uus teema   vasta Tarkvara »  Arvutimängude foorum »  Guild Wars märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 26, 27, 28 ... 34, 35, 36  järgmine
Mario.
sõnum 26.02.2006 02:54:28 vasta tsitaadiga
http://img527.imageshack.us/my.php?image=gw0998fj.jpg selline asi tuleks küll nüüd ara muuta...isegi kollide nimetused on asendatud ---- :S
h62k
sõnum 26.02.2006 12:09:35 vasta tsitaadiga
Eternal Estonian oli mingi 2nädalat tagasi väga active koguaeg minig 10 inimest sees. Nüüd on kuidagi vaikseks jäänud aga ma usun et varsti jälle elavnub. Ühtlasi on see ka guild warsi esimene eesti guild. Kui tahad liituda siis mo IGN on Kuri Hunt
Kommentaarid: 29 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 24
ahvilõust
ahvilõust
sõnum 27.02.2006 02:58:48 vasta tsitaadiga
Milliste questide eest sai lisa attribuute?
Gdesainer
M: MSI RTX 3070 Gaming Trio
un3v3n
sõnum 27.02.2006 18:04:55 vasta tsitaadiga
ahvilõust kirjutas:
tahaks veel küsida ,et mis itemitega saaks ma oma fire magicut üles bootida
praegu runega ja selle flame eyega 16 :S aga tahaks ikka rohkem ... ja palju need itemid maksta võiks
leidsin gw foorumist
There are two quests that give 15 attribute points.
The first is called "Forgotten Wisdom" and it is received from the Quest NPC that completes "the Forgotten Ones" quest. You must first receive "the Forgotten Ones" from Annelle Fipps in Destiny's Gorge. After completing "the Forgotten Ones", you will receive "Forgotten Wisdom" from the snake that talks to you at the end of it. The end of this quest is in the Arid Sea, due south. You must approach the cliffs in the southern portion of the Arid Sea from the East side.
The second is called "Hero's Challenge". To receive this quest, you have to first complete the "Hero's Journey". To do this quest, you have to talk to Vanyi in Droknar's Forge after ascending. You complete the quest by going to each of the non-mission outpost towns (it is in your quest log). Then you must complete one of the secondary class changing quests in those outpost towns. Note that you do NOT have to change your class, just complete the quest that is offered. After completing "Hero's Journey" and the secondary class changing quest of your choice, Vanyi will offer you "Hero's Challenge". You must go meet her sister Sanyi in Frozen Forest just outside of Copperhammer Mines. Most folks run out to Copperhammer Mines
Kommentaarid: 339 loe/lisa Kasutajad arvavad:  :: 0 :: 4 :: 299
h62k
sõnum 27.02.2006 18:49:09 vasta tsitaadiga
rohkem kui 16 ei saagi 1 attribute olla
eShelobik
eShelobik
sõnum 07.03.2006 18:25:09 vasta tsitaadiga
kas keegi teab, kas kuidagi saab accoundile nö reseti ka teha? et kõik opened skills /runes jne nullida
Kommentaarid: 294 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 261
lawrey
lawrey
sõnum 07.03.2006 20:49:09 vasta tsitaadiga
Ei tea, et selline asi võimalik oleks...
Ostsid kasutatud accoundi ja tahad korralikult nullist alustada? icon_smile.gif
-bash: chpwn: command not found
eShelobik
eShelobik
sõnum 09.03.2006 11:43:47 vasta tsitaadiga
lawrey kirjutas:
nujah, ei teadnud, et miskid faction pointsid ka sisse toodud
edit: müüsin accoundi maha ja ostsin uue mängu icon_biggrin.gif
edit: Kas keegi teab mõnda eestlast kes on pvp guildis mis aktiivselt pvp'ga tegeleb. ei pea olema eesti keelt rääkiv guild
salde
sõnum 12.03.2006 13:36:46 vasta tsitaadiga
[quote="Inimen3"]panen siis oma GW acci müüki. PM[/q
Müüd ikka veel guildwarsi? ma sooviks osta..
Lisa mind oma msni: rauavanne@hotmail.com
un3v3n
sõnum 13.03.2006 21:22:14 vasta tsitaadiga
minu GW acc ka siis müügiks..
300eeksi ... saatke ps kes huvitatud on
h62k
sõnum 21.03.2006 12:13:29 vasta tsitaadiga
Keegi on juba Chapter 2-e ära tellinud?
lawrey
lawrey
sõnum 21.03.2006 19:10:15 vasta tsitaadiga
Õnneks guildi leader lubas mulle kuskilt 1$ eest pre-order packi muretseda, niiet pre-order item ja early access on tagatud icon_wink.gif
eShelobik
eShelobik
sõnum 21.03.2006 20:46:34 vasta tsitaadiga
mis guildis oled? teete gvg'd ka?
lawrey
lawrey
sõnum 21.03.2006 21:31:51 vasta tsitaadiga
BOYD (Bring Out Your Dead). GvG'd oleme kaks mängu teinud, sügisel vist kunagi proovisime. Meil rahvas tegeleb rohkem PvE'ga. Ise rahuldan oma PvP vajadusi random arenas icon_biggrin.gif
coolmode
coolmode
sõnum 24.03.2006 20:55:53 vasta tsitaadiga
Pidime sõbraga ka Eesti guildi tegema kui keegi on huvitatud andke teada.Aga enne pean weel mängu muretsema kui kellelgi on soovi vahetada wowi täisekomplekt Gw täiskomplekti vastu siis andke teada.
h62k
sõnum 24.03.2006 22:34:06 vasta tsitaadiga
kle sul pole mõtet jälle uut eesti guildi teha, neid on juba küllaldgi.
Parem tule meie guildi.
coolmode
coolmode
sõnum 25.03.2006 14:39:33 vasta tsitaadiga
Meil pidi päris palju rahvast tulema sinna guildi
lawrey
lawrey
sõnum 25.03.2006 16:28:54 vasta tsitaadiga
Mõningaid muljeid varsti juba kahjuks poole peale jõudvast FPE'st
Assassin/Monk praegu nii kaugele arendatud:
Full set of Nightstalker's Kurzick Armor, all dyed silver. Skillpointe olen praeguseks 7 saanud, kuigi kui vaatama hakata, siis assassinil kõik suht jurad skillid. Kohe algusest peale peab hakkama skillide kombodele mõtlema, üksikutena pole neist mingit kasu. Praegu kasutan Impale + Black Lotus Strike + Repeating Strike (5-6 korda) ja lõpuks Twisting Fangs. Enamustel level 20+ kollidel võtab ligi 50-60% elusid silmagi pilgutamata maha icon_biggrin.gif
Üldmulje Factions'ist on igatahes väga hea, proovisime guildiga just Alliance Battle'it, 12v12 pvp, päris kreisi igatahes, a õnneks võitsime 500:200 icon_biggrin.gif
coolmode
coolmode
sõnum 30.03.2006 18:07:41 vasta tsitaadiga
Mul küsimus kas see factions on siis lisapakett et pean ostma alguses Guild Warsi ja siis Guild Wars:Factioni?
Kas sellega on sama moodi nagu Diablo II et pean veel juurde osta Diablo II Expansion ?
eShelobik
eShelobik
sõnum 30.03.2006 18:14:02 vasta tsitaadiga
võid osta ainult factionsi aga siis ei pääse vanale contentile ligi ...
coolmode
coolmode
sõnum 30.03.2006 18:28:29 vasta tsitaadiga
Mis see contentile on sorry aga ma algaja veel?
eShelobik
eShelobik
sõnum 30.03.2006 18:31:39 vasta tsitaadiga
esimese osa kaart, linnad, questid
coolmode
coolmode
sõnum 30.03.2006 18:37:01 vasta tsitaadiga
Ok peaks siis vist ikka mõlema ostma aga kas Factions on Eestis üldse müügil ma vaatasin K-arvuti salongis oli ainult esimene osa
s4nder
sõnum 30.03.2006 18:42:35 vasta tsitaadiga
Lisaosa tuleb alles 28. aprill välja, eks näis millal ta ükskord Eestisse jõuab. Originaaliga läks ikka paar kuud aega enne kui normaalses koguses lettidel müügil oli.
coolmode
coolmode
sõnum 30.03.2006 20:35:58 vasta tsitaadiga
s4nder kirjutas:
Hinda tahavad ka ikka sitax ma arvan.Vaatasin just tunf aega tagasi e-bays oli müügil GW:Faction müüa 0.99 dollari eest
Guild Wars Factions Box W/CD Key+Tactical Guide UPS2DAY ja 1 minut veel aega pakkuda icon_biggrin.gif ja üks pakkuja ainult oli icon_mad.gif oleks pidanud ise ära ostma krt nagu mingi 0.99 dollarit see ikka vähe odav.
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Guild Wars mine lehele eelmine  1, 2, 3 ... 26, 27, 28 ... 34, 35, 36  järgmine
