi ja siis Guild Wars:Factioni?
Kas sellega on sama moodi nagu Diablo II et pean veel juurde osta Diablo II Expansion ?
eShelobik
eShelobik
sõnum 30.03.2006 18:14:02 vasta tsitaadiga
võid osta ainult factionsi aga siis ei pääse vanale contentile ligi ...
coolmode
coolmode
sõnum 30.03.2006 18:28:29 vasta tsitaadiga
Mis see contentile on sorry aga ma algaja veel?
eShelobik
eShelobik
sõnum 30.03.2006 18:31:39 vasta tsitaadiga
esimese osa kaart, linnad, questid
coolmode
coolmode
sõnum 30.03.2006 18:37:01 vasta tsitaadiga
Ok peaks siis vist ikka mõlema ostma aga kas Factions on Eestis üldse müügil ma vaatasin K-arvuti salongis oli ainult esimene osa
s4nder
sõnum 30.03.2006 18:42:35 vasta tsitaadiga
Lisaosa tuleb alles 28. aprill välja, eks näis millal ta ükskord Eestisse jõuab. Originaaliga läks ikka paar kuud aega enne kui normaalses koguses lettidel müügil oli.
coolmode
coolmode
sõnum 30.03.2006 20:35:58 vasta tsitaadiga
s4nder kirjutas:
Hinda tahavad ka ikka sitax ma arvan.Vaatasin just tunf aega tagasi e-bays oli müügil GW:Faction müüa 0.99 dollari eest
Guild Wars Factions Box W/CD Key+Tactical Guide UPS2DAY ja 1 minut veel aega pakkuda icon_biggrin.gif ja üks pakkuja ainult oli icon_mad.gif oleks pidanud ise ära ostma krt nagu mingi 0.99 dollarit see ikka vähe odav.
Rb.Andu
Rb.Andu
sõnum 30.03.2006 20:41:50 vasta tsitaadiga
ffs.
Hind tuleb sama mis eelmisel guild warsil.
ebays on raudselt pre-order box.
Eestlased! Teeme liidud oma guildidega?
s4nder
sõnum 30.03.2006 21:51:20 vasta tsitaadiga
Ei usu, et selle 0,99$ eest õiget mängu pakuti, sest see tuleb ka Ameerikas alles 28. aprill välja. Äkki pakuti selle special eventi keyd vms, mis nüüd juba läbi on muidugi icon_rolleyes.gif .
Rb.Andu
Rb.Andu
sõnum 30.03.2006 21:57:46 vasta tsitaadiga
OMFG?!
See oli nagunii pre-order dumbshit.
http://guildwars.com/aboutgw/wheretobuy/factionspreorder.php
H!tman
H!tman
sõnum 11.04.2006 21:46:12 vasta tsitaadiga
Hakkan siis uuesti Guild Wars mängima ja olen suht nuub ei oska eriti midagi teha kas oleks mõni Mängja siit foorumit kes oleks mind Nõus aitama ja õpetama icon_smile.gif
Kommentaarid: 43 loe/lisa Kasutajad arvavad:  :: 5 :: 3 :: 28
mairox
mairox
sõnum 12.04.2006 09:13:11 vasta tsitaadiga
Tervist, endalegi kukkus guildwars kätte, et kas siin eestlasi kah leidub.
Just buy my shitt !!!
lawrey
lawrey
sõnum 12.04.2006 09:21:59 vasta tsitaadiga
mairox kirjutas:
Kui seda teemat natukenegi lähemalt uurida siis leiab vähemalt kümne eestlase IGN'i
H!tman
H!tman
sõnum 12.04.2006 12:49:00 vasta tsitaadiga
ma mängin olen lvl 6 aga nuub :/ ei oska eriti midagi icon_sad.gif ja kuluks abi ära icon_biggrin.gif
mairox
mairox
sõnum 12.04.2006 21:04:43 vasta tsitaadiga
Siin tegijad tüübid, et äkki oskaksite mõnele küsimusele vastata.
1)Kuidas ma guildist lahkuda saan, lollipeaga läksin mõttetusse guildi. Tahaks ikka eternal dragonisse saada.
2)Vahepel leiab salvage itemeid(purple) mida identifitseerides viskab mingi rune kirja ette, nagu +30 healt (not stacking) , et kuidas ma neid kasutada saan, kui salvage kiti kasutan, peksab lihtsalt asja tanned hidiks või ironiks.
3)Mis valemiga saab energyt juurde ja kas on staffe, mis näiteks spellile damaget juurde annavad. Omal on küll cold damage staff nii 6-9, aga nagu death magic spellile midagi juurde justkui ei anna.
h62k
sõnum 12.04.2006 21:16:35 vasta tsitaadiga
1) Tee guildi aken lahti (G) ja siis otsi oma nimi sealt listist üles, siis kliki sinu nime ees olevale kasitle ja sealt saad valida leave guild.
2) Runesid saab oma armori peale panna. Salvagedes teed ta lihtsalt materjaliks.
3) MAX energiat saab osade weponitega juurde ja kui oled elementalist, siis ka energy storagege.
eShelobik
eShelobik
sõnum 12.04.2006 21:22:57 vasta tsitaadiga
lilladele kasuta expert salvage kit'i siis teeb runeks asju ...
lawrey
lawrey
sõnum 12.04.2006 21:37:53 vasta tsitaadiga
mairox kirjutas:
Veidi täpsustaks veel h62k antud infot
2)Selleks et armorist ruun kätte saada, pead kasutama expert salvage kit'i, mitte tavalist. Kui ruun käes, teed selle peal topeltklõpsu ja siis klikid armori peale kuhu selle panna tahad. Non stacking tähendab seda, et mitu samat tüüpi ruuni lisaeffekti ei anna, mõjub ainult üks (vastupidiselt asjadele millel on kirjas stacking).
3)Energiat saab juurde kas kandes vastavat armorit ja kasutades relvi, millel on kirjas näiteks "+10 energy", või kui oled elementalist, siis pannes punkte Energy Storage atribuuti. Damage kohta niipalju, et spell teeb ikka ainult niipalju damaget kui kirjelduses kirjas on. See, et relval on Cold Dmg: 6-9 tähendab seda, et relvaga rünnates teed sa niipalju damaget (muidugi mitte täpselt niipalju, kõik sõltub vastase armorist ja sajast muust faktorist, aga see on juba omaette teema).
Erandiks on relvad, milledel on kirjas näiteks "Death Magic +1 (16% chance while using skills)", sellisel juhul on Death Magic spelli kasutades 16%-line tõenäosus, et spelli damage arvutatakse ühe võrra suurema atribuudi järgi kui muidu.
Loodan et jutt väga segane ei saanud, kui veel küsimusi tekib, või mõne missiooni/questiga abi vaja, siis lisa mind mängus sõbralisti (IGN: Miss Gwen) ja üritan abiks olla.
mairox
mairox
sõnum 12.04.2006 21:52:16 vasta tsitaadiga
Väga tore, jutt täiesti arusaadav, expert salvage kitt tahab aga hingehinda icon_biggrin.gif
Eks ma lisan su sõbralisti siis, saab küsimustega pommitada.
H!tman
H!tman
sõnum 12.04.2006 22:45:51 vasta tsitaadiga
mairox kirjutas:
lawrey
lawrey
sõnum 21.04.2006 20:13:28 vasta tsitaadiga
Küllaltki hea uudis Mikromaailmalt! Vastuseks päringule, millal GW: Factions Eesti poelettidele jõuab, sain
Tere
Mäng Guild Wars: Factions jõuab maaletooja sõnul meie kauplusesse
2-e nädala jooksul. Täpset hinda veel ei oska öelda.
Tervitades
Ranno Siimus
AS PT Mikro
Kpl. Mikromaailm
Adoffi 11, Rakvere
Kroonikeskus
Küllap see hind ka 650-750 vahele jääb...
sõnum 21.04.2006 20:35:25 vasta tsitaadiga
oot kas Factions hõlmab ainult PvP mängu uuendusi või on ka midagi uut explore mode-s?
lawrey
lawrey
sõnum 21.04.2006 21:07:37 vasta tsitaadiga
Factions on terve iseseisev toode, mille mängimiseks ei ole vaja GW: Prophecies't. Seega on seal piisavalt PvE alasid, missioone, queste jne, et õigustada iseseisva mängu nimetus.
Niipalju kui FPE ajal näha sai, on kaardi suurus täiesti võrreldav GW esimese osa omaga.
Edit: ahjaa, ja suvest hakatakse ju eraldi character slotte müüma, hinnaga 10$ tükk thumbs_up.gif
un3v3n
sõnum 26.04.2006 11:25:37 vasta tsitaadiga
minu konto ikka veel müügil 300 eest
Braindead
sõnum 29.04.2006 11:46:18 vasta tsitaadiga
Tere,
Et kui keegi n2eb kusgil poes factionsit, siis kirjutage siia, ise k2isin eile k6ik poed l2bi veel polnud m2rgata nagu.
Ahjaa, kui keegi tahab siis mu IGN on Brain The Archer v6i Brain Of Ascalon
h62k
sõnum 30.04.2006 18:11:42 vasta tsitaadiga
ega ta jah, eestisse kohe relase päeval ei tule, üksigi mäng pole vist veel tulnud samal päeval eestise kui mujal maailmasgi. Kõige kergem viis on cd-key osta. Lihstalt kannad raha neile üle ja saad e-mailile cd-key kätte. Selle karbi, cd ja muu nodiga niiguinii midagi asjaliku peale ei hakka.
Braindead
sõnum 01.05.2006 10:20:43 vasta tsitaadiga
ega ma tean jah et ei tule icon_razz.gif ma niisama k2isin, igav oli ja aega oli yle icon_biggrin.gif arvutis ka istuda ei viitsind ja lihased trennist v2sind, niiet midagi muud asjaliku teha polnud ,m6tlesin et teen niisama v2ikese jalutusk2igu m66da linna . Aga jah, siiski kui keegi n2eb v6iks öelda ma m6tlen, vblla ostan CD Key t6esti .icon_wink.gif
Brom
Brom
sõnum 01.05.2006 13:24:12 vasta tsitaadiga
Kes soovib osta siis üks account on müüa. 350EEK.
un3v3n
sõnum 01.05.2006 21:03:14 vasta tsitaadiga
minul myygil 300eekuga..
Mikiki
Mikiki
sõnum 02.05.2006 17:51:48 vasta tsitaadiga
lawrey kirjutas:
Tere
Tervitades
Ranno Siimus
AS PT Mikro
Kpl. Mikromaailm
Adoffi 11, Rakvere
Kroonikeskus
Aga noh 2 nädalat saab ju varsti läbi siis, kuid kuidas ma uurida saaksin kunas ta nende letil juba on? Kas naad updatevad kohe oma kodulehte vms?
Aaa ja ma olen mängus N/E lvl 20 ja hiljuti sain ascended.
Nimi Blue Helloween kui keegi tahab juttu puhuda.
Muidu kuskilt kuulsin, et need kellel sai aasta guild warsi täis said endale mingi peti kingituseks vms.
Mario.
sõnum 02.05.2006 19:10:57 vasta tsitaadiga
kui primary või secondary on Ranger, ainult siis saab peti omada...niisama ei hakta mängu loogikast üle astuma.
h62k
sõnum 02.05.2006 20:53:20 vasta tsitaadiga
täista õige jutt, kellel on char 1 aasta vana said kingituseks mini peti. Igasuguseid on neid: rurik, char, troll jne.
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Guild Wars mine lehele eelmine  1, 2, 3 ... 13, 14, 15, 16, 17, 18  järgmine
